Thanks for the New Configure Error
Joel Sherrill
joel at rtems.org
Wed Apr 11 23:02:18 UTC 2018
Hi
For once in my life, I was thrilled to get an error! I mistyped a BSP name
and BOOM! the build failed earlier than it ever has!
checking for gmake... gmake
checking for RTEMS Version... 5.0.0
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... mips-unknown-rtems5
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether gmake sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
configure: error: BSP 'rtbx4925' not found, run 'rtems-bsp' (in the top of
the source tree) for a valid BSP list
Thanks Chris!
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180411/945d91e5/attachment-0001.html>
