Test suite's minimum sample has no test banners
Wed Sep 20 05:08:03 UTC 2017
On 20/09/2017 15:04, Sebastian Huber wrote:
> On 20/09/17 05:26, Chris Johns wrote:
>> The test suite's sample test minimum.exe has no test banners and so it appears
>> in the test results as invalid or time out.
>> How should we gather a result for this test?
> The test documentation in minimum.doc is quite fitting. I guess the purpose of
> this test is to see how much code and data is needed to run one task without
> drivers and anything else. So, the test output is probably the ELF file itself.
Is it worth running? I am wondering about hard coding a filter to not run it in
rtems-test runs.
