[PATCH 1/2] libdl: Remove _t from all structures as this is reserved for the standards
Thu Apr 12 07:50:21 UTC 2018
 cpukit/include/rtems/rtl/rap.h              |   6 +-
 cpukit/include/rtems/rtl/rtl-allocator.h    |  40 ++---
 cpukit/include/rtems/rtl/rtl-fwd.h          |   6 +-
 cpukit/include/rtems/rtl/rtl-indirect-ptr.h |  54 +++----
 cpukit/include/rtems/rtl/rtl-obj-cache.h    |  32 ++--
 cpukit/include/rtems/rtl/rtl-obj-comp.h     |  46 +++---
 cpukit/include/rtems/rtl/rtl-obj-fwd.h      |   8 +-
 cpukit/include/rtems/rtl/rtl-obj.h          | 226 +++++++++++++--------------
 cpukit/include/rtems/rtl/rtl-sym.h          |  30 ++--
 cpukit/include/rtems/rtl/rtl-unresolved.h   |  86 +++++-----
 cpukit/include/rtems/rtl/rtl.h              |  82 +++++-----
 cpukit/libdl/dlfcn-shell.c                  |   6 +-
 cpukit/libdl/dlfcn.c                        |  22 +--
 cpukit/libdl/rap.c                          |  70 ++++-----
 cpukit/libdl/rtl-alloc-heap.c               |   8 +-
 cpukit/libdl/rtl-alloc-heap.h               |  10 +-
 cpukit/libdl/rtl-allocator.c                |  38 ++---
 cpukit/libdl/rtl-debugger.c                 |   6 +-
 cpukit/libdl/rtl-elf.c                      | 148 +++++++++---------
 cpukit/libdl/rtl-elf.h                      |  48 +++---
 cpukit/libdl/rtl-error.c                    |   8 +-
 cpukit/libdl/rtl-error.h                    |   2 +-
 cpukit/libdl/rtl-mdreloc-arm.c              |  42 ++---
 cpukit/libdl/rtl-mdreloc-bfin.c             |  42 ++---
 cpukit/libdl/rtl-mdreloc-h8300.c            |  42 ++---
 cpukit/libdl/rtl-mdreloc-i386.c             |  40 ++---
 cpukit/libdl/rtl-mdreloc-lm32.c             |  38 ++---
 cpukit/libdl/rtl-mdreloc-m68k.c             |  40 ++---
 cpukit/libdl/rtl-mdreloc-mips.c             |  38 ++---
 cpukit/libdl/rtl-mdreloc-moxie.c            |  38 ++---
 cpukit/libdl/rtl-mdreloc-powerpc.c          |  38 ++---
 cpukit/libdl/rtl-mdreloc-sparc.c            |  38 ++---
 cpukit/libdl/rtl-mdreloc-v850.c             |  38 ++---
 cpukit/libdl/rtl-obj-cache.c                |  28 ++--
 cpukit/libdl/rtl-obj-comp.c                 |  24 +--
 cpukit/libdl/rtl-obj.c                      | 234 ++++++++++++++--------------
 cpukit/libdl/rtl-rap.c                      | 140 ++++++++---------
 cpukit/libdl/rtl-rap.h                      |  12 +-
 cpukit/libdl/rtl-shell.c                    |  76 ++++-----
 cpukit/libdl/rtl-sym.c                      |  58 +++----
 cpukit/libdl/rtl-unresolved.c               | 155 +++++++++---------
 cpukit/libdl/rtl-unwind-dw2.c               |  16 +-
 cpukit/libdl/rtl-unwind-dw2.h               |  12 +-
 cpukit/libdl/rtl-unwind.h                   |  12 +-
 cpukit/libdl/rtl.c                          |  60 +++----
 45 files changed, 1121 insertions(+), 1122 deletions(-)
diff --git a/cpukit/include/rtems/rtl/rap.h b/cpukit/include/rtems/rtl/rap.h
index 0b86553e2b..03cf096cb0 100644
--- a/cpukit/include/rtems/rtl/rap.h
+++ b/cpukit/include/rtems/rtl/rap.h
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2013 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2013, 2018 Chris Johns <chrisj at rtems.org>
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -42,7 +42,7 @@ extern "C" {
  * The module iterator handle.
-typedef bool (*rtems_rap_iterator_t) (void* handle);
+typedef bool (*rtems_rap_iterator) (void* handle);
  * Load an application.
@@ -78,7 +78,7 @@ void* rtems_rap_find (const char* name);
  * @retval true The iterator function returned did not return false.
  * @retval false The iterator function returned false..
-bool rtems_rap_iterate (rtems_rap_iterator_t iterator);
+bool rtems_rap_iterate (rtems_rap_iterator iterator);
  * Return the name of the module given a handle.
diff --git a/cpukit/include/rtems/rtl/rtl-allocator.h b/cpukit/include/rtems/rtl/rtl-allocator.h
index e8044ee1e8..c5b3d4ec72 100644
--- a/cpukit/include/rtems/rtl/rtl-allocator.h
+++ b/cpukit/include/rtems/rtl/rtl-allocator.h
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2012 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2012, 2018 Chris Johns <chrisj at rtems.org>
@@ -30,7 +30,7 @@ extern "C" {
  * @note It is best to use the object tag for general memory allocation and to
  *       leave the tags with specific access properties to the module data
-enum rtems_rtl_alloc_tags_e {
+enum rtems_rtl_alloc_tags {
   RTEMS_RTL_ALLOC_OBJECT,     /**< A generic memory object. */
   RTEMS_RTL_ALLOC_SYMBOL,     /**< Memory used for symbols. */
   RTEMS_RTL_ALLOC_EXTERNAL,   /**< Memory used for external symbols. */
@@ -42,7 +42,7 @@ enum rtems_rtl_alloc_tags_e {
  * The allocator tag type.
-typedef enum rtems_rtl_alloc_tags_e rtems_rtl_alloc_tag_t;
+typedef enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag;
  * The number of tags.
@@ -63,29 +63,29 @@ typedef enum rtems_rtl_alloc_tags_e rtems_rtl_alloc_tag_t;
  * @param size The size of the allocation if an allocation request and
  *             not used if deleting or freeing a previous allocation.
-typedef void (*rtems_rtl_allocator_t)(bool                  allocate,
-                                      rtems_rtl_alloc_tag_t tag,
-                                      void**                address,
-                                      size_t                size);
+typedef void (*rtems_rtl_allocator)(bool                allocate,
+                                    rtems_rtl_alloc_tag tag,
+                                    void**              address,
+                                    size_t              size);
  * The allocator data.
-struct rtems_rtl_alloc_data_s {
+struct rtems_rtl_alloc_data {
   /**< The memory allocator handler. */
-  rtems_rtl_allocator_t allocator;
+  rtems_rtl_allocator allocator;
   /**< The indirect pointer chains. */
   rtems_chain_control indirects[RTEMS_RTL_ALLOC_TAGS];
-typedef struct rtems_rtl_alloc_data_s rtems_rtl_alloc_data_t;
+typedef struct rtems_rtl_alloc_data rtems_rtl_alloc_data;
  * Initialise the allocate data.
  * @param data The data to initialise.
-void rtems_rtl_alloc_initialise (rtems_rtl_alloc_data_t* data);
+void rtems_rtl_alloc_initialise (rtems_rtl_alloc_data* data);
  * The Runtime Loader allocator new allocates new memory and optionally clear
@@ -96,7 +96,7 @@ void rtems_rtl_alloc_initialise (rtems_rtl_alloc_data_t* data);
  * @param zero If true the memory is cleared.
  * @return void* The memory address or NULL is not memory available.
-void* rtems_rtl_alloc_new (rtems_rtl_alloc_tag_t tag, size_t size, bool zero);
+void* rtems_rtl_alloc_new (rtems_rtl_alloc_tag tag, size_t size, bool zero);
  * The Runtime Loader allocator delete deletes allocated memory.
@@ -104,7 +104,7 @@ void* rtems_rtl_alloc_new (rtems_rtl_alloc_tag_t tag, size_t size, bool zero);
  * @param tag The type of allocation request.
  * @param address The memory address to delete. A NULL is ignored.
-void rtems_rtl_alloc_del (rtems_rtl_alloc_tag_t tag, void* address);
+void rtems_rtl_alloc_del (rtems_rtl_alloc_tag tag, void* address);
  * Hook the Runtime Loader allocatior. A handler can call the previous handler
@@ -113,9 +113,9 @@ void rtems_rtl_alloc_del (rtems_rtl_alloc_tag_t tag, void* address);
  * returned.
  * @param handler The handler to use as the allocator.
- * @return rtems_rtl_alloc_handler_t The previous handler.
+ * @return rtems_rtl_alloc_handler The previous handler.
-rtems_rtl_allocator_t rtems_rtl_alloc_hook (rtems_rtl_allocator_t handler);
+rtems_rtl_allocator rtems_rtl_alloc_hook (rtems_rtl_allocator handler);
  * Allocate memory to an indirect handle.
@@ -124,9 +124,9 @@ rtems_rtl_allocator_t rtems_rtl_alloc_hook (rtems_rtl_allocator_t handler);
  * @param handle The handle to allocate the memory to.
  * @param size The size of the allocation.
-void rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag_t tag,
-                                   rtems_rtl_ptr_t*      handle,
-                                   size_t                size);
+void rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag tag,
+                                   rtems_rtl_ptr*      handle,
+                                   size_t              size);
  * Free memory from an indirect handle.
@@ -134,8 +134,8 @@ void rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag_t tag,
  * @param handle The handle to free the memory from.
-void rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag_t tag,
-                                   rtems_rtl_ptr_t*      handle);
+void rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag tag,
+                                   rtems_rtl_ptr*      handle);
  * Allocate the memory for a module given the size of the text, const, data and
diff --git a/cpukit/include/rtems/rtl/rtl-fwd.h b/cpukit/include/rtems/rtl/rtl-fwd.h
index 4641ad5d5e..b5b4eae495 100644
--- a/cpukit/include/rtems/rtl/rtl-fwd.h
+++ b/cpukit/include/rtems/rtl/rtl-fwd.h
@@ -1,5 +1,5 @@
@@ -23,8 +23,8 @@ extern "C" {
  * The forward declaration of the obj structure.
-struct rtems_rtl_data_s;
-typedef struct rtems_rtl_data_s rtems_rtl_data_t;
+struct rtems_rtl_data;
+typedef struct rtems_rtl_data rtems_rtl_data;
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtl/rtl-indirect-ptr.h b/cpukit/include/rtems/rtl/rtl-indirect-ptr.h
index 81503a3b45..dbfa70679c 100644
--- a/cpukit/include/rtems/rtl/rtl-indirect-ptr.h
+++ b/cpukit/include/rtems/rtl/rtl-indirect-ptr.h
@@ -1,5 +1,5 @@
@@ -11,7 +11,7 @@
  * @ingroup rtems_rtl
  * @brief RTEMS Run-Time Linker Indirect Pointer Management allows memory
- *        compaction in the allocator.
+ *        compaction in the allocator.
 #if !defined (_RTEMS_RTL_INDIRECT_PTR_H_)
@@ -26,22 +26,22 @@ extern "C" {
  * The RTL Indirect pointer.
-struct rtems_rtl_ptr_s {
+struct rtems_rtl_ptr {
   rtems_chain_node node;     /**< Indirect pointers are held on lists. */
   void*            pointer;  /**< The actual pointer. */
-typedef struct rtems_rtl_ptr_s rtems_rtl_ptr_t;
+typedef struct rtems_rtl_ptr rtems_rtl_ptr;
  * The RTL Indirect size and pointer.
-struct rtems_rtl_sptr_s {
-  rtems_rtl_ptr_t  ptr;      /**< The indirect pointer. */
-  size_t           size;     /**< The size of the memory block. */
+struct rtems_rtl_sptr {
+  rtems_rtl_ptr  ptr;      /**< The indirect pointer. */
+  size_t         size;     /**< The size of the memory block. */
-typedef struct rtems_rtl_sptr_s rtems_rtl_sptr_t;
+typedef struct rtems_rtl_sptr rtems_rtl_sptr;
  * A chain of indirect pointers for users to chain in applications.
@@ -49,12 +49,12 @@ typedef struct rtems_rtl_sptr_s rtems_rtl_sptr_t;
  * @note The chain the pointer is on is internal to the allocator and cannot be
  *       used by applications.
-struct rtems_rtl_ptr_chain_s {
+struct rtems_rtl_ptr_chain {
   rtems_chain_node node;  /**< Chain of indirect pointers. */
-typedef struct rtems_rtl_ptr_chain_s rtems_rtl_ptr_chain_t;
+typedef struct rtems_rtl_ptr_chain rtems_rtl_ptr_chain;
  * A chain of indirect sized pointers for users to chain in applications.
@@ -62,12 +62,12 @@ typedef struct rtems_rtl_ptr_chain_s rtems_rtl_ptr_chain_t;
-struct rtems_rtl_sptr_chain_s {
-  rtems_chain_node node;  /**< Chain of indirect pointers. */
-  rtems_rtl_sptr_t  ptr;  /**< The indirect pointer. */
+struct rtems_rtl_sptr_chain {
+  rtems_chain_node node; /**< Chain of indirect pointers. */
+  rtems_rtl_sptr   ptr;  /**< The indirect pointer. */
-typedef struct rtems_rtl_sptr_chain_s rtems_rtl_sptr_chain_t;
+typedef struct rtems_rtl_sptr_chain rtems_rtl_sptr_chain;
  * Get the pointer given an indirect handle.
@@ -75,7 +75,7 @@ typedef struct rtems_rtl_sptr_chain_s rtems_rtl_sptr_chain_t;
  * @param handle The handle the pointer is returned from.
  * @return void* The pointer held in the handle.
-static inline void* rtems_rtl_ptr_get (rtems_rtl_ptr_t* handle)
+static inline void* rtems_rtl_ptr_get (rtems_rtl_ptr* handle)
   return handle->pointer;
@@ -86,7 +86,7 @@ static inline void* rtems_rtl_ptr_get (rtems_rtl_ptr_t* handle)
  * @param pointer The pointer to set in the handle.
-static inline void rtems_rtl_ptr_set (rtems_rtl_ptr_t* handle, void* pointer)
+static inline void rtems_rtl_ptr_set (rtems_rtl_ptr* handle, void* pointer)
   handle->pointer = pointer;
@@ -96,7 +96,7 @@ static inline void rtems_rtl_ptr_set (rtems_rtl_ptr_t* handle, void* pointer)
  * @param handle The handle to initialise.
-static inline void rtems_rtl_ptr_init (rtems_rtl_ptr_t* handle)
+static inline void rtems_rtl_ptr_init (rtems_rtl_ptr* handle)
   rtems_chain_set_off_chain (&handle->node);
   handle->pointer = NULL;
@@ -108,7 +108,7 @@ static inline void rtems_rtl_ptr_init (rtems_rtl_ptr_t* handle)
  * @param handle The handle to test.
  * @return bool True if the pointer is NULL.
-static inline bool rtems_rtl_ptr_null (rtems_rtl_ptr_t* handle)
+static inline bool rtems_rtl_ptr_null (rtems_rtl_ptr* handle)
   return handle->pointer == NULL;
@@ -120,7 +120,7 @@ static inline bool rtems_rtl_ptr_null (rtems_rtl_ptr_t* handle)
  * @param src The source handle to move the pointer from.
  * @param dst The destination handle to receive the pointer.
-static inline void rtems_rtl_ptr_move (rtems_rtl_ptr_t* dst, rtems_rtl_ptr_t* src)
+static inline void rtems_rtl_ptr_move (rtems_rtl_ptr* dst, rtems_rtl_ptr* src)
    * We do not know which chain the src handle resides on so insert the dst
@@ -146,7 +146,7 @@ static inline void rtems_rtl_ptr_move (rtems_rtl_ptr_t* dst, rtems_rtl_ptr_t* sr
-static inline void* rtems_rtl_sptr_get (rtems_rtl_sptr_t* handle)
+static inline void* rtems_rtl_sptr_get (rtems_rtl_sptr* handle)
   return rtems_rtl_ptr_get (&handle->ptr);
@@ -157,7 +157,7 @@ static inline void* rtems_rtl_sptr_get (rtems_rtl_sptr_t* handle)
-static inline void rtems_rtl_sptr_set (rtems_rtl_sptr_t* handle, void* pointer)
+static inline void rtems_rtl_sptr_set (rtems_rtl_sptr* handle, void* pointer)
   rtems_rtl_ptr_set (&handle->ptr, pointer);
@@ -167,7 +167,7 @@ static inline void rtems_rtl_sptr_set (rtems_rtl_sptr_t* handle, void* pointer)
-static inline void rtems_rtl_sptr_init (rtems_rtl_sptr_t* handle)
+static inline void rtems_rtl_sptr_init (rtems_rtl_sptr* handle)
   rtems_rtl_ptr_init (&handle->ptr);
   handle->size = 0;
@@ -179,7 +179,7 @@ static inline void rtems_rtl_sptr_init (rtems_rtl_sptr_t* handle)
-static inline bool rtems_rtl_sptr_null (rtems_rtl_sptr_t* handle)
+static inline bool rtems_rtl_sptr_null (rtems_rtl_sptr* handle)
   return rtems_rtl_ptr_null (&handle->ptr);
@@ -191,7 +191,7 @@ static inline bool rtems_rtl_sptr_null (rtems_rtl_sptr_t* handle)
-static inline void rtems_rtl_sptr_move (rtems_rtl_sptr_t* dst, rtems_rtl_sptr_t* src)
+static inline void rtems_rtl_sptr_move (rtems_rtl_sptr* dst, rtems_rtl_sptr* src)
   rtems_rtl_ptr_move (&dst->ptr, &src->ptr);
   dst->size = src->size;
@@ -204,7 +204,7 @@ static inline void rtems_rtl_sptr_move (rtems_rtl_sptr_t* dst, rtems_rtl_sptr_t*
  * @param handle The handle to get the size from.
