Improve coverage analysis toolset
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Apr 2 15:22:10 UTC 2018
Hello ,
I'm currently going through the coverage code , Can you please help me
understand what are the specific changes that are needed for the coverage
to be running again?
thanks
-- vijay
On 26 March 2018 at 09:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> 1. Yes , I plan to work on identifying the discrepancies between what
> covoar reports directly and what the gcov reports based on its gcov output.
> 2. I understand this point that the scripting that generates symbol set
> file, needs to be modified accordingly
> 3. I have planned to make a note and understand the requirements, changes
> needed and the desired type of output during the community bonding period,
> so that I have a clear picture of the objective before I start working on
> it.
> The plan is to work on gcov after the existing work is merged.
> Have I planned too much to work on during the summer? Should I modify my
> plan in some way? Please suggest .
> Thanks
> -- vijay
> On 26 March 2018 at 03:49, Joel Sherrill <joel at rtems.org> wrote:
>> Just a couple of questions and planning issues. The planning issues
>> are because the requirements for some of the work are likely not solid
>> on our side.
>> 1. Do you plan to work on identifying the discrepancies between
>> what covoar reports directly and what gcov reports based on its
>> gcov file output? I ask because I lined up someone from the GCC
>> community who should be able to tell us what is not right once
>> we have specific cases.
>> 2. My recollection is that the symbol set file is generated from
>> the RTEMS libraries under test. The scripting that generates this
>> file will have to change also. The set of symbols changes as
>> RTEMS evolves.
>> 3. Chris has had ideas on changing the output from directly
>> producing ascii and html to something else. It is on he and I
>> to give you input on the actual format.
>> Personally getting all existing work merged and it in a state
>> where we can produce coverage reports again is really a
>> critical thing. The previous work changed it from being
>> a standalone shell script that drove things to part of the RSB
>> and make it possible to have the reports based on subdirectories
>> rather than one large report.
>> I don't 'think this changes your plan except that the plan seems to
>> put gcov as bonus work. It isn't discussed as work during the
>> summer.It would be nice to get gcov correctness done earlier
>> because that might be the best way to nice reports. For
>> example, running lcov on the .gcov files produced by covoar
>> might be an option.
>> --joel
>> On Sun, Mar 25, 2018 at 3:16 PM, Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> submitted !
>>> If you find time , please give final review as well.
>>> Thanks
>>> On 26 Mar 2018 1:44 a.m., "Joel Sherrill" <joel at rtems.org> wrote:
>>>> I am out and not at a computer. Someone can double check me but I
>>>> believe you can replace the PDF you upload.
>>>> Unless someone answers soon, just upload it.
>>>> --joel
>>>> On Mar 25, 2018 2:37 PM, "Vijay Kumar Banerjee" <
>>>>> It's the last day before the deadline!
>>>>> Please provide a final review of the proposal before submitting.
>>>>> Thanks
>>>>> -- vijay
>>>>> On 24 March 2018 at 21:37, Vijay Kumar Banerjee <
>>>>>> hello mentors and other developers of the community , there are only
>>>>>> three days remaining to the GSoC proposal submission deadline.
>>>>>> I request the mentors and everyone in the community who has
>>>>>> experience in RTEMS, to please go through my proposal for Coverage Analysis
>>>>>> tool improvement project , if they have time , and suggest any kind of
>>>>>> improvements and changes .
>>>>>> here is the link to the proposal
>>>>>> https://docs.google.com/document/d/1UjCWE1ojrpDQLQ2fQqxHU0SC
>>>>>> rLETlerxD6t0SOcQNLQ/edit?usp=sharing
>>>>>> Thank you
>>>>>> -- vijay
>>>>>> On 22 March 2018 at 04:30, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> Glad you have tests running. Hopefully as Cillian suggested, you can
>>>>>>> fix the
>>>>>>> remaining issues to see coverage.
>>>>>>> We certainly need to get this merged if Chris is OK with it and it
>>>>>>> doesn't
>>>>>>> break anything else.
>>>>>>> I am reviewing proposals now. Seems to be a queue. :)
>>>>>>> --joel
>>>>>>> On Wed, Mar 21, 2018 at 4:42 AM, Vijay Kumar Banerjee <
>>>>>>>> Sir ,
>>>>>>>> I have done the changes in the proposal , based on the comments in
>>>>>>>> the google doc , please review it and suggest any further changes if
>>>>>>>> required
>>>>>>>> Thank you ,
>>>>>>>> -- vijay
>>>>>>>> P.S : the previous version is in parentheses , I will remove them
>>>>>>>> after you review the changes .
>>>>>>>> On 18 March 2018 at 16:05, Vijay Kumar Banerjee <
>>>>>>>>> Thanks Cillian :)
>>>>>>>>> It's great to see it running , I'll do some background reading
>>>>>>>>> about RSB, and RTEMS-Tools along with the covoar code . And also work on my
>>>>>>>>> python skills.
>>>>>>>>> to try rtems-test on a bsp that runs gdb , I tried it on erc32 and
>>>>>>>>> that also worked.
