[PATCH] posix: Implement self-contained POSIX condvar
Wed Sep 27 09:25:26 UTC 2017
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
 c/src/ada-tests/mptests/mp01/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp03/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp04/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp05/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp06/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp07/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp08/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp09/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp10/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp11/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp12/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp13/config_base.h         |   1 -
 c/src/ada-tests/mptests/mp14/config_base.h         |   1 -
 c/src/ada-tests/samples/base_mp/config.h           |   1 -
 c/src/ada-tests/samples/base_sp/config.h           |   1 -
 c/src/ada-tests/samples/hello/config.h             |   1 -
 c/src/ada-tests/samples/nsecs/config.h             |   1 -
 c/src/ada-tests/samples/ticker/config.h            |   1 -
 c/src/ada-tests/sptests/sp01/config.h              |   1 -
 c/src/ada-tests/sptests/sp02/config.h              |   1 -
 c/src/ada-tests/sptests/sp03/config.h              |   1 -
 c/src/ada-tests/sptests/sp04/config.h              |   1 -
 c/src/ada-tests/sptests/sp05/config.h              |   1 -
 c/src/ada-tests/sptests/sp06/config.h              |   1 -
 c/src/ada-tests/sptests/sp07/config.h              |   1 -
 c/src/ada-tests/sptests/sp08/config.h              |   1 -
 c/src/ada-tests/sptests/sp09/config.h              |   1 -
 c/src/ada-tests/sptests/sp11/config.h              |   1 -
 c/src/ada-tests/sptests/sp12/config.h              |   1 -
 c/src/ada-tests/sptests/sp13/config.h              |   1 -
 c/src/ada-tests/sptests/sp14/config.h              |   1 -
 c/src/ada-tests/sptests/sp15/config.h              |   1 -
 c/src/ada-tests/sptests/sp16/config.h              |   1 -
 c/src/ada-tests/sptests/sp17/config.h              |   1 -
 c/src/ada-tests/sptests/sp19/config.h              |   1 -
 c/src/ada-tests/sptests/sp20/config.h              |   1 -
 c/src/ada-tests/sptests/sp22/config.h              |   1 -
 c/src/ada-tests/sptests/sp23/config.h              |   1 -
 c/src/ada-tests/sptests/sp24/config.h              |   1 -
 c/src/ada-tests/sptests/sp25/config.h              |   1 -
 c/src/ada-tests/sptests/spname01/config.h          |   1 -
 c/src/ada-tests/tmtests/tm01/config.h              |   1 -
 c/src/ada-tests/tmtests/tm02/config.h              |   1 -
 c/src/ada-tests/tmtests/tm03/config.h              |   1 -
 c/src/ada-tests/tmtests/tm04/config.h              |   1 -
 c/src/ada-tests/tmtests/tm05/config.h              |   1 -
 c/src/ada-tests/tmtests/tm06/config.h              |   1 -
 c/src/ada-tests/tmtests/tm07/config.h              |   1 -
 c/src/ada-tests/tmtests/tm08/config.h              |   1 -
 c/src/ada-tests/tmtests/tm09/config.h              |   1 -
 c/src/ada-tests/tmtests/tm10/config.h              |   1 -
 c/src/ada-tests/tmtests/tm11/config.h              |   1 -
 c/src/ada-tests/tmtests/tm12/config.h              |   1 -
 c/src/ada-tests/tmtests/tm13/config.h              |   1 -
 c/src/ada-tests/tmtests/tm14/config.h              |   1 -
 c/src/ada-tests/tmtests/tm15/config.h              |   1 -
 c/src/ada-tests/tmtests/tm16/config.h              |   1 -
 c/src/ada-tests/tmtests/tm17/config.h              |   1 -
 c/src/ada-tests/tmtests/tm18/config.h              |   1 -
 c/src/ada-tests/tmtests/tm19/config.h              |   1 -
 c/src/ada-tests/tmtests/tm20/config.h              |   1 -
 c/src/ada-tests/tmtests/tm21/config.h              |   1 -
 c/src/ada-tests/tmtests/tm22/config.h              |   1 -
 c/src/ada-tests/tmtests/tm23/config.h              |   1 -
 c/src/ada-tests/tmtests/tm24/config.h              |   1 -
 c/src/ada-tests/tmtests/tm25/config.h              |   1 -
 c/src/ada-tests/tmtests/tm28/config.h              |   1 -
 c/src/ada-tests/tmtests/tm29/config.h              |   1 -
 c/src/ada-tests/tmtests/tmck/config.h              |   1 -
 c/src/ada-tests/tmtests/tmoverhd/config.h          |   1 -
 cpukit/libcsupport/include/rtems/libcsupport.h     |   1 -
 cpukit/libcsupport/src/resource_snapshot.c         |   2 -
 cpukit/posix/Makefile.am                           |  21 ++--
 cpukit/posix/include/rtems/posix/cond.h            |  57 ---------
 cpukit/posix/include/rtems/posix/condimpl.h        | 133 +++++++++++++--------
 cpukit/posix/include/rtems/posix/config.h          |   6 -
 cpukit/posix/preinstall.am                         |  12 +-
 cpukit/posix/src/cond.c                            |  65 ----------
 cpukit/posix/src/conddestroy.c                     |  25 +---
 cpukit/posix/src/condget.c                         |  30 -----
 cpukit/posix/src/condinit.c                        |  62 +++++-----
 cpukit/posix/src/condsignalsupp.c                  |  34 +++---
 cpukit/posix/src/condwait.c                        |  21 ++++
 cpukit/posix/src/condwaitsupp.c                    |  26 ++--
 cpukit/rtems/src/rtemsobjectgetapiclassname.c      |   1 -
 cpukit/sapi/include/confdefs.h                     |  63 ----------
 cpukit/score/include/rtems/score/objectimpl.h      |   1 -
 cpukit/score/include/rtems/sysinit.h               |   1 -
 testsuites/psxtests/psx10/init.c                   | 129 ++++++++++++++++++--
 testsuites/psxtests/psx10/psx10.scn                |   2 -
 testsuites/psxtests/psx10/system.h                 |   1 -
 testsuites/psxtests/psxaio01/system.h              |   1 -
 testsuites/psxtests/psxaio02/system.h              |   1 -
 testsuites/psxtests/psxaio03/system.h              |   1 -
 testsuites/psxtests/psxautoinit02/init.c           |  59 +++++++--
 .../psxtests/psxautoinit02/psxautoinit02.scn       |  15 ++-
 testsuites/psxtests/psxcleanup/system.h            |   1 -
 testsuites/psxtests/psxcond01/init.c               |   1 -
 testsuites/psxtests/psxconfig01/init.c             |  14 ---
 testsuites/psxtests/psxkey07/init.c                |   1 -
 testsuites/psxtests/psxsignal06/init.c             |   1 -
 testsuites/psxtests/psxtimer01/system.h            |   1 -
 testsuites/psxtmtests/psxtmcond01/init.c           |   1 -
 testsuites/psxtmtests/psxtmcond02/init.c           |   1 -
 testsuites/psxtmtests/psxtmcond03/init.c           |   1 -
 testsuites/psxtmtests/psxtmcond04/init.c           |   1 -
 testsuites/psxtmtests/psxtmcond05/init.c           |   1 -
 testsuites/psxtmtests/psxtmcond06/init.c           |   1 -
 testsuites/psxtmtests/psxtmcond07/init.c           |   1 -
 testsuites/psxtmtests/psxtmcond08/init.c           |   2 -
 testsuites/sptests/spsysinit01/init.c              |  17 ---
 testsuites/sptests/spthreadq01/init.c              |   3 -
 112 files changed, 369 insertions(+), 519 deletions(-)
 delete mode 100644 cpukit/posix/include/rtems/posix/cond.h
 delete mode 100644 cpukit/posix/src/cond.c
 delete mode 100644 cpukit/posix/src/condget.c
diff --git a/c/src/ada-tests/mptests/mp01/config_base.h b/c/src/ada-tests/mptests/mp01/config_base.h
index 2f9df40e53..d8fb72a5aa 100644
--- a/c/src/ada-tests/mptests/mp01/config_base.h
+++ b/c/src/ada-tests/mptests/mp01/config_base.h
@@ -23,7 +23,6 @@
 #define CONFIGURE_MAXIMUM_POSIX_THREADS              10
 #define CONFIGURE_MAXIMUM_POSIX_KEYS                 10
 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES              20
-#define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES  10
 #include <rtems/confdefs.h>
diff --git a/c/src/ada-tests/mptests/mp03/config_base.h b/c/src/ada-tests/mptests/mp03/config_base.h
--- a/c/src/ada-tests/mptests/mp03/config_base.h
+++ b/c/src/ada-tests/mptests/mp03/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp04/config_base.h b/c/src/ada-tests/mptests/mp04/config_base.h
--- a/c/src/ada-tests/mptests/mp04/config_base.h
+++ b/c/src/ada-tests/mptests/mp04/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp05/config_base.h b/c/src/ada-tests/mptests/mp05/config_base.h
--- a/c/src/ada-tests/mptests/mp05/config_base.h
+++ b/c/src/ada-tests/mptests/mp05/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp06/config_base.h b/c/src/ada-tests/mptests/mp06/config_base.h
--- a/c/src/ada-tests/mptests/mp06/config_base.h
+++ b/c/src/ada-tests/mptests/mp06/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp07/config_base.h b/c/src/ada-tests/mptests/mp07/config_base.h
--- a/c/src/ada-tests/mptests/mp07/config_base.h
+++ b/c/src/ada-tests/mptests/mp07/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp08/config_base.h b/c/src/ada-tests/mptests/mp08/config_base.h
--- a/c/src/ada-tests/mptests/mp08/config_base.h
+++ b/c/src/ada-tests/mptests/mp08/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp09/config_base.h b/c/src/ada-tests/mptests/mp09/config_base.h
--- a/c/src/ada-tests/mptests/mp09/config_base.h
+++ b/c/src/ada-tests/mptests/mp09/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp10/config_base.h b/c/src/ada-tests/mptests/mp10/config_base.h
--- a/c/src/ada-tests/mptests/mp10/config_base.h
+++ b/c/src/ada-tests/mptests/mp10/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp11/config_base.h b/c/src/ada-tests/mptests/mp11/config_base.h
--- a/c/src/ada-tests/mptests/mp11/config_base.h
+++ b/c/src/ada-tests/mptests/mp11/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp12/config_base.h b/c/src/ada-tests/mptests/mp12/config_base.h
--- a/c/src/ada-tests/mptests/mp12/config_base.h
+++ b/c/src/ada-tests/mptests/mp12/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp13/config_base.h b/c/src/ada-tests/mptests/mp13/config_base.h
--- a/c/src/ada-tests/mptests/mp13/config_base.h
+++ b/c/src/ada-tests/mptests/mp13/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/mptests/mp14/config_base.h b/c/src/ada-tests/mptests/mp14/config_base.h
--- a/c/src/ada-tests/mptests/mp14/config_base.h
+++ b/c/src/ada-tests/mptests/mp14/config_base.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/samples/base_mp/config.h b/c/src/ada-tests/samples/base_mp/config.h
index d5ae258199..5bc381d1e6 100644
--- a/c/src/ada-tests/samples/base_mp/config.h
+++ b/c/src/ada-tests/samples/base_mp/config.h
@@ -25,7 +25,6 @@
  *  Put the overrides of default configuration parameters here.
