[PATCH] posix: Implement self-contained POSIX rwlocks
Fri Sep 22 13:59:27 UTC 2017
POSIX rwlocks are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3115.
 cpukit/libcsupport/include/rtems/libcsupport.h    |   1 -
 cpukit/libcsupport/src/resource_snapshot.c        |   2 -
 cpukit/posix/Makefile.am                          |  15 +-
 cpukit/posix/include/rtems/posix/config.h         |   6 -
 cpukit/posix/include/rtems/posix/rwlock.h         |  63 ------
 cpukit/posix/include/rtems/posix/rwlockimpl.h     |  54 ++---
 cpukit/posix/preinstall.am                        |  12 +-
 cpukit/posix/src/prwlock.c                        |  48 -----
 cpukit/posix/src/prwlockdestroy.c                 |  20 +-
 cpukit/posix/src/prwlockinit.c                    |  81 +++----
 cpukit/posix/src/prwlockrdlock.c                  |   9 +-
 cpukit/posix/src/prwlocktimedrdlock.c             |   9 +-
 cpukit/posix/src/prwlocktimedwrlock.c             |   9 +-
 cpukit/posix/src/prwlocktryrdlock.c               |   9 +-
 cpukit/posix/src/prwlocktrywrlock.c               |   9 +-
 cpukit/posix/src/prwlockunlock.c                  |  26 ++-
 cpukit/posix/src/prwlockwrlock.c                  |  11 +-
 cpukit/rtems/src/rtemsobjectgetapiclassname.c     |   1 -
 cpukit/sapi/include/confdefs.h                    |  26 ---
 cpukit/score/Makefile.am                          |   8 +-
 cpukit/score/include/rtems/score/corerwlock.h     |  77 -------
 cpukit/score/include/rtems/score/corerwlockimpl.h |  68 ++++--
 cpukit/score/include/rtems/score/objectimpl.h     |   1 -
 cpukit/score/include/rtems/sysinit.h              |   1 -
 cpukit/score/preinstall.am                        |  13 +-
 cpukit/score/src/corerwlock.c                     |   3 +-
 cpukit/score/src/corerwlockobtainread.c           |  17 +-
 cpukit/score/src/corerwlockobtainwrite.c          |   7 +-
 cpukit/score/src/corerwlockrelease.c              |  20 +-
 testsuites/psxtests/psxconfig01/init.c            |  13 --
 testsuites/psxtests/psxrwlock01/main.c            |   1 -
 testsuites/psxtests/psxrwlock01/psxrwlock01.scn   |   5 +-
 testsuites/psxtests/psxrwlock01/test.c            | 252 +++++++++++++++++-----
 testsuites/psxtmtests/psxtmrwlock01/init.c        |   1 -
 testsuites/psxtmtests/psxtmrwlock02/init.c        |   1 -
 testsuites/psxtmtests/psxtmrwlock03/init.c        |   1 -
 testsuites/psxtmtests/psxtmrwlock04/init.c        |   1 -
 testsuites/psxtmtests/psxtmrwlock05/init.c        |   1 -
 testsuites/psxtmtests/psxtmrwlock06/init.c        |   1 -
 testsuites/psxtmtests/psxtmrwlock07/init.c        |   1 -
 testsuites/sptests/spsysinit01/init.c             |  16 --
 testsuites/sptests/spthreadq01/init.c             |  19 --
 42 files changed, 389 insertions(+), 550 deletions(-)
 delete mode 100644 cpukit/posix/include/rtems/posix/rwlock.h
 delete mode 100644 cpukit/posix/src/prwlock.c
 delete mode 100644 cpukit/score/include/rtems/score/corerwlock.h
diff --git a/cpukit/libcsupport/include/rtems/libcsupport.h b/cpukit/libcsupport/include/rtems/libcsupport.h
index ace61c5c0d..3246209bad 100644
--- a/cpukit/libcsupport/include/rtems/libcsupport.h
+++ b/cpukit/libcsupport/include/rtems/libcsupport.h
@@ -114,7 +114,6 @@ typedef struct {
   uint32_t active_condition_variables;
   uint32_t active_message_queues;
   uint32_t active_mutexes;
-  uint32_t active_rwlocks;
   uint32_t active_semaphores;
   uint32_t active_threads;
   uint32_t active_timers;
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 87d4a0108a..243ffd33cd 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -47,7 +47,6 @@
   #include <rtems/posix/psignal.h>
-  #include <rtems/posix/rwlockimpl.h>
   #include <rtems/posix/semaphoreimpl.h>
   #include <rtems/posix/timerimpl.h>
 #endif
@@ -72,7 +71,6 @@ static const struct {
     { OBJECTS_POSIX_API, OBJECTS_POSIX_CONDITION_VARIABLES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_MESSAGE_QUEUES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_MUTEXES },
-    { OBJECTS_POSIX_API, OBJECTS_POSIX_RWLOCKS },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_SEMAPHORES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_THREADS },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_TIMERS }
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 153f684029..531acde156 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -22,6 +22,7 @@ include_rtems_posix_HEADERS += include/rtems/posix/keyimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/config.h
 include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
 include_rtems_posix_HEADERS += include/rtems/posix/priorityimpl.h
+include_rtems_posix_HEADERS += include/rtems/posix/rwlockimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/semaphore.h
 include_rtems_posix_HEADERS += include/rtems/posix/semaphoreimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/spinlockimpl.h
@@ -50,8 +51,6 @@ include_rtems_posix_HEADERS += include/rtems/posix/shmimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/threadsup.h
 include_rtems_posix_HEADERS += include/rtems/posix/timer.h
 include_rtems_posix_HEADERS += include/rtems/posix/timerimpl.h
-include_rtems_posix_HEADERS += include/rtems/posix/rwlock.h
-include_rtems_posix_HEADERS += include/rtems/posix/rwlockimpl.h
 ## src
 libposix_a_SOURCES += src/aio_cancel.c src/aio_error.c src/aio_fsync.c \
@@ -192,18 +191,18 @@ libposix_a_SOURCES += src/semaphore.c \
     src/semopen.c src/sempost.c src/semtimedwait.c src/semtrywait.c \
     src/semunlink.c src/semwait.c
-if HAS_PTHREADS
-libposix_a_SOURCES += src/sigpending.c \
-    src/sigqueue.c src/sigsuspend.c src/sigtimedwait.c \
-    src/sigwait.c src/sigwaitinfo.c src/signal_2.c src/ualarm.c
 ## RWLOCK_C_FILES
-libposix_a_SOURCES += src/prwlock.c src/prwlockdestroy.c src/prwlockinit.c \
+libposix_a_SOURCES += src/prwlockdestroy.c src/prwlockinit.c \
     src/prwlockrdlock.c src/prwlocktimedrdlock.c src/prwlocktimedwrlock.c \
     src/prwlocktryrdlock.c src/prwlocktrywrlock.c src/prwlockunlock.c \
     src/prwlockwrlock.c src/rwlockattrdestroy.c src/rwlockattrgetpshared.c \
     src/rwlockattrinit.c src/rwlockattrsetpshared.c
+if HAS_PTHREADS
+libposix_a_SOURCES += src/sigpending.c \
+    src/sigqueue.c src/sigsuspend.c src/sigtimedwait.c \
+    src/sigwait.c src/sigwaitinfo.c src/signal_2.c src/ualarm.c
 ## TIME_C_FILES
 libposix_a_SOURCES += src/adjtime.c src/clockgetcpuclockid.c
diff --git a/cpukit/posix/include/rtems/posix/config.h b/cpukit/posix/include/rtems/posix/config.h
index dc1ef0c2f1..799eb62f03 100644
--- a/cpukit/posix/include/rtems/posix/config.h
+++ b/cpukit/posix/include/rtems/posix/config.h
@@ -99,12 +99,6 @@ typedef struct {
   uint32_t                            maximum_semaphores;
-   * This field contains the maximum number of POSIX API
-   * read/write locks which are configured for this application.
