ARM build failing
Mon Apr 9 05:41:46 UTC 2018
On 09/04/18 07:38, Chris Johns wrote:
>> I am not sure if we should omit BSPs which cannot cope with a --enable-* option.
>> If you want to build all BSPs you want to build all BSPs?
> I think it would too hard at this point in time to probe and create a list of
> those BSPs that support the options. I am thinking if you use --enable-smp or
> --enable-multiprocessing you must provide a list of BSPs so the wildcard or all
> default cannot be used. If a user supplies a BSP that is not support that is a
> different issue and the need to handle that better for SMP would be nice.
Yes, this sounds good.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
