[PATCH 06/12] NFS: Remove support for cexp
Wed Apr 11 14:07:32 UTC 2018
Avoid use of RTEMS_RELLDFLAGS.
 cpukit/libfs/src/nfsclient/Makefile.am        |  55 +---
 cpukit/libfs/src/nfsclient/src/cexphelp.c     |  27 --
 cpukit/libfs/src/nfsclient/src/dirutils.c     | 385 -------------------------
 cpukit/libfs/src/nfsclient/src/nfs.c          |   4 +-
 cpukit/libfs/src/nfsclient/src/nfs.modini.c   |  38 ---
 cpukit/libfs/src/nfsclient/src/nfsTest.c      | 386 --------------------------
 cpukit/libfs/src/nfsclient/src/rpcio.modini.c |  26 --
 7 files changed, 9 insertions(+), 912 deletions(-)
 delete mode 100644 cpukit/libfs/src/nfsclient/src/cexphelp.c
 delete mode 100644 cpukit/libfs/src/nfsclient/src/dirutils.c
 delete mode 100644 cpukit/libfs/src/nfsclient/src/nfs.modini.c
 delete mode 100644 cpukit/libfs/src/nfsclient/src/nfsTest.c
 delete mode 100644 cpukit/libfs/src/nfsclient/src/rpcio.modini.c
diff --git a/cpukit/libfs/src/nfsclient/Makefile.am b/cpukit/libfs/src/nfsclient/Makefile.am
index 04d840f507..db539b95ba 100644
--- a/cpukit/libfs/src/nfsclient/Makefile.am
+++ b/cpukit/libfs/src/nfsclient/Makefile.am
@@ -1,55 +1,14 @@
 include $(top_srcdir)/automake/compile.am
-#%dirutils.obj: %dirutils.o
-#	$(LD) -r -o $@ $^
-project_lib_PROGRAMS = dirutils.rel
-dirutils_rel_SOURCES = src/dirutils.c
-dirutils_rel_CPPFLAGS = $(AM_CPPFLAGS)
-dirutils_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
 if LIBNETWORKING
 project_lib_LIBRARIES = libnfs.a
-$(PROJECT_LIB)/libnfs.a: libnfs.a
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/libnfs.a
-TMPINSTALL_FILES = $(PROJECT_LIB)/libnfs.a
-# if you have CEXP set this variable to 'YES'
-# and some "help" info will be compiled in.
-libnfs_a_SOURCES = src/rpcio.c src/rpcio.h
-libnfs_a_SOURCES += src/nfs.c src/sock_mbuf.c src/xdr_mbuf.c
-libnfs_a_SOURCES += proto/mount_prot.h proto/nfs_prot.h
-# With CEXP
-# libnfs_a_SOURCES += dirutils.c rpcio.modini.c nfs.modini.c cexphelp.c
-# PGMS=${ARCH}/nfs.obj ${ARCH}/rpcio.obj ${ARCH}/dirutils.obj
-libnfs_a_CPPFLAGS = $(AM_CPPFLAGS)
-libnfs_a_CPPFLAGS += -I$(srcdir)/proto
-libnfs_a_CPPFLAGS += -UHAVE_CEXP
-#%nfs.obj: %nfs.o %nfs.modini.o
-#	$(LD) -r -o $@ $^ -L../proto/$(ARCH) -lnfsprot
-project_lib_PROGRAMS += nfs.rel
-nfs_rel_SOURCES = src/nfs.c proto/nfs_prot.h proto/mount_prot.h
-nfs_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/proto
-nfs_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-nfs_rel_LDADD = libnfs.a
-#%rpcio.obj: %rpcio.o %sock_mbuf.o %xdr_mbuf.o %rpcio.modini.o
-project_lib_PROGRAMS += rpcio.rel
-rpcio_rel_SOURCES = src/rpcio.c src/sock_mbuf.c src/xdr_mbuf.c
-rpcio_rel_CPPFLAGS = $(AM_CPPFLAGS)
-rpcio_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-libnfs_a_SOURCES += proto/nfs_prot_xdr.c proto/nfs_prot.h
-libnfs_a_SOURCES += proto/mount_prot_xdr.c proto/mount_prot.h
+libnfs_a_SOURCES =
+libnfs_a_SOURCES += proto/mount_prot_xdr.c
+libnfs_a_SOURCES += proto/nfs_prot_xdr.c
+libnfs_a_SOURCES += src/nfs.c
+libnfs_a_SOURCES += src/rpcio.c