-  uint32_t                            maximum_rwlocks;
    * Maximum configured number of POSIX Shared memory objects.
   uint32_t                            maximum_shms;
diff --git a/cpukit/posix/include/rtems/posix/rwlock.h b/cpukit/posix/include/rtems/posix/rwlock.h
deleted file mode 100644
index 3d33d40915..0000000000
--- a/cpukit/posix/include/rtems/posix/rwlock.h
+++ /dev/null
@@ -1,63 +0,0 @@
- * @file
- * @brief Constants and Structures Associated with the POSIX RWLock Manager
- * This include file contains all the constants and structures associated
- * with the POSIX RWLock Manager.
- * Directives provided are:
- *   - create a RWLock
- *   - delete a RWLock
- *   - wait for a RWLock
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_POSIX_RWLOCK_H
-#define _RTEMS_POSIX_RWLOCK_H
-#include <rtems/score/object.h>
-#include <rtems/score/corerwlock.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup POSIX_RWLOCK POSIX RWLock Manager
- * @ingroup POSIXAPI
- * This type defines the control block used to manage each RWLock.
-typedef struct {
-  /** This is used to manage a RWLock as an object. */
-  Objects_Control          Object;
-  /** This is used to implement the RWLock. */
-  CORE_RWLock_Control      RWLock;
-}   POSIX_RWLock_Control;
-#ifdef __cplusplus
-#endif
-#endif
-/*  end of include file */
diff --git a/cpukit/posix/include/rtems/posix/rwlockimpl.h b/cpukit/posix/include/rtems/posix/rwlockimpl.h
index c355f7dc19..b92ca9d04c 100644
--- a/cpukit/posix/include/rtems/posix/rwlockimpl.h
+++ b/cpukit/posix/include/rtems/posix/rwlockimpl.h
@@ -19,9 +19,7 @@
 #ifndef _RTEMS_POSIX_RWLOCKIMPL_H
 #define _RTEMS_POSIX_RWLOCKIMPL_H
-#include <rtems/posix/rwlock.h>
 #include <rtems/score/corerwlockimpl.h>
-#include <rtems/score/objectimpl.h>
 #include <pthread.h>
@@ -30,43 +28,33 @@
 extern "C" {
 #endif
- * The following defines the information control block used to manage
- * this class of objects.
-extern Objects_Information _POSIX_RWLock_Information;
+#define POSIX_RWLOCK_MAGIC 0x9621dabdUL
- * @brief Allocate a RWLock control block.
- * This function allocates a RWLock control block from
- * the inactive chain of free RWLock control blocks.
-RTEMS_INLINE_ROUTINE POSIX_RWLock_Control *_POSIX_RWLock_Allocate( void )
-  return (POSIX_RWLock_Control *)
-    _Objects_Allocate( &_POSIX_RWLock_Information );
+typedef struct {
+  unsigned long flags;
+  CORE_RWLock_Control RWLock;
+} POSIX_RWLock_Control;
- * @brief Free a RWLock control block.
- * This routine frees a RWLock control block to the
- * inactive chain of free RWLock control blocks.
-RTEMS_INLINE_ROUTINE void _POSIX_RWLock_Free (
-  POSIX_RWLock_Control *the_RWLock
+RTEMS_INLINE_ROUTINE POSIX_RWLock_Control *_POSIX_RWLock_Get(
+  pthread_rwlock_t *rwlock
-  _CORE_RWLock_Destroy( &the_RWLock->RWLock );
-  _Objects_Free( &_POSIX_RWLock_Information, &the_RWLock->Object );
+  return (POSIX_RWLock_Control *) rwlock;
-POSIX_RWLock_Control *_POSIX_RWLock_Get(
-  pthread_rwlock_t     *rwlock,
-  Thread_queue_Context *queue_context
+bool _POSIX_RWLock_Auto_initialization( POSIX_RWLock_Control *the_rwlock );
+#define POSIX_RWLOCK_VALIDATE_OBJECT( rw ) \
+  do { \
+    if ( ( rw ) == NULL ) { \
+      return EINVAL; \
+    if ( ( (uintptr_t) ( rw ) ^ POSIX_RWLOCK_MAGIC ) != ( rw )->flags ) { \
+      if ( !_POSIX_RWLock_Auto_initialization( rw ) ) { \
+        return EINVAL; \
+  } while ( 0 )
 #ifdef __cplusplus
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index 903591ad65..45d1c465b5 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -51,6 +51,10 @@ $(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h: include/rtems/posix/priorityimpl.
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h
+$(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h: include/rtems/posix/rwlockimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h
 $(PROJECT_INCLUDE)/rtems/posix/semaphore.h: include/rtems/posix/semaphore.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/semaphore.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/semaphore.h
@@ -143,14 +147,6 @@ PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/timer.h
 $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h: include/rtems/posix/timerimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h
-$(PROJECT_INCLUDE)/rtems/posix/rwlock.h: include/rtems/posix/rwlock.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/rwlock.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/rwlock.h
-$(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h: include/rtems/posix/rwlockimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h
 endif
 if HAS_PTHREADS
 endif
diff --git a/cpukit/posix/src/prwlock.c b/cpukit/posix/src/prwlock.c
index f81d4e5bba..0000000000
--- a/cpukit/posix/src/prwlock.c
+++ /dev/null
@@ -1,48 +0,0 @@
- *  RWLock Manager -- Initialization
- *  COPYRIGHT (c) 1989-2008.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <limits.h>
-#include <rtems/system.h>
-#include <rtems/config.h>
-#include <rtems/sysinit.h>
-#include <rtems/posix/rwlockimpl.h>
-Objects_Information _POSIX_RWLock_Information;
- *  @brief _POSIX_RWLock_Manager_initialization
-static void _POSIX_RWLock_Manager_initialization(void)
-  _Objects_Initialize_information(
-    &_POSIX_RWLock_Information,     /* object information table */
-    OBJECTS_POSIX_API,              /* object API */
-    OBJECTS_POSIX_RWLOCKS,          /* object class */
-    Configuration_POSIX_API.maximum_rwlocks,
-                                    /* maximum objects of this class */
-    sizeof( POSIX_RWLock_Control ), /* size of this object's control block */
-    true,                           /* true if the name is a string */
-    _POSIX_PATH_MAX,                /* maximum length of each object's name */
-    NULL                            /* Proxy extraction support callout */
-RTEMS_SYSINIT_ITEM(
-  _POSIX_RWLock_Manager_initialization,
-  RTEMS_SYSINIT_POSIX_RWLOCK,
-  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/posix/src/prwlockdestroy.c b/cpukit/posix/src/prwlockdestroy.c
index 0ced556146..7088bf964f 100644
--- a/cpukit/posix/src/prwlockdestroy.c
+++ b/cpukit/posix/src/prwlockdestroy.c
@@ -20,29 +20,23 @@
 int pthread_rwlock_destroy(
+  pthread_rwlock_t *_rwlock
   POSIX_RWLock_Control *the_rwlock;
   Thread_queue_Context  queue_context;
-  _Objects_Allocator_lock();
-  the_rwlock = _POSIX_RWLock_Get( rwlock, &queue_context );
+  the_rwlock = _POSIX_RWLock_Get( _rwlock );
+  POSIX_RWLOCK_VALIDATE_OBJECT( the_rwlock );
-  if ( the_rwlock == NULL ) {
-    _Objects_Allocator_unlock();
-    return EINVAL;
-  _CORE_RWLock_Acquire_critical( &the_rwlock->RWLock, &queue_context );
+  _CORE_RWLock_Acquire( &the_rwlock->RWLock, &queue_context );
    *  If there is at least one thread waiting, then do not delete it.
