ARM build failing
Mon Apr 9 05:29:59 UTC 2018
On 09/04/18 07:20, Chris Johns wrote:
> On 09/04/2018 15:05, Sebastian Huber wrote:
>> On 09/04/18 01:06, Chris Johns wrote:
>>> I am testing testsuite Makefile.am changes and the following configure:
>>> /opt/work/chris/rtems/kernel/rtems.git/configure --prefix=/opt/work/rtems/bsps/5
>>> --target=arm-rtems5 --enable-posix --enable-networking --enable-smp
>>> --enable-tests --enable-maintainer-mode
>>> fails with:
>>> gmake[5]: Entering directory
>>> '/opt/work/chris/rtems/kernel/bsps/arm/arm-rtems5/c/atsamv/cpukit/score'
>> The --enable-smp doesn't work with this BSP.
> Seems a brutal way to let a user know?
> Considering this is a little it means --enable-smp and --enable-multiprocessing
> is broken when the BSP wildcard is used. Should we require a BSP or list of BSPs
> be provided to configure? It would avoid this issue?
I think for the --enable-multiprocessing we already have something like
this:
c/src/aclocal/check-multiprocessing.m4
I am not sure if we should omit BSPs which cannot cope with a --enable-*
option. If you want to build all BSPs you want to build all BSPs?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