+libnfs_a_SOURCES += src/sock_mbuf.c
+libnfs_a_SOURCES += src/xdr_mbuf.c
 endif
diff --git a/cpukit/libfs/src/nfsclient/src/cexphelp.c b/cpukit/libfs/src/nfsclient/src/cexphelp.c
deleted file mode 100644
index 09c73774f6..0000000000
--- a/cpukit/libfs/src/nfsclient/src/cexphelp.c
+++ /dev/null
@@ -1,27 +0,0 @@
- * @file
- * @brief CEXP Help Information
- * @ingroup libfs
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <librtemsNfs.h>
-#include <cexpHelp.h>
-CEXP_HELP_TAB_BEGIN(rtemsNfs)
-	HELP(
-"Mount a remote filesystem (NFS). The mount point (must not be a NFS dir)\n"
-"is created on the fly if not existing already.\n"
-"uid/gid to use may be specified:\n"
-"   hostspec: [uid.gid@]hostname_or_ipaddr\n"
-	, int, nfsMount, (char *hostspec, char *exportdir, char *mntpoint)
-	HELP(
-"Print all currently mounted NFS directories to open file handle.\n"
-"Pass f = 0 to print to stdout\n"
-	, int, nfsMountsShow, (FILE *f)
-CEXP_HELP_TAB_END
diff --git a/cpukit/libfs/src/nfsclient/src/dirutils.c b/cpukit/libfs/src/nfsclient/src/dirutils.c
index 7155ef998a..0000000000
--- a/cpukit/libfs/src/nfsclient/src/dirutils.c
+++ /dev/null
@@ -1,385 +0,0 @@
- * @file
- * @brief Basic NFS Filesystem Utilities for Testing the NFS
- * @ingroup libfs
- * Author: Till Straumann, <strauman at slac.stanford.edu>, 10/2002
- * Authorship
- * This software (NFS-2 client implementation for RTEMS) was created by
- *     Till Straumann <strauman at slac.stanford.edu>, 2002-2007,
- * 	   Stanford Linear Accelerator Center, Stanford University.
- * Acknowledgement of sponsorship
- * The NFS-2 client implementation for RTEMS was produced by
- *     the Stanford Linear Accelerator Center, Stanford University,
- * 	   under Contract DE-AC03-76SFO0515 with the Department of Energy.
- * Government disclaimer of liability
- * Neither the United States nor the United States Department of Energy,
- * nor any of their employees, makes any warranty, express or implied, or
- * assumes any legal liability or responsibility for the accuracy,
- * completeness, or usefulness of any data, apparatus, product, or process
- * disclosed, or represents that its use would not infringe privately owned
- * rights.
- * Stanford disclaimer of liability
- * Stanford University makes no representations or warranties, express or
- * implied, nor assumes any liability for the use of this software.
- * Stanford disclaimer of copyright
- * Stanford University, owner of the copyright, hereby disclaims its
- * copyright and all other rights in this software.  Hence, anyone may
- * freely use it for any purpose without restriction.
- * Maintenance of notices
- * In the interest of clarity regarding the origin and status of this
- * SLAC software, this and all the preceding Stanford University notices
- * are to remain affixed to any copy or derivative of this software made
- * or distributed by the recipient and are to be affixed to any copy of
- * software made or distributed by the recipient that contains a copy or
- * derivative of this software.
- * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
-#if HAVE_CONFIG_H
-#endif
-#ifdef __vxworks
-#include <vxWorks.h>
-#endif
-#include <stdio.h>
-#include <dirent.h>
-#include <unistd.h>
-#include <string.h>
-#include <fcntl.h>
-#include <sys/stat.h>
-#include <errno.h>
-#include <stdlib.h>
-#include <limits.h> /* PATH_MAX */
-#include <inttypes.h> /* PRI* */
-#include <rtems/inttypes.h> /* extended PRI* */
-#ifdef HAVE_CEXP
-#endif
-#ifndef __vxworks
- *  Prototypes to avoid warnings
-int pwd(void);
-int ls(char *dir, char *opts);
-int cp(char *from, char *to, char *opts);
-int ln(char *to, char *name, char *opts);
-int rm(char *path);
-int cd(char *path);
-#endif
-#ifndef __vxworks
-int
-pwd(void)
-char buf[PATH_MAX];
-	if ( !getcwd(buf,PATH_MAX)) {
-		perror("getcwd");
-		return -1;
-	} else {
-		printf("%s\n",buf);
-	return 0;
-static int
-ls_r(char *path, char *chpt, char *name, struct stat *buf)
-char *t;
-	sprintf(chpt, "/%s", name);
-	if (lstat(path,buf)) {
-		fprintf(stderr,"stat(%s): %s\n", path, strerror(errno));
-		return -1;
-	switch ( buf->st_mode & S_IFMT ) {
-		case S_IFSOCK:
-		case S_IFIFO:	t = "|"; break;
-		default:
-		case S_IFREG:
-		case S_IFBLK:
-		case S_IFCHR:
-						t = "";  break;
-		case S_IFDIR:
-						t = "/"; break;
-		case S_IFLNK:
-						t = "@"; break;
-	printf("%10li, %10" PRIooff_t "b, %5i.%-5i 0%04" PRIomode_t " %s%s\n",
-				buf->st_ino,
-				buf->st_size,
-				buf->st_uid,
-				buf->st_gid,
-				buf->st_mode & ~S_IFMT,
-				name,
-				t);
-	*chpt = 0;
-	return 0;
-int
-ls(char *dir, char *opts)
-struct dirent	*de;
-char			path[PATH_MAX+1];
-char			*chpt;
-DIR				*dp  = 0;
-int				rval = -1;
-struct stat		buf;
-	if ( !dir )
-		dir = ".";
-	strncpy(path, dir, PATH_MAX);
-	path[PATH_MAX] = 0;
-	chpt = path+strlen(path);
-	if ( !(dp=opendir(dir)) ) {
-		perror("opendir");
-		goto cleanup;
-	while ( (de = readdir(dp)) ) {
-		ls_r(path, chpt, de->d_name, &buf);
-	rval = 0;
-cleanup:
-	if (dp)
-		closedir(dp);
-	return rval;
-#endif
-#if 0
-		fprintf(stderr, "usage: cp(""from"",[""to""[,""-f""]]\n");
-		fprintf(stderr, "          ""to""==NULL -> stdout\n");
-		fprintf(stderr, "          ""-f""       -> overwrite existing file\n");
-#endif
-int
-cp(char *from, char *to, char *opts)
-struct stat	st;
-int			rval  = -1;
-int			fd    = -1;
-FILE		*fst  = 0;
-FILE		*tst  = 0;
-int			flags = O_CREAT | O_WRONLY | O_TRUNC | O_EXCL;
-	if (from) {
-	if ((fd=open(from,O_RDONLY,0)) < 0) {
-		fprintf(stderr,
-				"Opening %s for reading: %s\n",
-				from,
-				strerror(errno));
-		goto cleanup;
-	if (fstat(fd, &st)) {
-		fprintf(stderr,
-				"rstat(%s): %s\n",
-				from,
-				strerror(errno));
-		goto cleanup;
-	if (!S_ISREG(st.st_mode)) {
-		fprintf(stderr,"Refuse to copy a non-regular file\n");
-		errno = EINVAL;
-		goto cleanup;
-	/* Now create a stream -- I experienced occasional weirdness
-	 * when circumventing the streams attached to fildno(stdin)
-	 * by reading/writing to the underlying fd's directly ->
-	 * for now we always go through buffered I/O...