-  if ( !_Thread_queue_Is_empty( &the_rwlock->RWLock.Wait_queue.Queue ) ) {
+  if ( !_Thread_queue_Is_empty( &the_rwlock->RWLock.Queue.Queue ) ) {
     _CORE_RWLock_Release( &the_rwlock->RWLock, &queue_context );
     return EBUSY;
@@ -50,9 +44,7 @@ int pthread_rwlock_destroy(
    *  POSIX doesn't require behavior when it is locked.
-  _Objects_Close( &_POSIX_RWLock_Information, &the_rwlock->Object );
+  the_rwlock->flags = 0;
-  _POSIX_RWLock_Free( the_rwlock );
   return 0;
diff --git a/cpukit/posix/src/prwlockinit.c b/cpukit/posix/src/prwlockinit.c
index ffce8149a9..a5e2ba1f54 100644
--- a/cpukit/posix/src/prwlockinit.c
+++ b/cpukit/posix/src/prwlockinit.c
@@ -23,35 +23,34 @@
 #include <rtems/posix/posixapi.h>
-  _POSIX_Get_object_body(
-    POSIX_RWLock_Control,
-    rwlock,
-    queue_context,
-    PTHREAD_RWLOCK_INITIALIZER,
-    pthread_rwlock_init
+RTEMS_STATIC_ASSERT(
+  offsetof( POSIX_RWLock_Control, flags )
+    == offsetof( pthread_rwlock_t, _flags ),
+  POSIX_RWLOCK_CONTROL_FLAGS
- *  pthread_rwlock_init
- *  This directive creates a rwlock.  A rwlock id is returned.
- *  Input parameters:
- *    rwlock          - pointer to rwlock id
- *    attr            - rwlock attributes
- *  Output parameters:
- *    rwlock     - rwlock id
- *    0          - if successful
- *    error code - if unsuccessful
+  offsetof( POSIX_RWLock_Control, RWLock.current_state )
+    == offsetof( pthread_rwlock_t, _current_state ),
+  POSIX_RWLOCK_CONTROL_CURRENT_STATE
+  offsetof( POSIX_RWLock_Control, RWLock.number_of_readers )
+    == offsetof( pthread_rwlock_t, _number_of_readers ),
+  POSIX_RWLOCK_CONTROL_NUMBER_OF_READERS
+  offsetof( POSIX_RWLock_Control, RWLock.Queue )
+    == offsetof( pthread_rwlock_t, _Queue ),
+  POSIX_RWLOCK_CONTROL_QUEUE
+  sizeof( POSIX_RWLock_Control ) == sizeof( pthread_rwlock_t ),
+  POSIX_RWLOCK_CONTROL_SIZE
 int pthread_rwlock_init(
@@ -60,11 +59,11 @@ int pthread_rwlock_init(
-   *  Error check parameters
-  if ( !rwlock )
+  the_rwlock = _POSIX_RWLock_Get( rwlock );
+  if ( the_rwlock == NULL ) {
     return EINVAL;
   if ( attr != NULL ) {
     if ( !attr->is_initialized ) {
@@ -76,23 +75,7 @@ int pthread_rwlock_init(
-  the_rwlock = _POSIX_RWLock_Allocate();
-  if ( !the_rwlock ) {
-    return EAGAIN;
+  the_rwlock->flags = (uintptr_t) the_rwlock ^ POSIX_RWLOCK_MAGIC;
   _CORE_RWLock_Initialize( &the_rwlock->RWLock );
-  _Objects_Open_u32(
-    &the_rwlock->Object,
-    0
-  *rwlock = the_rwlock->Object.id;
   return 0;
diff --git a/cpukit/posix/src/prwlockrdlock.c b/cpukit/posix/src/prwlockrdlock.c
index 5b15f5568f..4019c1fcb2 100644
--- a/cpukit/posix/src/prwlockrdlock.c
+++ b/cpukit/posix/src/prwlockrdlock.c
@@ -29,16 +29,13 @@ int pthread_rwlock_rdlock(
   Status_Control        status;
-    return EINVAL;
+  _Thread_queue_Context_initialize( &queue_context );
   _Thread_queue_Context_set_no_timeout( &queue_context );
   status = _CORE_RWLock_Seize_for_reading(
-    _Thread_Executing,
     true,                 /* we are willing to wait forever */
     &queue_context
diff --git a/cpukit/posix/src/prwlocktimedrdlock.c b/cpukit/posix/src/prwlocktimedrdlock.c
index 623453073e..a9ac13348d 100644
--- a/cpukit/posix/src/prwlocktimedrdlock.c
+++ b/cpukit/posix/src/prwlocktimedrdlock.c
@@ -50,16 +50,13 @@ int pthread_rwlock_timedrdlock(
   timeout_status = _TOD_Absolute_timeout_to_ticks( abstime, CLOCK_REALTIME, &ticks );
   do_wait = ( timeout_status == TOD_ABSOLUTE_TIMEOUT_IS_IN_FUTURE );
-    return EINVAL;
   _Thread_queue_Context_set_relative_timeout( &queue_context, ticks );
     do_wait,
     &queue_context
diff --git a/cpukit/posix/src/prwlocktimedwrlock.c b/cpukit/posix/src/prwlocktimedwrlock.c
index 1fd57c0106..1f1e654d53 100644
--- a/cpukit/posix/src/prwlocktimedwrlock.c
+++ b/cpukit/posix/src/prwlocktimedwrlock.c
@@ -52,16 +52,13 @@ int pthread_rwlock_timedwrlock(
-    return EINVAL;
   status = _CORE_RWLock_Seize_for_writing(
     do_wait,
     &queue_context
diff --git a/cpukit/posix/src/prwlocktryrdlock.c b/cpukit/posix/src/prwlocktryrdlock.c
index 052f1b011e..e934d286ae 100644
--- a/cpukit/posix/src/prwlocktryrdlock.c
+++ b/cpukit/posix/src/prwlocktryrdlock.c
@@ -29,15 +29,12 @@ int pthread_rwlock_tryrdlock(
-    return EINVAL;
     false,                  /* do not wait for the rwlock */
     &queue_context
diff --git a/cpukit/posix/src/prwlocktrywrlock.c b/cpukit/posix/src/prwlocktrywrlock.c
index 976e7a84ac..ccbeb3114b 100644
--- a/cpukit/posix/src/prwlocktrywrlock.c
+++ b/cpukit/posix/src/prwlocktrywrlock.c
@@ -29,15 +29,12 @@ int pthread_rwlock_trywrlock(
-    return EINVAL;
     false,                 /* we are not willing to wait */
     &queue_context
diff --git a/cpukit/posix/src/prwlockunlock.c b/cpukit/posix/src/prwlockunlock.c
index 05be366c23..92cc0bfde2 100644
--- a/cpukit/posix/src/prwlockunlock.c
+++ b/cpukit/posix/src/prwlockunlock.c
@@ -23,20 +23,32 @@
+#include <string.h>
+  POSIX_RWLock_Control zero;
+  memset( &zero, 0, sizeof( zero ) );
+  if ( memcmp( the_rwlock, &zero, sizeof( *the_rwlock ) ) != 0 ) {
+    return false;
+  the_rwlock->flags = POSIX_RWLOCK_MAGIC;
+  return true;
 int pthread_rwlock_unlock(
-  Thread_queue_Context  queue_context;
-    return EINVAL;
-  status = _CORE_RWLock_Surrender( &the_rwlock->RWLock, &queue_context );
+  status = _CORE_RWLock_Surrender( &the_rwlock->RWLock );
   return _POSIX_Get_error( status );
diff --git a/cpukit/posix/src/prwlockwrlock.c b/cpukit/posix/src/prwlockwrlock.c
index a78554f878..df4d2685aa 100644
--- a/cpukit/posix/src/prwlockwrlock.c
+++ b/cpukit/posix/src/prwlockwrlock.c
@@ -23,8 +23,6 @@
-THREAD_QUEUE_OBJECT_ASSERT( POSIX_RWLock_Control, RWLock.Wait_queue );
 int pthread_rwlock_wrlock(
@@ -33,16 +31,13 @@ int pthread_rwlock_wrlock(
-    return EINVAL;
     true,          /* do not timeout -- wait forever */
     &queue_context
diff --git a/cpukit/rtems/src/rtemsobjectgetapiclassname.c b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
