error while running rtems-test with coverage
Aditya Upadhyay aadit0402 at gmail.com
Tue Apr 10 19:25:12 UTC 2018
You can use this command to send a patch to devel:
git send-email LOCATION_OF_PATCH_FILE --to devel at rtems.org --cc=_EMAIL_ID
It makes easier to review the patch.
On Tue, Apr 10, 2018 at 6:10 PM, Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> I managed to get the tests running with the following two patches .
> Please review them .
> -- vijay
> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
>> wrote:
>>> I tried to solve the empty get in the way shown in the patch , but it
>>> doesn't seems to work, I'm getting the following error now
>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>> Traceback (most recent call last):
>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
>>> line 40, in <module>
>>>     rt.test.run()
>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
>>> line 303, in run
>>>     bsp = config.load(bsp[1], opts)
>>>   File "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py",
>>> line 461, in load
>>>     return opts.defaults['bsp']
>>>   File
>>> "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py", line
>>> 190, in __getitem__
>>>     raise IndexError('key: %s' % (key))
>>> IndexError: key: bsp
>> I still Couldn't figure out why it's happening, when I use RawConfigParse
>> , it seems to run nicely though .
>> Any Ideas on solving it without using RawConfigParser ?
>>> -- vijay
>>> On 5 April 2018 at 11:51, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee,
>>>>> I got the rtems-test running
>>>>> I found that get_item_names(section, err) in configuration.py  was
>>>>> returning an empty list to the
>>>>> item_names in load(bsp,opts) for config.py this was giving out the
>>>>> error mandatory item not found .
>>>>> I have attached the patch file .
>>>>> current status :
>>>>> rtems-test is running without coverage
>>>>> running coverage gives the following error :
>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>     rt.test.run()
>>>>> line 310, in run
>>>>>     coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>> line 230, in coverage_get_obj
>>>>>     coverage_obj = coverage.coverage_run(opts.defaults,
>>>>> path_to_builddir)
>>>>>   File
>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py", line
>>>>> 335, in __init__
>>>>>     self.report_format = self.config_map['report_format'][2]
>>>> This is back to the difference in cfg formats. It's looking for the last
>>>> line here
>>>> https://github.com/cillianodonnell/rtems-tools/blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>> Which is now
>>>> https://github.com/cillianodonnell/rtems-tools/blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>> It's trying to grab the 'html' text so it can trigger the right section
>>>> of code in coverage.py
>>>> It's something just to tell which format we want the report to output
>>> Understood , I'll come to that after I manage to get the test running
>>> first .
>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>> Thanks
>>>>> -- vijay
>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>> > after pulling the ini-update branch from
>>>>>> > https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>> Any local changes?
>>>>>> > I tried running the rtems-test with the following command
>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>> > --rtems-tools=$HOME/development/rtems/5 --log=coverage_analysis.log
>>>>>> > --rtems-bsp=leon3_qemu
>>>>>> > --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>> > sparc-rtems5/c/leon3/testsuites/samples
>>>>>> > was getting the KeyError for 'coverage'
>>>>>> Please paste the command and output as it appears in the terminal?
>>>>>> > current status :
>>>>>> > the same command gives the error :
>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>> > to make sure I didn't break something , I also tried running from a
>>>>>> > freshly
>>>>>> > downloaded directory as well, it gives the same error.
>>>>>> Did you try running the following command from the top of the source
>>>>>> tree:
>>>>>>  $ grep -r "mandatory item not found" *
>>>>>> Chris
> devel mailing list
> devel at rtems.org