  * @return size_t The size_t.
-static inline size_t rtems_rtl_sptr_get_size (rtems_rtl_sptr_t* handle)
+static inline size_t rtems_rtl_sptr_get_size (rtems_rtl_sptr* handle)
   return handle->size;
@@ -215,7 +215,7 @@ static inline size_t rtems_rtl_sptr_get_size (rtems_rtl_sptr_t* handle)
  * @param handle The handle to set the size.
  * @param size The size to set..
-static inline void rtems_rtl_sptr_set_size (rtems_rtl_sptr_t* handle, size_t size)
+static inline void rtems_rtl_sptr_set_size (rtems_rtl_sptr* handle, size_t size)
   handle->size = size;
diff --git a/cpukit/include/rtems/rtl/rtl-obj-cache.h b/cpukit/include/rtems/rtl/rtl-obj-cache.h
index 8eacdd316b..3613e88246 100644
--- a/cpukit/include/rtems/rtl/rtl-obj-cache.h
+++ b/cpukit/include/rtems/rtl/rtl-obj-cache.h
@@ -1,5 +1,5 @@
@@ -50,7 +50,7 @@ extern "C" {
  * The buffer cache.
-typedef struct rtems_rtl_obj_cache_s
+typedef struct rtems_rtl_obj_cache
   int      fd;        /**< The file descriptor of the data in the cache. */
   size_t   file_size; /**< The size of the file. */
@@ -59,7 +59,7 @@ typedef struct rtems_rtl_obj_cache_s
   size_t   level;     /**< The amount of data in the cache. A file can be
                        * smaller than the cache file. */
   uint8_t* buffer;    /**< The buffer */
-} rtems_rtl_obj_cache_t;
+} rtems_rtl_obj_cache;
  * Open a cache allocating a single buffer of the size passed. The default
@@ -70,21 +70,21 @@ typedef struct rtems_rtl_obj_cache_s
  * @retval true The cache is open.
  * @retval false The cache is not open. The RTL error is set.
-bool rtems_rtl_obj_cache_open (rtems_rtl_obj_cache_t* cache, size_t size);
+bool rtems_rtl_obj_cache_open (rtems_rtl_obj_cache* cache, size_t size);
  * Close a cache.
  * @param cache The cache to close.
-void rtems_rtl_obj_cache_close (rtems_rtl_obj_cache_t* cache);
+void rtems_rtl_obj_cache_close (rtems_rtl_obj_cache* cache);
  * Flush the cache. Any further read will read the data from the file.
  * @param cache The cache to flush.
-void rtems_rtl_obj_cache_flush (rtems_rtl_obj_cache_t* cache);
+void rtems_rtl_obj_cache_flush (rtems_rtl_obj_cache* cache);
  * Read data by reference. The length contains the amount of data that should
@@ -102,11 +102,11 @@ void rtems_rtl_obj_cache_flush (rtems_rtl_obj_cache_t* cache);
  * @retval true The data referenced is in the cache.
  * @retval false The read failed and the RTL error has been set.
-bool rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
-                               int                    fd,
-                               off_t                  offset,
-                               void**                 buffer,
-                               size_t*                length);
+bool rtems_rtl_obj_cache_read (rtems_rtl_obj_cache* cache,
+                               int                  fd,
+                               off_t                offset,
+                               void**               buffer,
+                               size_t*              length);
  * Read data by value. The data is copied to the user supplied buffer.
@@ -119,11 +119,11 @@ bool rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
  * @retval true The data has been read from the cache.
-bool rtems_rtl_obj_cache_read_byval (rtems_rtl_obj_cache_t* cache,
-                                     int                    fd,
-                                     off_t                  offset,
-                                     void*                  buffer,
-                                     size_t                 length);
+bool rtems_rtl_obj_cache_read_byval (rtems_rtl_obj_cache* cache,
+                                     int                  fd,
+                                     off_t                offset,
+                                     void*                buffer,
+                                     size_t               length);
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtl/rtl-obj-comp.h b/cpukit/include/rtems/rtl/rtl-obj-comp.h
index 34bfa6ffa1..963824b277 100644
--- a/cpukit/include/rtems/rtl/rtl-obj-comp.h
+++ b/cpukit/include/rtems/rtl/rtl-obj-comp.h
@@ -1,5 +1,5 @@
@@ -43,23 +43,23 @@ extern "C" {
  * The compressed file.
-typedef struct rtems_rtl_obj_cpmp_s
+typedef struct rtems_rtl_obj_cpmp
-  rtems_rtl_obj_cache_t* cache;       /**< The cache provides the input
+  rtems_rtl_obj_cache* cache;       /**< The cache provides the input
                                        *   buffer. */
-  int                    fd;          /**< The file descriptor. */
-  int                    compression; /**< The type of compression. */
-  off_t                  offset;      /**< The base offset of the buffer. */
-  size_t                 size;        /**< The size of the output buffer. */
-  size_t                 level;       /**< The amount of data in the buffer. */
-  uint8_t*               buffer;      /**< The buffer */
-  uint32_t               read;        /**< The amount of data read. */
-} rtems_rtl_obj_comp_t;
+  int                  fd;          /**< The file descriptor. */
+  int                  compression; /**< The type of compression. */
+  off_t                offset;      /**< The base offset of the buffer. */
+  size_t               size;        /**< The size of the output buffer. */
+  size_t               level;       /**< The amount of data in the buffer. */
+  uint8_t*             buffer;      /**< The buffer */
+  uint32_t             read;        /**< The amount of data read. */
+} rtems_rtl_obj_comp;
  * Return the input level.
-static inline uint32_t rtems_rtl_obj_comp_input (rtems_rtl_obj_comp_t* comp)
+static inline uint32_t rtems_rtl_obj_comp_input (rtems_rtl_obj_comp* comp)
   return comp->read;
@@ -72,15 +72,15 @@ static inline uint32_t rtems_rtl_obj_comp_input (rtems_rtl_obj_comp_t* comp)
  * @retval true The compressor is open.
  * @retval false The compressor is not open. The RTL error is set.
-bool rtems_rtl_obj_comp_open (rtems_rtl_obj_comp_t*  comp,
-                              size_t                 size);
+bool rtems_rtl_obj_comp_open (rtems_rtl_obj_comp*  comp,
+                              size_t               size);
  * Close a compressor.
  * @param comp The compressor to close.
-void rtems_rtl_obj_comp_close (rtems_rtl_obj_comp_t* comp);
+void rtems_rtl_obj_comp_close (rtems_rtl_obj_comp* comp);
  * Set the cache and offset in the file the compressed stream starts.
@@ -91,11 +91,11 @@ void rtems_rtl_obj_comp_close (rtems_rtl_obj_comp_t* comp);
  * @param compression The type of compression being streamed.
  * @param offset The offset in the file the compressed stream starts.
-void rtems_rtl_obj_comp_set (rtems_rtl_obj_comp_t*  comp,
-                             rtems_rtl_obj_cache_t* cache,
-                             int                    fd,
-                             int                    compression,
-                             off_t                  offset);
+void rtems_rtl_obj_comp_set (rtems_rtl_obj_comp*  comp,
+                             rtems_rtl_obj_cache* cache,
+                             int                  fd,
+                             int                  compression,
+                             off_t                offset);
  * Read decompressed data. The length contains the amount of data that should
@@ -111,9 +111,9 @@ void rtems_rtl_obj_comp_set (rtems_rtl_obj_comp_t*  comp,
-bool rtems_rtl_obj_comp_read (rtems_rtl_obj_comp_t* comp,
-                              void*                 buffer,
-                              size_t                length);
+bool rtems_rtl_obj_comp_read (rtems_rtl_obj_comp* comp,
+                              void*               buffer,
+                              size_t              length);
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtl/rtl-obj-fwd.h b/cpukit/include/rtems/rtl/rtl-obj-fwd.h
index 2c53244316..39e28c58e1 100644
--- a/cpukit/include/rtems/rtl/rtl-obj-fwd.h
+++ b/cpukit/include/rtems/rtl/rtl-obj-fwd.h
@@ -23,14 +23,14 @@ extern "C" {
  * The forward declaration of the obj section structure.
-struct rtems_rtl_obj_sect_s;
-typedef struct rtems_rtl_obj_sect_s rtems_rtl_obj_sect_t;
+struct rtems_rtl_obj_sect;
+typedef struct rtems_rtl_obj_sect rtems_rtl_obj_sect;
-struct rtems_rtl_obj_s;
-typedef struct rtems_rtl_obj_s rtems_rtl_obj_t;
+struct rtems_rtl_obj;
+typedef struct rtems_rtl_obj rtems_rtl_obj;
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtl/rtl-obj.h b/cpukit/include/rtems/rtl/rtl-obj.h
index 6a35a72822..ff7b2a197d 100644
--- a/cpukit/include/rtems/rtl/rtl-obj.h
+++ b/cpukit/include/rtems/rtl/rtl-obj.h
@@ -35,7 +35,7 @@ extern "C" {
  * Loader format definition.
-typedef struct rtems_rtl_loader_format_s
+typedef struct rtems_rtl_loader_format
    * The format label. This can be used to determine and manage
@@ -47,42 +47,42 @@ typedef struct rtems_rtl_loader_format_s
    * The format flags.
   uint32_t flags;
-} rtems_rtl_loader_format_t;
+} rtems_rtl_loader_format;
  * The type of the format loader check handler. This handler checks the format
  * and if it is detected as suitable it returns true.
-typedef bool (*rtems_rtl_loader_check) (rtems_rtl_obj_t* obj, int fd);
+typedef bool (*rtems_rtl_loader_check) (rtems_rtl_obj* obj, int fd);
  * The type of the format loader load handler. This handler loads the specific
  * format.
-typedef bool (*rtems_rtl_loader_load) (rtems_rtl_obj_t* obj, int fd);
+typedef bool (*rtems_rtl_loader_load) (rtems_rtl_obj* obj, int fd);
  * The type of the format loader unload handler. This handler unloads the
  * specific format.
-typedef bool (*rtems_rtl_loader_unload) (rtems_rtl_obj_t* obj);
+typedef bool (*rtems_rtl_loader_unload) (rtems_rtl_obj* obj);
  * The type of the format loader signature handler. This handler checks the
  * format signature.
-typedef rtems_rtl_loader_format_t* (*rtems_rtl_loader_sig) (void);
+typedef rtems_rtl_loader_format* (*rtems_rtl_loader_sig) (void);
  * Table for supported loadable formats.
-typedef struct rtems_rtl_loader_table_s
+typedef struct rtems_rtl_loader_table
   rtems_rtl_loader_check  check;     /**< The check handler. */
   rtems_rtl_loader_load   load;      /**< The loader. */
   rtems_rtl_loader_unload unload;    /**< The unloader. */
   rtems_rtl_loader_sig    signature; /**< The loader's signature. */
-} rtems_rtl_loader_table_t;
+} rtems_rtl_loader_table;
  * Flags for the various section types.
@@ -121,7 +121,7 @@ typedef struct rtems_rtl_loader_table_s
  * one of a specific type of sections. All sections and grouped
  * together in memory.
   rtems_chain_node node;        /**< The node's link in the chain. */
   int              section;     /**< The section number. */
@@ -150,51 +150,51 @@ struct rtems_rtl_obj_sect_s
  * RTL Object. There is one for each object module loaded plus one for the base
  * kernel image.
-  rtems_chain_node     link;         /**< The node's link in the chain. */
-  uint32_t             flags;        /**< The status of the object file. */
-  uint32_t             users;        /**< References to the object file. */
-  int                  format;       /**< The format of the object file. */
-  const char*          fname;        /**< The file name for the object. */
-  const char*          oname;        /**< The object file name. Can be
-                                      *   relative. */
-  const char*          aname;        /**< The archive name containing the
-                                      *   object. NULL means the object is not
-                                      *   in a lib */
-  off_t                ooffset;      /**< The object offset in the archive. */
-  size_t               fsize;        /**< Size of the object file. */
-  rtems_chain_control  sections;     /**< The sections of interest in the
-                                      *   object file. */
-  rtems_rtl_obj_sym_t* local_table;  /**< Local symbol table. */
-  size_t               local_syms;   /**< Local symbol count. */
-  size_t               local_size;   /**< Local symbol memory usage. */
-  rtems_rtl_obj_sym_t* global_table; /**< Global symbol table. */
-  size_t               global_syms;  /**< Global symbol count. */
-  size_t               global_size;  /**< Global symbol memory usage. */
-  uint32_t             unresolved;   /**< The number of unresolved relocations. */
-  void*                text_base;    /**< The base address of the text section
-                                      *   in memory. */
-  size_t               text_size;     /**< The size of the text section. */
-  void*                const_base;   /**< The base address of the const section
-                                      *   in memory. */
-  void*                eh_base;      /**< The base address of the eh section
-                                      *   in memory. */
-  size_t               eh_size;      /**< The size of the eh section. */
-  void*                data_base;    /**< The base address of the data section
-                                      *   in memory. */
-  void*                bss_base;     /**< The base address of the bss section
-                                      *   in memory. */
-  size_t               bss_size;     /**< The size of the bss section. */
-  size_t               exec_size;    /**< The amount of executable memory
-                                      *   allocated */
-  void*                entry;        /**< The entry point of the module. */
-  uint32_t             checksum;     /**< The checksum of the text sections. A
-                                      *   zero means do not checksum. */
-  uint32_t*            sec_num;      /**< The sec nums of each obj. */
-  uint32_t             obj_num;      /**< The count of elf files in an rtl obj. */
-  struct link_map*     linkmap;      /**< For GDB. */
-  void*                loader;       /**< The file details specific to a loader. */
+  rtems_chain_node    link;         /**< The node's link in the chain. */
+  uint32_t            flags;        /**< The status of the object file. */
+  uint32_t            users;        /**< References to the object file. */
+  int                 format;       /**< The format of the object file. */
+  const char*         fname;        /**< The file name for the object. */
+  const char*         oname;        /**< The object file name. Can be
+                                     *   relative. */
+  const char*         aname;        /**< The archive name containing the
+                                     *   object. NULL means the object is not
+                                     *   in a lib */
+  off_t               ooffset;      /**< The object offset in the archive. */
+  size_t              fsize;        /**< Size of the object file. */
+  rtems_chain_control sections;     /**< The sections of interest in the
+                                     *   object file. */
+  rtems_rtl_obj_sym*  local_table;  /**< Local symbol table. */
+  size_t              local_syms;   /**< Local symbol count. */
+  size_t              local_size;   /**< Local symbol memory usage. */
+  rtems_rtl_obj_sym*  global_table; /**< Global symbol table. */
+  size_t              global_syms;  /**< Global symbol count. */
+  size_t              global_size;  /**< Global symbol memory usage. */
+  uint32_t            unresolved;   /**< The number of unresolved relocations. */
+  void*               text_base;    /**< The base address of the text section
+                                     *   in memory. */
+  size_t              text_size;    /**< The size of the text section. */
+  void*               const_base;   /**< The base address of the const section
+                                     *   in memory. */
+  void*               eh_base;      /**< The base address of the eh section
+                                     *   in memory. */
+  size_t              eh_size;      /**< The size of the eh section. */
+  void*               data_base;    /**< The base address of the data section
+                                     *   in memory. */
+  void*               bss_base;     /**< The base address of the bss section
+                                     *   in memory. */
+  size_t              bss_size;     /**< The size of the bss section. */
+  size_t              exec_size;    /**< The amount of executable memory
+                                     *   allocated */
+  void*               entry;        /**< The entry point of the module. */
+  uint32_t            checksum;     /**< The checksum of the text sections. A
+                                     *   zero means do not checksum. */
+  uint32_t*           sec_num;      /**< The sec nums of each obj. */
+  uint32_t            obj_num;      /**< The count of elf files in an rtl obj. */
+  struct link_map*    linkmap;      /**< For GDB. */
+  void*               loader;       /**< The file details specific to a loader. */
@@ -208,10 +208,10 @@ struct rtems_rtl_obj_s
  * @retval true The operation was successful.
  * @retval false The operation failed and the RTL has been set.
-typedef bool (*rtems_rtl_obj_sect_handler_t)(rtems_rtl_obj_t*      obj,
-                                             int                   fd,
-                                             rtems_rtl_obj_sect_t* sect,
-                                             void*                 data);
+typedef bool (*rtems_rtl_obj_sect_handler)(rtems_rtl_obj*      obj,
+                                           int                 fd,
+                                           rtems_rtl_obj_sect* sect,
+                                           void*               data);
  * Get the file name.
