ARM build failing
Mon Apr 9 05:20:17 UTC 2018
On 09/04/2018 15:05, Sebastian Huber wrote:
> On 09/04/18 01:06, Chris Johns wrote:
>> I am testing testsuite Makefile.am changes and the following configure:
>> /opt/work/chris/rtems/kernel/rtems.git/configure --prefix=/opt/work/rtems/bsps/5
>> --target=arm-rtems5 --enable-posix --enable-networking --enable-smp
>> --enable-tests --enable-maintainer-mode
>> fails with:
>> gmake[5]: Entering directory
>> '/opt/work/chris/rtems/kernel/bsps/arm/arm-rtems5/c/atsamv/cpukit/score'
> The --enable-smp doesn't work with this BSP.
Seems a brutal way to let a user know?
Considering this is a little it means --enable-smp and --enable-multiprocessing
is broken when the BSP wildcard is used. Should we require a BSP or list of BSPs
be provided to configure? It would avoid this issue?
