[PATCH v2 4/6] waf: Remove module without sources.
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Apr 9 13:53:29 UTC 2018
There are no imported sources for a number of modules. Some of them
doesn't even have the right paths for freebsd-org anymore. Therefore
this patch removes the following modules:
- dev_usb_add_on
- dev_usb_bluetooth
- dev_usb_controller_add_on
- dev_usb_misc
- dev_usb_storage_add_on
- dev_usb_template
- dev_nic_cs
Update #3351
 libbsd.py | 194 --------------------------------------------------------------
 1 file changed, 194 deletions(-)
diff --git a/libbsd.py b/libbsd.py
index ca3a2fb1..e3c0a3ac 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -833,53 +833,6 @@ class dev_usb(builder.Module):
-# USB Add Ons
-class dev_usb_add_on(builder.Module):
-    def __init__(self, manager):
-        super(dev_usb_add_on, self).__init__(manager, type(self).__name__, enabled = False)
-    def generate(self):
-        mm = self.manager
-        self.addKernelSpaceHeaderFiles(
-                'sys/dev/usb/usb_pci.h',
-                'sys/dev/usb/usb_compat_linux.h',
-        self.addKernelSpaceSourceFiles(
-                'sys/dev/usb/usb_compat_linux.c',
-            mm.generator['source']()
-# USB Bluetooth
-class dev_usb_bluetooth(builder.Module):
-        super(dev_usb_bluetooth, self).__init__(manager, type(self).__name__, enabled = False)
-        mm = self.manager
-        self.addDependency(mm['dev_usb'])
-                'sys/dev/usb/bluetooth/ng_ubt_var.h'
-                'sys/dev/usb/bluetooth/ng_ubt.c',
-                'sys/dev/usb/bluetooth/ubtbcmfw.c',
 # USB Controller.
 class dev_usb_controller(builder.Module):
@@ -919,45 +872,6 @@ class dev_usb_controller(builder.Module):
-# USB Controller Add Ons
-class dev_usb_controller_add_on(builder.Module):
-        super(dev_usb_controller_add_on, self).__init__(manager, type(self).__name__, enabled = False)
-        mm = self.manager
-                'sys/dev/usb/controller/at91dci.h',
-                'sys/dev/usb/controller/atmegadci.h',
-                'sys/dev/usb/controller/musb_otg.h',
-                'sys/dev/usb/controller/uss820dci.h',
-                'sys/dev/usb/controller/at91dci_atmelarm.c',
-                'sys/dev/usb/controller/at91dci.c',
-                'sys/dev/usb/controller/atmegadci_atmelarm.c',
-                'sys/dev/usb/controller/atmegadci.c',
-                'sys/dev/usb/controller/ehci_ixp4xx.c',
-                'sys/dev/usb/controller/ehci_pci.c',
-                'sys/dev/usb/controller/musb_otg.c',
-                'sys/dev/usb/controller/ehci_mbus.c',
-                'sys/dev/usb/controller/musb_otg_atmelarm.c',
-                'sys/dev/usb/controller/ohci_atmelarm.c',
-                'sys/dev/usb/controller/ohci_pci.c',
-                'sys/dev/usb/controller/uhci_pci.c',
-                'sys/dev/usb/controller/uss820dci_atmelarm.c',
-                'sys/dev/usb/controller/uss820dci.c',
 # USB Input
 class dev_usb_input(builder.Module):
@@ -986,30 +900,6 @@ class dev_usb_input(builder.Module):
-# USB Misc.
-class dev_usb_misc(builder.Module):
-        super(dev_usb_misc, self).__init__(manager, type(self).__name__, enabled = False)
-        mm = self.manager
-                'sys/dev/usb/misc/udbp.h',
-                'sys/dev/usb/misc/udbp.c',
-                'sys/dev/usb/misc/ufm.c',
 # USB Networking
 class dev_usb_net(builder.Module):
@@ -1146,30 +1036,6 @@ class dev_usb_storage(builder.Module):
-# USB Storage Add Ons
-class dev_usb_storage_add_on(builder.Module):
-        super(dev_usb_storage_add_on, self).__init__(manager, type(self).__name__, enabled = False)
-        mm = self.manager
-                'sys/dev/usb/storage/rio500_usb.h',
-                'sys/dev/usb/storage/urio.c',
-                'sys/dev/usb/storage/ustorage_fs.c',
 # BBB USB
 class dev_usb_controller_bbb(builder.Module):
@@ -1207,32 +1073,6 @@ class dev_usb_controller_bbb(builder.Module):
-# USB Template
-class dev_usb_template(builder.Module):
-        super(dev_usb_template, self).__init__(manager, type(self).__name__, enabled = False)
-        mm = self.manager
-                'sys/dev/usb/template/usb_template.h',
-                'sys/dev/usb/template/usb_template.c',
-                'sys/dev/usb/template/usb_template_cdce.c',
-                'sys/dev/usb/template/usb_template_msc.c',
-                'sys/dev/usb/template/usb_template_mtp.c',
 # USB WLAN
 class dev_usb_wlan(builder.Module):
@@ -1780,31 +1620,6 @@ class dev_nic_smc(builder.Module):
-# Crystal Semiconductor CS8900
-class dev_nic_cs(builder.Module):
-        super(dev_nic_cs, self).__init__(manager, type(self).__name__, enabled = False)
-        mm = self.manager
-                'sys/dev/cs/if_csreg.h',
-                'sys/dev/cs/if_csvar.h',
-                'sys/dev/cs/if_cs.c',
-                'sys/dev/cs/if_cs_isa.c',
-                'sys/dev/cs/if_cs_pccard.c',
 # Broadcomm BCE, BFE, BGE - MII is intertwined
 class dev_nic_broadcomm(builder.Module):
@@ -4983,13 +4798,9 @@ def load(mm):
     mm.addModule(evdev(mm))
     mm.addModule(dev_usb(mm))
-    mm.addModule(dev_usb_add_on(mm))
     mm.addModule(dev_usb_controller(mm))
-    mm.addModule(dev_usb_controller_add_on(mm))
     mm.addModule(dev_usb_quirk(mm))
-    mm.addModule(dev_usb_misc(mm))
-    mm.addModule(dev_usb_bluetooth(mm))
     mm.addModule(dev_usb_input(mm))
     mm.addModule(dev_usb_serial(mm))
     mm.addModule(dev_usb_net(mm))
@@ -4998,11 +4809,8 @@ def load(mm):
     mm.addModule(cam(mm))
     mm.addModule(dev_usb_storage(mm))
-    mm.addModule(dev_usb_storage_add_on(mm))
     mm.addModule(dev_usb_controller_bbb(mm))
-    mm.addModule(dev_usb_template(mm))
     mm.addModule(net(mm))
     mm.addModule(netinet(mm))
     mm.addModule(netinet6(mm))
@@ -5026,8 +4834,6 @@ def load(mm):
     mm.addModule(dev_nic_dc(mm))
     mm.addModule(dev_nic_smc(mm))
     mm.addModule(dev_nic_broadcomm(mm))
-    # TBD Requires ISA and PCCard Support to be pulled in.
-    mm.addModule(dev_nic_cs(mm))
     # Add in_chksum
     mm.addModule(in_cksum(mm))
2.13.6