@@ -219,7 +219,7 @@ typedef bool (*rtems_rtl_obj_sect_handler_t)(rtems_rtl_obj_t*      obj,
  * @param obj The object file.
  * @return const char* The string.
-static inline const char* rtems_rtl_obj_fname (const rtems_rtl_obj_t* obj)
+static inline const char* rtems_rtl_obj_fname (const rtems_rtl_obj* obj)
   return obj->fname;
@@ -230,7 +230,7 @@ static inline const char* rtems_rtl_obj_fname (const rtems_rtl_obj_t* obj)
  * @return bool There is a file name
-static inline bool rtems_rtl_obj_fname_valid (const rtems_rtl_obj_t* obj)
+static inline bool rtems_rtl_obj_fname_valid (const rtems_rtl_obj* obj)
   return obj->fname;
@@ -241,7 +241,7 @@ static inline bool rtems_rtl_obj_fname_valid (const rtems_rtl_obj_t* obj)
-static inline const char* rtems_rtl_obj_oname (const rtems_rtl_obj_t* obj)
+static inline const char* rtems_rtl_obj_oname (const rtems_rtl_obj* obj)
   return obj->oname;
@@ -252,7 +252,7 @@ static inline const char* rtems_rtl_obj_oname (const rtems_rtl_obj_t* obj)
  * @return bool There is an object name
-static inline bool rtems_rtl_obj_oname_valid (const rtems_rtl_obj_t* obj)
+static inline bool rtems_rtl_obj_oname_valid (const rtems_rtl_obj* obj)
   return obj->oname;
@@ -263,7 +263,7 @@ static inline bool rtems_rtl_obj_oname_valid (const rtems_rtl_obj_t* obj)
-static inline const char* rtems_rtl_obj_aname (const rtems_rtl_obj_t* obj)
+static inline const char* rtems_rtl_obj_aname (const rtems_rtl_obj* obj)
   return obj->aname;
@@ -274,7 +274,7 @@ static inline const char* rtems_rtl_obj_aname (const rtems_rtl_obj_t* obj)
  * @return bool There is an archive name
-static inline bool rtems_rtl_obj_aname_valid (const rtems_rtl_obj_t* obj)
+static inline bool rtems_rtl_obj_aname_valid (const rtems_rtl_obj* obj)
   return obj->aname;
@@ -285,8 +285,8 @@ static inline bool rtems_rtl_obj_aname_valid (const rtems_rtl_obj_t* obj)
-static inline bool rtems_rtl_obj_text_inside (const rtems_rtl_obj_t* obj,
-                                              const void*            address)
+static inline bool rtems_rtl_obj_text_inside (const rtems_rtl_obj* obj,
+                                              const void*          address)
   return
     (address >= obj->text_base) &&
@@ -298,7 +298,7 @@ static inline bool rtems_rtl_obj_text_inside (const rtems_rtl_obj_t* obj,
  * @retval NULL No memory for the object.
-rtems_rtl_obj_t* rtems_rtl_obj_alloc (void);
+rtems_rtl_obj* rtems_rtl_obj_alloc (void);
  * Free the object structure and related resources.
@@ -307,7 +307,7 @@ rtems_rtl_obj_t* rtems_rtl_obj_alloc (void);
  * @retval false The object has dependences.
  * @retval true The object has been freed.
-bool rtems_rtl_obj_free (rtems_rtl_obj_t* obj);
+bool rtems_rtl_obj_free (rtems_rtl_obj* obj);
  * Does the object file have unresolved external references ? If it does the
@@ -317,7 +317,7 @@ bool rtems_rtl_obj_free (rtems_rtl_obj_t* obj);
  * @retval true The object file has unresolved externals.
  * @retval false The object file has all external references resolved.
-bool rtems_rtl_obj_unresolved (rtems_rtl_obj_t* obj);
+bool rtems_rtl_obj_unresolved (rtems_rtl_obj* obj);
  * Parses a filename and returns newly allocated strings with the archive name,
@@ -341,7 +341,7 @@ bool rtems_rtl_parse_name (const char*  name,
  * @param obj The object file's descriptor.
  * @param name The name to match.
-bool rtems_rtl_match_name (rtems_rtl_obj_t* obj, const char* name);
+bool rtems_rtl_match_name (rtems_rtl_obj* obj, const char* name);
  * Find an object file on disk that matches the name. The object descriptor is
@@ -353,7 +353,7 @@ bool rtems_rtl_match_name (rtems_rtl_obj_t* obj, const char* name);
  * @retval true The file has been found.
  * @retval false The file could not be located. The RTL error has been set.
-bool rtems_rtl_obj_find_file (rtems_rtl_obj_t* obj, const char* name);
+bool rtems_rtl_obj_find_file (rtems_rtl_obj* obj, const char* name);
  * Add a section to the object descriptor.
@@ -370,22 +370,22 @@ bool rtems_rtl_obj_find_file (rtems_rtl_obj_t* obj, const char* name);
  * @retval true The section has been added.
  * @retval false The section has not been added. See the RTL error.
-bool rtems_rtl_obj_add_section (rtems_rtl_obj_t* obj,
-                                int              section,
-                                const char*      name,
-                                size_t           size,
-                                off_t            offset,
-                                uint32_t         alignment,
-                                int              link,
-                                int              info,
-                                uint32_t         flags);
+bool rtems_rtl_obj_add_section (rtems_rtl_obj* obj,
+                                int            section,
+                                const char*    name,
+                                size_t         size,
+                                off_t          offset,
+                                uint32_t       alignment,
+                                int            link,
+                                int            info,
+                                uint32_t       flags);
  * Erase the object file descriptor's sections.
-void rtems_rtl_obj_erase_sections (rtems_rtl_obj_t* obj);
+void rtems_rtl_obj_erase_sections (rtems_rtl_obj* obj);
  * Find the section given a name.
@@ -395,8 +395,8 @@ void rtems_rtl_obj_erase_sections (rtems_rtl_obj_t* obj);
  * @retval NULL The section was not found.
  * @return rtems_rtl_obj_sect_t* The named section.
-rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section (const rtems_rtl_obj_t* obj,
-                                                  const char*            name);
+rtems_rtl_obj_sect* rtems_rtl_obj_find_section (const rtems_rtl_obj* obj,
+                                                const char*          name);
  * Find a section given a section's index number.
@@ -406,8 +406,8 @@ rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section (const rtems_rtl_obj_t* obj,
  * @return rtems_rtl_obj_sect_t* The found section.
-rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj_t* obj,
-                                                           int                    index);
+rtems_rtl_obj_sect* rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj* obj,
+                                                         int                  index);
  * The text section size. Only use once all the sections has been added. It
@@ -417,7 +417,7 @@ rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj_t
  * @return size_t The size of the text area of the object file.
-size_t rtems_rtl_obj_text_size (const rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_text_size (const rtems_rtl_obj* obj);
  * The text section alignment for the object file. Only use once all the
@@ -430,7 +430,7 @@ size_t rtems_rtl_obj_text_size (const rtems_rtl_obj_t* obj);
  * @return uint32_t The alignment. Can be 0 or 1 for not aligned or the alignment.
-uint32_t rtems_rtl_obj_text_alignment (const rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_text_alignment (const rtems_rtl_obj* obj);
  * The const section size. Only use once all the sections has been added. It
@@ -440,7 +440,7 @@ uint32_t rtems_rtl_obj_text_alignment (const rtems_rtl_obj_t* obj);
  * @return size_t The size of the const area of the object file.
-size_t rtems_rtl_obj_const_size (const rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_const_size (const rtems_rtl_obj* obj);
  * The const section alignment for the object file. Only use once all the
@@ -453,7 +453,7 @@ size_t rtems_rtl_obj_const_size (const rtems_rtl_obj_t* obj);
-uint32_t rtems_rtl_obj_const_alignment (const rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_const_alignment (const rtems_rtl_obj* obj);
  * The eh section size. Only use once all the sections has been added. It
@@ -462,7 +462,7 @@ uint32_t rtems_rtl_obj_const_alignment (const rtems_rtl_obj_t* obj);
  * @return size_t The size of the bss area of the object file.
-size_t rtems_rtl_obj_eh_size (const rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_eh_size (const rtems_rtl_obj* obj);
  * The eh section alignment for the object file. Only use once all the sections
@@ -475,7 +475,7 @@ size_t rtems_rtl_obj_eh_size (const rtems_rtl_obj_t* obj);
-uint32_t rtems_rtl_obj_eh_alignment (const rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_eh_alignment (const rtems_rtl_obj* obj);
  * The data section size. Only use once all the sections has been added. It
@@ -485,7 +485,7 @@ uint32_t rtems_rtl_obj_eh_alignment (const rtems_rtl_obj_t* obj);
  * @return size_t The size of the data area of the object file.
-size_t rtems_rtl_obj_data_size (const rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_data_size (const rtems_rtl_obj* obj);
  * The data section alignment for the object file. Only use once all the
@@ -498,7 +498,7 @@ size_t rtems_rtl_obj_data_size (const rtems_rtl_obj_t* obj);
-uint32_t rtems_rtl_obj_data_alignment (const rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_data_alignment (const rtems_rtl_obj* obj);
  * The bss section size. Only use once all the sections has been added. It
@@ -507,7 +507,7 @@ uint32_t rtems_rtl_obj_data_alignment (const rtems_rtl_obj_t* obj);
-size_t rtems_rtl_obj_bss_size (const rtems_rtl_obj_t* obj);
+size_t rtems_rtl_obj_bss_size (const rtems_rtl_obj* obj);
  * The bss section alignment for the object file. Only use once all the
@@ -520,7 +520,7 @@ size_t rtems_rtl_obj_bss_size (const rtems_rtl_obj_t* obj);
-uint32_t rtems_rtl_obj_bss_alignment (const rtems_rtl_obj_t* obj);
+uint32_t rtems_rtl_obj_bss_alignment (const rtems_rtl_obj* obj);
  * Relocate the object file. The object file's section are parsed for any
@@ -533,17 +533,17 @@ uint32_t rtems_rtl_obj_bss_alignment (const rtems_rtl_obj_t* obj);
  * @retval true The object file was relocated.
  * @retval false The relocation failed. The RTL error is set.
-bool rtems_rtl_obj_relocate (rtems_rtl_obj_t*             obj,
-                             int                          fd,
-                             rtems_rtl_obj_sect_handler_t handler,
-                             void*                        data);
+bool rtems_rtl_obj_relocate (rtems_rtl_obj*             obj,
+                             int                        fd,
+                             rtems_rtl_obj_sect_handler handler,
+                             void*                      data);
  * Synchronize caches to make code visible to CPU(s)
-void rtems_rtl_obj_synchronize_cache (rtems_rtl_obj_t*    obj);
+void rtems_rtl_obj_synchronize_cache (rtems_rtl_obj* obj);
  * Relocate an object file's unresolved reference.
@@ -553,8 +553,8 @@ void rtems_rtl_obj_synchronize_cache (rtems_rtl_obj_t*    obj);
  * @retval true The object file record was relocated.
-bool rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t* reloc,
-                                        rtems_rtl_obj_sym_t*        sym);
+bool rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc* reloc,
+                                        rtems_rtl_obj_sym*        sym);
  * Load the symbols from the object file. Only the exported or public symbols
@@ -567,10 +567,10 @@ bool rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t* reloc,
  * @retval true The object file's symbol where loaded.
  * @retval false The symbol loading failed. The RTL error is set.
-bool rtems_rtl_obj_load_symbols (rtems_rtl_obj_t*             obj,
-                                 int                          fd,
-                                 void*                        data);
+bool rtems_rtl_obj_load_symbols (rtems_rtl_obj*             obj,
+                                 int                        fd,
+                                 void*                      data);
  * Load the sections that have been allocated memory in the target. The bss
@@ -584,10 +584,10 @@ bool rtems_rtl_obj_load_symbols (rtems_rtl_obj_t*             obj,
  * @retval true The object has been sucessfully loaded.
  * @retval false The load failed. The RTL error has been set.
-bool rtems_rtl_obj_load_sections (rtems_rtl_obj_t*             obj,
-                                  int                          fd,
-                                  void*                        data);
+bool rtems_rtl_obj_load_sections (rtems_rtl_obj*             obj,
+                                  int                        fd,
+                                  void*                      data);
  * Invoke the constructors the object has. Constructors are a table of pointers
@@ -597,7 +597,7 @@ bool rtems_rtl_obj_load_sections (rtems_rtl_obj_t*             obj,
-void rtems_rtl_obj_run_ctors (rtems_rtl_obj_t* obj);
+void rtems_rtl_obj_run_ctors (rtems_rtl_obj* obj);
  * Invoke the destructors the object has. Destructors are a table of pointers
@@ -607,7 +607,7 @@ void rtems_rtl_obj_run_ctors (rtems_rtl_obj_t* obj);
-void rtems_rtl_obj_run_dtors (rtems_rtl_obj_t* obj);
+void rtems_rtl_obj_run_dtors (rtems_rtl_obj* obj);
  * Load the object file, reading all sections into memory, symbols and
@@ -617,7 +617,7 @@ void rtems_rtl_obj_run_dtors (rtems_rtl_obj_t* obj);
  * @retval true The object file has been loaded.
-bool rtems_rtl_obj_load (rtems_rtl_obj_t* obj);
+bool rtems_rtl_obj_load (rtems_rtl_obj* obj);
  * Unload the object file, erasing all symbols and releasing all memory.
@@ -626,7 +626,7 @@ bool rtems_rtl_obj_load (rtems_rtl_obj_t* obj);
  * @retval true The object file has been unloaded.
  * @retval false The unload failed. The RTL error has been set.
-bool rtems_rtl_obj_unload (rtems_rtl_obj_t* obj);
+bool rtems_rtl_obj_unload (rtems_rtl_obj* obj);
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtl/rtl-sym.h b/cpukit/include/rtems/rtl/rtl-sym.h
index fe00da89d7..be246a908d 100644
--- a/cpukit/include/rtems/rtl/rtl-sym.h
+++ b/cpukit/include/rtems/rtl/rtl-sym.h
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2012-2014 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2012-2014, 2018 Chris Johns <chrisj at rtems.org>
  * An object file symbol.
-typedef struct rtems_rtl_obj_sym_s
+typedef struct rtems_rtl_obj_sym
   const char*      name;    /**< The symbol's name. */
   void*            value;   /**< The value of the symbol. */
   uint32_t         data;    /**< Format specific data. */
-} rtems_rtl_obj_sym_t;
+} rtems_rtl_obj_sym;
  * Table of symbols stored in a hash table.
-typedef struct rtems_rtl_symbols_s
+typedef struct rtems_rtl_symbols
   rtems_chain_control* buckets;
   size_t               nbuckets;
-} rtems_rtl_symbols_t;
+} rtems_rtl_symbols;
  * Open a symbol table with the specified number of buckets.
@@ -52,15 +52,15 @@ typedef struct rtems_rtl_symbols_s
  * @retval false The symbol table could not created. The RTL
  *               error has the error.
-bool rtems_rtl_symbol_table_open (rtems_rtl_symbols_t* symbols,
-                                  size_t               buckets);
+bool rtems_rtl_symbol_table_open (rtems_rtl_symbols* symbols,
+                                  size_t             buckets);
  * Close the table and erase the hash table.
  * @param symbols Close the symbol table.
-void rtems_rtl_symbol_table_close (rtems_rtl_symbols_t* symbols);
+void rtems_rtl_symbol_table_close (rtems_rtl_symbols* symbols);
  * Add a table of exported symbols to the symbol table.
@@ -83,7 +83,7 @@ void rtems_rtl_symbol_table_close (rtems_rtl_symbols_t* symbols);
  * @param esyms The exported symbol table.
  * @param size The size of the table in bytes.
-bool rtems_rtl_symbol_global_add (rtems_rtl_obj_t*     obj,
+bool rtems_rtl_symbol_global_add (rtems_rtl_obj*       obj,
                                   const unsigned char* esyms,
                                   unsigned int         size);
@@ -94,7 +94,7 @@ bool rtems_rtl_symbol_global_add (rtems_rtl_obj_t*     obj,
  * @retval NULL No symbol found.
  * @return rtems_rtl_obj_sym_t* Reference to the symbol.
-rtems_rtl_obj_sym_t* rtems_rtl_symbol_global_find (const char* name);
+rtems_rtl_obj_sym* rtems_rtl_symbol_global_find (const char* name);
  * Find a symbol given the symbol label in the local object file.
@@ -104,29 +104,29 @@ rtems_rtl_obj_sym_t* rtems_rtl_symbol_global_find (const char* name);
-rtems_rtl_obj_sym_t* rtems_rtl_symbol_obj_find (rtems_rtl_obj_t* obj,
+rtems_rtl_obj_sym* rtems_rtl_symbol_obj_find (rtems_rtl_obj* obj,
  * Add the object file's symbols to the global table.
  * @param obj The object file the symbols are to be added.
-void rtems_rtl_symbol_obj_add (rtems_rtl_obj_t* obj);
+void rtems_rtl_symbol_obj_add (rtems_rtl_obj* obj);
  * Erase the object file's local symbols.
  * @param obj The object file the local symbols are to be erased from.
