Warnings in BSPs on Master
Fri Sep 29 05:22:52 UTC 2017
On 28/09/17 21:01, Joel Sherrill wrote:
> On Wed, Sep 27, 2017 at 11:59 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 28/09/17 01:02, Joel Sherrill wrote:
>         The warning situation hasn't improved recently.
>     We have now a 64-bit PowerPC BSP. This introduced new warnings.
>     Some warnings are compiler bugs.
> If you can point me at any specific ones that are compiler bugs, I will
> filter them out of the report. I remember at least one that is already
> filtered out.
Compiler bugs are probably:
cpukit/libblock/src/bdbuf.c:512:15: warning: 'q' may be used
uninitialized in this function [-Wmaybe-uninitialized]
cpukit/libfs/src/dosfs/msdos_conv.c:458:48: warning: 'c' may be used
cpukit/libfs/src/dosfs/msdos_misc.c:1912:16: warning:
'name_len_for_save' may be used uninitialized in this function
> Those caused by the 64-bit PowerPC will just have to be worked on. But
> false positives need to be added to the ignore list in the script
https://devel.rtems.org/ticket/3155
https://devel.rtems.org/ticket/3156
Both tickets are not relevant for the 4.12 release.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