>>>>>>>>> I'm also waiting for Joel and other mentors' review on my draft
>>>>>>>>> proposal, so that I can also work on it and make any changes if needed.
>>>>>>>>> Thanks .
>>>>>>>>> -- vijay
>>>>>>>>> On 18 March 2018 at 14:17, Cillian O'Donnell <
>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>> On 18 March 2018 at 06:47, Vijay Kumar Banerjee <
>>>>>>>>>>> It worked !
>>>>>>>>>> That's great! That's the good news then. I was using an old
>>>>>>>>>> leon3 build and maybe some older Qemu too and I think that's why I didn't
>>>>>>>>>> see any issues initially. I was hoping you could see the coverage running
>>>>>>>>>> and the reports generated from that but it looks like the full update to
>>>>>>>>>> the current master will be necessary to have a look. So until the parsing
>>>>>>>>>> for the INI files is added to the coverage.py we won't see the coverage
>>>>>>>>>> running. Unfortunately, I'm in the middle of exams until the following
>>>>>>>>>> Monday so I won't be able to sink any more time into it until then. You can
>>>>>>>>>> still figure out the RSB problem you're having and do some background
>>>>>>>>>> reading, brush up on your Python skills, have a read of the covoar code
>>>>>>>>>> https://github.com/RTEMS/rtems-tools/blob/master/tester/covo
>>>>>>>>>> ar/covoar.cc
>>>>>>>>>> just skim through, read the comments, get a sense of the what
>>>>>>>>>> it's doing and in what order.
>>>>>>>>>>> It's great to see it running ! I have attached the result .
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 18 March 2018 at 02:31, Cillian O'Donnell <
>>>>>>>>>>>> On 17 March 2018 at 20:08, Vijay Kumar Banerjee <
>>>>>>>>>>>>> yes it prints hello world
>>>>>>>>>>>> Alright I've added an .ini for leon3-qemu to the current
>>>>>>>>>>>> rtems-tools. Pull this branch
>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>>>> and try
>>>>>>>>>>>> $HOME/development/rtems/test/rtems-tools/tester/rtems-test
>>>>>>>>>>>> --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>> --log=coverage-analysis.log --rtems-bsp=leon3_qemu
>>>>>>>>>>>> $HOME/development/rtems/leon3/sparc-rtems5/c/leon3/testsuite
>>>>>>>>>>>> s/samples
>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>> On 18 March 2018 at 01:31, Cillian O'Donnell <
>>>>>>>>>>>>>> If you run just one test by itself without rtems-test
>>>>>>>>>>>>>> qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>>>>>>>>>> -nographic -M leon3_generic -kernel $HOME/development/rtems/leon3/
>>>>>>>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>>>>>>>>>>>>> Does the hello world print out?
>>>>>>>>>>>>>> On 17 March 2018 at 14:46, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>> I built it manually
>>>>>>>>>>>>>>> the environment variable PATH looks like this
>>>>>>>>>>>>>>> /home/lunatic/qemu/install/bin:/home/lunatic/development/rte
>>>>>>>>>>>>>>> ms/5/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/
>>>>>>>>>>>>>>> home/lunatic/.local/bin:/home/lunatic/bin
>>>>>>>>>>>>>>> I tried to run rtems-test again without --coverage , it
>>>>>>>>>>>>>>> gives the same result
>>>>>>>>>>>>>>> I have attached the log.
>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>> On 17 March 2018 at 00:55, Cillian O'Donnell <
>>>>>>>>>>>>>>>> Yes this is something more than my build, I'll need someone
>>>>>>>>>>>>>>>> a bit more expert in the RSB to step in there. In the meantime, lets just
>>>>>>>>>>>>>>>> build couverture-qemu manually so we can see is everything else working.
>>>>>>>>>>>>>>>> git clone https://github.com/AdaCore/qemu
>>>>>>>>>>>>>>>> cd qemu
>>>>>>>>>>>>>>>> ./configure --target-list=sparc-softmmu
>>>>>>>>>>>>>>>> --prefix=$HOME/qemu/install --disable-docs --disable-virtfs --disable-werror
>>>>>>>>>>>>>>>> make
>>>>>>>>>>>>>>>> make install
>>>>>>>>>>>>>>>> then add the prefix to $PATH in .bashrc as well like before.
>>>>>>>>>>>>>>>> export PATH=$HOME/qemu/install/bin:$PATH
>>>>>>>>>>>>>>>> Then run rtem-test and see what happens
>>>>>>>>>>>>>>>> On 16 March 2018 at 19:13, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>> the same error comes when I try to build qemu from the
>>>>>>>>>>>>>>>>> RTEMS/rtems-source-builder as well
>>>>>>>>>>>>>>>>> is the issue coming from my system ? I'm using fedora 27
>>>>>>>>>>>>>>>>> 64bit
>>>>>>>>>>>>>>>>> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
>>>>>>>>>>>>>>>>>> yes , the same thing happens
>>>>>>>>>>>>>>>>>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <
>>>>>>>>>>>>>>>>>>> If you build regular qemu with the RSB, does the same
>>>>>>>>>>>>>>>>>>> thing happen?