-void rtems_rtl_symbol_obj_erase_local (rtems_rtl_obj_t* obj);
+void rtems_rtl_symbol_obj_erase_local (rtems_rtl_obj* obj);
  * Erase the object file's symbols.
  * @param obj The object file the symbols are to be erased from.
-void rtems_rtl_symbol_obj_erase (rtems_rtl_obj_t* obj);
+void rtems_rtl_symbol_obj_erase (rtems_rtl_obj* obj);
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtl/rtl-unresolved.h b/cpukit/include/rtems/rtl/rtl-unresolved.h
index bd4ce2a215..884d909fa6 100644
--- a/cpukit/include/rtems/rtl/rtl-unresolved.h
+++ b/cpukit/include/rtems/rtl/rtl-unresolved.h
@@ -1,5 +1,5 @@
@@ -63,75 +63,75 @@ extern "C" {
  * Hack to work around machine size. This needs to be cleaned up
  * to better support 64bit targets.
-typedef uint32_t rtems_rtl_word_t;
+typedef uint32_t rtems_rtl_word;
  * The types of records in the blocks.
-typedef enum rtems_rtl_unresolved_rtype_e
+typedef enum rtems_rtl_unresolved_rtype
   rtems_rtl_unresolved_empty = 0,  /**< The records is empty. Must always be 0 */
   rtems_rtl_unresolved_name = 1,   /**< The record is a name. */
   rtems_rtl_unresolved_reloc = 2   /**< The record is a relocation record. */
-} rtems_rtl_unresolved_rtype_t;
+} rtems_rtl_unresolved_rtype;
  * Unresolved externals symbol names. The names are reference counted and
  * separate from the relocation records because a number of records could
  * reference the same symbol name.
-typedef struct rtems_rtl_unresolv_name_s
+typedef struct rtems_rtl_unresolv_name
-  uint16_t refs;       /**< The number of references to this name. */
-  uint16_t length;     /**< The length of this name. */
+  uint16_t   refs;     /**< The number of references to this name. */
+  uint16_t   length;   /**< The length of this name. */
   const char name[12]; /**< The symbol name. */
-} rtems_rtl_unresolv_name_t;
+} rtems_rtl_unresolv_name;
  * Unresolved externals symbols require the relocation records to be held
  * and references.
-typedef struct rtems_rtl_unresolv_reloc_s
+typedef struct rtems_rtl_unresolv_reloc
-  rtems_rtl_obj_t* obj;     /**< The relocation's object file. */
-  uint16_t         flags;   /**< Format specific flags. */
-  uint16_t         name;    /**< The symbol's name. */
-  uint16_t         sect;    /**< The target section. */
-  rtems_rtl_word_t rel[3];  /**< Relocation record. */
-} rtems_rtl_unresolv_reloc_t;
+  rtems_rtl_obj* obj;     /**< The relocation's object file. */
+  uint16_t       flags;   /**< Format specific flags. */
+  uint16_t       name;    /**< The symbol's name. */
+  uint16_t       sect;    /**< The target section. */
+  rtems_rtl_word rel[3];  /**< Relocation record. */
+} rtems_rtl_unresolv_reloc;
  * Unresolved externals records.
-typedef struct rtems_rtl_unresolv_rec_s
+typedef struct rtems_rtl_unresolv_rec
-  rtems_rtl_unresolved_rtype_t type;
+  rtems_rtl_unresolved_rtype type;
   union
-    rtems_rtl_unresolv_name_t name;    /**< The name, or */
-    rtems_rtl_unresolv_reloc_t reloc;  /**< the relocation record. */
+    rtems_rtl_unresolv_name  name;   /**< The name, or */
+    rtems_rtl_unresolv_reloc reloc;  /**< the relocation record. */
   } rec;
-} rtems_rtl_unresolv_rec_t;
+} rtems_rtl_unresolv_rec;
  * Unresolved blocks.
-typedef struct rtems_rtl_unresolv_block_s
+typedef struct rtems_rtl_unresolv_block
-  rtems_chain_node         link; /**< Blocks are chained. */
-  uint32_t                 recs; /**< The number of records in the block. */
-  rtems_rtl_unresolv_rec_t rec;  /**< The records. More follow. */
-} rtems_rtl_unresolv_block_t;
+  rtems_chain_node       link; /**< Blocks are chained. */
+  uint32_t               recs; /**< The number of records in the block. */
+  rtems_rtl_unresolv_rec rec;  /**< The records. More follow. */
+} rtems_rtl_unresolv_block;
  * Unresolved table holds the names and relocations.
-typedef struct rtems_rtl_unresolved_s
+typedef struct rtems_rtl_unresolved
   uint32_t marker;
   size_t              block_recs; /**< The records per blocks allocated. */
   rtems_chain_control blocks;     /**< List of blocks. */
-} rtems_rtl_unresolved_t;
+} rtems_rtl_unresolved;
  * The iterator function used to iterate over the unresolved table.
@@ -141,8 +141,8 @@ typedef struct rtems_rtl_unresolved_s
  * @retval true The iterator has finished.
  * @retval false The iterator has not finished. Keep iterating.
-typedef bool rtems_rtl_unresolved_iterator_t (rtems_rtl_unresolv_rec_t* rec,
-                                              void*                     data);
+typedef bool rtems_rtl_unresolved_iterator (rtems_rtl_unresolv_rec* rec,
+                                            void*                   data);
  * Open an unresolved relocation table.
@@ -153,21 +153,21 @@ typedef bool rtems_rtl_unresolved_iterator_t (rtems_rtl_unresolv_rec_t* rec,
  * @retval false The unresolved relocation table could not created. The RTL
-bool rtems_rtl_unresolved_table_open (rtems_rtl_unresolved_t* unresolved,
-                                      size_t                  block_records);
+bool rtems_rtl_unresolved_table_open (rtems_rtl_unresolved* unresolved,
+                                      size_t                block_records);
  * Close the table and erase the blocks.
  * @param unreolved Close the unresolved table.
-void rtems_rtl_unresolved_table_close (rtems_rtl_unresolved_t* unresolved);
+void rtems_rtl_unresolved_table_close (rtems_rtl_unresolved* unresolved);
  * Iterate over the table of unresolved entries.
-bool rtems_rtl_unresolved_interate (rtems_rtl_unresolved_iterator_t iterator,
-                                    void*                           data);
+bool rtems_rtl_unresolved_interate (rtems_rtl_unresolved_iterator iterator,
+                                    void*                         data);
  * Add a relocation to the list of unresolved relocations.
@@ -181,11 +181,11 @@ bool rtems_rtl_unresolved_interate (rtems_rtl_unresolved_iterator_t iterator,
  * @retval true The relocation has been added.
  * @retval false The relocation could not be added.
-bool rtems_rtl_unresolved_add (rtems_rtl_obj_t*        obj,
-                               const uint16_t          flags,
-                               const char*             name,
-                               const uint16_t          sect,
-                               const rtems_rtl_word_t* rel);
+bool rtems_rtl_unresolved_add (rtems_rtl_obj*        obj,
+                               const uint16_t        flags,
+                               const char*           name,
+                               const uint16_t        sect,
+                               const rtems_rtl_word* rel);
  * Resolve the unresolved symbols.
@@ -200,10 +200,10 @@ void rtems_rtl_unresolved_resolve (void);
-bool rtems_rtl_unresolved_remove (rtems_rtl_obj_t*        obj,
-                                  const char*             name,
+bool rtems_rtl_unresolved_remove (rtems_rtl_obj*        obj,
+                                  const char*           name,
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtl/rtl.h b/cpukit/include/rtems/rtl/rtl.h
index 513a6741aa..e30dba90ef 100644
--- a/cpukit/include/rtems/rtl/rtl.h
+++ b/cpukit/include/rtems/rtl/rtl.h
@@ -1,5 +1,5 @@
@@ -84,7 +84,7 @@ extern void _rtld_debug_state (void);
  * The type of constructor/destructor function.
-typedef void (*rtems_rtl_cdtor_t)(void);
+typedef void (*rtems_rtl_cdtor)(void);
  * The global RTL data. This structure is allocated on the heap when the first
@@ -94,48 +94,48 @@ typedef void (*rtems_rtl_cdtor_t)(void);
  * actual symbols are part of the object's structure. If this is a problem we
  * could look at a hash table per object file.
-  rtems_recursive_mutex  lock;           /**< The RTL lock */
-  rtems_rtl_alloc_data_t allocator;      /**< The allocator data. */
-  rtems_chain_control    objects;        /**< List if loaded object files. */
-  const char*            paths;          /**< Search paths for archives. */
-  rtems_rtl_symbols_t    globals;        /**< Global symbol table. */
-  rtems_rtl_unresolved_t unresolved;     /**< Unresolved symbols. */
-  rtems_rtl_obj_t*       base;           /**< Base object file. */
-  rtems_rtl_obj_cache_t  symbols;        /**< Symbols object file cache. */
-  rtems_rtl_obj_cache_t  strings;        /**< Strings object file cache. */
-  rtems_rtl_obj_cache_t  relocs;         /**< Relocations object file cache. */
-  rtems_rtl_obj_comp_t   decomp;         /**< The decompression compressor. */
-  int                    last_errno;     /**< Last error number. */
-  char                   last_error[64]; /**< Last error string. */
+  rtems_recursive_mutex lock;           /**< The RTL lock */
+  rtems_rtl_alloc_data  allocator;      /**< The allocator data. */
+  rtems_chain_control   objects;        /**< List if loaded object files. */
+  const char*           paths;          /**< Search paths for archives. */
+  rtems_rtl_symbols     globals;        /**< Global symbol table. */
+  rtems_rtl_unresolved  unresolved;     /**< Unresolved symbols. */
+  rtems_rtl_obj*        base;           /**< Base object file. */
+  rtems_rtl_obj_cache   symbols;        /**< Symbols object file cache. */
+  rtems_rtl_obj_cache   strings;        /**< Strings object file cache. */
+  rtems_rtl_obj_cache   relocs;         /**< Relocations object file cache. */
+  rtems_rtl_obj_comp    decomp;         /**< The decompression compressor. */
+  int                   last_errno;     /**< Last error number. */
+  char                  last_error[64]; /**< Last error string. */
  * Get the RTL data with out locking. This call assumes the RTL is locked.
- * @return rtems_rtl_data_t* The RTL data after being locked.
+ * @return rtems_rtl_data* The RTL data after being locked.
  * @retval NULL The RTL data is not initialised.
-rtems_rtl_data_t* rtems_rtl_data (void);
+rtems_rtl_data* rtems_rtl_data_unprotected (void);
  * Get the RTL global symbol table with out locking. This call assmes the RTL
  * is locked.
- * @return rtems_rtl_symbols_t* The RTL global symbols after being locked.
+ * @return rtems_rtl_symbols* The RTL global symbols after being locked.
-rtems_rtl_symbols_t* rtems_rtl_global_symbols (void);
+rtems_rtl_symbols* rtems_rtl_global_symbols (void);
  * Get the RTL resolved table with out locking. This call assmes the RTL
  * is locked.
- * @return rtems_rtl_unresolv_t* The RTL unresolved symbols and reloc records.
+ * @return rtems_rtl_unresolv* The RTL unresolved symbols and reloc records.
-rtems_rtl_unresolved_t* rtems_rtl_unresolved (void);
+rtems_rtl_unresolved* rtems_rtl_unresolved_unprotected (void);
  * Get the RTL symbols, strings, or relocations object file caches. This call
@@ -148,9 +148,9 @@ rtems_rtl_unresolved_t* rtems_rtl_unresolved (void);
  * @param relocs Pointer to the location to set the cache into. Returns NULL
  *               is rtl is not initialised. If NULL is passed in no value set.
-void rtems_rtl_obj_caches (rtems_rtl_obj_cache_t** symbols,
-                           rtems_rtl_obj_cache_t** strings,
-                           rtems_rtl_obj_cache_t** relocs);
+void rtems_rtl_obj_caches (rtems_rtl_obj_cache** symbols,
+                           rtems_rtl_obj_cache** strings,
+                           rtems_rtl_obj_cache** relocs);
  * Flush all the object file caches.
@@ -158,28 +158,28 @@ void rtems_rtl_obj_caches (rtems_rtl_obj_cache_t** symbols,
 void rtems_rtl_obj_caches_flush (void);
- * Get the RTL decompressor setting the cache and the offset in the file the
- * compressed stream starts. This call assmes the RTL is locked.
+ * Get the RTL decompressor setting for the cache and the offset in the file
+ * the compressed stream starts. This call assumes the RTL is locked.
  * @param decomp Pointer to the location to set the compressor into. Returns
  *               NULL is rtl is not initialised.
  * @param cache The cache to read the file with. Saves needing an extrs buffer.
-void rtems_rtl_obj_comp (rtems_rtl_obj_comp_t** decomp,
-                         int                    fd,
-                         int                    compression,
-                         off_t                  offset);
+void rtems_rtl_obj_decompress (rtems_rtl_obj_comp** decomp,
+                               int                  fd,
+                               int                  compression,
+                               off_t                offset);
  * Lock the Run-time Linker.
  * @retval NULL The RTL data could not be initialised or locked. Typically this
  *              means the lock could not be created.
-rtems_rtl_data_t* rtems_rtl_lock (void);
+rtems_rtl_data* rtems_rtl_lock (void);
  * Unlock the Run-time Linker.
@@ -195,16 +195,16 @@ void rtems_rtl_unlock (void);
  * @param handle Pointer to the object file to be validated.
  * @return rtl_obj* The object file descriptor. NULL is returned if invalid.
-rtems_rtl_obj_t* rtems_rtl_check_handle (void* handle);
+rtems_rtl_obj* rtems_rtl_check_handle (void* handle);
  * Find the object given a file name.
  * @param name The name of the object file.
  * @retval NULL No object file with that name found.
- * @return rtems_rtl_obj_t* The object file descriptor.
+ * @return rtems_rtl_obj* The object file descriptor.
-rtems_rtl_obj_t* rtems_rtl_find_obj (const char* name);
+rtems_rtl_obj* rtems_rtl_find_obj (const char* name);
  * Load an object file into memory relocating it. It will not be resolved
@@ -237,7 +237,7 @@ rtems_rtl_obj_t* rtems_rtl_find_obj (const char* name);
  * @param mode The mode of the load as defined by the dlopen call.
  * @return rtl_obj* The object file descriptor. NULL is returned if the load fails.
-rtems_rtl_obj_t* rtems_rtl_load_object (const char* name, int mode);
+rtems_rtl_obj* rtems_rtl_load_object (const char* name, int mode);
  * Unload an object file. This only happens when the user count is 0.
@@ -248,7 +248,7 @@ rtems_rtl_obj_t* rtems_rtl_load_object (const char* name, int mode);
  * @retval false The object file could not be unloaded.
-bool rtems_rtl_unload_object (rtems_rtl_obj_t* obj);
+bool rtems_rtl_unload_object (rtems_rtl_obj* obj);
  * Run any constructor functions the object file may contain. This call
@@ -256,7 +256,7 @@ bool rtems_rtl_unload_object (rtems_rtl_obj_t* obj);
-void rtems_rtl_run_ctors (rtems_rtl_obj_t* obj);
+void rtems_rtl_run_ctors (rtems_rtl_obj* obj);
  * Get the last error message clearing it. This operation locks the run time
@@ -309,7 +309,7 @@ void rtems_rtl_base_sym_global_add (const unsigned char* esyms,
  * @return rtl_obj* The object file descriptor for the base image. NULL is
  *                  returned if the load fails.
-rtems_rtl_obj_t* rtems_rtl_baseimage (void);
+rtems_rtl_obj* rtems_rtl_baseimage (void);
 #ifdef __cplusplus
diff --git a/cpukit/libdl/dlfcn-shell.c b/cpukit/libdl/dlfcn-shell.c
index 3746711ef1..539774d6dd 100644
--- a/cpukit/libdl/dlfcn-shell.c
+++ b/cpukit/libdl/dlfcn-shell.c
@@ -1,5 +1,5 @@
@@ -98,7 +98,7 @@ shell_dlsym (int argc, char* argv[])
   return -1;
-typedef int (*call_t)(int argc, char* argv[]);
+typedef int (*call_p)(int argc, char* argv[]);
 int
 shell_dlcall (int argc, char* argv[])
@@ -106,7 +106,7 @@ shell_dlcall (int argc, char* argv[])
   void* value;
   if (lookup_dlsym (&value, argc, argv))
-    call_t call = value;
+    call_p call = value;
     int    r;
     printf ("(*%p)(%d, ....)\n", value, argc - 3);
     r = call (argc - 3, argv + 3);
diff --git a/cpukit/libdl/dlfcn.c b/cpukit/libdl/dlfcn.c
index 3b31bb2e8e..1d7164539b 100644
--- a/cpukit/libdl/dlfcn.c
+++ b/cpukit/libdl/dlfcn.c
@@ -1,5 +1,5 @@
@@ -19,10 +19,10 @@
 #include <dlfcn.h>
 #include <rtems/rtl/rtl.h>
-static rtems_rtl_obj_t*
+static rtems_rtl_obj*
 dl_get_obj_from_handle (void* handle)
    * Handle the special cases provided in NetBSD and Sun documentation.