index ecac3a5c5f..b2db41a8df 100644
--- a/cpukit/rtems/src/rtemsobjectgetapiclassname.c
+++ b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
@@ -53,7 +53,6 @@ static const rtems_assoc_t rtems_object_api_posix_assoc[] = {
   { "Semaphore",               OBJECTS_POSIX_SEMAPHORES, 0},
   { "Condition Variable",      OBJECTS_POSIX_CONDITION_VARIABLES, 0},
   { "Timer",                   OBJECTS_POSIX_TIMERS, 0},
-  { "RWLock",                  OBJECTS_POSIX_RWLOCKS, 0},
   { "Shared Memory",           OBJECTS_POSIX_SHMS, 0},
   { NULL,                      0, 0}
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index c8bb18ae07..596c3420b0 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2081,10 +2081,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \
         rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
     #endif
-    #if !defined(CONFIGURE_MAXIMUM_POSIX_RWLOCKS)
-      #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS \
-        rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
-    #endif
     #if !defined(CONFIGURE_MAXIMUM_POSIX_SHMS)
       #define CONFIGURE_MAXIMUM_POSIX_SHMS \
@@ -2449,7 +2445,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #include <rtems/posix/mutex.h>
   #include <rtems/posix/pthread.h>
-  #include <rtems/posix/rwlock.h>
   #include <rtems/posix/semaphore.h>
   #include <rtems/posix/shm.h>
   #include <rtems/posix/threadsup.h>
@@ -2567,21 +2562,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
        _semaphores, sizeof(POSIX_Semaphore_Control) )
-   * This configuration parameter specifies the maximum number of
-   * POSIX API rwlocks.
-  #ifndef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
-    #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 0
-  #endif
-   * This macro is calculated to specify the memory required for
-  #define _CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS(_rwlocks) \
-    _Configure_Object_RAM(_rwlocks, sizeof(POSIX_RWLock_Control) )
    * Configure the maximum number of POSIX shared memory objects.
@@ -2822,8 +2802,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
         CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES) + \
       _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \
         CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) + \
-      _CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( \
-        CONFIGURE_MAXIMUM_POSIX_RWLOCKS) + \
       _CONFIGURE_MEMORY_FOR_POSIX_SHMS( \
         CONFIGURE_MAXIMUM_POSIX_SHMS) + \
       _CONFIGURE_MEMORY_FOR_POSIX_TIMERS(CONFIGURE_MAXIMUM_POSIX_TIMERS))
@@ -3275,7 +3253,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS,
       CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES,
       CONFIGURE_MAXIMUM_POSIX_SEMAPHORES,
-      CONFIGURE_MAXIMUM_POSIX_RWLOCKS,
       CONFIGURE_MAXIMUM_POSIX_SHMS,
       CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE,
       CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME
@@ -3490,7 +3467,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     uint32_t POSIX_QUEUED_SIGNALS;
     uint32_t POSIX_MESSAGE_QUEUES;
     uint32_t POSIX_SEMAPHORES;
-    uint32_t POSIX_RWLOCKS;
     uint32_t POSIX_SHMS;
 #endif
@@ -3543,7 +3519,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     _CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES(
       CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES ),
     _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ),
-    _CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( CONFIGURE_MAXIMUM_POSIX_RWLOCKS ),
     _CONFIGURE_MEMORY_FOR_POSIX_SHMS( CONFIGURE_MAXIMUM_POSIX_SHMS ),
     _CONFIGURE_MEMORY_FOR_POSIX_TIMERS( CONFIGURE_MAXIMUM_POSIX_TIMERS ),
 #endif
@@ -3614,7 +3589,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
        (CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_SEMAPHORES != 0) || \
-       (CONFIGURE_MAXIMUM_POSIX_RWLOCKS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_SHMS != 0) || \
       defined(CONFIGURE_POSIX_INIT_THREAD_TABLE))
   #error "CONFIGURATION ERROR: POSIX API support not configured!!"
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 03a15e3b09..86af199ec3 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -38,6 +38,7 @@ include_rtems_score_HEADERS += include/rtems/score/coremsg.h
 include_rtems_score_HEADERS += include/rtems/score/coremsgimpl.h
 include_rtems_score_HEADERS += include/rtems/score/coremutex.h
 include_rtems_score_HEADERS += include/rtems/score/coremuteximpl.h
+include_rtems_score_HEADERS += include/rtems/score/corerwlockimpl.h
 include_rtems_score_HEADERS += include/rtems/score/coresem.h
 include_rtems_score_HEADERS += include/rtems/score/coresemimpl.h
 include_rtems_score_HEADERS += include/rtems/score/cpuset.h
@@ -112,11 +113,6 @@ include_rtems_score_HEADERS += include/rtems/score/wkspace.h
 include_rtems_score_HEADERS += include/rtems/score/cpuopts.h
 include_rtems_score_HEADERS += include/rtems/score/basedefs.h
-if HAS_PTHREADS
-include_rtems_score_HEADERS += include/rtems/score/corerwlock.h
-include_rtems_score_HEADERS += include/rtems/score/corerwlockimpl.h
-endif
 if HAS_MP
 # We only build multiprocessing related files if HAS_MP was defined
 include_rtems_score_HEADERS += include/rtems/score/mpci.h
@@ -189,10 +185,8 @@ libscore_a_SOURCES += src/percpu.c
 libscore_a_SOURCES += src/percpuasm.c
 ## CORE_RWLOCK_C_FILES
-if HAS_PTHREADS
 libscore_a_SOURCES += src/corerwlock.c src/corerwlockobtainread.c \
     src/corerwlockobtainwrite.c src/corerwlockrelease.c
-endif
 ## CORE_SEMAPHORE_C_FILES
 libscore_a_SOURCES += src/coresem.c
diff --git a/cpukit/score/include/rtems/score/corerwlock.h b/cpukit/score/include/rtems/score/corerwlock.h
index 89c18c6c65..0000000000
--- a/cpukit/score/include/rtems/score/corerwlock.h
+++ /dev/null
@@ -1,77 +0,0 @@
- *  @file  rtems/score/corerwlock.h
- *  @brief Constants and Structures Associated with the RWLock Handler
- *  with the RWLock Handler.
