x86 TLS when PIC is enabled
Mon Sep 25 17:28:55 UTC 2017
HI
I am working on RTEMS on an i386 paravirtualized environment which requires
PIC.
This means the TLS method is not %gs but instead a function call which
appears to
be this per https://www.akkadia.org/drepper/tls.pdf
typedef struct {
  unsigned long ti_module;
  unsigned long ti_offset;
} tls_index;
void *__tls_get_addr(const tls_Index *ti)
  // XXX FIX ME
  return NULL;
Suggestions on how to fill this method in appreciated.
It looks like the ARM has the same method. Will the same code work?
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170925/91eecbce/attachment.html>
