error while running rtems-test with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Apr 3 20:36:19 UTC 2018
after pulling the ini-update branch from
https://github.com/cillianodonnell/rtems-tools/tree/ini-update
I tried running the rtems-test with the following command
$HOME/development/rtems/rtems-tools/tester/rtems-test
--rtems-tools=$HOME/development/rtems/5 --log=coverage_analysis.log
--rtems-bsp=leon3_qemu
--rtems-builddir=$HOME/development/rtems/kernel/leon3
sparc-rtems5/c/leon3/testsuites/samples
was getting the KeyError for 'coverage'
current status :
the same command gives the error :
"mandatory item not found in bsp section : bsp,"
to make sure I didn't break something , I also tried running from a freshly
downloaded directory as well, it gives the same error.
-- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180404/04ccd72b/attachment.html>