-	if ( !(fst=fdopen(fd,"r")) ) {
-		fprintf(stderr,
-				"Opening input stream [fdopen()] failed: %s\n",
-				strerror(errno));
-		goto cleanup;
-	/* at this point, we have a stream and don't need 'fd' anymore */
-	fd = -1;
-	} else {
-		fst			= stdin;
-		st.st_mode	= 0644;
-	if (opts && strchr(opts,'f'))
-		flags &= ~ O_EXCL;
-	if (to) {
-		if ( (fd=open(to,flags,st.st_mode)) < 0 ) {
-			fprintf(stderr,
-					"Opening %s for writing: %s\n",
-					to,
-					strerror(errno));
-			goto cleanup;
-		if ( !(tst=fdopen(fd, "w")) ) {
-			fprintf(stderr,
-					"Opening output stream [fdopen()] failed: %s\n",
-					strerror(errno));
-			goto cleanup;
-		/* at this point we have a stream and don't need 'fd' anymore */
-		fd = -1;
-	} else {
-		tst = stdout;
-	/* clear old errors */
-	clearerr(fst);
-	clearerr(tst);
-	/* use macro versions on register vars; stdio is already buffered,
-	 * there's nothing to be gained by reading/writing blocks into
-	 * a secondary buffer...
-	register int ch;
-	register FILE *f = fst;
-	register FILE *t = tst;
-		while ( EOF != (ch = getc(f)) && EOF != putc(ch, t) )
-			/* nothing else */;
-	if ( ferror(fst) ) {
-		fprintf(stderr,"Read error: %s\n",strerror(errno));
-		goto cleanup;
-	if ( ferror(tst) ) {
-		fprintf(stderr,"Write error: %s\n",strerror(errno));
-		goto cleanup;
-	rval = 0;
-cleanup:
-	if ( fd >= 0 )
-		close(fd);
-	if ( fst ) {
-		if ( from )
-			fclose(fst);
-		else
-			clearerr(fst);
-	if ( tst ) {
-		if ( to )
-			fclose(tst);
-		else {
-			/* flush stdout */
-			fflush(tst);
-			clearerr(tst);
-	return rval;
-int
-ln(char *to, char *name, char *opts)
-	if (!to) {
-		fprintf(stderr,"ln: need 'to' argument\n");
-		return -1;
-	if (!name) {
-		if ( !(name = strrchr(to,'/')) ) {
-			fprintf(stderr,
-					"ln: 'unable to link %s to %s\n",
-					to,to);
-			return -1;
-		name++;
-	if (opts && strchr(opts,'s')) {
-		if (symlink(name,to)) {
-			fprintf(stderr,"symlink: %s\n",strerror(errno));
-			return -1;
-	} else {
-		if (link(name,to)) {
-			fprintf(stderr,"hardlink: %s\n",strerror(errno));
-			return -1;
-	return 0;
-int
-rm(char *path)
-	return unlink(path);
-int
-cd(char *path)
-	return chdir(path);
-#ifdef HAVE_CEXP
-static CexpHelpTabRec _cexpHelpTabDirutils[] RTEMS_UNUSED = {
-	HELP(
-"copy a file: cp(""from"",[""to""[,""-f""]])\n\
-                 from = NULL <-- stdin\n\
-                 to   = NULL --> stdout\n\
-                 option -f: overwrite existing file\n",
-		int,
-		cp, (char *from, char *to, char *options)
-	HELP(
-"list a directory: ls([""dir""])\n",
-		int,
-		ls, (char *dir)
-	HELP(
-"remove a file\n",
-		int,
-		rm, (char *path)
-	HELP(
-"change the working directory\n",
-		int,
-		cd, (char *path)
-	HELP(
-"create a link: ln(""to"",""name"",""[-s]""\n\
-                   -s creates a symlink\n",
-		int,
-		ln, (char *to, char *name, char *options)
-	HELP("",,0,)
-#endif
diff --git a/cpukit/libfs/src/nfsclient/src/nfs.c b/cpukit/libfs/src/nfsclient/src/nfs.c
index f4f53191b5..b8427f1387 100644
--- a/cpukit/libfs/src/nfsclient/src/nfs.c
+++ b/cpukit/libfs/src/nfsclient/src/nfs.c
@@ -80,8 +80,8 @@
 #include <netinet/in.h>
 #include <arpa/inet.h>
-#include <nfs_prot.h>
-#include <mount_prot.h>
+#include "../proto/nfs_prot.h"