diff --git a/c/src/ada-tests/samples/base_sp/config.h b/c/src/ada-tests/samples/base_sp/config.h
index 76699e4fc4..99e023117b 100644
--- a/c/src/ada-tests/samples/base_sp/config.h
+++ b/c/src/ada-tests/samples/base_sp/config.h
@@ -23,7 +23,6 @@
 #define CONFIGURE_MAXIMUM_TASKS            2
diff --git a/c/src/ada-tests/samples/hello/config.h b/c/src/ada-tests/samples/hello/config.h
index f4febdf491..712c14c284 100644
--- a/c/src/ada-tests/samples/hello/config.h
+++ b/c/src/ada-tests/samples/hello/config.h
@@ -24,7 +24,6 @@
 #define CONFIGURE_MAXIMUM_TASKS              1
diff --git a/c/src/ada-tests/samples/nsecs/config.h b/c/src/ada-tests/samples/nsecs/config.h
index 909750a51d..c359b76651 100644
--- a/c/src/ada-tests/samples/nsecs/config.h
+++ b/c/src/ada-tests/samples/nsecs/config.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/samples/ticker/config.h b/c/src/ada-tests/samples/ticker/config.h
index 43d27fdefc..0fb068fb32 100644
--- a/c/src/ada-tests/samples/ticker/config.h
+++ b/c/src/ada-tests/samples/ticker/config.h
@@ -23,7 +23,6 @@
 #define CONFIGURE_MAXIMUM_TASKS             4
diff --git a/c/src/ada-tests/sptests/sp01/config.h b/c/src/ada-tests/sptests/sp01/config.h
index f7858db811..4cc789dc1a 100644
--- a/c/src/ada-tests/sptests/sp01/config.h
+++ b/c/src/ada-tests/sptests/sp01/config.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/sptests/sp02/config.h b/c/src/ada-tests/sptests/sp02/config.h
--- a/c/src/ada-tests/sptests/sp02/config.h
+++ b/c/src/ada-tests/sptests/sp02/config.h
@@ -23,7 +23,6 @@
diff --git a/c/src/ada-tests/sptests/sp03/config.h b/c/src/ada-tests/sptests/sp03/config.h
index eb1076e417..655026e6ef 100644
--- a/c/src/ada-tests/sptests/sp03/config.h
+++ b/c/src/ada-tests/sptests/sp03/config.h
@@ -23,7 +23,6 @@
 #define CONFIGURE_MAXIMUM_TASKS             3
diff --git a/c/src/ada-tests/sptests/sp04/config.h b/c/src/ada-tests/sptests/sp04/config.h
index b8ae20e8ed..a7b928fd4a 100644
--- a/c/src/ada-tests/sptests/sp04/config.h
+++ b/c/src/ada-tests/sptests/sp04/config.h
@@ -26,7 +26,6 @@
diff --git a/c/src/ada-tests/sptests/sp05/config.h b/c/src/ada-tests/sptests/sp05/config.h
index 2bf7d9ebb6..b72a42bcd1 100644
--- a/c/src/ada-tests/sptests/sp05/config.h
+++ b/c/src/ada-tests/sptests/sp05/config.h
@@ -25,7 +25,6 @@
diff --git a/c/src/ada-tests/sptests/sp06/config.h b/c/src/ada-tests/sptests/sp06/config.h
--- a/c/src/ada-tests/sptests/sp06/config.h
+++ b/c/src/ada-tests/sptests/sp06/config.h
@@ -25,7 +25,6 @@
diff --git a/c/src/ada-tests/sptests/sp07/config.h b/c/src/ada-tests/sptests/sp07/config.h
index 7bef527da3..afc6b2f676 100644
--- a/c/src/ada-tests/sptests/sp07/config.h
+++ b/c/src/ada-tests/sptests/sp07/config.h
@@ -26,7 +26,6 @@
 #define CONFIGURE_MAXIMUM_TASKS             5
diff --git a/c/src/ada-tests/sptests/sp08/config.h b/c/src/ada-tests/sptests/sp08/config.h
index 678bdc16aa..380883768d 100644
--- a/c/src/ada-tests/sptests/sp08/config.h
+++ b/c/src/ada-tests/sptests/sp08/config.h
@@ -25,7 +25,6 @@
diff --git a/c/src/ada-tests/sptests/sp09/config.h b/c/src/ada-tests/sptests/sp09/config.h
index 288d72a975..861180e438 100644
--- a/c/src/ada-tests/sptests/sp09/config.h
+++ b/c/src/ada-tests/sptests/sp09/config.h
@@ -33,7 +33,6 @@
diff --git a/c/src/ada-tests/sptests/sp11/config.h b/c/src/ada-tests/sptests/sp11/config.h
index ba7dbe9d15..f4ef59ede9 100644
--- a/c/src/ada-tests/sptests/sp11/config.h
+++ b/c/src/ada-tests/sptests/sp11/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/sptests/sp12/config.h b/c/src/ada-tests/sptests/sp12/config.h
index fdaeb98e61..2be58dbdcf 100644
--- a/c/src/ada-tests/sptests/sp12/config.h
+++ b/c/src/ada-tests/sptests/sp12/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/sptests/sp13/config.h b/c/src/ada-tests/sptests/sp13/config.h
index 93dd34bc35..448cea9ffd 100644
--- a/c/src/ada-tests/sptests/sp13/config.h
+++ b/c/src/ada-tests/sptests/sp13/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/sptests/sp14/config.h b/c/src/ada-tests/sptests/sp14/config.h
index fddc75cd78..89071c3388 100644
--- a/c/src/ada-tests/sptests/sp14/config.h
+++ b/c/src/ada-tests/sptests/sp14/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/sptests/sp15/config.h b/c/src/ada-tests/sptests/sp15/config.h
index 47aacdae2b..8db00f3616 100644
--- a/c/src/ada-tests/sptests/sp15/config.h
+++ b/c/src/ada-tests/sptests/sp15/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/sptests/sp16/config.h b/c/src/ada-tests/sptests/sp16/config.h
index 6055b61d4f..63bdd592bd 100644
--- a/c/src/ada-tests/sptests/sp16/config.h
+++ b/c/src/ada-tests/sptests/sp16/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/sptests/sp17/config.h b/c/src/ada-tests/sptests/sp17/config.h
index b3cfdaeb06..ce8ea3728f 100644
--- a/c/src/ada-tests/sptests/sp17/config.h
+++ b/c/src/ada-tests/sptests/sp17/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/sptests/sp19/config.h b/c/src/ada-tests/sptests/sp19/config.h
index 8776bfeaa9..9264b83be4 100644
--- a/c/src/ada-tests/sptests/sp19/config.h
+++ b/c/src/ada-tests/sptests/sp19/config.h
@@ -23,7 +23,6 @@
 #define CONFIGURE_MAXIMUM_TASKS             7
diff --git a/c/src/ada-tests/sptests/sp20/config.h b/c/src/ada-tests/sptests/sp20/config.h
index d01f68e8ce..ccbd3e6a0b 100644
--- a/c/src/ada-tests/sptests/sp20/config.h
+++ b/c/src/ada-tests/sptests/sp20/config.h
@@ -26,7 +26,6 @@
diff --git a/c/src/ada-tests/sptests/sp22/config.h b/c/src/ada-tests/sptests/sp22/config.h
index 29246a181c..36a984ab80 100644
--- a/c/src/ada-tests/sptests/sp22/config.h
+++ b/c/src/ada-tests/sptests/sp22/config.h
@@ -26,7 +26,6 @@
diff --git a/c/src/ada-tests/sptests/sp23/config.h b/c/src/ada-tests/sptests/sp23/config.h
index f6e94678cb..de87c32e45 100644
--- a/c/src/ada-tests/sptests/sp23/config.h
+++ b/c/src/ada-tests/sptests/sp23/config.h
@@ -26,7 +26,6 @@
diff --git a/c/src/ada-tests/sptests/sp24/config.h b/c/src/ada-tests/sptests/sp24/config.h
index 70a92d7f37..bfd5f1ee30 100644
--- a/c/src/ada-tests/sptests/sp24/config.h
+++ b/c/src/ada-tests/sptests/sp24/config.h
@@ -26,7 +26,6 @@
diff --git a/c/src/ada-tests/sptests/sp25/config.h b/c/src/ada-tests/sptests/sp25/config.h
index b6ce643953..ab5b7356ad 100644
--- a/c/src/ada-tests/sptests/sp25/config.h
+++ b/c/src/ada-tests/sptests/sp25/config.h
@@ -26,7 +26,6 @@
diff --git a/c/src/ada-tests/sptests/spname01/config.h b/c/src/ada-tests/sptests/spname01/config.h
--- a/c/src/ada-tests/sptests/spname01/config.h
+++ b/c/src/ada-tests/sptests/spname01/config.h
@@ -24,7 +24,6 @@
diff --git a/c/src/ada-tests/tmtests/tm01/config.h b/c/src/ada-tests/tmtests/tm01/config.h
index 4696518ffb..2a720540a9 100644
--- a/c/src/ada-tests/tmtests/tm01/config.h
+++ b/c/src/ada-tests/tmtests/tm01/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm02/config.h b/c/src/ada-tests/tmtests/tm02/config.h
index 2c15f3d80d..bd25a5b7c5 100644
--- a/c/src/ada-tests/tmtests/tm02/config.h
+++ b/c/src/ada-tests/tmtests/tm02/config.h
@@ -28,7 +28,6 @@
diff --git a/c/src/ada-tests/tmtests/tm03/config.h b/c/src/ada-tests/tmtests/tm03/config.h
--- a/c/src/ada-tests/tmtests/tm03/config.h
+++ b/c/src/ada-tests/tmtests/tm03/config.h
@@ -28,7 +28,6 @@
diff --git a/c/src/ada-tests/tmtests/tm04/config.h b/c/src/ada-tests/tmtests/tm04/config.h