@@ -43,7 +43,7 @@ dl_get_obj_from_handle (void* handle)
 void*
 dlopen (const char* name, int mode)
-  rtems_rtl_obj_t* obj = NULL;
+  rtems_rtl_obj* obj = NULL;
   if (!rtems_rtl_lock ())
     return NULL;
@@ -67,8 +67,8 @@ dlopen (const char* name, int mode)
 int
 dlclose (void* handle)
-  int              r;
+  int            r;
     return -1;
@@ -96,9 +96,9 @@ dlclose (void* handle)
 void*
 dlsym (void* handle, const char *symbol)
-  rtems_rtl_obj_sym_t* sym = NULL;
-  void*                symval = NULL;
+  rtems_rtl_obj_sym* sym = NULL;
+  void*              symval = NULL;
     return NULL;
@@ -136,8 +136,8 @@ dlerror (void)
 int
 dlinfo (void* handle, int request, void* p)
-  int              rc = -1;
+  int            rc = -1;
   if (!rtems_rtl_lock () || !p)
     return -1;
diff --git a/cpukit/libdl/rap.c b/cpukit/libdl/rap.c
index bb42072b21..ff945314ce 100644
--- a/cpukit/libdl/rap.c
+++ b/cpukit/libdl/rap.c
@@ -1,5 +1,5 @@
@@ -44,18 +44,18 @@ typedef struct rtems_rap_data_s
   rtems_chain_control apps;           /**< List if loaded application. */
-} rtems_rap_data_t;
+} rtems_rap_data;
  * The RAP file data. This structure is allocated on the heap when a file is
  * loaded.
-typedef struct rtems_rap_app_s
+typedef struct rtems_rap_app
   const char*      name;         /**< The file name */
   void*            handle;       /**< The dlopen handle. */
-} rtems_rap_app_t;
+} rtems_rap_app;
  * RTL entry.
@@ -69,7 +69,7 @@ typedef struct rtems_rap_app_s
  * Static RAP data is returned to the user when the loader is locked.
-static rtems_rap_data_t rap_ = { .once = PTHREAD_ONCE_INIT };
+static rtems_rap_data rap_ = { .once = PTHREAD_ONCE_INIT };
  * Verbose level for the RAP loader.
@@ -79,7 +79,7 @@ static bool rap_verbose;
  * RAP entry call signature.
-typedef int (*rtems_rap_entry_t)(int argc, const char* argv[]);
+typedef int (*rtems_rap_entry)(int argc, const char* argv[]);
  * Forward decl.
@@ -100,7 +100,7 @@ rtems_rap_data_init (void)
   rtems_chain_initialize_empty (&rap_.apps);
-static rtems_rap_data_t*
+static rtems_rap_data*
 rtems_rap_lock (void)
   pthread_once (&rap_.once, rtems_rap_data_init);
@@ -115,10 +115,10 @@ rtems_rap_unlock (void)
   rtems_mutex_unlock (&rap_.lock);
-static rtems_rap_app_t*
+static rtems_rap_app*
 rtems_rap_check_handle (void* handle)
-  rtems_rap_app_t*  app;
+  rtems_rap_app*    app;
   rtems_chain_node* node;
   app = handle;
@@ -126,7 +126,7 @@ rtems_rap_check_handle (void* handle)
   while (!rtems_chain_is_tail (&rap_.apps, node))
-    rtems_rap_app_t* check = (rtems_rap_app_t*) node;
+    rtems_rap_app* check = (rtems_rap_app*) node;
     if (check == app)
       return app;
     node = rtems_chain_next (node);
@@ -135,17 +135,17 @@ rtems_rap_check_handle (void* handle)
   return NULL;
 rtems_rap_app_alloc (void)
-  rtems_rap_app_t* app = malloc (sizeof (rtems_rap_app_t));
-  memset (app, 0, sizeof (rtems_rap_app_t));
+  rtems_rap_app* app = malloc (sizeof (rtems_rap_app));
+  memset (app, 0, sizeof (rtems_rap_app));
   rtems_chain_append (&rap_.apps, &app->node);
   return app;
 static void
-rtems_rap_app_free (rtems_rap_app_t* app)
+rtems_rap_app_free (rtems_rap_app* app)
   if (app->handle)
@@ -158,7 +158,7 @@ rtems_rap_app_free (rtems_rap_app_t* app)
 static bool
-rtems_rap_match_name (rtems_rap_app_t* app, const char* name)
+rtems_rap_match_name (rtems_rap_app* app, const char* name)
   const char* a;
@@ -211,8 +211,8 @@ rtems_rap_get_rtl_error (void)
 static void
 rtems_rap_set_error (int error, const char* format, ...)
-  rtems_rap_data_t* rap = rtems_rap_lock ();
-  va_list           ap;
+  rtems_rap_data* rap = rtems_rap_lock ();
+  va_list         ap;
   va_start (ap, format);
   rap->last_errno = error;
   vsnprintf (rap->last_error, sizeof (rap->last_error), format, ap);
@@ -223,7 +223,7 @@ rtems_rap_set_error (int error, const char* format, ...)
 bool
 rtems_rap_load (const char* name, int mode, int argc, const char* argv[])
   if (!rap)
     return false;
@@ -236,11 +236,11 @@ rtems_rap_load (const char* name, int mode, int argc, const char* argv[])
   if (!rtems_rap_find (name))
-    rtems_rap_entry_t init;
-    rtems_rap_entry_t fini;
-    size_t            size = 0;
-    int               r;
+    rtems_rap_entry init;
+    rtems_rap_entry fini;
+    size_t          size = 0;
+    int             r;
      * Allocate a new application descriptor and attempt to load it.
@@ -309,9 +309,9 @@ rtems_rap_load (const char* name, int mode, int argc, const char* argv[])
 bool
 rtems_rap_unload (const char* name)
-  int               r;
+  int             r;
   rtems_rap_lock ();
@@ -352,14 +352,14 @@ rtems_rap_unload (const char* name)
 void*
   node = rtems_chain_first (&rap->apps);
   while (!rtems_chain_is_tail (&rap->apps, node))
-    rtems_rap_app_t* app = (rtems_rap_app_t*) node;
+    rtems_rap_app* app = (rtems_rap_app*) node;
     if (rtems_rap_match_name (app, name))
       rtems_rap_unlock ();
@@ -374,9 +374,9 @@ rtems_rap_find (const char* name)
 bool
-rtems_rap_iterate (rtems_rap_iterator_t iterator)
+rtems_rap_iterate (rtems_rap_iterator iterator)
   bool              result = true;
@@ -384,7 +384,7 @@ rtems_rap_iterate (rtems_rap_iterator_t iterator)
     result = iterator (app);
     if (!result)
       break;
@@ -399,7 +399,7 @@ rtems_rap_iterate (rtems_rap_iterator_t iterator)
 const char*
 rtems_rap_name (void* handle)
-  rtems_rap_app_t* app = rtems_rap_check_handle (handle);
+  rtems_rap_app* app = rtems_rap_check_handle (handle);
   if (app)
     return app->name;
   return NULL;
@@ -408,7 +408,7 @@ rtems_rap_name (void* handle)
 void*
 rtems_rap_dl_handle (void* handle)
   if (app)
     return app->handle;
   return NULL;
@@ -417,8 +417,8 @@ rtems_rap_dl_handle (void* handle)
 int
 rtems_rap_get_error (char* message, size_t max_message)
-  int               last_errno = rap->last_errno;
+  int             last_errno = rap->last_errno;
   strlcpy (message, rap->last_error, max_message);
   return last_errno;
diff --git a/cpukit/libdl/rtl-alloc-heap.c b/cpukit/libdl/rtl-alloc-heap.c
index 44a4816c5d..2483e89fed 100644
--- a/cpukit/libdl/rtl-alloc-heap.c
+++ b/cpukit/libdl/rtl-alloc-heap.c
@@ -18,10 +18,10 @@
 #include "rtl-alloc-heap.h"
 void
-rtems_rtl_alloc_heap (bool                  allocate,
-                      void**                address,
-                      size_t                size)
+rtems_rtl_alloc_heap (bool                allocate,
+                      void**              address,
+                      size_t              size)
   if (allocate)
     *address = malloc (size);
diff --git a/cpukit/libdl/rtl-alloc-heap.h b/cpukit/libdl/rtl-alloc-heap.h
index d9276553e4..befcad19b0 100644
--- a/cpukit/libdl/rtl-alloc-heap.h
+++ b/cpukit/libdl/rtl-alloc-heap.h
@@ -1,5 +1,5 @@
@@ -35,10 +35,10 @@ extern "C" {
-void rtems_rtl_alloc_heap(bool                  allocate,
-                          void**                address,
-                          size_t                size);
+void rtems_rtl_alloc_heap(bool                allocate,
+                          void**              address,
+                          size_t              size);
 #ifdef __cplusplus
diff --git a/cpukit/libdl/rtl-allocator.c b/cpukit/libdl/rtl-allocator.c
index 575ce5356e..605cdbde83 100644
--- a/cpukit/libdl/rtl-allocator.c
+++ b/cpukit/libdl/rtl-allocator.c
@@ -1,5 +1,5 @@
@@ -39,7 +39,7 @@ static const char* tag_labels[6] =
 #endif
 void
-rtems_rtl_alloc_initialise (rtems_rtl_alloc_data_t* data)
+rtems_rtl_alloc_initialise (rtems_rtl_alloc_data* data)
   int c;
   data->allocator = rtems_rtl_alloc_heap;
@@ -48,10 +48,10 @@ rtems_rtl_alloc_initialise (rtems_rtl_alloc_data_t* data)
 void*
-rtems_rtl_alloc_new (rtems_rtl_alloc_tag_t tag, size_t size, bool zero)
+rtems_rtl_alloc_new (rtems_rtl_alloc_tag tag, size_t size, bool zero)
-  rtems_rtl_data_t* rtl = rtems_rtl_lock ();
-  void*             address = NULL;
+  rtems_rtl_data* rtl = rtems_rtl_lock ();
+  void*           address = NULL;
    * Obtain memory from the allocator. The address field is set by the
@@ -76,9 +76,9 @@ rtems_rtl_alloc_new (rtems_rtl_alloc_tag_t tag, size_t size, bool zero)
 void
-rtems_rtl_alloc_del (rtems_rtl_alloc_tag_t tag, void* address)
+rtems_rtl_alloc_del (rtems_rtl_alloc_tag tag, void* address)
   if (rtems_rtl_trace (RTEMS_RTL_TRACE_ALLOCATOR))
     printf ("rtl: alloc: del: %s addr=%p\n",
@@ -90,22 +90,22 @@ rtems_rtl_alloc_del (rtems_rtl_alloc_tag_t tag, void* address)
   rtems_rtl_unlock ();
-rtems_rtl_alloc_hook (rtems_rtl_allocator_t handler)
+rtems_rtl_alloc_hook (rtems_rtl_allocator handler)
-  rtems_rtl_allocator_t previous = rtl->allocator.allocator;
+  rtems_rtl_allocator previous = rtl->allocator.allocator;
   rtl->allocator.allocator = handler;
   return previous;
 void
-rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag_t tag,
-                              size_t                size)
+rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag tag,
+                              size_t              size)
@@ -118,7 +118,7 @@ rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag_t tag,
   if (rtl)
-    rtems_rtl_alloc_data_t* allocator = &rtl->allocator;
+    rtems_rtl_alloc_data* allocator = &rtl->allocator;
     handle->pointer = rtems_rtl_alloc_new (tag, size, false);
     if (!rtems_rtl_ptr_null (handle))
       rtems_chain_append_unprotected (&allocator->indirects[tag],
@@ -129,10 +129,10 @@ rtems_rtl_alloc_indirect_new (rtems_rtl_alloc_tag_t tag,
 void
-rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag_t tag,
+rtems_rtl_alloc_indirect_del (rtems_rtl_alloc_tag tag,
diff --git a/cpukit/libdl/rtl-debugger.c b/cpukit/libdl/rtl-debugger.c
index 1ba826f669..92ab98e3c5 100644
--- a/cpukit/libdl/rtl-debugger.c
+++ b/cpukit/libdl/rtl-debugger.c
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2012 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2012, 2018 Chris Johns <chrisj at rtems.org>
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -43,7 +43,7 @@ _rtld_debug_state (void)
 int
-_rtld_linkmap_add (rtems_rtl_obj_t* obj)
+_rtld_linkmap_add (rtems_rtl_obj* obj)
   struct link_map* l = obj->linkmap;
   struct link_map* prev;
@@ -76,7 +76,7 @@ _rtld_linkmap_add (rtems_rtl_obj_t* obj)
 void
-_rtld_linkmap_delete (rtems_rtl_obj_t* obj)
+_rtld_linkmap_delete (rtems_rtl_obj* obj)
diff --git a/cpukit/libdl/rtl-elf.c b/cpukit/libdl/rtl-elf.c
index 47c92d5f39..53f43aaeac 100644
--- a/cpukit/libdl/rtl-elf.c
+++ b/cpukit/libdl/rtl-elf.c
@@ -1,5 +1,5 @@
+ *  COPYRIGHT (c) 2012-2018 Chris Johns <chrisj at rtems.org>
@@ -43,7 +43,7 @@
  * The ELF format signature.
-static rtems_rtl_loader_format_t elf_sig =
+static rtems_rtl_loader_format elf_sig =
   .label = "ELF",
   .flags = RTEMS_RTL_FMT_ELF
@@ -65,19 +65,19 @@ rtems_rtl_elf_machine_check (Elf_Ehdr* ehdr)
 bool
-rtems_rtl_elf_find_symbol (rtems_rtl_obj_t* obj,
-                           const Elf_Sym*   sym,
-                           const char*      symname,
-                           Elf_Word*        value)
+rtems_rtl_elf_find_symbol (rtems_rtl_obj* obj,
+                           const Elf_Sym* sym,
+                           const char*    symname,
+                           Elf_Word*      value)
-  rtems_rtl_obj_sect_t* sect;
+  rtems_rtl_obj_sect* sect;
   if (ELF_ST_TYPE(sym->st_info) == STT_NOTYPE)
      * Search the object file then the global table for the symbol.
