[PATCH v2] testsuite: Merge all fstests into a single Makefile.am.
Thu Apr 5 05:39:28 UTC 2018
On 05/04/2018 15:25, Sebastian Huber wrote:
> The patch looks good.
Thanks, and it works with 1.16.1 as well as the automake version we are using.
> I just have some general questions.
> On 05/04/18 05:20, Chris Johns wrote:
>> This change is part of refactoring the testsuite's build system to
>> remove nested make builds for every test.
>> Update #3382
>> diff --git a/c/src/make/leaf.cfg b/c/src/make/leaf.cfg
>> index 8d3f52ecde..045ee1ab0e 100644
>> --- a/c/src/make/leaf.cfg
>> +++ b/c/src/make/leaf.cfg
> Why do we need this leaf.cfg at all for the internal build system? Can't we use
> the default Automake link rules if we are satisfied with an ELF file?
Because it was there? I have not chased down these areas. Small steps and then
removal etc.
>> +if TEST_fsdosfsname02
>> +fs_tests += fsdosfsname02
>> +fs_screens += fsdosfsname02/fsdosfsname02.scn
>> +fs_docs += fsdosfsname02/fsdosfsname02.doc
>> +fsdosfsname02_SOURCES = fsdosfsname02/init.c
>> +fsdosfsname02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_fsdosfsname02)
>> $(fs_support_includes)
>> +endif
> Do we really have install all the *.doc and *.scn files? Do we have to install
> the test programs?
Just providing what was there. If the consensus is not installing these files
the support can be removed, it is not hard to update.
> I usually build a BSP with tests and run them. Afterwards I build the BSP again
> without tests and install it.
I can see a possible work flow for configuration management of a BSP having
tests installed for a "golden" RTEMS. A hardware revision could run those tests
and the results checked against our published and expected results.