index 6a35a2e0d9..d861fe9621 100644
--- a/c/src/ada-tests/tmtests/tm04/config.h
+++ b/c/src/ada-tests/tmtests/tm04/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm05/config.h b/c/src/ada-tests/tmtests/tm05/config.h
--- a/c/src/ada-tests/tmtests/tm05/config.h
+++ b/c/src/ada-tests/tmtests/tm05/config.h
@@ -28,7 +28,6 @@
diff --git a/c/src/ada-tests/tmtests/tm06/config.h b/c/src/ada-tests/tmtests/tm06/config.h
--- a/c/src/ada-tests/tmtests/tm06/config.h
+++ b/c/src/ada-tests/tmtests/tm06/config.h
@@ -28,7 +28,6 @@
diff --git a/c/src/ada-tests/tmtests/tm07/config.h b/c/src/ada-tests/tmtests/tm07/config.h
--- a/c/src/ada-tests/tmtests/tm07/config.h
+++ b/c/src/ada-tests/tmtests/tm07/config.h
@@ -28,7 +28,6 @@
diff --git a/c/src/ada-tests/tmtests/tm08/config.h b/c/src/ada-tests/tmtests/tm08/config.h
--- a/c/src/ada-tests/tmtests/tm08/config.h
+++ b/c/src/ada-tests/tmtests/tm08/config.h
@@ -28,7 +28,6 @@
diff --git a/c/src/ada-tests/tmtests/tm09/config.h b/c/src/ada-tests/tmtests/tm09/config.h
index 7fb031f18f..60c467cbf0 100644
--- a/c/src/ada-tests/tmtests/tm09/config.h
+++ b/c/src/ada-tests/tmtests/tm09/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm10/config.h b/c/src/ada-tests/tmtests/tm10/config.h
index 0d33e36a0d..df3eb123bf 100644
--- a/c/src/ada-tests/tmtests/tm10/config.h
+++ b/c/src/ada-tests/tmtests/tm10/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm11/config.h b/c/src/ada-tests/tmtests/tm11/config.h
index 9bcf4c0edd..43726419af 100644
--- a/c/src/ada-tests/tmtests/tm11/config.h
+++ b/c/src/ada-tests/tmtests/tm11/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm12/config.h b/c/src/ada-tests/tmtests/tm12/config.h
--- a/c/src/ada-tests/tmtests/tm12/config.h
+++ b/c/src/ada-tests/tmtests/tm12/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm13/config.h b/c/src/ada-tests/tmtests/tm13/config.h
--- a/c/src/ada-tests/tmtests/tm13/config.h
+++ b/c/src/ada-tests/tmtests/tm13/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm14/config.h b/c/src/ada-tests/tmtests/tm14/config.h
--- a/c/src/ada-tests/tmtests/tm14/config.h
+++ b/c/src/ada-tests/tmtests/tm14/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm15/config.h b/c/src/ada-tests/tmtests/tm15/config.h
--- a/c/src/ada-tests/tmtests/tm15/config.h
+++ b/c/src/ada-tests/tmtests/tm15/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm16/config.h b/c/src/ada-tests/tmtests/tm16/config.h
--- a/c/src/ada-tests/tmtests/tm16/config.h
+++ b/c/src/ada-tests/tmtests/tm16/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm17/config.h b/c/src/ada-tests/tmtests/tm17/config.h
--- a/c/src/ada-tests/tmtests/tm17/config.h
+++ b/c/src/ada-tests/tmtests/tm17/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm18/config.h b/c/src/ada-tests/tmtests/tm18/config.h
--- a/c/src/ada-tests/tmtests/tm18/config.h
+++ b/c/src/ada-tests/tmtests/tm18/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm19/config.h b/c/src/ada-tests/tmtests/tm19/config.h
--- a/c/src/ada-tests/tmtests/tm19/config.h
+++ b/c/src/ada-tests/tmtests/tm19/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm20/config.h b/c/src/ada-tests/tmtests/tm20/config.h
index b56b34c338..c2ea25d0f8 100644
--- a/c/src/ada-tests/tmtests/tm20/config.h
+++ b/c/src/ada-tests/tmtests/tm20/config.h
@@ -28,7 +28,6 @@
diff --git a/c/src/ada-tests/tmtests/tm21/config.h b/c/src/ada-tests/tmtests/tm21/config.h
index e16b8b3ae4..b397ebc521 100644
--- a/c/src/ada-tests/tmtests/tm21/config.h
+++ b/c/src/ada-tests/tmtests/tm21/config.h
@@ -33,7 +33,6 @@
diff --git a/c/src/ada-tests/tmtests/tm22/config.h b/c/src/ada-tests/tmtests/tm22/config.h
index a4612b11a9..7e2efe1743 100644
--- a/c/src/ada-tests/tmtests/tm22/config.h
+++ b/c/src/ada-tests/tmtests/tm22/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm23/config.h b/c/src/ada-tests/tmtests/tm23/config.h
index 33b3dc3dc5..da5214bb1c 100644
--- a/c/src/ada-tests/tmtests/tm23/config.h
+++ b/c/src/ada-tests/tmtests/tm23/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm24/config.h b/c/src/ada-tests/tmtests/tm24/config.h
index c59203a676..13e936bb03 100644
--- a/c/src/ada-tests/tmtests/tm24/config.h
+++ b/c/src/ada-tests/tmtests/tm24/config.h
@@ -26,7 +26,6 @@
diff --git a/c/src/ada-tests/tmtests/tm25/config.h b/c/src/ada-tests/tmtests/tm25/config.h
--- a/c/src/ada-tests/tmtests/tm25/config.h
+++ b/c/src/ada-tests/tmtests/tm25/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm28/config.h b/c/src/ada-tests/tmtests/tm28/config.h
index 710b2b626d..bf2a951908 100644
--- a/c/src/ada-tests/tmtests/tm28/config.h
+++ b/c/src/ada-tests/tmtests/tm28/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tm29/config.h b/c/src/ada-tests/tmtests/tm29/config.h
index c294a0701c..b81f5d11ca 100644
--- a/c/src/ada-tests/tmtests/tm29/config.h
+++ b/c/src/ada-tests/tmtests/tm29/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tmck/config.h b/c/src/ada-tests/tmtests/tmck/config.h
--- a/c/src/ada-tests/tmtests/tmck/config.h
+++ b/c/src/ada-tests/tmtests/tmck/config.h
@@ -27,7 +27,6 @@
diff --git a/c/src/ada-tests/tmtests/tmoverhd/config.h b/c/src/ada-tests/tmtests/tmoverhd/config.h
--- a/c/src/ada-tests/tmtests/tmoverhd/config.h
+++ b/c/src/ada-tests/tmtests/tmoverhd/config.h
@@ -27,7 +27,6 @@
diff --git a/cpukit/libcsupport/include/rtems/libcsupport.h b/cpukit/libcsupport/include/rtems/libcsupport.h
index 3246209bad..080fee471d 100644
--- a/cpukit/libcsupport/include/rtems/libcsupport.h
+++ b/cpukit/libcsupport/include/rtems/libcsupport.h
@@ -111,7 +111,6 @@ typedef struct {
 } rtems_resource_rtems_api;
 typedef struct {
-  uint32_t active_condition_variables;
   uint32_t active_message_queues;
   uint32_t active_mutexes;
   uint32_t active_semaphores;
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 243ffd33cd..695c94867e 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -42,7 +42,6 @@
 #ifdef RTEMS_POSIX_API
   #include <rtems/posix/barrierimpl.h>
-  #include <rtems/posix/condimpl.h>
   #include <rtems/posix/mqueueimpl.h>
   #include <rtems/posix/psignal.h>
@@ -68,7 +67,6 @@ static const struct {
   { OBJECTS_CLASSIC_API, OBJECTS_RTEMS_TIMERS }
-    { OBJECTS_POSIX_API, OBJECTS_POSIX_CONDITION_VARIABLES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_MESSAGE_QUEUES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_MUTEXES },
     { OBJECTS_POSIX_API, OBJECTS_POSIX_SEMAPHORES },
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 531acde156..3498961007 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -17,6 +17,7 @@ include_rtems_posix_HEADERS = include/rtems/posix/sigset.h
 ## Some POSIX threads features are needed all the time
 include_rtems_posix_HEADERS += include/rtems/posix/barrierimpl.h
+include_rtems_posix_HEADERS += include/rtems/posix/condimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/key.h
 include_rtems_posix_HEADERS += include/rtems/posix/keyimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/config.h
@@ -34,8 +35,6 @@ include_HEADERS += include/mqueue.h
 # include/rtems/posix
 include_rtems_posix_HEADERS += include/rtems/posix/aio_misc.h
-include_rtems_posix_HEADERS += include/rtems/posix/cond.h