-    rtems_rtl_obj_sym_t* symbol = rtems_rtl_symbol_obj_find (obj, symname);
+    rtems_rtl_obj_sym* symbol = rtems_rtl_symbol_obj_find (obj, symname);
     if (!symbol)
       rtems_rtl_set_error (EINVAL, "global symbol not found: %s", symname);
@@ -100,20 +100,20 @@ rtems_rtl_elf_find_symbol (rtems_rtl_obj_t* obj,
 static bool
-rtems_rtl_elf_relocator (rtems_rtl_obj_t*      obj,
-                         int                   fd,
-                         void*                 data)
+rtems_rtl_elf_relocator (rtems_rtl_obj*      obj,
+                         int                 fd,
+                         void*               data)
-  rtems_rtl_obj_cache_t* symbols;
-  rtems_rtl_obj_cache_t* strings;
-  rtems_rtl_obj_cache_t* relocs;
-  rtems_rtl_obj_sect_t*  targetsect;
-  rtems_rtl_obj_sect_t*  symsect;
-  rtems_rtl_obj_sect_t*  strtab;
-  bool                   is_rela;
-  size_t                 reloc_size;
-  int                    reloc;
+  rtems_rtl_obj_cache* symbols;
+  rtems_rtl_obj_cache* strings;
+  rtems_rtl_obj_cache* relocs;
+  rtems_rtl_obj_sect*  targetsect;
+  rtems_rtl_obj_sect*  symsect;
+  rtems_rtl_obj_sect*  strtab;
+  bool                 is_rela;
+  size_t               reloc_size;
+  int                  reloc;
    * First check if the section the relocations are for exists. If it does not
@@ -215,8 +215,8 @@ rtems_rtl_elf_relocator (rtems_rtl_obj_t*      obj,
       if (!rtems_rtl_elf_find_symbol (obj, &sym, symname, &symvalue))
-        uint16_t         flags = 0;
-        rtems_rtl_word_t rel_words[3];
+        uint16_t       flags = 0;
+        rtems_rtl_word rel_words[3];
         relocate = false;
@@ -282,12 +282,12 @@ rtems_rtl_elf_relocator (rtems_rtl_obj_t*      obj,
 bool
-rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t* reloc,
+rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc* reloc,
-  bool                  is_rela;
-  Elf_Word              symvalue;
+  bool                is_rela;
+  Elf_Word            symvalue;
   is_rela =reloc->flags & 1;
@@ -338,23 +338,23 @@ rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t* reloc,
 static bool
-rtems_rtl_elf_symbols (rtems_rtl_obj_t*      obj,
-                       int                   fd,
-                       void*                 data)
+rtems_rtl_elf_symbols (rtems_rtl_obj*      obj,
+                       int                 fd,
+                       void*               data)
-  int                    locals;
-  int                    local_string_space;
-  rtems_rtl_obj_sym_t*   lsym;
-  char*                  lstring;
-  int                    globals;
-  int                    global_string_space;
-  rtems_rtl_obj_sym_t*   gsym;
-  char*                  gstring;
-  int                    sym;
+  int                  locals;
+  int                  local_string_space;
+  rtems_rtl_obj_sym*   lsym;
+  char*                lstring;
+  int                  globals;
+  int                  global_string_space;
+  rtems_rtl_obj_sym*   gsym;
+  char*                gstring;
+  int                  sym;
   strtab = rtems_rtl_obj_find_section (obj, ".strtab");
   if (!strtab)
@@ -408,7 +408,7 @@ rtems_rtl_elf_symbols (rtems_rtl_obj_t*      obj,
          (ELF_ST_TYPE (symbol.st_info) == STT_FUNC) ||
          (ELF_ST_TYPE (symbol.st_info) == STT_NOTYPE)))
       symsect = rtems_rtl_obj_find_section_by_index (obj, symbol.st_shndx);
       if (symsect)
@@ -446,7 +446,7 @@ rtems_rtl_elf_symbols (rtems_rtl_obj_t*      obj,
   if (locals)
-    obj->local_size = locals * sizeof (rtems_rtl_obj_sym_t) + local_string_space;
+    obj->local_size = locals * sizeof (rtems_rtl_obj_sym) + local_string_space;
     obj->local_table = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_SYMBOL,
                                             obj->local_size, true);
     if (!obj->local_table)
@@ -461,7 +461,7 @@ rtems_rtl_elf_symbols (rtems_rtl_obj_t*      obj,
   if (globals)
-    obj->global_size = globals * sizeof (rtems_rtl_obj_sym_t) + global_string_space;
+    obj->global_size = globals * sizeof (rtems_rtl_obj_sym) + global_string_space;
     obj->global_table = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_SYMBOL,
                                              obj->global_size, true);
     if (!obj->global_table)
@@ -482,10 +482,10 @@ rtems_rtl_elf_symbols (rtems_rtl_obj_t*      obj,
   lsym = obj->local_table;
   lstring =
-    (((char*) obj->local_table) + (locals * sizeof (rtems_rtl_obj_sym_t)));
+    (((char*) obj->local_table) + (locals * sizeof (rtems_rtl_obj_sym)));
   gsym = obj->global_table;
   gstring =
-    (((char*) obj->global_table) + (globals * sizeof (rtems_rtl_obj_sym_t)));
+    (((char*) obj->global_table) + (globals * sizeof (rtems_rtl_obj_sym)));
   for (sym = 0; sym < (sect->size / sizeof (Elf_Sym)); ++sym)
@@ -530,9 +530,9 @@ rtems_rtl_elf_symbols (rtems_rtl_obj_t*      obj,
           (ELF_ST_BIND (symbol.st_info) == STB_WEAK) ||
           (ELF_ST_BIND (symbol.st_info) == STB_LOCAL)))
-        rtems_rtl_obj_sym_t*  osym;
-        char*                 string;
+        rtems_rtl_obj_sym*  osym;
+        char*               string;
         if (symsect)
@@ -578,10 +578,10 @@ rtems_rtl_elf_symbols (rtems_rtl_obj_t*      obj,
 static bool
-rtems_rtl_elf_loader (rtems_rtl_obj_t*      obj,
-                      int                   fd,
-                      void*                 data)
+rtems_rtl_elf_loader (rtems_rtl_obj*      obj,
+                      int                 fd,
+                      void*               data)
   uint8_t* base_offset;
   size_t   len;
@@ -611,14 +611,14 @@ rtems_rtl_elf_loader (rtems_rtl_obj_t*      obj,
 static bool
-rtems_rtl_elf_parse_sections (rtems_rtl_obj_t* obj, int fd, Elf_Ehdr* ehdr)
+rtems_rtl_elf_parse_sections (rtems_rtl_obj* obj, int fd, Elf_Ehdr* ehdr)
-  rtems_rtl_obj_cache_t* sects;
-  int                    section;
-  off_t                  sectstroff;
-  off_t                  off;
-  Elf_Shdr               shdr;
+  rtems_rtl_obj_cache* sects;
+  int                  section;
+  off_t                sectstroff;
+  off_t                off;
+  Elf_Shdr             shdr;
   rtems_rtl_obj_caches (&sects, &strings, NULL);
@@ -772,10 +772,10 @@ rtems_rtl_elf_parse_sections (rtems_rtl_obj_t* obj, int fd, Elf_Ehdr* ehdr)
 bool
-rtems_rtl_elf_file_check (rtems_rtl_obj_t* obj, int fd)
+rtems_rtl_elf_file_check (rtems_rtl_obj* obj, int fd)
-  rtems_rtl_obj_cache_t* header;
-  Elf_Ehdr               ehdr;
+  rtems_rtl_obj_cache* header;
+  Elf_Ehdr             ehdr;
   rtems_rtl_obj_caches (&header, NULL, NULL);
@@ -803,7 +803,7 @@ rtems_rtl_elf_file_check (rtems_rtl_obj_t* obj, int fd)
 static bool
-rtems_rtl_elf_load_linkmap (rtems_rtl_obj_t* obj)
+rtems_rtl_elf_load_linkmap (rtems_rtl_obj* obj)
   rtems_chain_control* sections = NULL;
   rtems_chain_node*    node = NULL;
@@ -824,7 +824,7 @@ rtems_rtl_elf_load_linkmap (rtems_rtl_obj_t* obj)
     node = rtems_chain_first (sections);
     while (!rtems_chain_is_tail (sections, node))
-      rtems_rtl_obj_sect_t* sect = (rtems_rtl_obj_sect_t*) node;
+      rtems_rtl_obj_sect* sect = (rtems_rtl_obj_sect*) node;
       if ((sect->size != 0) && ((sect->flags & mask) != 0))
         ++sec_num;
@@ -867,7 +867,7 @@ rtems_rtl_elf_load_linkmap (rtems_rtl_obj_t* obj)
@@ -904,10 +904,10 @@ rtems_rtl_elf_load_linkmap (rtems_rtl_obj_t* obj)
 bool
-rtems_rtl_elf_file_load (rtems_rtl_obj_t* obj, int fd)
+rtems_rtl_elf_file_load (rtems_rtl_obj* obj, int fd)
-  Elf_Ehdr               ehdr;
+  Elf_Ehdr             ehdr;
@@ -994,13 +994,13 @@ rtems_rtl_elf_file_load (rtems_rtl_obj_t* obj, int fd)
 bool
-rtems_rtl_elf_file_unload (rtems_rtl_obj_t* obj)
+rtems_rtl_elf_file_unload (rtems_rtl_obj* obj)
   rtems_rtl_elf_unwind_deregister (obj);
   return true;
-rtems_rtl_loader_format_t*
+rtems_rtl_loader_format*
 rtems_rtl_elf_file_sig (void)
   return &elf_sig;
diff --git a/cpukit/libdl/rtl-elf.h b/cpukit/libdl/rtl-elf.h
index abe0889fae..5d560a0b34 100644
--- a/cpukit/libdl/rtl-elf.h
+++ b/cpukit/libdl/rtl-elf.h
@@ -1,5 +1,5 @@
@@ -67,8 +67,8 @@ extern "C" {
  * @retval 0 Unknown or unsupported flags.
  * @retval uint32_t RTL object file flags.
-uint32_t rtems_rtl_elf_section_flags (const rtems_rtl_obj_t* obj,
-                                      const Elf_Shdr*        shdr);
+uint32_t rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
+                                      const Elf_Shdr*      shdr);
  * Architecture specific handler to check is a relocation record's type is
@@ -94,12 +94,12 @@ bool rtems_rtl_elf_rel_resolve_sym (Elf_Word type);
  * @retval bool The relocation has been applied.
  * @retval bool The relocation could not be applied.
-bool rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t*      obj,
-                                 const Elf_Rel*              rel,
-                                 const rtems_rtl_obj_sect_t* sect,
-                                 const Elf_Byte              syminfo,
-                                 const Elf_Word              symvalue);
+bool rtems_rtl_elf_relocate_rel (const rtems_rtl_obj*      obj,
+                                 const Elf_Rel*            rel,
+                                 const rtems_rtl_obj_sect* sect,
+                                 const Elf_Byte            syminfo,
+                                 const Elf_Word            symvalue);
  * Architecture specific relocation handler compiled in for a specific
@@ -115,12 +115,12 @@ bool rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t*      obj,
-bool rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
-                                  const Elf_Rela*             rela,
+bool rtems_rtl_elf_relocate_rela (const rtems_rtl_obj*      obj,
+                                  const Elf_Rela*           rela,
  * Find the symbol. The symbol is passed as an ELF type symbol with the name
@@ -139,10 +139,10 @@ bool rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
  * @retval true The symbol resolved.
  * @retval false The symbol could not be result. The RTL error is set.
-bool rtems_rtl_elf_find_symbol (rtems_rtl_obj_t* obj,
-                                Elf_Word*        value);
+bool rtems_rtl_elf_find_symbol (rtems_rtl_obj* obj,
+                                Elf_Word*      value);
  * The ELF format check handler.
@@ -150,7 +150,7 @@ bool rtems_rtl_elf_find_symbol (rtems_rtl_obj_t* obj,
  * @param obj The object being checked.
  * @param fd The file descriptor.
-bool rtems_rtl_elf_file_check (rtems_rtl_obj_t* obj, int fd);
+bool rtems_rtl_elf_file_check (rtems_rtl_obj* obj, int fd);
  * The ELF format load handler.
@@ -158,21 +158,21 @@ bool rtems_rtl_elf_file_check (rtems_rtl_obj_t* obj, int fd);
  * @param obj The object to load.
-bool rtems_rtl_elf_file_load (rtems_rtl_obj_t* obj, int fd);
+bool rtems_rtl_elf_file_load (rtems_rtl_obj* obj, int fd);
  * The ELF format unload handler.
  * @param obj The object to unload.
-bool rtems_rtl_elf_file_unload (rtems_rtl_obj_t* obj);
+bool rtems_rtl_elf_file_unload (rtems_rtl_obj* obj);
  * The ELF format signature handler.
- * @return rtems_rtl_loader_format_t* The format's signature.
+ * @return rtems_rtl_loader_format* The format's signature.
-rtems_rtl_loader_format_t* rtems_rtl_elf_file_sig (void);
+rtems_rtl_loader_format* rtems_rtl_elf_file_sig (void);
 #ifdef __cplusplus
diff --git a/cpukit/libdl/rtl-error.c b/cpukit/libdl/rtl-error.c
index 5638b88705..7b72c0a26d 100644
--- a/cpukit/libdl/rtl-error.c
+++ b/cpukit/libdl/rtl-error.c
@@ -1,5 +1,5 @@
@@ -28,8 +28,8 @@
 void
 rtems_rtl_set_error (int error, const char* format, ...)
-  va_list           ap;
+  va_list         ap;
   rtl->last_errno = error;
   vsnprintf (rtl->last_error, sizeof (rtl->last_error), format, ap);
@@ -40,7 +40,7 @@ rtems_rtl_set_error (int error, const char* format, ...)
 int
 rtems_rtl_get_error (char* message, size_t max_message)
   if (rtl != NULL)
     int last_errno = rtl->last_errno;
diff --git a/cpukit/libdl/rtl-error.h b/cpukit/libdl/rtl-error.h
index 0badf51e21..576384ed5d 100644
--- a/cpukit/libdl/rtl-error.h
+++ b/cpukit/libdl/rtl-error.h
@@ -27,7 +27,7 @@ extern "C" {
 #endif
- * Sets the error.
+ * Sets the error.
  * Assumes the RTL has been locked.
diff --git a/cpukit/libdl/rtl-mdreloc-arm.c b/cpukit/libdl/rtl-mdreloc-arm.c
index 7b47345427..96e14fc676 100644
--- a/cpukit/libdl/rtl-mdreloc-arm.c
+++ b/cpukit/libdl/rtl-mdreloc-arm.c
@@ -67,8 +67,8 @@ sign_extend31(Elf_Addr val)
 uint32_t
-rtems_rtl_elf_section_flags (const rtems_rtl_obj_t* obj,
+rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
   uint32_t flags = 0;
   if (shdr->sh_type == SHT_ARM_EXIDX)
@@ -83,24 +83,24 @@ rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
 bool
-rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
+rtems_rtl_elf_relocate_rela (const rtems_rtl_obj*      obj,
   rtems_rtl_set_error (EINVAL, "rela type record not supported");
   return false;
 bool
-rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t*      obj,
+rtems_rtl_elf_relocate_rel (const rtems_rtl_obj*      obj,
   Elf_Addr *where;
   Elf_Addr tmp;
@@ -357,9 +357,9 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t*      obj,
 bool
-rtems_rtl_elf_unwind_parse (const rtems_rtl_obj_t* obj,
-                            const char*            name,
-                            uint32_t               flags)
+rtems_rtl_elf_unwind_parse (const rtems_rtl_obj* obj,
+                            const char*          name,
+                            uint32_t             flags)
    * We location the EH sections in section flags.
@@ -368,13 +368,13 @@ rtems_rtl_elf_unwind_parse (const rtems_rtl_obj_t* obj,
 bool
-rtems_rtl_elf_unwind_register (rtems_rtl_obj_t* obj)
+rtems_rtl_elf_unwind_register (rtems_rtl_obj* obj)
   return true;
 bool
-rtems_rtl_elf_unwind_deregister (rtems_rtl_obj_t* obj)
+rtems_rtl_elf_unwind_deregister (rtems_rtl_obj* obj)
   obj->loader = NULL;
   return true;
@@ -406,7 +406,7 @@ _Unwind_Ptr __gnu_Unwind_Find_exidx (_Unwind_Ptr return_address,
                                      int*        nrec)
-  rtems_rtl_data_t* rtl;
+  rtems_rtl_data*   rtl;
   __EIT_entry*      exidx_start = &__exidx_start;
   __EIT_entry*      exidx_end = &__exidx_end;
@@ -415,7 +415,7 @@ _Unwind_Ptr __gnu_Unwind_Find_exidx (_Unwind_Ptr return_address,
   node = rtems_chain_first (&rtl->objects);
   while (!rtems_chain_is_tail (&rtl->objects, node)) {
-    rtems_rtl_obj_t* obj = (rtems_rtl_obj_t*) node;
+    rtems_rtl_obj* obj = (rtems_rtl_obj*) node;
     if (rtems_rtl_obj_text_inside (obj, (void*) return_address)) {
       exidx_start = (__EIT_entry*) obj->eh_base;
       exidx_end = (__EIT_entry*) (obj->eh_base + obj->eh_size);
diff --git a/cpukit/libdl/rtl-mdreloc-bfin.c b/cpukit/libdl/rtl-mdreloc-bfin.c
index b6542c38a6..e1190046a3 100644
--- a/cpukit/libdl/rtl-mdreloc-bfin.c
+++ b/cpukit/libdl/rtl-mdreloc-bfin.c
@@ -33,17 +33,17 @@ load_ptr(void *where)
 bool
-  Elf_Addr	target = 0;
-  Elf_Addr	*where;
-  Elf_Word	tmp;
-  Elf_Word	size; //byte
+  Elf_Addr target = 0;
+  Elf_Addr *where;
+  Elf_Word tmp;
+  Elf_Word size; //byte
   where = (Elf_Addr *)(sect->base + rela->r_offset);
@@ -112,33 +112,33 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
 bool
   rtems_rtl_set_error (EINVAL, "rel type record not supported");
   return false;
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
   return rtems_rtl_elf_unwind_dw2_parse (obj, name, flags);
 bool
   return rtems_rtl_elf_unwind_dw2_register (obj);
 bool
   return rtems_rtl_elf_unwind_dw2_deregister (obj);
diff --git a/cpukit/libdl/rtl-mdreloc-h8300.c b/cpukit/libdl/rtl-mdreloc-h8300.c
index ddc0dc160f..54af83973f 100644
--- a/cpukit/libdl/rtl-mdreloc-h8300.c
+++ b/cpukit/libdl/rtl-mdreloc-h8300.c
@@ -13,8 +13,8 @@
 #include "rtl-unwind-dw2.h"
 uint32_t
   return 0;
@@ -26,15 +26,15 @@ rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
 bool
-  Elf_Addr	*where;
-  Elf_Word	tmp;
+  Elf_Addr *where;
+  Elf_Word tmp;
@@ -98,33 +98,33 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
 bool
   return false;
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-i386.c b/cpukit/libdl/rtl-mdreloc-i386.c
index c653274a90..f0aa61b8ee 100644
--- a/cpukit/libdl/rtl-mdreloc-i386.c
+++ b/cpukit/libdl/rtl-mdreloc-i386.c
@@ -19,8 +19,8 @@
 uint32_t
   return 0;
@@ -32,26 +32,26 @@ rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
 bool
-                             const Elf_Rela*             rel,
+                             const Elf_Rela*           rel,
   return false;
 bool
   Elf_Addr* where;
   Elf_Addr  tmp;
@@ -112,21 +112,21 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t*      obj,
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-lm32.c b/cpukit/libdl/rtl-mdreloc-lm32.c
index 6175585ccd..ad59ec2e09 100644
--- a/cpukit/libdl/rtl-mdreloc-lm32.c
+++ b/cpukit/libdl/rtl-mdreloc-lm32.c
@@ -13,8 +13,8 @@
 uint32_t
   return 0;
@@ -26,12 +26,12 @@ rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
 bool
   Elf_Addr *where;
   Elf32_Word tmp;
@@ -117,33 +117,33 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
 bool
   return false;
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-m68k.c b/cpukit/libdl/rtl-mdreloc-m68k.c
index 5df739aa5b..f42899b118 100644
--- a/cpukit/libdl/rtl-mdreloc-m68k.c
+++ b/cpukit/libdl/rtl-mdreloc-m68k.c
@@ -33,8 +33,8 @@ static inline int overflow_16_check(int value)
 uint32_t
   return 0;
@@ -46,14 +46,14 @@ rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
 bool
-                             const char*                 symnane,
+                             const char*               symnane,
   Elf_Addr* where;
   Elf_Word  tmp;
@@ -145,33 +145,33 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
 bool
   return false;
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-mips.c b/cpukit/libdl/rtl-mdreloc-mips.c
index 360719e157..7ad18b382f 100644
--- a/cpukit/libdl/rtl-mdreloc-mips.c
+++ b/cpukit/libdl/rtl-mdreloc-mips.c
@@ -13,8 +13,8 @@
 uint32_t
   return 0;
 bool
   return false;
@@ -46,12 +46,12 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
  * just consider symtype here.
