[PATCH] posix: Ignore pshared for semaphores
Joel Sherrill
joel at rtems.org
Fri Sep 8 15:43:09 UTC 2017
I have no idea how that is much clearer except that pthreads have defined
macros for scope and thus an invalid value is an error.
But POSIX isn't good at addressing error cases which existed based on the
profiles defined in PSE52-54. And those were not updated for POSIX 2008 or
2013
On Sep 8, 2017 10:16 AM, "Sebastian Huber" <
> ----- Joel Sherrill <joel at rtems.org> schrieb:
> > On Fri, Sep 8, 2017 at 8:33 AM, Sebastian Huber <
> > > Since we have only one process, sharing between processes is trivial.
> > > Close #3124.
> > > cpukit/posix/include/rtems/posix/semaphore.h | 1 -
> > > cpukit/posix/include/rtems/posix/semaphoreimpl.h | 1 -
> > > cpukit/posix/src/semaphorecreatesupp.c | 7 -------
> > > cpukit/posix/src/seminit.c | 1 -
> > > cpukit/posix/src/semopen.c | 1 -
> > > testsuites/psxtests/psxsem01/init.c | 14 +++++++++-----
> > > 6 files changed, 9 insertions(+), 16 deletions(-)
> > > diff --git a/cpukit/posix/include/rtems/posix/semaphore.h
> > > b/cpukit/posix/include/rtems/posix/semaphore.h
> > > index 45de4a93b9..6598397052 100644
> > > --- a/cpukit/posix/include/rtems/posix/semaphore.h
> > > +++ b/cpukit/posix/include/rtems/posix/semaphore.h
> > > @@ -43,7 +43,6 @@ extern "C" {
> > > typedef struct {
> > > Objects_Control Object;
> > > CORE_semaphore_Control Semaphore;
> > > - int process_shared;
> > > bool named;
> > > bool linked;
> > > uint32_t open_count;
> > > diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> > > b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> > > index 2bafbe9b97..43440298ec 100644
> > > --- a/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> > > +++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
> > > @@ -78,7 +78,6 @@ RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control
> > > *_POSIX_Semaphore_Get(
> > > int _POSIX_Semaphore_Create_support(
> > > const char *name,
> > > size_t name_len,
> > > - int pshared,
> > > unsigned int value,
> > > POSIX_Semaphore_Control **the_sem
> > > diff --git a/cpukit/posix/src/semaphorecreatesupp.c
> b/cpukit/posix/src/
> > > index d66e1942c9..4a33336230 100644
> > > --- a/cpukit/posix/src/semaphorecreatesupp.c
> > > +++ b/cpukit/posix/src/semaphorecreatesupp.c
> > > @@ -42,7 +42,6 @@
> > > const char *name_arg,
> > > size_t name_len,
> > > - int pshared,
> > > unsigned int value,
> > > @@ -50,10 +49,6 @@ int _POSIX_Semaphore_Create_support(
> > > POSIX_Semaphore_Control *the_semaphore;
> > > char *name;
> > > - /* Sharing semaphores among processes is not currently supported */
> > > - if (pshared != 0)
> > > - rtems_set_errno_and_return_minus_one( ENOSYS );
> > Why are you deleting this error check? I can see not storing the value or
> > passing
> > it to create support. But I think it still should be validated. We only
> > support
> > requests for process private. Anything else is an error.
> Why is this an error? With only one process its easy to support sharing
> between processes. The text in the semaphore documentation is a bit vague.
> This description is a bit more clear:
> http://pubs.opengroup.org/onlinepubs/9699919799/
> functions/pthread_mutexattr_getpshared.html
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170908/de891c49/attachment-0002.html>