-include_rtems_posix_HEADERS += include/rtems/posix/condimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/mmanimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/mqueue.h
 include_rtems_posix_HEADERS += include/rtems/posix/mqueueimpl.h
@@ -72,6 +71,15 @@ libposix_a_SOURCES += src/barrierattrdestroy.c src/barrierattrgetpshared.c \
     src/pbarrierdestroy.c src/pbarrierinit.c \
     src/pbarrierwait.c
+## CONDITION_VARIABLE_C_FILES
+libposix_a_SOURCES += src/condattrdestroy.c \
+    src/condattrinit.c  \
+    src/condattrgetpshared.c src/condattrsetpshared.c \
+    src/condattrgetclock.c src/condattrsetclock.c \
+    src/condbroadcast.c src/conddefaultattributes.c src/conddestroy.c \
+    src/condinit.c src/condsignal.c src/condsignalsupp.c \
+    src/condtimedwait.c src/condwait.c src/condwaitsupp.c
 if HAS_PTHREADS
 libposix_a_SOURCES +=  src/pthreadatfork.c
@@ -80,15 +88,6 @@ libposix_a_SOURCES += src/cancel.c \
     src/cleanuppush.c src/setcancelstate.c \
     src/setcanceltype.c src/testcancel.c
-## CONDITION_VARIABLE_C_FILES
-libposix_a_SOURCES += src/cond.c src/condattrdestroy.c \
-    src/condattrinit.c  \
-    src/condattrgetpshared.c src/condattrsetpshared.c \
-    src/condattrgetclock.c src/condattrsetclock.c \
-    src/condbroadcast.c src/conddefaultattributes.c src/conddestroy.c \
-    src/condinit.c src/condsignal.c src/condsignalsupp.c \
-    src/condtimedwait.c src/condwait.c src/condwaitsupp.c src/condget.c
 ## MEMORY_C_FILES
 libposix_a_SOURCES += src/mlockall.c
 libposix_a_SOURCES += src/mlock.c
diff --git a/cpukit/posix/include/rtems/posix/cond.h b/cpukit/posix/include/rtems/posix/cond.h
deleted file mode 100644
index 52b9a59929..0000000000
--- a/cpukit/posix/include/rtems/posix/cond.h
+++ /dev/null
@@ -1,57 +0,0 @@
- * @file
- * @brief POSIX Condition Variables Private Support
- * This include file contains all the private support information for
- * POSIX condition variables.
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_POSIX_COND_H
-#define _RTEMS_POSIX_COND_H
-#include <rtems/score/object.h>
-#include <rtems/score/threadq.h>
-#include <pthread.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup POSIX_COND_VARS POSIX Condition Variables
- * @ingroup POSIXAPI
- *  Data Structure used to manage a POSIX condition variable
-typedef struct {
-   Objects_Control       Object;
-   Thread_queue_Control  Wait_queue;
-   pthread_mutex_t      *mutex;
-   clockid_t             clock;
-}  POSIX_Condition_variables_Control;
-#ifdef __cplusplus
-#endif
-#endif
-/*  end of include file */
diff --git a/cpukit/posix/include/rtems/posix/condimpl.h b/cpukit/posix/include/rtems/posix/condimpl.h
index e9375c1075..3d861d38db 100644
--- a/cpukit/posix/include/rtems/posix/condimpl.h
+++ b/cpukit/posix/include/rtems/posix/condimpl.h
@@ -16,17 +16,29 @@
 #ifndef _RTEMS_POSIX_CONDIMPL_H
 #define _RTEMS_POSIX_CONDIMPL_H
-#include <rtems/posix/cond.h>
-#include <rtems/score/objectimpl.h>
-#include <rtems/score/threadqimpl.h>
+#include <pthread.h>
+#include <rtems/score/percpu.h>
+#include <rtems/score/threadqimpl.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
+typedef struct {
+  unsigned long flags;
+  pthread_mutex_t *mutex;
+  Thread_queue_Syslock_queue Queue;
+} POSIX_Condition_variables_Control;
+#define POSIX_CONDITION_VARIABLES_CLOCK_MONOTONIC 0x1UL
+#define POSIX_CONDITION_VARIABLES_FLAGS_MASK 0x1UL
+#define POSIX_CONDITION_VARIABLES_MAGIC 0x18dfb1feUL
  *  Constant to indicate condition variable does not currently have
  *  a mutex assigned to it.
@@ -37,86 +49,90 @@ extern "C" {
 #define POSIX_CONDITION_VARIABLE_OF_THREAD_QUEUE_QUEUE( queue ) \
   RTEMS_CONTAINER_OF( \
-    queue, POSIX_Condition_variables_Control, Wait_queue.Queue )
- *  The following defines the information control block used to manage
- *  this class of objects.
-extern Objects_Information _POSIX_Condition_variables_Information;
+    queue, POSIX_Condition_variables_Control, Queue.Queue )
  *  The default condition variable attributes structure.
 extern const pthread_condattr_t _POSIX_Condition_variables_Default_attributes;
+static inline POSIX_Condition_variables_Control *_POSIX_Condition_variables_Get(
+  pthread_cond_t *cond
+  return (POSIX_Condition_variables_Control *) cond;
 RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Initialize(
   POSIX_Condition_variables_Control *the_cond,
   const pthread_condattr_t          *the_attr
-  _Thread_queue_Object_initialize( &the_cond->Wait_queue );
+  _Thread_queue_Queue_initialize( &the_cond->Queue.Queue, NULL );
   the_cond->mutex = POSIX_CONDITION_VARIABLES_NO_MUTEX;
-  the_cond->clock = the_attr->clock;
+  flags = (uintptr_t) the_cond ^ POSIX_CONDITION_VARIABLES_MAGIC;
+  flags &= ~POSIX_CONDITION_VARIABLES_FLAGS_MASK;
+  if ( the_attr->clock == CLOCK_MONOTONIC ) {
+    flags |= POSIX_CONDITION_VARIABLES_CLOCK_MONOTONIC;
+  the_cond->flags = flags;
 RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Destroy(
-  _Thread_queue_Destroy( &the_cond->Wait_queue );
+  the_cond->flags = 0;
-RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Acquire_critical(
-  POSIX_Condition_variables_Control *the_cond,
-  Thread_queue_Context              *queue_context
+RTEMS_INLINE_ROUTINE clockid_t _POSIX_Condition_variables_Get_clock(
-  _Thread_queue_Acquire_critical( &the_cond->Wait_queue, queue_context );
+  if ( ( flags & POSIX_CONDITION_VARIABLES_CLOCK_MONOTONIC ) != 0 ) {
+    return CLOCK_MONOTONIC;
+  return CLOCK_REALTIME;
-RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Release(
+RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Condition_variables_Acquire(
-  _Thread_queue_Release( &the_cond->Wait_queue, queue_context );
+  ISR_Level       level;
+  Thread_Control *executing;
+  _Thread_queue_Context_initialize( queue_context );
+  _Thread_queue_Context_ISR_disable( queue_context, level );
+  _Thread_queue_Context_set_ISR_level( queue_context, level );
+  executing = _Thread_Executing;
+  _Thread_queue_Queue_acquire_critical(
+    &the_cond->Queue.Queue,
+    &executing->Potpourri_stats,
+    &queue_context->Lock_context.Lock_context
- *  @brief POSIX Condition Variable Allocate
- *  This function allocates a condition variable control block from
- *  the inactive chain of free condition variable control blocks.
-RTEMS_INLINE_ROUTINE POSIX_Condition_variables_Control *
-  _POSIX_Condition_variables_Allocate( void )
-  return (POSIX_Condition_variables_Control *)
-    _Objects_Allocate( &_POSIX_Condition_variables_Information );
+  return executing;
- *  @brief POSIX Condition Variable Free
- *  This routine frees a condition variable control block to the
- *  inactive chain of free condition variable control blocks.
-RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Free (
-  POSIX_Condition_variables_Control *the_condition_variable
+RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Release(
+  POSIX_Condition_variables_Control *the_cond,
+  Thread_queue_Context              *queue_context
-  _Objects_Free(
-    &_POSIX_Condition_variables_Information,
-    &the_condition_variable->Object
+  _Thread_queue_Queue_release(
-POSIX_Condition_variables_Control *_POSIX_Condition_variables_Get(
-  pthread_cond_t       *cond,
  * @brief Implements wake up version of the "signal" operation.