-#ifndef _RTEMS_SCORE_CORERWLOCK_H
-#define _RTEMS_SCORE_CORERWLOCK_H
-#include <rtems/score/threadq.h>
- *  @defgroup ScoreRWLock RWLock Handler
- *  @ingroup Score
- *  This handler encapsulates functionality which provides the foundation
- *  RWLock services used in all of the APIs supported by RTEMS.
-#ifdef __cplusplus
-extern "C" {
-#endif
- *  RWLock State.
-typedef enum {
-  /** This indicates the the RWLock is not currently locked.
-  CORE_RWLOCK_UNLOCKED,
-  /** This indicates the the RWLock is currently locked for reading.
-  CORE_RWLOCK_LOCKED_FOR_READING,
-  CORE_RWLOCK_LOCKED_FOR_WRITING
-}   CORE_RWLock_States;
- *  The following defines the control block used to manage each
- *  RWLock.
-typedef struct {
-  /** This field is the Waiting Queue used to manage the set of tasks
-   *  which are blocked waiting for the RWLock to be released.
-  Thread_queue_Control     Wait_queue;
-  /** This element is the current state of the RWLock.
-  CORE_RWLock_States       current_state;
-  /** This element contains the current number of thread waiting for this
-   *  RWLock to be released. */
-  uint32_t                 number_of_readers;
-}   CORE_RWLock_Control;
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/score/include/rtems/score/corerwlockimpl.h b/cpukit/score/include/rtems/score/corerwlockimpl.h
index 330d9acc55..dae3159f45 100644
--- a/cpukit/score/include/rtems/score/corerwlockimpl.h
+++ b/cpukit/score/include/rtems/score/corerwlockimpl.h
@@ -19,10 +19,10 @@
 #ifndef _RTEMS_SCORE_CORERWLOCKIMPL_H
 #define _RTEMS_SCORE_CORERWLOCKIMPL_H
+#include <rtems/score/percpu.h>
+#include <rtems/score/status.h>
-#include <rtems/score/status.h>
 #ifdef __cplusplus
@@ -49,6 +49,40 @@ extern "C" {
 #define CORE_RWLOCK_THREAD_WAITING_FOR_WRITE 1
+ *  RWLock State.
+typedef enum {
+  /** This indicates the the RWLock is not currently locked.
+  CORE_RWLOCK_UNLOCKED,
+  /** This indicates the the RWLock is currently locked for reading.
+  CORE_RWLOCK_LOCKED_FOR_READING,
+  CORE_RWLOCK_LOCKED_FOR_WRITING
+}   CORE_RWLock_States;
+ *  The following defines the control block used to manage each
+ *  RWLock.
+typedef struct {
+  /** This element is the current state of the RWLock.
+  CORE_RWLock_States current_state;
+  /** This element contains the current number of thread waiting for this
+   *  RWLock to be released. */
+  unsigned int number_of_readers;
+  /** This field is the Waiting Queue used to manage the set of tasks
+   *  which are blocked waiting for the RWLock to be released.
+  Thread_queue_Syslock_queue Queue;
+}   CORE_RWLock_Control;
  *  @brief Initialize a RWlock.
  *  This routine initializes the RWLock based on the parameters passed.
@@ -63,15 +97,27 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Destroy(
   CORE_RWLock_Control *the_rwlock
-  _Thread_queue_Destroy( &the_rwlock->Wait_queue );
+  (void) the_rwlock;
-RTEMS_INLINE_ROUTINE void _CORE_RWLock_Acquire_critical(
+RTEMS_INLINE_ROUTINE Thread_Control *_CORE_RWLock_Acquire(
   CORE_RWLock_Control  *the_rwlock,
-  _Thread_queue_Acquire_critical( &the_rwlock->Wait_queue, queue_context );
+  ISR_Level       level;
+  Thread_Control *executing;
+  _Thread_queue_Context_ISR_disable( queue_context, level );
+  _Thread_queue_Context_set_ISR_level( queue_context, level );
+  executing = _Thread_Executing;
+  _Thread_queue_Queue_acquire_critical(
+    &the_rwlock->Queue.Queue,
+    &executing->Potpourri_stats,
+    &queue_context->Lock_context.Lock_context
+  return executing;
 RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
@@ -79,7 +125,10 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
-  _Thread_queue_Release( &the_rwlock->Wait_queue, queue_context );
+  _Thread_queue_Queue_release(
@@ -93,7 +142,6 @@ RTEMS_INLINE_ROUTINE void _CORE_RWLock_Release(
 Status_Control _CORE_RWLock_Seize_for_reading(
-  Thread_Control       *executing,
   bool                  wait,
@@ -108,7 +156,6 @@ Status_Control _CORE_RWLock_Seize_for_reading(
 Status_Control _CORE_RWLock_Seize_for_writing(
   bool                  wait,
@@ -123,10 +170,7 @@ Status_Control _CORE_RWLock_Seize_for_writing(
  *  @retval Status is returned to indicate successful or failure.