+#include "../proto/mount_prot.h"
 #include "rpcio.h"
 #include "librtemsNfs.h"
diff --git a/cpukit/libfs/src/nfsclient/src/nfs.modini.c b/cpukit/libfs/src/nfsclient/src/nfs.modini.c
index 57adf23aa1..0000000000
--- a/cpukit/libfs/src/nfsclient/src/nfs.modini.c
+++ /dev/null
@@ -1,38 +0,0 @@
- * @file
- * @brief NFS Module Initialize
- * @ingroup libfs
-#if HAVE_CONFIG_H
-#endif
-#include "librtemsNfs.h"
-/* CEXP dynamic loader support */
-void
-_cexpModuleInitialize(void *mod)
-#if defined(DEBUG)
-	/* print load address (in case we crash while initializing) */
-unsigned lr;
-	__asm__ __volatile__(
-			"	    bl     thisis_loaded_at \n"
-			"thisis_loaded_at:              \n"
-			"       mflr   %0               \n"
-			: "=r"(lr) ::"lr");
-	printf("thisis_loaded_at: 0x%08x\n",lr);
-#endif
-	nfsInit(0,0);
-int
-_cexpModuleFinalize(void *mod)
-	return nfsCleanup();
diff --git a/cpukit/libfs/src/nfsclient/src/nfsTest.c b/cpukit/libfs/src/nfsclient/src/nfsTest.c
index 5b6951af58..0000000000
--- a/cpukit/libfs/src/nfsclient/src/nfsTest.c
+++ /dev/null
@@ -1,386 +0,0 @@
- * @file
- * @brief Test Program for Evaluating NFS Read Throughput
- * @ingroup libfs
- * This test code allows for evaluating NFS read performance
- * under various scenarios:
- *  - synchronous reads with various buffer sizes (select
- *    'num_readers' == 0, see below).
- *  - pseudo 'read-ahead' using multiple threads that issue
- *    NFS reads from the same file (but from different offsets)
- *    in parallel.
- *    Rationale: each NFS read request is synchronous, i.e., the
- *    caller sends a request to the server and waits for the
- *    reply to come back. Performance enhancement can be expected
- *    by requesting multiple blocks in parallel rather than
- *    sequentially.
- * rtems_interval
- * nfsTestRead(char *file_name, int chunk_size, int num_readers);
- * 1) creates 'num_readers' threads, each opening 'file_name' for
- *    reading on a separate file descriptor.
- * 2) creates message queues for communicating with reader threads
- * 3) read file using nfsTestReadBigbuf() until EOF is reached
- * 4) releases resources.
- * RETURNS: Time elapsed during step 3 in ms. This is measured
- *          using the system clock so make sure the test file
- *          is big enough.
- * nfsTestReadBigbuf() synchronously reads a block of
- * 'num_readers * chunk_size' (which may be bigger than
- * the UDP limit of 8k) using 'num_reader' threads to
- * retrieve the various pieces of the big block in parallel.
- * This speeds up things since several RPC calls can
- * be in the works at once.
- * NOTES:
- *  - if 'num_readers' == 0 this corresponds to an 'ordinary'
- *    NFS read. 'num_readers' == 1 schedules a single reader
- *    thread (== ordinary NFS read + message passing overhead).
- *  - no actual processing on the data is done; they are simply
- *    thrown away. A real, performance-critical application could
- *    pipeline 'reader' and 'cruncher' threads.
- *  - read is not completely asynchronous; synchronization is still
- *    performed at 'big block' boundaries (num_readers * chunk_size).
- * Author: Till Straumann <strauman at slac.stanford.edu>, 2006
- * Authorship
- * rights.