@@ -140,6 +156,27 @@ int _POSIX_Condition_variables_Wait_support(
   const struct timespec     *abstime
+bool _POSIX_Condition_variables_Auto_initialization(
+#define POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT( the_cond, flags ) \
+  do { \
+    if ( ( the_cond ) == NULL ) { \
+      return EINVAL; \
+    flags = ( the_cond )->flags; \
+    if ( \
+      ( ( (uintptr_t) ( the_cond ) ^ POSIX_CONDITION_VARIABLES_MAGIC ) \
+          & ~POSIX_CONDITION_VARIABLES_FLAGS_MASK ) \
+        != ( flags & ~POSIX_CONDITION_VARIABLES_FLAGS_MASK ) \
+      if ( !_POSIX_Condition_variables_Auto_initialization( the_cond ) ) { \
+        return EINVAL; \
+  } while ( 0 )
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/posix/include/rtems/posix/config.h b/cpukit/posix/include/rtems/posix/config.h
index 799eb62f03..2f5a5d7600 100644
--- a/cpukit/posix/include/rtems/posix/config.h
+++ b/cpukit/posix/include/rtems/posix/config.h
@@ -70,12 +70,6 @@ typedef struct {
    * This field contains the maximum number of POSIX API
-   * condition variables which are configured for this application.
-  uint32_t                            maximum_condition_variables;
-   * This field contains the maximum number of POSIX API
    * timers which are configured for this application.
   uint32_t                            maximum_timers;
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index 45d1c465b5..285999360f 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -31,6 +31,10 @@ $(PROJECT_INCLUDE)/rtems/posix/barrierimpl.h: include/rtems/posix/barrierimpl.h
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/barrierimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/barrierimpl.h
+$(PROJECT_INCLUDE)/rtems/posix/condimpl.h: include/rtems/posix/condimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/condimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/condimpl.h
 $(PROJECT_INCLUDE)/rtems/posix/key.h: include/rtems/posix/key.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/key.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/key.h
@@ -80,14 +84,6 @@ $(PROJECT_INCLUDE)/rtems/posix/aio_misc.h: include/rtems/posix/aio_misc.h $(PROJ
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/aio_misc.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/aio_misc.h
-$(PROJECT_INCLUDE)/rtems/posix/cond.h: include/rtems/posix/cond.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/cond.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/cond.h
-$(PROJECT_INCLUDE)/rtems/posix/condimpl.h: include/rtems/posix/condimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/condimpl.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/condimpl.h
 $(PROJECT_INCLUDE)/rtems/posix/mmanimpl.h: include/rtems/posix/mmanimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/mmanimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/mmanimpl.h
diff --git a/cpukit/posix/src/cond.c b/cpukit/posix/src/cond.c
index 8ee57d89fd..0000000000
--- a/cpukit/posix/src/cond.c
+++ /dev/null
@@ -1,65 +0,0 @@
- * @file
- * @brief Initialization Necessary for this Manager
- * @ingroup POSIX_COND_VARS Condition Variables
- *  COPYRIGHT (c) 1989-2008.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <errno.h>
-#include <limits.h>
-#include <rtems/system.h>
-#include <rtems/config.h>
-#include <rtems/sysinit.h>
-#include <rtems/score/watchdog.h>
-#include <rtems/posix/condimpl.h>
-#include <rtems/posix/muteximpl.h>
-Objects_Information _POSIX_Condition_variables_Information;
- *  _POSIX_Condition_variables_Manager_initialization
- *  This routine initializes all condition variable manager related data
- *  structures.
- *  Input parameters:   NONE
- *  Output parameters:  NONE
-static void _POSIX_Condition_variables_Manager_initialization(void)
-  _Objects_Initialize_information(
-    &_POSIX_Condition_variables_Information, /* object information table */
-    OBJECTS_POSIX_API,                       /* object API */
-    OBJECTS_POSIX_CONDITION_VARIABLES,       /* object class */
-    Configuration_POSIX_API.maximum_condition_variables,
-                                /* maximum objects of this class */
-    sizeof( POSIX_Condition_variables_Control ),
-                                /* size of this object's control block */
-    true,                       /* true if names for this object are strings */
-    _POSIX_PATH_MAX,            /* maximum length of each object's name */
-    NULL                        /* Proxy extraction support callout */
-RTEMS_SYSINIT_ITEM(
-  _POSIX_Condition_variables_Manager_initialization,
-  RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE,
-  RTEMS_SYSINIT_ORDER_MIDDLE
diff --git a/cpukit/posix/src/conddestroy.c b/cpukit/posix/src/conddestroy.c
index a2c8dc188f..c7bba65d1b 100644
--- a/cpukit/posix/src/conddestroy.c
+++ b/cpukit/posix/src/conddestroy.c
@@ -24,36 +24,23 @@
  *  11.4.2 Initializing and Destroying a Condition Variable,
  *         P1003.1c/Draft 10, p. 87
-int pthread_cond_destroy(
+int pthread_cond_destroy( pthread_cond_t *cond )
   POSIX_Condition_variables_Control *the_cond;
   Thread_queue_Context               queue_context;
-  _Objects_Allocator_lock();
-  the_cond = _POSIX_Condition_variables_Get( cond, &queue_context );
+  the_cond = _POSIX_Condition_variables_Get( cond );
+  POSIX_CONDITION_VARIABLES_VALIDATE_OBJECT( the_cond, flags );
-  if ( the_cond == NULL ) {
-    _Objects_Allocator_unlock();
-    return EINVAL;
-  _POSIX_Condition_variables_Acquire_critical( the_cond, &queue_context );
+  _POSIX_Condition_variables_Acquire( the_cond, &queue_context );
-  if ( !_Thread_queue_Is_empty( &the_cond->Wait_queue.Queue ) ) {
+  if ( !_Thread_queue_Is_empty( &the_cond->Queue.Queue ) ) {
     _POSIX_Condition_variables_Release( the_cond, &queue_context );
     return EBUSY;
-  _Objects_Close(
-    &the_cond->Object
   _POSIX_Condition_variables_Destroy( the_cond );
-  _POSIX_Condition_variables_Free( the_cond );
   return 0;
diff --git a/cpukit/posix/src/condget.c b/cpukit/posix/src/condget.c
index 5b086ef7c9..0000000000
--- a/cpukit/posix/src/condget.c
+++ /dev/null
@@ -1,30 +0,0 @@
- *  COPYRIGHT (c) 1989-2007.
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/posix/posixapi.h>
-  _POSIX_Get_object_body(
-    POSIX_Condition_variables_Control,
-    cond,
-    queue_context,
-    PTHREAD_COND_INITIALIZER,
-    pthread_cond_init
diff --git a/cpukit/posix/src/condinit.c b/cpukit/posix/src/condinit.c
index 8d3aa8e244..aab26aa9f7 100644
--- a/cpukit/posix/src/condinit.c
+++ b/cpukit/posix/src/condinit.c
@@ -21,6 +21,29 @@
+RTEMS_STATIC_ASSERT(
+  offsetof( POSIX_Condition_variables_Control, flags )
+    == offsetof( pthread_cond_t, _flags ),
+  POSIX_CONDITION_VARIABLES_CONTROL_FLAGS
+  offsetof( POSIX_Condition_variables_Control, mutex )
+    == offsetof( pthread_cond_t, _mutex ),
+  POSIX_CONDITION_VARIABLES_CONTROL_COUNT
+  offsetof( POSIX_Condition_variables_Control, Queue )
+    == offsetof( pthread_cond_t, _Queue ),
+  POSIX_CONDITION_VARIABLES_CONTROL_QUEUE
+  sizeof( POSIX_Condition_variables_Control ) == sizeof( pthread_cond_t ),
+  POSIX_CONDITION_VARIABLES_CONTROL_SIZE
@@ -30,41 +53,26 @@ int pthread_cond_init(
   const pthread_condattr_t *attr
-  POSIX_Condition_variables_Control   *the_cond;
-  const pthread_condattr_t            *the_attr;
+  POSIX_Condition_variables_Control *the_cond;
-  if ( attr ) the_attr = attr;
-  else        the_attr = &_POSIX_Condition_variables_Default_attributes;
-   *  Be careful about attributes when global!!!
