Self-contained POSIX synchronization objects for RTEMS 4.12?
Joel Sherrill
joel at rtems.org
Tue Sep 19 14:09:12 UTC 2017
On Tue, Sep 19, 2017 at 8:16 AM, Sebastian Huber <
> Hello,
> we have to make some trade-offs in the implementation with respect to the
> error checking. The operations get a pointer to the synchronization object,
> e.g.
> int sem_post(sem_t *sem);
> int pthread_mutex_lock(pthread_mutex_t *mutex);
> Do we want to check for NULL pointers?
Is newlib consistently using the non-NULL declaration on the argument?
Newlib/Cygwin folks have been pretty insistent that they do not want to
check for NULL on the shared methods.
Personally I hate to delete NULL argument pointer checks. Would a
long-term compromise be to move them to argument checking macros
that are enabled with --enable-rtems-debug?
> Do we want to check for other obviously invalid pointer values, e.g.
> SEM_FAILED?
IMO Yes
> Do we want to check if the object has been initialized?
Yes. We want to have predictable behavior.
> glibc uses no checks at all.
Performance over correctness? That doesn't seem like a good trade.
> FreeBSD checks that the object has been initialized. For this purpose it
> embeds a magic value field in the object structure. The drawback is that if
> we also do this, the objects are not zero-initialized and thus cannot
> reside in the BSS section.
This is an impossible trade. Some systems have big Flash and small RAM.
Others are the opposite.
I would rather follow the FreeBSD model and know the object is initialized.
> Destruction of synchronization objects in use is undefined behaviour
> according to POSIX. Do we want to flush waiting threads during destruction?
> This is a complex operation.
We have over 20 years of defined behavior in this case. I think
we flush and return the same error we always did. Otherwise,
we get a deadlock.
> What you think?
> Address : Dornierstr. 4
> <https://maps.google.com/?q=Dornierstr.+4&entry=gmail&source=g>, D-82178
> Puchheim, Germany
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170919/1caa715b/attachment-0002.html>
