Thanks for the New Configure Error
Wed Apr 11 23:08:42 UTC 2018
On 12/04/2018 09:02, Joel Sherrill wrote:
> Hi
> For once in my life, I was thrilled to get an error! I mistyped a BSP name and
> BOOM! the build failed earlier than it ever has!
> checking for gmake... gmake
> checking for RTEMS Version... 5.0.0
> checking build system type... x86_64-pc-linux-gnu
> checking host system type... x86_64-pc-linux-gnu
> checking target system type... mips-unknown-rtems5
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
> checking for gawk... gawk
> checking whether gmake sets $(MAKE)... yes
> checking whether to enable maintainer-specific portions of Makefiles... yes
> configure: error: BSP 'rtbx4925' not found, run 'rtems-bsp' (in the top of the
> source tree) for a valid BSP list
Hehe, nice. And if you have the wrong --target for the BSP or your path to the
tools is wrong you also get an error just as quickly.
> Thanks Chris!
No problem, a much needed change. If we get it wrong and hated the old error
imagine a new user!