-  if ( !the_attr->is_initialized )
-    return EINVAL;
-  if ( !_POSIX_Is_valid_pshared( the_attr->process_shared ) ) {
+  if ( the_cond == NULL ) {
     return EINVAL;
-  the_cond = _POSIX_Condition_variables_Allocate();
-  if ( !the_cond ) {
-    return ENOMEM;
+  if ( attr == NULL ) {
+    attr = &_POSIX_Condition_variables_Default_attributes;
-  _POSIX_Condition_variables_Initialize( the_cond, the_attr );
-  _Objects_Open_u32(
-    &the_cond->Object,
-    0
-  *cond = the_cond->Object.id;
+  if ( !attr->is_initialized ) {
+    return EINVAL;
+  if ( !_POSIX_Is_valid_pshared( attr->process_shared ) ) {
+    return EINVAL;
+  _POSIX_Condition_variables_Initialize( the_cond, attr );
   return 0;
diff --git a/cpukit/posix/src/condsignalsupp.c b/cpukit/posix/src/condsignalsupp.c
index e42476e1c4..2f92a55128 100644
--- a/cpukit/posix/src/condsignalsupp.c
+++ b/cpukit/posix/src/condsignalsupp.c
@@ -32,29 +32,29 @@ int _POSIX_Condition_variables_Signal_support(
   bool                       is_broadcast
-  Thread_Control *the_thread;
+  const Thread_queue_Operations     *operations;
+  Thread_queue_Heads                *heads;
-  do {
-    Thread_queue_Context               queue_context;
+  operations = POSIX_CONDITION_VARIABLES_TQ_OPERATIONS;
+  do {
+    Thread_queue_Context queue_context;
-      return EINVAL;
+    heads = the_cond->Queue.Queue.heads;
-    the_thread = _Thread_queue_First_locked(
-      &the_cond->Wait_queue,
-      POSIX_CONDITION_VARIABLES_TQ_OPERATIONS
+    if ( heads != NULL ) {
+      Thread_Control *the_thread;
-    if ( the_thread != NULL ) {
+      the_thread = ( *operations->first )( heads );
       _Thread_queue_Extract_critical(
-        &the_cond->Wait_queue.Queue,
-        POSIX_CONDITION_VARIABLES_TQ_OPERATIONS,
+        operations,
         the_thread,
         &queue_context
@@ -62,7 +62,7 @@ int _POSIX_Condition_variables_Signal_support(
-  } while ( is_broadcast && the_thread != NULL );
+  } while ( is_broadcast && heads != NULL );
   return 0;
diff --git a/cpukit/posix/src/condwait.c b/cpukit/posix/src/condwait.c
index 9a88287d0d..9527077757 100644
--- a/cpukit/posix/src/condwait.c
+++ b/cpukit/posix/src/condwait.c
@@ -20,6 +20,27 @@
+#include <string.h>
+  POSIX_Condition_variables_Control zero;
+  memset( &zero, 0, sizeof( zero ) );
+  if ( memcmp( the_cond, &zero, sizeof( *the_cond ) ) != 0 ) {
+    return false;
+  return true;
  *  11.4.4 Waiting on a Condition, P1003.1c/Draft 10, p. 105
diff --git a/cpukit/posix/src/condwaitsupp.c b/cpukit/posix/src/condwaitsupp.c
index 486bab879c..7486ae5c8e 100644
--- a/cpukit/posix/src/condwaitsupp.c
+++ b/cpukit/posix/src/condwaitsupp.c
@@ -25,8 +25,6 @@
 #include <rtems/score/status.h>
-THREAD_QUEUE_OBJECT_ASSERT( POSIX_Condition_variables_Control, Wait_queue );
 static void _POSIX_Condition_variables_Enqueue_callout(
   Thread_queue_Queue   *queue,
   Thread_Control       *the_thread,
@@ -58,6 +56,7 @@ int _POSIX_Condition_variables_Wait_support(
   int                                error;
   int                                mutex_error;
@@ -66,15 +65,8 @@ int _POSIX_Condition_variables_Wait_support(
   bool                               already_timedout;
   TOD_Absolute_timeout_conversion_results  status;
-  if ( mutex == NULL ) {
-    return EINVAL;
-    return EINVAL;
   already_timedout = false;
@@ -88,8 +80,11 @@ int _POSIX_Condition_variables_Wait_support(
      *  then we do a polling operation and convert the UNSATISFIED
      *  status into the appropriate error.
-    _Assert( the_cond->clock );
-    status = _TOD_Absolute_timeout_to_ticks(abstime, the_cond->clock, &timeout);
+    status = _TOD_Absolute_timeout_to_ticks(
+      abstime,
+      _POSIX_Condition_variables_Get_clock( flags ),
+      &timeout
     if ( status == TOD_ABSOLUTE_TIMEOUT_INVALID )
       return EINVAL;
@@ -103,7 +98,7 @@ int _POSIX_Condition_variables_Wait_support(
     _Thread_queue_Context_set_no_timeout( &queue_context );
+  executing = _POSIX_Condition_variables_Acquire( the_cond, &queue_context );
   if (
     the_cond->mutex != POSIX_CONDITION_VARIABLES_NO_MUTEX
@@ -114,7 +109,6 @@ int _POSIX_Condition_variables_Wait_support(
   the_cond->mutex = mutex;
-  executing = _Thread_Executing;
   if ( !already_timedout ) {
     _Thread_queue_Context_set_thread_state(
@@ -126,7 +120,7 @@ int _POSIX_Condition_variables_Wait_support(
     _Thread_queue_Enqueue(
       executing,
       &queue_context
diff --git a/cpukit/rtems/src/rtemsobjectgetapiclassname.c b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
index b2db41a8df..00f0de894a 100644
--- a/cpukit/rtems/src/rtemsobjectgetapiclassname.c
+++ b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
@@ -51,7 +51,6 @@ static const rtems_assoc_t rtems_object_api_posix_assoc[] = {
   { "Message Queue",           OBJECTS_POSIX_MESSAGE_QUEUES, 0},
   { "Mutex",                   OBJECTS_POSIX_MUTEXES, 0},
   { "Semaphore",               OBJECTS_POSIX_SEMAPHORES, 0},
-  { "Condition Variable",      OBJECTS_POSIX_CONDITION_VARIABLES, 0},
   { "Timer",                   OBJECTS_POSIX_TIMERS, 0},
   { "Shared Memory",           OBJECTS_POSIX_SHMS, 0},
   { NULL,                      0, 0}
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 596c3420b0..402a467762 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1841,14 +1841,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
      *  o bdbuf sync lock
     #define _CONFIGURE_LIBBLOCK_POSIX_MUTEXES 2
-     * POSIX Condition Variables:
-     *  o bdbuf access condition
-     *  o bdbuf transfer condition
-     *  o bdbuf buffer condition
-    #define _CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES 3
   #else
      * Semaphores:
@@ -1862,7 +1854,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #define _CONFIGURE_LIBBLOCK_SEMAPHORES 6
     #define _CONFIGURE_LIBBLOCK_POSIX_MUTEXES 0
-    #define _CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES 0
   #endif
   #if defined(CONFIGURE_HAS_OWN_BDBUF_TABLE) || \
@@ -1879,11 +1870,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #define _CONFIGURE_LIBBLOCK_SEMAPHORES 0
   /** This specifies the number of POSIX Mutexes needed by libblock. */
-   * This specifies the number of POSIX Condition Variables needed
-   * by libblock.
 #endif /* CONFIGURE_APPLICATION_NEEDS_LIBBLOCK */
@@ -2059,10 +2045,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       #define CONFIGURE_MAXIMUM_POSIX_MUTEXES \
         rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
     #endif
-    #if !defined(CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES)
-      #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES \
-        rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
-    #endif
     #if !defined(CONFIGURE_MAXIMUM_POSIX_TIMERS)
       #define CONFIGURE_MAXIMUM_POSIX_TIMERS \
@@ -2440,7 +2422,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #include <signal.h>
   #include <limits.h>
   #include <mqueue.h>
-  #include <rtems/posix/cond.h>
   #include <rtems/posix/mqueue.h>
   #include <rtems/posix/mutex.h>
@@ -2484,22 +2465,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
    * This configuration parameter specifies the maximum number of
-   * POSIX API condition variables.
-  #ifndef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
-    #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 0
-  #endif
-   * This macro is calculated to specify the memory required for
-  #define _CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES(_condvars) \
-      _Configure_Object_RAM(_condvars, \
-                          sizeof(POSIX_Condition_variables_Control) )
-   * This configuration parameter specifies the maximum number of
    * POSIX API timers.
   #ifndef CONFIGURE_MAXIMUM_POSIX_TIMERS
@@ -2712,12 +2677,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #ifndef CONFIGURE_MAXIMUM_POSIX_MUTEXES
     #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 1
   #endif
-    #define CONFIGURE_MAXIMUM_CONDITION_VARIABLES 1
-  #endif
   #define _CONFIGURE_GO_INIT_MUTEXES 77
-  #define _CONFIGURE_GO_INIT_CONDITION_VARIABLES 4
   #ifndef CONFIGURE_MAXIMUM_GOROUTINES
     #define CONFIGURE_MAXIMUM_GOROUTINES 400
@@ -2734,12 +2695,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #define _CONFIGURE_GO_INIT_MUTEXES             0
-   * This specifies the number of condition variables required by the Go
-   * run-time for its own use.
-  #define _CONFIGURE_GO_INIT_CONDITION_VARIABLES 0
   /** This specifies the maximum number of Go co-routines. */
   #define CONFIGURE_MAXIMUM_GOROUTINES          0
@@ -2778,24 +2733,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       CONFIGURE_MAXIMUM_GO_CHANNELS)
-   * This macro provides summation of the POSIX Condition Variables.
-  #define _CONFIGURE_POSIX_CONDITION_VARIABLES \
-    (CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES + \
-      _CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES + \
-      CONFIGURE_MAXIMUM_ADA_TASKS + \
-      CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + \
-      _CONFIGURE_GO_INIT_CONDITION_VARIABLES + \
-      CONFIGURE_MAXIMUM_GO_CHANNELS)
    * the POSIX API in its entirety.