-#if HAVE_CONFIG_H
-#endif
-#include <rtems.h>
-#include <rtems/error.h>
-#include <fcntl.h>
-#include <stdio.h>
-unsigned nfsTestReaderPri = 80;
-struct nfsTestReq_ {
-	unsigned offset;	/* file offset */
-	int      size;		/* IN: block size to read (must be < 8192), OUT: bytes actually read */
-	void	 *buf;		/* data buffer address */
-/* Queue for sending requests to parallel reader tasks */
-rtems_id nfsTestRQ = 0;
-/* Queue to pickup replies from parallel reader tasks  */
-rtems_id nfsTestAQ = 0;
-/* Reader task; opens its own file descriptor
- * and works on requests:
- *    - obtain request from request queue.
- *    - lseek to the requested file offset
- *    - NFS read into buffer
- *    - queue reply.
- * Note that this implementation is very simple
- *  - no full error checking.
- *  - file is opened/closed by thread
- * it's main purpose is running quick tests.
-static rtems_task
-nfsTestReader(rtems_task_argument arg)
-int                fd = open((char*)arg,O_RDONLY);
-unsigned long      s;
-struct nfsTestReq_ r;
-rtems_status_code  sc;
-	if ( fd < 0 ) {
-		perror("nfsReader: opening file");
-		goto cleanup;
-	do {
-		s  = sizeof(r);
-		sc = rtems_message_queue_receive(nfsTestRQ, &r, &s, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-		if ( RTEMS_SUCCESSFUL != sc ) {
-			rtems_error(sc, "(Error) reading from message queue");
-			goto cleanup;
-		if ( !r.buf ) {
-			/* They send a NULL buffer as a shutdown request */
-			break;
-#ifdef DEBUG
-		printf("Reader: reading offset %u, size %i to %p ... ",
-			r.offset, r.size, r.buf);
-#endif
-		/* seek to requested offset */
-		lseek(fd, r.offset, SEEK_SET);
-		r.size = read(fd, r.buf, r.size);
-#ifdef DEBUG
-		printf("got %i\n",r.size);
-#endif
-		rtems_message_queue_send(nfsTestAQ, &r, sizeof(r));
-	} while (1) ;
-cleanup:
-	if ( fd >= 0 )
-		close(fd);
-	rtems_task_delete(RTEMS_SELF);
-/* helper to create and start a reader task */
-static rtems_id
-taskSpawn(char *filenm, int inst)
-rtems_id          tid;
-	sc = rtems_task_create(
-			rtems_build_name('n','t','t','0'+inst),
-			nfsTestReaderPri,
-			1400,
-			RTEMS_DEFAULT_MODES,
-			RTEMS_DEFAULT_ATTRIBUTES,
-			&tid);
-		rtems_error(sc,"(Error) Creating nfs reader task %i",inst);
-		return 0;
-	sc = rtems_task_start(tid, nfsTestReader, (rtems_task_argument)filenm);
-		rtems_error(sc,"(Error) Staritng nfs reader task %i",inst);
-		rtems_task_delete(tid);
-		return 0;
-	return tid;
- * Read nrd*sz bytes into 'buf' from file offset 'off'
- * using 'nrd' parallel reader tasks to do the job.
- * This helper routine schedules 'nrd' requests to
- * the reader tasks and waits for all requests to
- * finish.
- * RETURNS: number of bytes read or -1 (error).
- * CAVEATS:
- *	- assumes read requests always return 'sz' bytes
- *    unless the end of file is reached.
- *    THIS ASSUMPTION SHOULD NOT BE MADE WHEN WRITING
- *    ANY 'REAL' CODE.
-static int
-nfsTestReadBigbuf(char *buf, int off, int sz, int nrd)
-int i,rval=0;
-	r.buf    = buf;
-	r.size   = sz;
-	r.offset = off;
-	/* send out parallel requests */
-	for (i=0; i<nrd; i++) {
-		rtems_message_queue_send(nfsTestRQ, &r, sizeof(r));
-		r.offset += sz;
-		r.buf    += sz;
-	/* wait for answers */
-		unsigned long s = sizeof(r);
-		rtems_message_queue_receive(nfsTestAQ, &r, &s, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-		if ( r.size < 0 ) {
-			fprintf(stderr,"A reader failed\n");
-			rval = -1;
-		} else {
-			/* FIXME sanity checks:
-			 *   - catch case where any-but-last read returns < sz
-			if ( rval >= 0 ) {
-				rval += r.size;
-	return rval;
-/* Main test routine
- * Read file 'fname' usint 'nrd' parallel reader tasks,
- * each operating on chunks of 'sz' bytes.