-Status_Control _CORE_RWLock_Surrender(
-  CORE_RWLock_Control  *the_rwlock,
+Status_Control _CORE_RWLock_Surrender( CORE_RWLock_Control *the_rwlock );
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index e68035d338..f8e7ddd284 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -91,7 +91,6 @@ typedef enum {
   OBJECTS_POSIX_SEMAPHORES          = 7,
   OBJECTS_POSIX_CONDITION_VARIABLES = 8,
   OBJECTS_POSIX_TIMERS              = 9,
-  OBJECTS_POSIX_RWLOCKS             = 11,
   OBJECTS_POSIX_SHMS                = 12
 } Objects_POSIX_API;
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index 29ad24dc2f..09b82e6836 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -52,7 +52,6 @@ extern "C" {
 #define RTEMS_SYSINIT_POSIX_MESSAGE_QUEUE        000364
 #define RTEMS_SYSINIT_POSIX_SEMAPHORE            000365
 #define RTEMS_SYSINIT_POSIX_TIMER                000366
-#define RTEMS_SYSINIT_POSIX_RWLOCK               000368
 #define RTEMS_SYSINIT_POSIX_SHM                  000369
 #define RTEMS_SYSINIT_POSIX_KEYS                 00036a
 #define RTEMS_SYSINIT_POSIX_CLEANUP              00036b
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 32356e3c4a..0e05b5548e 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -120,6 +120,10 @@ $(PROJECT_INCLUDE)/rtems/score/coremuteximpl.h: include/rtems/score/coremuteximp
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/coremuteximpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/coremuteximpl.h
+$(PROJECT_INCLUDE)/rtems/score/corerwlockimpl.h: include/rtems/score/corerwlockimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/corerwlockimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/corerwlockimpl.h
 $(PROJECT_INCLUDE)/rtems/score/coresem.h: include/rtems/score/coresem.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/coresem.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/coresem.h
@@ -412,15 +416,6 @@ $(PROJECT_INCLUDE)/rtems/score/basedefs.h: include/rtems/score/basedefs.h $(PROJ
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/basedefs.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/basedefs.h
-if HAS_PTHREADS
-$(PROJECT_INCLUDE)/rtems/score/corerwlock.h: include/rtems/score/corerwlock.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/corerwlock.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/corerwlock.h
-$(PROJECT_INCLUDE)/rtems/score/corerwlockimpl.h: include/rtems/score/corerwlockimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/corerwlockimpl.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/corerwlockimpl.h
-endif
 if HAS_MP
 $(PROJECT_INCLUDE)/rtems/score/mpci.h: include/rtems/score/mpci.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mpci.h
diff --git a/cpukit/score/src/corerwlock.c b/cpukit/score/src/corerwlock.c
index 51ae2c70df..9ebb796ac4 100644
--- a/cpukit/score/src/corerwlock.c
+++ b/cpukit/score/src/corerwlock.c
@@ -27,6 +27,5 @@ void _CORE_RWLock_Initialize(
   the_rwlock->number_of_readers = 0;
   the_rwlock->current_state = CORE_RWLOCK_UNLOCKED;
-  _Thread_queue_Object_initialize( &the_rwlock->Wait_queue );
+  _Thread_queue_Queue_initialize( &the_rwlock->Queue.Queue, NULL );
diff --git a/cpukit/score/src/corerwlockobtainread.c b/cpukit/score/src/corerwlockobtainread.c
index 641945635f..d0bd7b09ce 100644
--- a/cpukit/score/src/corerwlockobtainread.c
+++ b/cpukit/score/src/corerwlockobtainread.c
@@ -26,18 +26,19 @@
   bool                  wait,
    *  If unlocked, then OK to read.
    *  If locked for reading and no waiters, then OK to read.
    *  If any thread is waiting, then we wait.
-  _CORE_RWLock_Acquire_critical( the_rwlock, queue_context );
+  executing = _CORE_RWLock_Acquire( the_rwlock, queue_context );
   switch ( the_rwlock->current_state ) {
     case CORE_RWLOCK_UNLOCKED:
@@ -46,19 +47,13 @@ Status_Control _CORE_RWLock_Seize_for_reading(
       _CORE_RWLock_Release( the_rwlock, queue_context );
       return STATUS_SUCCESSFUL;
-    case CORE_RWLOCK_LOCKED_FOR_READING: {
-      Thread_Control *waiter;
-      waiter = _Thread_queue_First_locked(
-        &the_rwlock->Wait_queue,
-        CORE_RWLOCK_TQ_OPERATIONS
-      if ( !waiter ) {
+    case CORE_RWLOCK_LOCKED_FOR_READING:
+      if ( _Thread_queue_Is_empty( &the_rwlock->Queue.Queue ) ) {
         the_rwlock->number_of_readers += 1;
       break;
     case CORE_RWLOCK_LOCKED_FOR_WRITING:
       break;
@@ -84,7 +79,7 @@ Status_Control _CORE_RWLock_Seize_for_reading(
   _Thread_queue_Context_set_do_nothing_enqueue_callout( queue_context );
   _Thread_queue_Enqueue(
-     &the_rwlock->Wait_queue.Queue,
      CORE_RWLOCK_TQ_OPERATIONS,
      executing,
      queue_context
diff --git a/cpukit/score/src/corerwlockobtainwrite.c b/cpukit/score/src/corerwlockobtainwrite.c
index 7f636daa99..6859163f1f 100644
--- a/cpukit/score/src/corerwlockobtainwrite.c
+++ b/cpukit/score/src/corerwlockobtainwrite.c
@@ -26,11 +26,12 @@
   bool                  wait,
    *  Otherwise, we have to block.
@@ -38,7 +39,7 @@ Status_Control _CORE_RWLock_Seize_for_writing(
@@ -72,7 +73,7 @@ Status_Control _CORE_RWLock_Seize_for_writing(
      executing,
      queue_context
diff --git a/cpukit/score/src/corerwlockrelease.c b/cpukit/score/src/corerwlockrelease.c
index 71aa12a190..772d16dc25 100644
--- a/cpukit/score/src/corerwlockrelease.c
+++ b/cpukit/score/src/corerwlockrelease.c
@@ -45,7 +45,7 @@ static Thread_Control *_CORE_RWLock_Flush_filter(
   the_rwlock = RTEMS_CONTAINER_OF(
     queue,
     CORE_RWLock_Control,
-    Wait_queue.Queue
+    Queue.Queue
@@ -73,11 +73,10 @@ static Thread_Control *_CORE_RWLock_Flush_filter(
   return the_thread;
+  Thread_queue_Context queue_context;
@@ -85,11 +84,12 @@ Status_Control _CORE_RWLock_Surrender(
+  _CORE_RWLock_Acquire( the_rwlock, &queue_context );
   if ( the_rwlock->current_state == CORE_RWLOCK_UNLOCKED){
     /* This is an error at the caller site */
-    _CORE_RWLock_Release( the_rwlock, queue_context );
+    _CORE_RWLock_Release( the_rwlock, &queue_context );
@@ -98,7 +98,7 @@ Status_Control _CORE_RWLock_Surrender(
     if ( the_rwlock->number_of_readers != 0 ) {
       /* must be unlocked again */
@@ -116,10 +116,10 @@ Status_Control _CORE_RWLock_Surrender(
   _Thread_queue_Flush_critical(
     _CORE_RWLock_Flush_filter,
-    queue_context
+    &queue_context