 bool
   Elf_Addr *where;
   Elf_Word  tmp;
@@ -199,21 +199,21 @@ rtems_rtl_elf_relocate_rel (const rtems_rtl_obj_t*      obj,
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-moxie.c b/cpukit/libdl/rtl-mdreloc-moxie.c
index dc41a30679..68cbeeceb2 100644
--- a/cpukit/libdl/rtl-mdreloc-moxie.c
+++ b/cpukit/libdl/rtl-mdreloc-moxie.c
@@ -14,8 +14,8 @@
 uint32_t
   return 0;
@@ -27,12 +27,12 @@ rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
 bool
   Elf_Addr *where;
   Elf_Sword tmp;
@@ -85,33 +85,33 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
 bool
   return false;
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-powerpc.c b/cpukit/libdl/rtl-mdreloc-powerpc.c
index 06854a9028..e59c415828 100644
--- a/cpukit/libdl/rtl-mdreloc-powerpc.c
+++ b/cpukit/libdl/rtl-mdreloc-powerpc.c
@@ -24,8 +24,8 @@
 #define l(x) ((u_int32_t)(x) & 0xffff)
 uint32_t
   return 0;
@@ -37,12 +37,12 @@ rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
 bool
   Elf_Addr* where;
   Elf_Word tmp;
@@ -198,33 +198,33 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
 bool
   printf ("rtl: rel type record not supported; please report\n");
   return false;
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-sparc.c b/cpukit/libdl/rtl-mdreloc-sparc.c
index e4143a91bd..6bc62d5692 100644
--- a/cpukit/libdl/rtl-mdreloc-sparc.c
+++ b/cpukit/libdl/rtl-mdreloc-sparc.c
@@ -131,8 +131,8 @@ static const int reloc_target_bitmask[] = {
 #define RELOC_VALUE_BITMASK(t)  (reloc_target_bitmask[t])
 uint32_t
   return 0;
@@ -144,12 +144,12 @@ rtems_rtl_elf_rel_resolve_sym (Elf_Word type)
 bool
   Elf_Addr *where;
   Elf_Word type, value, mask;
@@ -260,33 +260,33 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
 bool
   return false;
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-mdreloc-v850.c b/cpukit/libdl/rtl-mdreloc-v850.c
index f00c07febb..cc2a1fa10e 100644
--- a/cpukit/libdl/rtl-mdreloc-v850.c
+++ b/cpukit/libdl/rtl-mdreloc-v850.c
@@ -14,8 +14,8 @@
 uint32_t
   return 0;
 bool
   Elf_Addr *where;
   Elf_Word tmp;
@@ -94,33 +94,33 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
 bool
   return false;
 bool
-                            const char*            name,
-                            uint32_t               flags)
+                            const char*          name,
+                            uint32_t             flags)
 bool
 bool
diff --git a/cpukit/libdl/rtl-obj-cache.c b/cpukit/libdl/rtl-obj-cache.c
index 00a2417f45..06ef8db384 100644
--- a/cpukit/libdl/rtl-obj-cache.c
+++ b/cpukit/libdl/rtl-obj-cache.c
@@ -1,5 +1,5 @@
@@ -31,7 +31,7 @@
 #include <rtems/rtl/rtl-trace.h>
 bool
-rtems_rtl_obj_cache_open (rtems_rtl_obj_cache_t* cache, size_t size)
+rtems_rtl_obj_cache_open (rtems_rtl_obj_cache* cache, size_t size)
   cache->fd        = -1;
   cache->file_size = 0;
@@ -48,7 +48,7 @@ rtems_rtl_obj_cache_open (rtems_rtl_obj_cache_t* cache, size_t size)
 void
-rtems_rtl_obj_cache_close (rtems_rtl_obj_cache_t* cache)
+rtems_rtl_obj_cache_close (rtems_rtl_obj_cache* cache)
   if (rtems_rtl_trace (RTEMS_RTL_TRACE_CACHE))
     printf ("rtl: cache: %2d: close\n", cache->fd);
@@ -60,7 +60,7 @@ rtems_rtl_obj_cache_close (rtems_rtl_obj_cache_t* cache)
 void
-rtems_rtl_obj_cache_flush (rtems_rtl_obj_cache_t* cache)
+rtems_rtl_obj_cache_flush (rtems_rtl_obj_cache* cache)
     printf ("rtl: cache: %2d: flush\n", cache->fd);
@@ -71,11 +71,11 @@ rtems_rtl_obj_cache_flush (rtems_rtl_obj_cache_t* cache)
 bool
-rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
-                          int                    fd,
-                          off_t                  offset,
-                          void**                 buffer,
-                          size_t*                length)
+rtems_rtl_obj_cache_read (rtems_rtl_obj_cache* cache,
+                          int                  fd,
+                          off_t                offset,
+                          void**               buffer,
+                          size_t*              length)
   struct stat sb;
@@ -238,11 +238,11 @@ rtems_rtl_obj_cache_read (rtems_rtl_obj_cache_t* cache,
 bool
-rtems_rtl_obj_cache_read_byval (rtems_rtl_obj_cache_t* cache,
-                                int                    fd,
-                                off_t                  offset,
-                                void*                  buffer,
-                                size_t                 length)
+rtems_rtl_obj_cache_read_byval (rtems_rtl_obj_cache* cache,
+                                int                  fd,
+                                off_t                offset,
+                                void*                buffer,
+                                size_t               length)
   void*  cbuffer = 0;
   size_t len = length;
diff --git a/cpukit/libdl/rtl-obj-comp.c b/cpukit/libdl/rtl-obj-comp.c
index c49f614368..bf9a2fc45f 100644
--- a/cpukit/libdl/rtl-obj-comp.c
+++ b/cpukit/libdl/rtl-obj-comp.c
@@ -1,5 +1,5 @@
@@ -31,8 +31,8 @@
 bool
-rtems_rtl_obj_comp_open (rtems_rtl_obj_comp_t*  comp,
-                         size_t                 size)
+rtems_rtl_obj_comp_open (rtems_rtl_obj_comp* comp,
+                         size_t              size)
   comp->cache  = NULL;
   comp->fd = -1;
@@ -51,7 +51,7 @@ rtems_rtl_obj_comp_open (rtems_rtl_obj_comp_t*  comp,
 void
-rtems_rtl_obj_comp_close (rtems_rtl_obj_comp_t* comp)
+rtems_rtl_obj_comp_close (rtems_rtl_obj_comp* comp)
   rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, comp->buffer);
   comp->cache = NULL;
@@ -64,11 +64,11 @@ rtems_rtl_obj_comp_close (rtems_rtl_obj_comp_t* comp)
 void
-rtems_rtl_obj_comp_set (rtems_rtl_obj_comp_t*  comp,
-                        rtems_rtl_obj_cache_t* cache,
-                        int                    fd,
-                        int                    compression,
-                        off_t                  offset)
+rtems_rtl_obj_comp_set (rtems_rtl_obj_comp*  comp,
+                        rtems_rtl_obj_cache* cache,
+                        int                  fd,
+                        int                  compression,
+                        off_t                offset)
   comp->cache = cache;
   comp->fd = fd;
@@ -79,9 +79,9 @@ rtems_rtl_obj_comp_set (rtems_rtl_obj_comp_t*  comp,
 bool
-rtems_rtl_obj_comp_read (rtems_rtl_obj_comp_t* comp,
-                         void*                 buffer,
-                         size_t                length)
+rtems_rtl_obj_comp_read (rtems_rtl_obj_comp* comp,
+                         void*               buffer,
+                         size_t              length)
   uint8_t* bin = buffer;
diff --git a/cpukit/libdl/rtl-obj.c b/cpukit/libdl/rtl-obj.c
index dd9a1cdcdc..5c2213e611 100644
--- a/cpukit/libdl/rtl-obj.c
+++ b/cpukit/libdl/rtl-obj.c
@@ -1,5 +1,5 @@
@@ -51,7 +51,7 @@
  * The table of supported loader formats.
 #define RTEMS_RTL_LOADERS (RTEMS_RTL_ELF_LOADER_COUNT + RTEMS_RTL_RAP_LOADER_COUNT)
-static const rtems_rtl_loader_table_t loaders[RTEMS_RTL_LOADERS] =
+static const rtems_rtl_loader_table loaders[RTEMS_RTL_LOADERS] =
 #if RTEMS_RTL_RAP_LOADER
   { .check     = rtems_rtl_rap_file_check,
@@ -68,12 +68,12 @@ static const rtems_rtl_loader_table_t loaders[RTEMS_RTL_LOADERS] =
 #endif
-rtems_rtl_obj_t*
+rtems_rtl_obj*
-  rtems_rtl_obj_t* obj = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
-                                              sizeof (rtems_rtl_obj_t),
-                                              true);
+  rtems_rtl_obj* obj = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
+                                            sizeof (rtems_rtl_obj),
+                                            true);
   if (obj)
@@ -89,7 +89,7 @@ rtems_rtl_obj_alloc (void)
 static void
-rtems_rtl_obj_free_names (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_free_names (rtems_rtl_obj* obj)
   if (rtems_rtl_obj_oname_valid (obj))
     rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, (void*) obj->oname);
@@ -100,7 +100,7 @@ rtems_rtl_obj_free_names (rtems_rtl_obj_t* obj)
 bool
-rtems_rtl_obj_free (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_free (rtems_rtl_obj* obj)
   if (obj->users || ((obj->flags & RTEMS_RTL_OBJ_LOCKED) != 0))
@@ -122,7 +122,7 @@ rtems_rtl_obj_free (rtems_rtl_obj_t* obj)
 bool
-rtems_rtl_obj_unresolved (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_unresolved (rtems_rtl_obj* obj)
   return (obj->flags & RTEMS_RTL_OBJ_UNRESOLVED) != 0 ? true : false;
@@ -208,7 +208,7 @@ rtems_rtl_parse_name (const char*  name,
 static bool
-rtems_rtl_obj_parse_name (rtems_rtl_obj_t* obj, const char* name)
+rtems_rtl_obj_parse_name (rtems_rtl_obj* obj, const char* name)
   return rtems_rtl_parse_name (name, &(obj->aname), &(obj->oname), &(obj->ooffset));
@@ -262,13 +262,13 @@ typedef struct
   uint32_t mask; /**< The selection mask to sum. */
   size_t   size; /**< The size of all section fragments. */
-} rtems_rtl_obj_sect_summer_t;
+} rtems_rtl_obj_sect_summer_data;
 static bool
 rtems_rtl_obj_sect_summer (rtems_chain_node* node, void* data)
-  rtems_rtl_obj_sect_summer_t* summer = data;
+  rtems_rtl_obj_sect_summer_data* summer = data;
   if ((sect->flags & summer->mask) == summer->mask)
     summer->size =
       rtems_rtl_sect_align (summer->size, sect->alignment) + sect->size;
@@ -276,9 +276,9 @@ rtems_rtl_obj_sect_summer (rtems_chain_node* node, void* data)
 static size_t
-rtems_rtl_obj_section_size (const rtems_rtl_obj_t* obj, uint32_t mask)
+rtems_rtl_obj_section_size (const rtems_rtl_obj* obj, uint32_t mask)
-  rtems_rtl_obj_sect_summer_t summer;
+  rtems_rtl_obj_sect_summer_data summer;
   summer.mask = mask;
   summer.size = 0;
   rtems_rtl_chain_iterate ((rtems_chain_control*) &obj->sections,
@@ -295,7 +295,7 @@ typedef struct
   uint32_t mask;      /**< The selection mask to look for alignment. */
   uint32_t alignment; /**< The alignment of the section type. */
-} rtems_rtl_obj_sect_aligner_t;
+} rtems_rtl_obj_sect_aligner_data;
  * The section aligner iterator.