   #define _CONFIGURE_MEMORY_FOR_POSIX \
     (_CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(_CONFIGURE_POSIX_MUTEXES) + \
-      _CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES( \
-        _CONFIGURE_POSIX_CONDITION_VARIABLES) + \
       _CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS( \
         CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS) + \
       _CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES( \
@@ -3248,7 +3190,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     posix_api_configuration_table Configuration_POSIX_API = {
       _CONFIGURE_POSIX_THREADS,
       _CONFIGURE_POSIX_MUTEXES,
-      _CONFIGURE_POSIX_CONDITION_VARIABLES,
       CONFIGURE_MAXIMUM_POSIX_TIMERS,
       CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS,
       CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES,
@@ -3462,7 +3403,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     /* POSIX API Pieces */
     uint32_t POSIX_MUTEXES;
-    uint32_t POSIX_CONDITION_VARIABLES;
     uint32_t POSIX_TIMERS;
     uint32_t POSIX_QUEUED_SIGNALS;
     uint32_t POSIX_MESSAGE_QUEUES;
@@ -3512,8 +3452,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     _CONFIGURE_MEMORY_FOR_POSIX_MUTEXES( _CONFIGURE_POSIX_MUTEXES ),
-      _CONFIGURE_POSIX_CONDITION_VARIABLES ),
       CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS ),
@@ -3584,7 +3522,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
 #if !defined(RTEMS_POSIX_API)
   #if ((CONFIGURE_MAXIMUM_POSIX_THREADS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_MUTEXES != 0) || \
-       (CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_TIMERS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS != 0) || \
        (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES != 0) || \
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index f8e7ddd284..435e82cc45 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -89,7 +89,6 @@ typedef enum {
   OBJECTS_POSIX_MESSAGE_QUEUES      = 5,
   OBJECTS_POSIX_MUTEXES             = 6,
   OBJECTS_POSIX_SEMAPHORES          = 7,
-  OBJECTS_POSIX_CONDITION_VARIABLES = 8,
   OBJECTS_POSIX_TIMERS              = 9,
   OBJECTS_POSIX_SHMS                = 12
 } Objects_POSIX_API;
diff --git a/cpukit/score/include/rtems/sysinit.h b/cpukit/score/include/rtems/sysinit.h
index 09b82e6836..595629fd04 100644
--- a/cpukit/score/include/rtems/sysinit.h
+++ b/cpukit/score/include/rtems/sysinit.h
@@ -47,7 +47,6 @@ extern "C" {
 #define RTEMS_SYSINIT_CLASSIC_BARRIER            00034a
 #define RTEMS_SYSINIT_POSIX_SIGNALS              000360
 #define RTEMS_SYSINIT_POSIX_THREADS              000361
-#define RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE   000362
 #define RTEMS_SYSINIT_POSIX_MUTEX                000363
 #define RTEMS_SYSINIT_POSIX_MESSAGE_QUEUE        000364
 #define RTEMS_SYSINIT_POSIX_SEMAPHORE            000365
diff --git a/testsuites/psxtests/psx10/init.c b/testsuites/psxtests/psx10/init.c
index 24265ba0ad..ad4e60e385 100644
--- a/testsuites/psxtests/psx10/init.c
+++ b/testsuites/psxtests/psx10/init.c
@@ -17,6 +17,121 @@
 const char rtems_test_name[] = "PSX 10";
+static void test_cond_null( void )
+  pthread_mutex_t mtx = PTHREAD_MUTEX_INITIALIZER;
+  int eno;
+  struct timespec to;
+  eno = pthread_cond_init( NULL, NULL );
+  rtems_test_assert( eno == EINVAL );
+  eno = pthread_mutex_lock( &mtx );
+  rtems_test_assert( eno == 0 );
+  eno = pthread_cond_wait( NULL, &mtx );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_cond_timedwait( NULL, &mtx, &to );
+  eno = pthread_mutex_unlock( &mtx );
+  eno = pthread_cond_signal( NULL );
+  eno = pthread_cond_broadcast( NULL );
+  eno = pthread_cond_destroy( NULL );
+  eno = pthread_mutex_destroy( &mtx );
+static void test_cond_not_initialized( void )
+  pthread_cond_t cond;
+  int eno;
+  memset( &cond, 0xff, sizeof( cond ) );
+  eno = pthread_cond_wait( &cond, &mtx );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_cond_timedwait( &cond, &mtx, &to );
+  eno = pthread_cond_signal( &cond );
+  eno = pthread_cond_broadcast( &cond );
+  eno = pthread_cond_destroy( &cond );
+static void test_cond_invalid_copy( void )
+  pthread_cond_t cond2;
+  int eno;
+  eno = pthread_cond_init( &cond, NULL );
+  memcpy( &cond2, &cond, sizeof( cond2 ) );
+  eno = pthread_cond_wait( &cond2, &mtx );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  eno = pthread_cond_timedwait( &cond2, &mtx, &to );
+  eno = pthread_cond_signal( &cond2 );
+  eno = pthread_cond_broadcast( &cond2 );
+  eno = pthread_cond_destroy( &cond2 );
 void *POSIX_Init(
   void *argument
@@ -30,6 +145,10 @@ void *POSIX_Init(
   TEST_BEGIN();
+  test_cond_null();
+  test_cond_not_initialized();
+  test_cond_invalid_copy();
   puts( "Init: pthread_condattr_init" );
   status = pthread_condattr_init( &attr );
   rtems_test_assert( !status );
@@ -97,16 +216,6 @@ void *POSIX_Init(
   rtems_test_assert( status == EINVAL );
   puts( "Init: pthread_cond_init - EINVAL (attr not initialized)" );
-  status = pthread_cond_init( &cond, NULL );
-  if ( status != ENOMEM )
-    printf( "status = %d\n", status );
-  rtems_test_assert( status == ENOMEM );
-  puts( "Init: pthread_cond_init - ENOMEM (too many conds)" );
-  puts( "Init: pthread_cond_destroy" );
-  status = pthread_cond_destroy( &cond );
-  rtems_test_assert( !status );
 /* error for bad condition variable passed */
   status = pthread_cond_destroy( NULL );
diff --git a/testsuites/psxtests/psx10/psx10.scn b/testsuites/psxtests/psx10/psx10.scn
index 2c70df8713..3d5680c9b5 100644
--- a/testsuites/psxtests/psx10/psx10.scn
+++ b/testsuites/psxtests/psx10/psx10.scn
@@ -12,8 +12,6 @@ Init: pthread_condattr_getpshared - 0
 Init: pthread_condattr_getpshared - EINVAL (attribute invalid)
 Init: pthread_cond_init - NULL attr
-Init: pthread_cond_init - ENOMEM (too many conds)
-Init: pthread_cond_destroy
 Init: pthread_cond_destroy - EINVAL (cond invalid)
 Init: pthread_cond_init - EINVAL (invalid pshared)
 Init: pthread_condattr_setpshared - PTHREAD_PROCESS_SHARED
diff --git a/testsuites/psxtests/psx10/system.h b/testsuites/psxtests/psx10/system.h
index 573a065c26..ee7e9c4dcf 100644
--- a/testsuites/psxtests/psx10/system.h
+++ b/testsuites/psxtests/psx10/system.h
@@ -41,7 +41,6 @@ void *Task_3(
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_MAXIMUM_POSIX_THREADS              4
 #define CONFIGURE_POSIX_INIT_THREAD_TABLE
diff --git a/testsuites/psxtests/psxaio01/system.h b/testsuites/psxtests/psxaio01/system.h
index 91a8658988..e17f7cab6d 100644
--- a/testsuites/psxtests/psxaio01/system.h
+++ b/testsuites/psxtests/psxaio01/system.h
@@ -29,7 +29,6 @@ void *POSIX_Init (void *argument);
 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES        10
diff --git a/testsuites/psxtests/psxaio02/system.h b/testsuites/psxtests/psxaio02/system.h
index 4137251d66..e3e1333964 100644
--- a/testsuites/psxtests/psxaio02/system.h
+++ b/testsuites/psxtests/psxaio02/system.h
diff --git a/testsuites/psxtests/psxaio03/system.h b/testsuites/psxtests/psxaio03/system.h
index fbea6f0e02..c809bc7045 100644
--- a/testsuites/psxtests/psxaio03/system.h
+++ b/testsuites/psxtests/psxaio03/system.h
@@ -30,7 +30,6 @@ void *POSIX_Init (void *argument);
 #define CONFIGURE_MAXIMUM_POSIX_THREADS        30
 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES        30
-#define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES     30
 #define CONFIGURE_MAXIMUM_POSIX_KEYS           30
diff --git a/testsuites/psxtests/psxautoinit02/init.c b/testsuites/psxtests/psxautoinit02/init.c
index 967b9b86d5..da2f58ad7e 100644
--- a/testsuites/psxtests/psxautoinit02/init.c
+++ b/testsuites/psxtests/psxautoinit02/init.c
@@ -25,20 +25,61 @@ void *POSIX_Init(
   int            sc;
-  pthread_cond_t cond1;
-  pthread_cond_t cond2;
+  pthread_cond_t cond1 = PTHREAD_COND_INITIALIZER;
+  pthread_cond_t cond2 = PTHREAD_COND_INITIALIZER;
+  pthread_cond_t cond3 = PTHREAD_COND_INITIALIZER;
+  pthread_cond_t cond4 = PTHREAD_COND_INITIALIZER;
+  pthread_cond_t cond5 = PTHREAD_COND_INITIALIZER;
   TEST_BEGIN();
-  cond1 = PTHREAD_COND_INITIALIZER;
-  cond2 = PTHREAD_COND_INITIALIZER;
   puts( "Init - pthread_cond_broadcast - auto initialize - OK" );
   sc = pthread_cond_broadcast( &cond1 );
   fatal_posix_service_status( sc, 0, "cond broadcast OK" );
-  puts( "Init - pthread_cond_broadcast - auto initialize - EINVAL" );
-  sc = pthread_cond_broadcast( &cond2 );
-  fatal_posix_service_status( sc, EINVAL, "cond lock EINVAL" );
+  puts( "Init - pthread_cond_signal - auto initialize - OK" );
+  sc = pthread_cond_signal( &cond2 );
+  fatal_posix_service_status( sc, 0, "cond signal OK" );
+  puts( "Init - pthread_cond_init - auto initialize - OK" );
+  sc = pthread_cond_init( &cond3, NULL );