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index c9e6bfd9fb..154b4d1bd6 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -64,7 +64,6 @@ const char rtems_test_name[] = "PSXCONFIG 1";
 #define POSIX_MQ_COUNT 5
 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 19
 #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 7
-#define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 31
 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 41
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
@@ -474,18 +473,6 @@ static rtems_task Init(rtems_task_argument argument)
 #endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
-  for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_RWLOCKS; ++i) {
-    pthread_rwlock_t rwlock;
-    eno = pthread_rwlock_init(&rwlock, NULL);
-    rtems_test_assert(eno == 0);
-  rtems_resource_snapshot_take(&snapshot);
-    snapshot.posix_api.active_rwlocks == CONFIGURE_MAXIMUM_POSIX_RWLOCKS
-#endif
 #ifdef CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
   for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_SEMAPHORES; ++i) {
     int oflag = O_RDWR | O_CREAT | O_EXCL;
diff --git a/testsuites/psxtests/psxrwlock01/main.c b/testsuites/psxtests/psxrwlock01/main.c
index 3719b326f9..88190ebb2a 100644
--- a/testsuites/psxtests/psxrwlock01/main.c
+++ b/testsuites/psxtests/psxrwlock01/main.c
@@ -39,7 +39,6 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 2
-#define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 1
diff --git a/testsuites/psxtests/psxrwlock01/psxrwlock01.scn b/testsuites/psxtests/psxrwlock01/psxrwlock01.scn
index fb315f35f2..fe47b19bea 100644
--- a/testsuites/psxtests/psxrwlock01/psxrwlock01.scn
+++ b/testsuites/psxtests/psxrwlock01/psxrwlock01.scn
@@ -1,4 +1,4 @@
-*** POSIX RWLOCK TEST 01 ***
+*** BEGIN OF TEST PSXRWLOCK 1 ***
 pthread_rwlockattr_init( NULL ) -- EINVAL
 pthread_rwlockattr_setpshared( NULL, private ) -- EINVAL
 pthread_rwlockattr_setpshared( NULL, shared ) -- EINVAL
@@ -37,7 +37,6 @@ pthread_rwlock_trywrlock(BadId) -- EINVAL
 pthread_rwlock_unlock(BadId) -- EINVAL
 pthread_rwlockattr_init( &attr ) -- OK
 pthread_rwlock_init( &rwlock, &attr ) -- OK
-pthread_rwlock_init( &rwlock, &attr ) -- EAGAIN
 pthread_rwlock_destroy( &rwlock ) -- OK
 pthread_rwlock_init( &rwlock, NULL ) -- OK
@@ -94,4 +93,4 @@ pthread_rwlock_destroy( &RWLock ) -- OK
 pthread_rwlock_unlock ( &rwlock ) -- OK
-*** END OF POSIX RWLOCK TEST 01 ***
+*** END OF TEST PSXRWLOCK 1 ***
diff --git a/testsuites/psxtests/psxrwlock01/test.c b/testsuites/psxtests/psxrwlock01/test.c
index 268f581a3e..0165838c2f 100644
--- a/testsuites/psxtests/psxrwlock01/test.c
+++ b/testsuites/psxtests/psxrwlock01/test.c
@@ -90,7 +90,7 @@ void *WriteLockThread(void *arg)
   return NULL;
-static void test_pshared_init(void)
+static void test_rwlock_pshared_init(void)
   pthread_rwlockattr_t attr;
@@ -126,6 +126,190 @@ static void test_pshared_init(void)
+static void test_rwlock_null( void )
+  struct timespec to;
+  int eno;
+  eno = pthread_rwlock_destroy( NULL );
+  rtems_test_assert( eno == EINVAL );
+  eno = pthread_rwlock_init( NULL, NULL );
+  eno = pthread_rwlock_rdlock( NULL );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_rwlock_timedrdlock( NULL, &to );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_rwlock_timedwrlock( NULL, &to );
+  eno = pthread_rwlock_tryrdlock( NULL );
+  eno = pthread_rwlock_trywrlock( NULL );
+  eno = pthread_rwlock_unlock( NULL );
+  eno = pthread_rwlock_wrlock( NULL );
+static void test_rwlock_not_initialized( void )
+  pthread_rwlock_t rw;
+  int eno;
+  memset( &rw, 0xff, sizeof( rw ) );
+  eno = pthread_rwlock_destroy( &rw );
+  eno = pthread_rwlock_rdlock( &rw );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_rwlock_timedrdlock( &rw, &to );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_rwlock_timedwrlock( &rw, &to );
+  eno = pthread_rwlock_tryrdlock( &rw );
+  eno = pthread_rwlock_trywrlock( &rw );
+  eno = pthread_rwlock_unlock( &rw );
+  eno = pthread_rwlock_wrlock( &rw );
+static void test_rwlock_invalid_copy( void )
+  pthread_rwlock_t rw2;
+  int eno;
+  eno = pthread_rwlock_init( &rw, NULL );
+  rtems_test_assert( eno == 0 );
+  memcpy( &rw2, &rw, sizeof( rw2 ) );
+  eno = pthread_rwlock_destroy( &rw2 );
+  eno = pthread_rwlock_rdlock( &rw2 );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_rwlock_timedrdlock( &rw2, &to );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_rwlock_timedwrlock( &rw2, &to );
+  eno = pthread_rwlock_tryrdlock( &rw2 );
+  eno = pthread_rwlock_trywrlock( &rw2 );
+  eno = pthread_rwlock_unlock( &rw2 );
+  eno = pthread_rwlock_wrlock( &rw2 );
+static void test_rwlock_auto_initialization( void )
+  int eno;
+    pthread_rwlock_t rw = PTHREAD_RWLOCK_INITIALIZER;
+    to.tv_sec = 1;
+    to.tv_nsec = 1;
+    to.tv_sec = 1;
+    to.tv_nsec = 1;
  *  main entry point to the test
@@ -140,7 +324,6 @@ int main(
 #endif
-  pthread_rwlock_t     rwlock2;
   int                  status;
   int                  p;
@@ -149,7 +332,11 @@ int main(
   TEST_BEGIN();
-  test_pshared_init();
+  test_rwlock_pshared_init();
+  test_rwlock_null();
+  test_rwlock_not_initialized();
+  test_rwlock_invalid_copy();
+  test_rwlock_auto_initialization();
   /*************** NULL POINTER CHECKS *****************/
   puts( "pthread_rwlockattr_init( NULL ) -- EINVAL" );
@@ -192,42 +379,6 @@ int main(
   status = pthread_rwlockattr_setpshared( &attr, ~PTHREAD_PROCESS_PRIVATE );
   rtems_test_assert( status == EINVAL );
-  /*************** AUTO INITIALIZATION *****************/
-  rwlock = PTHREAD_RWLOCK_INITIALIZER;
-  rwlock2 = PTHREAD_RWLOCK_INITIALIZER;
-  status = pthread_rwlock_rdlock( &rwlock );
-  rtems_test_assert( status == 0 );
-  status = pthread_rwlock_rdlock( &rwlock2 );
-  rtems_test_assert( status == EINVAL );
-  status = pthread_rwlock_destroy( &rwlock );
-  status = pthread_rwlock_destroy( &rwlock2 );
-  rtems_test_assert( rwlock2 != PTHREAD_RWLOCK_INITIALIZER );
   /*************** ACTUALLY WORK THIS TIME *****************/
   puts( "pthread_rwlockattr_init( &attr ) -- OK" );
   status = pthread_rwlockattr_init( &attr );
@@ -309,7 +460,6 @@ int main(
   /*************** BAD ID CHECK *****************/
-  rwlock = 1;
   /* make a valid abstime */
   puts( "clock_gettime(CLOCK_REALTIME, &abstime) -- OK" );
   status = clock_gettime( CLOCK_REALTIME, &abstime );
@@ -317,35 +467,35 @@ int main(
   abstime.tv_sec += 5;
