Bug in rtems-tester?
Joel Sherrill
joel at rtems.org
Wed Apr 11 14:39:54 UTC 2018
Hi
These failures have persisted across all the autoconf changes:
Failures:
powerpc/qemuprep-altivec:
configure --target=powerpc-rtems5 --enable-rtemsbsp=qemuprep-altivec\
--prefix=/home/joel/rtems-work/bsps --enable-networking --enable-smp
ld/collect2:0 error: no error message found!
--prefix=/home/joel/rtems-work/bsps --enable-debug --enable-smp
--prefix=/home/joel/rtems-work/bsps --enable-debug --enable-\
--prefix=/home/joel/rtems-work/bsps --enable-smp
I checked and it looks like qemuprep-altivec is listed in the smp excludes
section.
It is the only BSP with a - in the name that is in smp-excludes. Could it
be that the
matching fails in this case?
The other is pc586-sse which is SMP excluded also but using a different
mechanism..
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180411/cd904f76/attachment.html>