- * RETURNS: time elapsed in milliseconds. This is measured
- *          using the system clock. Hence, for the result
- *          to be meaningful, the file must be big enough.
-rtems_interval
-nfsTestRead(char *fnam, int sz, int nrd)
-int               i;
-unsigned          off;
-rtems_interval    now=-1, then, tickspsec;
-int		          fd=-1;
-char	          *buf=0;
-	if ( nrd < 0 )
-		nrd = 0;
-	if ( sz < 0 || sz > 8192 ) {
-		fprintf(stderr,"\n");
-		return -1;
-	nfsTestRQ = nfsTestAQ = 0;
-	/* Allocate buffer */
-	if ( ! (buf=malloc(sz*(nrd ? nrd : 1))) ) {
-		perror("allocating buffer");
-		goto cleanup;
-	/* Don't bother proceeding if we can't open the file for reading */
-	if ( (fd=open(fnam,O_RDONLY)) < 0 ) {
-		perror("opening file");
-		goto cleanup;
-	if ( nrd ) {
-		close(fd); fd = -1;
-	/* Create request queue */
-	if ( nrd ) {
-		sc = rtems_message_queue_create(
-				rtems_build_name('n','t','r','q'),
-				nrd,
-				sizeof(struct nfsTestReq_),
-				& nfsTestRQ );
-			rtems_error(sc, "(Error) creating request queue");
-			nfsTestRQ = 0;
-			goto cleanup;
-		/* Spawn reader tasks */
-		for ( i=0; i<nrd; i++ ) {
-			if ( ! taskSpawn(fnam, i) )
-				goto cleanup;
-		/* Create reply queue */
-				rtems_build_name('n','t','a','q'),
-				nrd,
-				& nfsTestAQ );
-			rtems_error(sc, "(Error) creating reply queue");
-			nfsTestAQ = 0;
-			goto cleanup;
-	/* Timed main loop */
-        then = rtems_clock_get_ticks_since_boot();
-	if ( nrd ) {
-		off = 0;
-		while  ((i = nfsTestReadBigbuf(buf, off, sz, nrd)) > 0 ) {
-#ifdef DEBUG
-			printf("bigbuf got %i\n", i);
-#endif
-			off += i;
-	} else {
-		while ( (i = read(fd, buf, sz)) > 0 )
-			/* nothing else to do */;
-		if ( i < 0 ) {
-			perror("reading");
-			goto cleanup;
-        now = rtems_clock_get_ticks_since_boot();
-	now = (now-then)*1000;
-	ticksspec = rtems_clock_get_ticks_per_second();
-	now /= tickspsec; /* time in ms */
-cleanup:
-	if ( fd >= 0 )
-		close(fd);
-	if ( nfsTestRQ ) {
-		/* request tasks to shutdown by sending NULL buf request  */
-		struct nfsTestReq_ r;
-		r.buf = 0;
-			rtems_message_queue_send( nfsTestRQ, &r, sizeof(r) );
-		/* cheat: instead of proper synchronization with shutdown we simply
-		 * delay for a second...
-		rtems_task_wake_after( tickspsec );
-		rtems_message_queue_delete( nfsTestRQ );
-	if ( nfsTestAQ )
-		rtems_message_queue_delete( nfsTestAQ );
-	free(buf);
-	return now;
diff --git a/cpukit/libfs/src/nfsclient/src/rpcio.modini.c b/cpukit/libfs/src/nfsclient/src/rpcio.modini.c
index f0359974de..0000000000
--- a/cpukit/libfs/src/nfsclient/src/rpcio.modini.c
+++ /dev/null
@@ -1,26 +0,0 @@
- * @file
- * @brief RPCIO Module Initialize
- * @ingroup libfs
-#if HAVE_CONFIG_H
-#endif
-/* CEXP module support (magic init) */
-void
-	rpcUdpInit();
-int
-	return rpcUdpCleanup();
2.12.3