   puts( "pthread_rwlock_destroy(BadId) -- EINVAL" );
-  status = pthread_rwlock_destroy(&rwlock);
+  status = pthread_rwlock_destroy(NULL);
   puts( "pthread_rwlock_rdlock(BadId) -- EINVAL" );
-  status = pthread_rwlock_rdlock(&rwlock);
+  status = pthread_rwlock_rdlock(NULL);
   puts( "pthread_rwlock_timedrdlock(BadId, &abstime) -- EINVAL" );
-  status = pthread_rwlock_timedrdlock( &rwlock, &abstime);
+  status = pthread_rwlock_timedrdlock( NULL, &abstime);
   puts( "pthread_rwlock_tryrdlock(BadId) -- EINVAL" );
-  status = pthread_rwlock_tryrdlock(&rwlock);
+  status = pthread_rwlock_tryrdlock(NULL);
   puts( "pthread_rwlock_wrlock(BadId) -- EINVAL" );
-  status = pthread_rwlock_wrlock(&rwlock);
+  status = pthread_rwlock_wrlock(NULL);
   puts( "pthread_rwlock_timedwrlock(BadId, &abstime) -- EINVAL" );
-  status = pthread_rwlock_timedwrlock( &rwlock, &abstime );
+  status = pthread_rwlock_timedwrlock( NULL, &abstime );
   puts( "pthread_rwlock_trywrlock(BadId) -- EINVAL" );
-  status = pthread_rwlock_trywrlock(&rwlock);
+  status = pthread_rwlock_trywrlock(NULL);
   puts( "pthread_rwlock_unlock(BadId) -- EINVAL" );
-  status = pthread_rwlock_unlock(&rwlock);
+  status = pthread_rwlock_unlock(NULL);
   /*************** BAD ABSTIME CHECK *****************/
@@ -368,11 +518,6 @@ int main(
   puts( "pthread_rwlock_init( &rwlock, &attr ) -- OK" );
   status = pthread_rwlock_init( &rwlock, &attr );
-  rtems_test_assert( rwlock != 0 );
-  puts( "pthread_rwlock_init( &rwlock, &attr ) -- EAGAIN" );
-  status = pthread_rwlock_init( &rwlock, &attr );
-  rtems_test_assert( status == EAGAIN );
   puts( "pthread_rwlock_destroy( &rwlock ) -- OK" );
@@ -549,7 +694,6 @@ int main(
   puts( "pthread_rwlock_init( &rwlock, NULL ) -- OK" );
   status = pthread_rwlock_init( &rwlock, NULL );
   puts( "pthread_rwlock_unlock ( &rwlock ) -- OK" );
   status = pthread_rwlock_unlock( &rwlock );
diff --git a/testsuites/psxtmtests/psxtmrwlock01/init.c b/testsuites/psxtmtests/psxtmrwlock01/init.c
index 0073e70382..93d9c8b5b5 100644
--- a/testsuites/psxtmtests/psxtmrwlock01/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock01/init.c
@@ -271,7 +271,6 @@ void *POSIX_Init(
 #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
 #define CONFIGURE_MAXIMUM_POSIX_THREADS     1
 #define CONFIGURE_POSIX_INIT_THREAD_TABLE
diff --git a/testsuites/psxtmtests/psxtmrwlock02/init.c b/testsuites/psxtmtests/psxtmrwlock02/init.c
index 4ce7fa5ec0..f2462b235b 100644
--- a/testsuites/psxtmtests/psxtmrwlock02/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock02/init.c
@@ -126,7 +126,6 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS     OPERATION_COUNT + 2
diff --git a/testsuites/psxtmtests/psxtmrwlock03/init.c b/testsuites/psxtmtests/psxtmrwlock03/init.c
index 5fdf522c63..10c7aee4cc 100644
--- a/testsuites/psxtmtests/psxtmrwlock03/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock03/init.c
@@ -139,7 +139,6 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmrwlock04/init.c b/testsuites/psxtmtests/psxtmrwlock04/init.c
index 8b1b45dd98..dd2d7357f1 100644
--- a/testsuites/psxtmtests/psxtmrwlock04/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock04/init.c
@@ -127,7 +127,6 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmrwlock05/init.c b/testsuites/psxtmtests/psxtmrwlock05/init.c
index 1ec86c0efe..f6668c370d 100644
--- a/testsuites/psxtmtests/psxtmrwlock05/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock05/init.c
diff --git a/testsuites/psxtmtests/psxtmrwlock06/init.c b/testsuites/psxtmtests/psxtmrwlock06/init.c
index b74ac251cb..93a49be1f5 100644
--- a/testsuites/psxtmtests/psxtmrwlock06/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock06/init.c
@@ -101,7 +101,6 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmrwlock07/init.c b/testsuites/psxtmtests/psxtmrwlock07/init.c
index 9a779028f8..303c3015c5 100644
--- a/testsuites/psxtmtests/psxtmrwlock07/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock07/init.c
@@ -158,7 +158,6 @@ void *POSIX_Init(
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index ff450b9ace..ab9e4a8e64 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -114,8 +114,6 @@ typedef enum {
   POSIX_SEMAPHORE_POST,
   POSIX_TIMER_PRE,
   POSIX_TIMER_POST,
-  POSIX_RWLOCK_PRE,
-  POSIX_RWLOCK_POST,
   POSIX_SHM_PRE,
   POSIX_SHM_POST,
 #endif /* RTEMS_POSIX_API */
@@ -503,18 +501,6 @@ LAST(RTEMS_SYSINIT_POSIX_TIMER)
   next_step(POSIX_TIMER_POST);
-FIRST(RTEMS_SYSINIT_POSIX_RWLOCK)
-  assert(_POSIX_RWLock_Information.maximum == 0);
-  next_step(POSIX_RWLOCK_PRE);
-LAST(RTEMS_SYSINIT_POSIX_RWLOCK)
-  assert(_POSIX_RWLock_Information.maximum != 0);
-  next_step(POSIX_RWLOCK_POST);
 FIRST(RTEMS_SYSINIT_POSIX_SHM)
   assert(_POSIX_Shm_Information.maximum == 0);
@@ -749,8 +735,6 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 1
 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 1
 #define CONFIGURE_MAXIMUM_POSIX_SHMS 1
diff --git a/testsuites/sptests/spthreadq01/init.c b/testsuites/sptests/spthreadq01/init.c
index 684d96b66a..1e25b62a2d 100644
--- a/testsuites/sptests/spthreadq01/init.c
+++ b/testsuites/sptests/spthreadq01/init.c
@@ -42,7 +42,6 @@ typedef struct {
 #if defined(RTEMS_POSIX_API)
   pthread_mutex_t pmtx;
   pthread_cond_t pcv;
-  pthread_rwlock_t prw;
   mqd_t pmq;
 #endif
 } test_context;
@@ -139,15 +138,6 @@ static void posix_worker(test_context *ctx)
   eno = pthread_mutex_unlock(&ctx->pmtx);
-  eno = pthread_rwlock_wrlock(&ctx->prw);
-  wake_up_master(ctx);
-  rtems_test_assert(get_wait_id(ctx) == ctx->prw);
-  eno = pthread_rwlock_unlock(&ctx->prw);
   rtems_test_assert(get_wait_id(ctx) == ctx->pmq);
@@ -220,9 +210,6 @@ static void test_posix_init(test_context *ctx)
   eno = pthread_cond_init(&ctx->pcv, NULL);
-  eno = pthread_rwlock_init(&ctx->prw, NULL);
   memset(&attr, 0, sizeof(attr));
   attr.mq_maxmsg = 1;
   attr.mq_msgsize = sizeof(char);
@@ -315,11 +302,6 @@ static void test_posix_obj(test_context *ctx)
   wait_for_worker(ctx);
-  wait_for_worker(ctx);
   buf[0] = 'y';
   prio = 1;
   n = mq_receive(ctx->pmq, &buf[0], sizeof(buf), &prio);
@@ -364,7 +346,6 @@ static rtems_task Init(
-  #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 1
   #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 1
   #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
     (2 * CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(1, 1))
2.12.3