>>>>>>>>>>>>>>>>>>> Try
>>>>>>>>>>>>>>>>>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>>>>>>>>>>>>>>>>>> --prefix=$HOME/development/5 devel/qemu
>>>>>>>>>>>>>>>>>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>> still the same error
>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>> Just checked and the build was failing because one of
>>>>>>>>>>>>>>>>>>>>> the patches needed its hash to be updated to sha256. Just pushed that
>>>>>>>>>>>>>>>>>>>>> change. The build finishes successfully on my end. Pull that change into
>>>>>>>>>>>>>>>>>>>>> couverture-build branch and try it again. I'm not seeing any automake stuff
>>>>>>>>>>>>>>>>>>>>> here, so just check that and let me know.
>>>>>>>>>>>>>>>>>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>>>>>>>>>>>>>>>>>> onnell/rtems-source-builder/tree/couverture-build )
>>>>>>>>>>>>>>>>>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1
>>>>>>>>>>>>>>>>>>>>>> I have attached the error report .
>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>>> It runs with a bunch of errors . I have attached
>>>>>>>>>>>>>>>>>>>>>>>> the log file
>>>>>>>>>>>>>>>>>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu
>>>>>>>>>>>>>>>>>>>>>>> (special version of qemu designed for generating extra trace data for
>>>>>>>>>>>>>>>>>>>>>>> coverage analysis). That's what those errors are about. I have an RSB build
>>>>>>>>>>>>>>>>>>>>>>> for that.
>>>>>>>>>>>>>>>>>>>>>>> and the instructions for building it are
>>>>>>>>>>>>>>>>>>>>>>> https://devel.rtems.org/wiki/G
>>>>>>>>>>>>>>>>>>>>>>> SoC/2017/coveragetools#Buildin
>>>>>>>>>>>>>>>>>>>>>>> gCouverture-QemuwiththeRSB
>>>>>>>>>>>>>>>>>>>>>>> I know what the other problem is too. I have a
>>>>>>>>>>>>>>>>>>>>>>> specific environment variable defined for the path, sorry I can't even
>>>>>>>>>>>>>>>>>>>>>>> remember putting it there, I thought that was automatically generated
>>>>>>>>>>>>>>>>>>>>>>> (probably should be, another thing to add to the list :)... ). So wherever
>>>>>>>>>>>>>>>>>>>>>>> you stuck the export path for where the rsb built the tools, in .bashrc or
>>>>>>>>>>>>>>>>>>>>>>> whatever you're using. Also put something like:
>>>>>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>>>> /bin:$PATH
>>>>>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/t
>>>>>>>>>>>>>>>>>>>>>>> est/rtems-tools/build/tester/covoar:$PATH
>>>>>>>>>>>>>>>>>>>>>>> or you could just copy covoar into the /bin
>>>>>>>>>>>>>>>>>>>>>>> directory with all the other rsb tools gcc and all that, it'll find it
>>>>>>>>>>>>>>>>>>>>>>> either way.
>>>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>>>> Looks good. If you run the samples without
>>>>>>>>>>>>>>>>>>>>>>>>> coverage is everything ok?
>>>>>>>>>>>>>>>>>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>>>>>>>>>>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>>>>>>>>> Do the tests run?
>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>>>>> I have attached the output of the ls of that
>>>>>>>>>>>>>>>>>>>>>>>>>> directory
>>>>>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee
>>>>>>>>>>>>>>>>>>>>>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> hello ,
>>>>>>>>>>>>>>>>>>>>>>>>>>>> as told by Joel , I started this thread to
>>>>>>>>>>>>>>>>>>>>>>>>>>>> further discuss the coverage analysis toolset .
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Current status is , I'm trying to builld and
>>>>>>>>>>>>>>>>>>>>>>>>>>>> run rtems-test from the coverage-merge branch of the previous GSoC student
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cillian .
>>>>>>>>>>>>>>>>>>>>>>>>>>>> nell/rtems-tools/tree/coverage-merge
>>>>>>>>>>>>>>>>>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>>>>>>>>>>>>>>>>> "Covoar not found !"
>>>>>>>>>>>>>>>>>>>>>>>>>>> It's supposed to find it in
>>>>>>>>>>>>>>>>>>>>>>>>>>> rtems-tools/build/tester/covoar/ If it's in
>>>>>>>>>>>>>>>>>>>>>>>>>>> there it should be fine. Can you show me the contents of that directory?
>>>>>>>>>>>>>>>>>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>>>>>>>>>>>>>>>>>> $ ls
>>>>>>>>>>>>>>>>>>>>>>>>>>>> the Covoar appeared in
>>>>>>>>>>>>>>>>>>>>>>>>>>>> rtems-tools/tester/covoar .
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180402/0c05f247/attachment-0001.html>
