[PATCH 4/6] bsps: Move version.c and use bspopts.h
Wed Apr 4 08:03:20 UTC 2018
On 04/04/18 09:55, Chris Johns wrote:
>> I think we need only three Makefile.am and two configure.ac:
>> configure.ac
>> Makefile.am (builds also cpukit, uses AM_CONDITIONAL for cpukit/score/cpu/*)
>> testsuites/Makefile.am (uses AM_CONDITIONAL for each test)
> 500+ tests in the one file? Really? I hope not.
Is this better or worse than 794 Makefile.am in testsuites?
> You cannot have more than one test in a Makefile.am currently. See $(make-exe)
> and LINK_OBJS and LINK_LIBS.
Yes, but if we remove the post link step, then we can probably use the
standard Automake program stuff. If not, then I will not touch the
testsuites build at all and leave it as is.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
