Many BSPs Fail with Debug Enabled
Tue Sep 19 19:18:09 UTC 2017
Hi
I am starting to investigate the failures but 41 BSPs fail to
build with --enable-rtems-debug and --enable-tests=all.
Some fail because tests are too large to fit with debug enabled.
These fail with an error related to bsp_interrupt_assert:
log/powerpc-mpc8260ads.log
log/powerpc-psim.log
log/powerpc-qemuppc.log
These fail with an error about bsp_interrupt_dispatch:
log/arm-raspberrypi2.log
log/arm-raspberrypi.log
log/powerpc-beatnik.log
log/powerpc-brs5l.log
log/powerpc-brs6l.log
log/powerpc-br_uid.log
log/powerpc-dp2.log
log/powerpc-haleakala.log
log/powerpc-hsc_cm01.log
log/powerpc-icecube.log
log/powerpc-mcp750.log
log/powerpc-mpc8309som.log
log/powerpc-mpc8313erdb.log
log/powerpc-mpc8349eamds.log
log/powerpc-mtx603e.log
log/powerpc-mvme2100.log
log/powerpc-mvme2307.log
log/powerpc-mvme3100.log
log/powerpc-mvme5500.log
log/powerpc-pghplus.log
log/powerpc-pm520_cr825.log
log/powerpc-pm520_ze30.log
log/powerpc-qemuprep-altivec.log
log/powerpc-qemuprep.log
log/powerpc-t32mppc.log
log/powerpc-tqm8xx_stk8xx.log
log/powerpc-virtex4.log
log/powerpc-virtex5.log
log/powerpc-virtex.log
Help is appreciated narrowing this list down.
---joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170919/e1f19255/attachment.html>