+  fatal_posix_service_status( sc, 0, "cond init OK" );
+  puts( "Init - pthread_mutex_lock - OK" );
+  sc = pthread_mutex_lock( &mtx );
+  fatal_posix_service_status( sc, 0, "mtx lock OK" );
+  puts( "Init - pthread_cond_timedwait - auto initialize - OK" );
+  to.tv_sec = 1;
+  to.tv_nsec = 1;
+  sc = pthread_cond_timedwait( &cond4, &mtx, &to );
+  fatal_posix_service_status( sc, ETIMEDOUT, "cond timedwait OK" );
+  puts( "Init - pthread_mutex_unlock - OK" );
+  sc = pthread_mutex_unlock( &mtx );
+  fatal_posix_service_status( sc, 0, "mtx unlock OK" );
+  puts( "Init - pthread_mutex_destroy - OK" );
+  sc = pthread_mutex_destroy( &mtx );
+  fatal_posix_service_status( sc, 0, "mtx destroy OK" );
+  puts( "Init - pthread_cond_destroy - OK" );
+  sc = pthread_cond_destroy( &cond5 );
+  fatal_posix_service_status( sc, 0, "cond destroy OK" );
+  sc = pthread_cond_destroy( &cond4 );
+  sc = pthread_cond_destroy( &cond3 );
+  sc = pthread_cond_destroy( &cond2 );
   sc = pthread_cond_destroy( &cond1 );
@@ -51,12 +92,12 @@ void *POSIX_Init(
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_POSIX_MUTEXES 1
diff --git a/testsuites/psxtests/psxautoinit02/psxautoinit02.scn b/testsuites/psxtests/psxautoinit02/psxautoinit02.scn
index bfe3067468..047088a6d9 100644
--- a/testsuites/psxtests/psxautoinit02/psxautoinit02.scn
+++ b/testsuites/psxtests/psxautoinit02/psxautoinit02.scn
@@ -1,5 +1,14 @@
-*** POSIX TEST -- AUTOMATIC INITIALIZAITON 02 ***
+*** BEGIN OF TEST PSXAUTOINIT 2 ***
-Init - pthread_cond_broadcast - auto initialize - EINVAL
+Init - pthread_cond_signal - auto initialize - OK
+Init - pthread_cond_init - auto initialize - OK
+Init - pthread_mutex_lock - OK
+Init - pthread_cond_timedwait - auto initialize - OK
+Init - pthread_mutex_unlock - OK
+Init - pthread_mutex_destroy - OK
-*** END OF POSIX TEST AUTOMATIC INITIALIZATION 02 ***
+Init - pthread_cond_destroy - OK
+*** END OF TEST PSXAUTOINIT 2 ***
diff --git a/testsuites/psxtests/psxcleanup/system.h b/testsuites/psxtests/psxcleanup/system.h
index 04818f8add..2111c9fab5 100644
--- a/testsuites/psxtests/psxcleanup/system.h
+++ b/testsuites/psxtests/psxcleanup/system.h
@@ -45,7 +45,6 @@ void *task_c(
 #define CONFIGURE_MAXIMUM_POSIX_TIMERS              4
 #define CONFIGURE_MAXIMUM_TIMERS                    4
-#define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 2
diff --git a/testsuites/psxtests/psxcond01/init.c b/testsuites/psxtests/psxcond01/init.c
index 395443a3c7..37fd4fdbb4 100644
--- a/testsuites/psxtests/psxcond01/init.c
+++ b/testsuites/psxtests/psxcond01/init.c
@@ -96,7 +96,6 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 2
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index 154b4d1bd6..f62c2d5508 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -60,7 +60,6 @@ const char rtems_test_name[] = "PSXCONFIG 1";
 #define CONFIGURE_MAXIMUM_TIMERS 59
 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 17
-#define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 29
 #define POSIX_MQ_COUNT 5
 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 19
 #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 7
@@ -429,19 +428,6 @@ static rtems_task Init(rtems_task_argument argument)
 #endif
-#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
-  for (i = 0; i < CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES; ++i) {
-    pthread_cond_t cond;
-    eno = pthread_cond_init(&cond, NULL);
-    rtems_test_assert(eno == 0);
-  rtems_resource_snapshot_take(&snapshot);
-    snapshot.posix_api.active_condition_variables
-      == CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
-#endif
 #ifdef POSIX_MQ_COUNT
   for (i = 0; i < POSIX_MQ_COUNT; ++i) {
     int oflag = O_RDWR | O_CREAT | O_EXCL;
diff --git a/testsuites/psxtests/psxkey07/init.c b/testsuites/psxtests/psxkey07/init.c
index ac7e0253d8..3790ea36aa 100644
--- a/testsuites/psxtests/psxkey07/init.c
+++ b/testsuites/psxtests/psxkey07/init.c
@@ -198,7 +198,6 @@ rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_MAXIMUM_TASKS          rtems_resource_unlimited(10)
 #define CONFIGURE_UNIFIED_WORK_AREAS
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/psxtests/psxsignal06/init.c b/testsuites/psxtests/psxsignal06/init.c
index decab51e78..0177a2acea 100644
--- a/testsuites/psxtests/psxsignal06/init.c
+++ b/testsuites/psxtests/psxsignal06/init.c
@@ -126,7 +126,6 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtests/psxtimer01/system.h b/testsuites/psxtests/psxtimer01/system.h
index 57462e7622..3fb71cadae 100644
--- a/testsuites/psxtests/psxtimer01/system.h
+++ b/testsuites/psxtests/psxtimer01/system.h
 #define CONFIGURE_MAXIMUM_POSIX_TIMERS              5
diff --git a/testsuites/psxtmtests/psxtmcond01/init.c b/testsuites/psxtmtests/psxtmcond01/init.c
index 6dd7ab1ce7..7ec876b9a0 100644
--- a/testsuites/psxtmtests/psxtmcond01/init.c
+++ b/testsuites/psxtmtests/psxtmcond01/init.c
@@ -85,7 +85,6 @@ void *POSIX_Init(
 #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
 /* configure an instance of the condition variable created and destroyed */
diff --git a/testsuites/psxtmtests/psxtmcond02/init.c b/testsuites/psxtmtests/psxtmcond02/init.c
index cbbb7992d8..c8cf9c2685 100644
--- a/testsuites/psxtmtests/psxtmcond02/init.c
+++ b/testsuites/psxtmtests/psxtmcond02/init.c
@@ -66,7 +66,6 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmcond03/init.c b/testsuites/psxtmtests/psxtmcond03/init.c
index fdf2dfeee4..782782a23d 100644
--- a/testsuites/psxtmtests/psxtmcond03/init.c
+++ b/testsuites/psxtmtests/psxtmcond03/init.c
@@ -106,7 +106,6 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmcond04/init.c b/testsuites/psxtmtests/psxtmcond04/init.c
index 889cc99b85..9ed2ae61b4 100644
--- a/testsuites/psxtmtests/psxtmcond04/init.c
+++ b/testsuites/psxtmtests/psxtmcond04/init.c
@@ -99,7 +99,6 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmcond05/init.c b/testsuites/psxtmtests/psxtmcond05/init.c
index 81b32d8b14..fcfad14b5f 100644
--- a/testsuites/psxtmtests/psxtmcond05/init.c
+++ b/testsuites/psxtmtests/psxtmcond05/init.c
@@ -65,7 +65,6 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmcond06/init.c b/testsuites/psxtmtests/psxtmcond06/init.c
index 4f86108ce8..630641d31d 100644
--- a/testsuites/psxtmtests/psxtmcond06/init.c
+++ b/testsuites/psxtmtests/psxtmcond06/init.c
@@ -123,7 +123,6 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS  2 + N
diff --git a/testsuites/psxtmtests/psxtmcond07/init.c b/testsuites/psxtmtests/psxtmcond07/init.c
index 275eab3b37..20952e5542 100644
--- a/testsuites/psxtmtests/psxtmcond07/init.c
+++ b/testsuites/psxtmtests/psxtmcond07/init.c
@@ -119,7 +119,6 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmcond08/init.c b/testsuites/psxtmtests/psxtmcond08/init.c
index 2224f230ba..6f11b9e619 100644
--- a/testsuites/psxtmtests/psxtmcond08/init.c
+++ b/testsuites/psxtmtests/psxtmcond08/init.c
@@ -169,9 +169,7 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS     OPERATION_COUNT + 2
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index ab9e4a8e64..902d6abe03 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -36,7 +36,6 @@
 #include <rtems/extensionimpl.h>
 #include <rtems/posix/psignalimpl.h>
@@ -104,8 +103,6 @@ typedef enum {
   POSIX_SIGNALS_POST,
   POSIX_THREADS_PRE,
   POSIX_THREADS_POST,
-  POSIX_CONDITION_VARIABLE_PRE,
-  POSIX_CONDITION_VARIABLE_POST,
   POSIX_MUTEX_PRE,
   POSIX_MUTEX_POST,
   POSIX_MESSAGE_QUEUE_PRE,
@@ -441,18 +438,6 @@ LAST(RTEMS_SYSINIT_POSIX_THREADS)
   next_step(POSIX_THREADS_POST);
-FIRST(RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE)
-  assert(_POSIX_Condition_variables_Information.maximum == 0);
-  next_step(POSIX_CONDITION_VARIABLE_PRE);
-LAST(RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE)
-  assert(_POSIX_Condition_variables_Information.maximum != 0);
-  next_step(POSIX_CONDITION_VARIABLE_POST);
 FIRST(RTEMS_SYSINIT_POSIX_MUTEX)
   assert(_POSIX_Mutex_Information.maximum == 0);
@@ -733,8 +718,6 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 1
 #define CONFIGURE_MAXIMUM_POSIX_SHMS 1
diff --git a/testsuites/sptests/spthreadq01/init.c b/testsuites/sptests/spthreadq01/init.c
index 5416118144..473db6d05a 100644
--- a/testsuites/sptests/spthreadq01/init.c
+++ b/testsuites/sptests/spthreadq01/init.c
@@ -130,8 +130,6 @@ static void posix_worker(test_context *ctx)
   eno = pthread_mutex_lock(&ctx->pmtx);
-  rtems_test_assert(get_wait_id(ctx) == ctx->pcv);
   eno = pthread_cond_signal(&ctx->pcv);
@@ -343,7 +341,6 @@ static rtems_task Init(
 #if defined(RTEMS_POSIX_API)
-  #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 1
   #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 1
   #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
     (2 * CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(1, 1))
2.12.3
