[PATCH v2] testsuite: Merge all fstests into a single Makefile.am.
Thu Apr 5 05:25:02 UTC 2018
The patch looks good. I just have some general questions.
On 05/04/18 05:20, Chris Johns wrote:
> This change is part of refactoring the testsuite's build system to
> remove nested make builds for every test.
> Update #3382
> diff --git a/c/src/make/leaf.cfg b/c/src/make/leaf.cfg
> index 8d3f52ecde..045ee1ab0e 100644
> --- a/c/src/make/leaf.cfg
> +++ b/c/src/make/leaf.cfg
Why do we need this leaf.cfg at all for the internal build system? Can't
we use the default Automake link rules if we are satisfied with an ELF file?
> +if TEST_fsdosfsname02
> +fs_tests += fsdosfsname02
> +fs_screens += fsdosfsname02/fsdosfsname02.scn
> +fs_docs += fsdosfsname02/fsdosfsname02.doc
> +fsdosfsname02_SOURCES = fsdosfsname02/init.c
> +fsdosfsname02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_fsdosfsname02) $(fs_support_includes)
> +endif
Do we really have install all the *.doc and *.scn files? Do we have to
install the test programs?
I usually build a BSP with tests and run them. Afterwards I build the
BSP again without tests and install it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
