[PATCH 07/18] libio: Remove rtems_libio_check_permissions()
Sebastian Huber
Wed Sep 13 13:39:40 UTC 2017
Remove rtems_libio_check_permissions() and convert single user to
rtems_libio_check_permissions_with_error().
Update #3132.
cpukit/libcsupport/include/rtems/libio_.h | 10 ----------
cpukit/libcsupport/src/ftruncate.c | 2 +-
2 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
index 9bd8a8979c..0a80c917b7 100644
--- a/cpukit/libcsupport/include/rtems/libio_.h
+++ b/cpukit/libcsupport/include/rtems/libio_.h
@@ -185,16 +185,6 @@ static inline rtems_libio_t *rtems_libio_iop( int fd )
} while (0)
- * rtems_libio_check_permissions
- * Macro to check if a file descriptor is open for this operation.
- * On failure, return EINVAL
-#define rtems_libio_check_permissions(_iop, _flag) \
- rtems_libio_check_permissions_with_error(_iop, _flag, EINVAL )
* @brief Clones a node.
diff --git a/cpukit/libcsupport/src/ftruncate.c b/cpukit/libcsupport/src/ftruncate.c
index 3f4e93307d..4a194066e5 100644
--- a/cpukit/libcsupport/src/ftruncate.c
+++ b/cpukit/libcsupport/src/ftruncate.c
@@ -32,7 +32,7 @@ int ftruncate( int fd, off_t length )
rtems_libio_check_fd( fd );
iop = rtems_libio_iop( fd );
rtems_libio_check_is_open( iop );
- rtems_libio_check_permissions( iop, LIBIO_FLAGS_WRITE );
+ rtems_libio_check_permissions_with_error( iop, LIBIO_FLAGS_WRITE, EINVAL );
rv = (*iop->pathinfo.handlers->ftruncate_h)( iop, length );
} else {
2.12.3