@@ -303,8 +303,8 @@ typedef struct
 static bool
 rtems_rtl_obj_sect_aligner (rtems_chain_node* node, void* data)
-  rtems_rtl_obj_sect_aligner_t* aligner = data;
+  rtems_rtl_obj_sect_aligner_data* aligner = data;
   if ((sect->flags & aligner->mask) == aligner->mask)
     aligner->alignment = sect->alignment;
@@ -314,9 +314,9 @@ rtems_rtl_obj_sect_aligner (rtems_chain_node* node, void* data)
 static size_t
-rtems_rtl_obj_section_alignment (const rtems_rtl_obj_t* obj, uint32_t mask)
+rtems_rtl_obj_section_alignment (const rtems_rtl_obj* obj, uint32_t mask)
-  rtems_rtl_obj_sect_aligner_t aligner;
+  rtems_rtl_obj_sect_aligner_data aligner;
   aligner.mask = mask;
   aligner.alignment = 0;
@@ -326,16 +326,16 @@ rtems_rtl_obj_section_alignment (const rtems_rtl_obj_t* obj, uint32_t mask)
 static bool
-rtems_rtl_obj_section_handler (uint32_t                     mask,
-                               rtems_rtl_obj_t*             obj,
-                               int                          fd,
-                               void*                        data)
+rtems_rtl_obj_section_handler (uint32_t                   mask,
+                               rtems_rtl_obj*             obj,
+                               int                        fd,
+                               void*                      data)
   rtems_chain_node* node = rtems_chain_first (&obj->sections);
   while (!rtems_chain_is_tail (&obj->sections, node))
     if ((sect->flags & mask) != 0)
       if (!handler (obj, fd, sect, data))
@@ -347,7 +347,7 @@ rtems_rtl_obj_section_handler (uint32_t                     mask,
 bool
-rtems_rtl_match_name (rtems_rtl_obj_t* obj, const char* name)
+rtems_rtl_match_name (rtems_rtl_obj* obj, const char* name)
   const char* n1 = obj->oname;
   while ((*n1 != '\0') && (*n1 != '\n') && (*n1 != '/') &&
@@ -363,10 +363,10 @@ rtems_rtl_match_name (rtems_rtl_obj_t* obj, const char* name)
 bool
-rtems_rtl_obj_find_file (rtems_rtl_obj_t* obj, const char* name)
+rtems_rtl_obj_find_file (rtems_rtl_obj* obj, const char* name)
-  const char*       pname;
+  const char*     pname;
    * Parse the name. The object descriptor will have the archive name and/or
@@ -403,21 +403,21 @@ rtems_rtl_obj_find_file (rtems_rtl_obj_t* obj, const char* name)
 bool
-rtems_rtl_obj_add_section (rtems_rtl_obj_t* obj,
-                           int              section,
-                           const char*      name,
-                           size_t           size,
-                           off_t            offset,
-                           uint32_t         alignment,
-                           int              link,
-                           int              info,
-                           uint32_t         flags)
+rtems_rtl_obj_add_section (rtems_rtl_obj* obj,
+                           int            section,
+                           const char*    name,
+                           size_t         size,
+                           off_t          offset,
+                           uint32_t       alignment,
+                           int            link,
+                           int            info,
+                           uint32_t       flags)
   if (size > 0)
-    rtems_rtl_obj_sect_t* sect = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
-                                                      sizeof (rtems_rtl_obj_sect_t),
-                                                      true);
+    rtems_rtl_obj_sect* sect = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_OBJECT,
+                                                    sizeof (rtems_rtl_obj_sect),
+                                                    true);
     if (!sect)
       rtems_rtl_set_error (ENOMEM, "adding allocated section");
@@ -442,13 +442,13 @@ rtems_rtl_obj_add_section (rtems_rtl_obj_t* obj,
 void
-rtems_rtl_obj_erase_sections (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_erase_sections (rtems_rtl_obj* obj)
-    rtems_chain_node*     next_node = rtems_chain_next (node);
+    rtems_chain_node*   next_node = rtems_chain_next (node);
     rtems_chain_extract (node);
     rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, (void*) sect->name);
     rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_OBJECT, sect);
@@ -461,16 +461,16 @@ rtems_rtl_obj_erase_sections (rtems_rtl_obj_t* obj)
 typedef struct
-  rtems_rtl_obj_sect_t*  sect;  /**< The matching section. */
-  const char*            name;  /**< The name to match. */
-  int                    index; /**< The index to match. */
-} rtems_rtl_obj_sect_finder_t;
+  rtems_rtl_obj_sect*  sect;  /**< The matching section. */
+  const char*          name;  /**< The name to match. */
+  int                  index; /**< The index to match. */
+} rtems_rtl_obj_sect_finder;
 static bool
 rtems_rtl_obj_sect_match_name (rtems_chain_node* node, void* data)
-  rtems_rtl_obj_sect_finder_t* match = data;
+  rtems_rtl_obj_sect_finder* match = data;
   if (strcmp (sect->name, match->name) == 0)
     match->sect = sect;
@@ -479,11 +479,11 @@ rtems_rtl_obj_sect_match_name (rtems_chain_node* node, void* data)
   return true;
-rtems_rtl_obj_sect_t*
-rtems_rtl_obj_find_section (const rtems_rtl_obj_t* obj,
-                            const char*            name)
+rtems_rtl_obj_sect*
+rtems_rtl_obj_find_section (const rtems_rtl_obj* obj,
+                            const char*          name)
-  rtems_rtl_obj_sect_finder_t match;
+  rtems_rtl_obj_sect_finder match;
   match.sect = NULL;
   match.name = name;
@@ -495,8 +495,8 @@ rtems_rtl_obj_find_section (const rtems_rtl_obj_t* obj,
 static bool
 rtems_rtl_obj_sect_match_index (rtems_chain_node* node, void* data)
   if (sect->section == match->index)
     match->sect = sect;
@@ -505,11 +505,11 @@ rtems_rtl_obj_sect_match_index (rtems_chain_node* node, void* data)
   return true;
-rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj_t* obj,
-                                     int                    index)
+rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj* obj,
+                                     int                  index)
   match.sect = NULL;
   match.index = index;
@@ -519,70 +519,70 @@ rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj_t* obj,
 size_t
-rtems_rtl_obj_text_size (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_text_size (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_TEXT);
 uint32_t
-rtems_rtl_obj_text_alignment (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_text_alignment (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_TEXT);
 size_t
-rtems_rtl_obj_const_size (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_const_size (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_CONST);
 uint32_t
-rtems_rtl_obj_eh_alignment (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_eh_alignment (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_EH);
 size_t
-rtems_rtl_obj_eh_size (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_eh_size (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_EH);
 uint32_t
-rtems_rtl_obj_const_alignment (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_const_alignment (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_CONST);
 size_t
-rtems_rtl_obj_data_size (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_data_size (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_DATA);
 uint32_t
-rtems_rtl_obj_data_alignment (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_data_alignment (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_DATA);
 size_t
-rtems_rtl_obj_bss_size (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_bss_size (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_size (obj, RTEMS_RTL_OBJ_SECT_BSS);
 uint32_t
-rtems_rtl_obj_bss_alignment (const rtems_rtl_obj_t* obj)
+rtems_rtl_obj_bss_alignment (const rtems_rtl_obj* obj)
   return rtems_rtl_obj_section_alignment (obj, RTEMS_RTL_OBJ_SECT_BSS);
 bool
-rtems_rtl_obj_relocate (rtems_rtl_obj_t*             obj,
-                        int                          fd,
-                        rtems_rtl_obj_sect_handler_t handler,
-                        void*                        data)
+rtems_rtl_obj_relocate (rtems_rtl_obj*             obj,
+                        int                        fd,
+                        rtems_rtl_obj_sect_handler handler,
+                        void*                      data)
   uint32_t mask = RTEMS_RTL_OBJ_SECT_REL | RTEMS_RTL_OBJ_SECT_RELA;
   return rtems_rtl_obj_section_handler (mask, obj, fd, handler, data);
@@ -597,15 +597,15 @@ typedef struct
   void     *start_va;
   void     *end_va;
   size_t   cache_line_size;
-} rtems_rtl_obj_sect_sync_ctx_t;
+} rtems_rtl_obj_sect_sync_ctx;
 static bool
 rtems_rtl_obj_sect_sync_handler (rtems_chain_node* node, void* data)
-  rtems_rtl_obj_sect_sync_ctx_t* sync_ctx = data;
-  uintptr_t                      old_end;
-  uintptr_t                      new_start;
+  rtems_rtl_obj_sect_sync_ctx* sync_ctx = data;
+  uintptr_t                    old_end;
+  uintptr_t                    new_start;
   if ((sect->flags & sync_ctx->mask) == 0 || sect->size == 0)
     return true;
@@ -633,9 +633,9 @@ rtems_rtl_obj_sect_sync_handler (rtems_chain_node* node, void* data)
 void
-rtems_rtl_obj_synchronize_cache (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_synchronize_cache (rtems_rtl_obj* obj)
-  rtems_rtl_obj_sect_sync_ctx_t sync_ctx;
+  rtems_rtl_obj_sect_sync_ctx sync_ctx;
   if (rtems_cache_get_instruction_line_size() == 0)
     return;
@@ -659,19 +659,19 @@ rtems_rtl_obj_synchronize_cache (rtems_rtl_obj_t* obj)
 bool
-rtems_rtl_obj_load_symbols (rtems_rtl_obj_t*             obj,
-                            int                          fd,
-                            void*                        data)
+rtems_rtl_obj_load_symbols (rtems_rtl_obj*             obj,
+                            int                        fd,
+                            void*                      data)
   uint32_t mask = RTEMS_RTL_OBJ_SECT_SYM;
 static int
-rtems_rtl_obj_sections_linked_to_order (rtems_rtl_obj_t* obj,
-                                        int              section,
-                                        uint32_t         visited_mask)
+rtems_rtl_obj_sections_linked_to_order (rtems_rtl_obj* obj,
+                                        int            section,
+                                        uint32_t       visited_mask)
   rtems_chain_control* sections = &obj->sections;
   rtems_chain_node*    node = rtems_chain_first (sections);
@@ -681,7 +681,7 @@ rtems_rtl_obj_sections_linked_to_order (rtems_rtl_obj_t* obj,
     if (sect->section == section)
       const uint32_t mask = sect->flags & RTEMS_RTL_OBJ_SECT_TYPES;
@@ -704,7 +704,7 @@ rtems_rtl_obj_sections_linked_to_order (rtems_rtl_obj_t* obj,
-        sect = (rtems_rtl_obj_sect_t*) node;
+        sect = (rtems_rtl_obj_sect*) node;
         if ((sect->flags & mask) == mask)
@@ -721,14 +721,14 @@ rtems_rtl_obj_sections_linked_to_order (rtems_rtl_obj_t* obj,
 static void
-rtems_rtl_obj_sections_link_order (uint32_t mask, rtems_rtl_obj_t* obj)
+rtems_rtl_obj_sections_link_order (uint32_t mask, rtems_rtl_obj* obj)
   int                  order = 0;
@@ -750,12 +750,12 @@ rtems_rtl_obj_sections_link_order (uint32_t mask, rtems_rtl_obj_t* obj)
 static size_t
-rtems_rtl_obj_sections_loader (uint32_t                     mask,
-                               int                          fd,
-                               uint8_t*                     base,
-                               void*                        data)
+rtems_rtl_obj_sections_loader (uint32_t                   mask,
+                               int                        fd,
+                               uint8_t*                   base,
+                               void*                      data)
@@ -765,7 +765,7 @@ rtems_rtl_obj_sections_loader (uint32_t                     mask,
@@ -819,10 +819,10 @@ rtems_rtl_obj_sections_loader (uint32_t                     mask,
 bool
-rtems_rtl_obj_load_sections (rtems_rtl_obj_t*             obj,
-                             int                          fd,
-                             void*                        data)
+rtems_rtl_obj_load_sections (rtems_rtl_obj*             obj,
+                             int                        fd,
+                             void*                      data)
   size_t text_size;
   size_t const_size;
@@ -907,17 +907,17 @@ rtems_rtl_obj_load_sections (rtems_rtl_obj_t*             obj,
 static void
-rtems_rtl_obj_run_cdtors (rtems_rtl_obj_t* obj, uint32_t mask)
+rtems_rtl_obj_run_cdtors (rtems_rtl_obj* obj, uint32_t mask)
-      rtems_rtl_cdtor_t* handler;
-      size_t             handlers = sect->size / sizeof (rtems_rtl_cdtor_t);
-      int                c;
+      rtems_rtl_cdtor* handler;
+      size_t           handlers = sect->size / sizeof (rtems_rtl_cdtor);
+      int              c;
       for (c = 0, handler = sect->base; c < handlers; ++c)
         if (*handler)
           (*handler) ();
@@ -927,13 +927,13 @@ rtems_rtl_obj_run_cdtors (rtems_rtl_obj_t* obj, uint32_t mask)
 void
-rtems_rtl_obj_run_ctors (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_run_ctors (rtems_rtl_obj* obj)
   return rtems_rtl_obj_run_cdtors (obj, RTEMS_RTL_OBJ_SECT_CTOR);
 void
-rtems_rtl_obj_run_dtors (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_run_dtors (rtems_rtl_obj* obj)
   return rtems_rtl_obj_run_cdtors (obj, RTEMS_RTL_OBJ_SECT_DTOR);
@@ -943,7 +943,7 @@ rtems_rtl_obj_run_dtors (rtems_rtl_obj_t* obj)
  * object descriptor.
 static bool
-rtems_rtl_obj_archive_find (rtems_rtl_obj_t* obj, int fd)
+rtems_rtl_obj_archive_find (rtems_rtl_obj* obj, int fd)
 #define RTEMS_RTL_AR_IDENT      "!<arch>\n"
 #define RTEMS_RTL_AR_IDENT_SIZE (sizeof (RTEMS_RTL_AR_IDENT) - 1)
@@ -1167,11 +1167,11 @@ rtems_rtl_obj_archive_find (rtems_rtl_obj_t* obj, int fd)
 static bool
-rtems_rtl_obj_file_load (rtems_rtl_obj_t* obj, int fd)
+rtems_rtl_obj_file_load (rtems_rtl_obj* obj, int fd)
   int l;
-  for (l = 0; l < (sizeof (loaders) / sizeof (rtems_rtl_loader_table_t)); ++l)
+  for (l = 0; l < (sizeof (loaders) / sizeof (rtems_rtl_loader_table)); ++l)
     if (loaders[l].check (obj, fd))
@@ -1185,7 +1185,7 @@ rtems_rtl_obj_file_load (rtems_rtl_obj_t* obj, int fd)
 static bool
-rtems_rtl_obj_file_unload (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_file_unload (rtems_rtl_obj* obj)
   if (obj->format >= 0 && obj->format < RTEMS_RTL_LOADERS)
       return loaders[obj->format].unload (obj);
@@ -1193,7 +1193,7 @@ rtems_rtl_obj_file_unload (rtems_rtl_obj_t* obj)
 bool
-rtems_rtl_obj_load (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_load (rtems_rtl_obj* obj)
   int fd;
@@ -1244,7 +1244,7 @@ rtems_rtl_obj_load (rtems_rtl_obj_t* obj)
 bool
-rtems_rtl_obj_unload (rtems_rtl_obj_t* obj)
+rtems_rtl_obj_unload (rtems_rtl_obj* obj)
   _rtld_linkmap_delete(obj);
   rtems_rtl_obj_file_unload (obj);
diff --git a/cpukit/libdl/rtl-rap.c b/cpukit/libdl/rtl-rap.c
index 59b3801f76..afbc268be6 100644
--- a/cpukit/libdl/rtl-rap.c
+++ b/cpukit/libdl/rtl-rap.c
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2012-2013 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2012-2013, 2018 Chris Johns <chrisj at rtems.org>
@@ -45,7 +45,7 @@
-static rtems_rtl_loader_format_t rap_sig =
+static rtems_rtl_loader_format rap_sig =
   .label = "RAP",
   .flags = RTEMS_RTL_FMT_COMP
@@ -54,11 +54,11 @@ static rtems_rtl_loader_format_t rap_sig =
  * The section definitions found in a RAP file.
-typedef struct rtems_rtl_rap_sectdef_s
+typedef struct rtems_rtl_rap_sectdef
   const char*    name;    /**< Name of the section. */
   const uint32_t flags;   /**< Section flags. */
-} rtems_rtl_rap_sectdef_t;
+} rtems_rtl_rap_sectdef;
  * The section indexes. These are fixed.
@@ -74,7 +74,7 @@ typedef struct rtems_rtl_rap_sectdef_s
  * The sections as loaded from a RAP file.
-static const rtems_rtl_rap_sectdef_t rap_sections[RTEMS_RTL_RAP_SECS] =
+static const rtems_rtl_rap_sectdef rap_sections[RTEMS_RTL_RAP_SECS] =
   { ".text",  RTEMS_RTL_OBJ_SECT_TEXT  | RTEMS_RTL_OBJ_SECT_LOAD },
   { ".const", RTEMS_RTL_OBJ_SECT_CONST | RTEMS_RTL_OBJ_SECT_LOAD },
@@ -87,38 +87,38 @@ static const rtems_rtl_rap_sectdef_t rap_sections[RTEMS_RTL_RAP_SECS] =
-typedef struct rtems_rtl_rap_section_s
+typedef struct rtems_rtl_rap_section
   uint32_t size;       /**< The size of the section. */
   uint32_t alignment;  /**< The alignment of the section. */
-} rtems_rtl_rap_section_t;
+} rtems_rtl_rap_section;
  * The RAP loader.
-  rtems_rtl_obj_cache_t*  file;         /**< The file cache for the RAP file. */
-  rtems_rtl_obj_comp_t*   decomp;       /**< The decompression streamer. */
-  uint32_t                length;       /**< The file length. */
-  uint32_t                version;      /**< The RAP file version. */
-  uint32_t                compression;  /**< The type of compression. */
-  uint32_t                checksum;     /**< The checksum. */
-  uint32_t                machinetype;  /**< The ELF machine type. */
-  uint32_t                datatype;     /**< The ELF data type. */
-  uint32_t                class;        /**< The ELF class. */
-  uint32_t                init;         /**< The initialisation strtab offset. */
-  uint32_t                fini;         /**< The finish strtab offset. */
-  rtems_rtl_rap_section_t secs[RTEMS_RTL_RAP_SECS]; /**< The sections. */
-  uint32_t                symtab_size;  /**< The symbol table size. */
-  char*                   strtab;       /**< The string table. */
-  uint32_t                strtab_size;  /**< The string table size. */
-  uint32_t                relocs_size;  /**< The relocation table size. */
-  uint32_t                symbols;      /**< The number of symbols. */
-  uint32_t                strtable_size;/**< The size of section names and obj names. */
-  uint32_t                rpathlen;     /**< The length of rpath. */
-  char*                   strtable;     /**< The detail string which resides in obj detail. */
-} rtems_rtl_rap_t;
+  rtems_rtl_obj_cache*  file;         /**< The file cache for the RAP file. */
+  rtems_rtl_obj_comp*   decomp;       /**< The decompression streamer. */
+  uint32_t              length;       /**< The file length. */
+  uint32_t              version;      /**< The RAP file version. */
+  uint32_t              compression;  /**< The type of compression. */
+  uint32_t              checksum;     /**< The checksum. */
+  uint32_t              machinetype;  /**< The ELF machine type. */
+  uint32_t              datatype;     /**< The ELF data type. */
+  uint32_t              class;        /**< The ELF class. */
+  uint32_t              init;         /**< The initialisation strtab offset. */
+  uint32_t              fini;         /**< The finish strtab offset. */
+  rtems_rtl_rap_section secs[RTEMS_RTL_RAP_SECS]; /**< The sections. */
+  uint32_t              symtab_size;  /**< The symbol table size. */
+  char*                 strtab;       /**< The string table. */
+  uint32_t              strtab_size;  /**< The string table size. */
+  uint32_t              relocs_size;  /**< The relocation table size. */
+  uint32_t              symbols;      /**< The number of symbols. */
+  uint32_t              strtable_size;/**< The size of section names and obj names. */
+  uint32_t              rpathlen;     /**< The length of rpath. */
+  char*                 strtable;     /**< The detail string which resides in obj detail. */
+} rtems_rtl_rap;
  * Check the machine type.
@@ -191,7 +191,7 @@ rtems_rtl_rap_get_uint32 (const uint8_t* buffer)
 static bool
-rtems_rtl_rap_read_uint32 (rtems_rtl_obj_comp_t* comp, uint32_t* value)
+rtems_rtl_rap_read_uint32 (rtems_rtl_obj_comp* comp, uint32_t* value)
   uint8_t buffer[sizeof (uint32_t)];
@@ -204,12 +204,12 @@ rtems_rtl_rap_read_uint32 (rtems_rtl_obj_comp_t* comp, uint32_t* value)
 static bool
-rtems_rtl_rap_loader (rtems_rtl_obj_t*      obj,
-                      int                   fd,
-                      rtems_rtl_obj_sect_t* sect,
-                      void*                 data)
+rtems_rtl_rap_loader (rtems_rtl_obj*      obj,
+                      int                 fd,
+                      rtems_rtl_obj_sect* sect,
+                      void*               data)
-  rtems_rtl_rap_t* rap = (rtems_rtl_rap_t*) data;
+  rtems_rtl_rap* rap = (rtems_rtl_rap*) data;
   if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD))
     printf ("rtl: rap: input %s=%" PRIu32 "\n",
@@ -219,7 +219,7 @@ rtems_rtl_rap_loader (rtems_rtl_obj_t*      obj,
 static bool
-rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
+rtems_rtl_rap_relocate (rtems_rtl_rap* rap, rtems_rtl_obj* obj)
   #define SYMNAME_BUFFER_SIZE (1024)
   char*    symname_buffer = NULL;
@@ -237,11 +237,11 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
   for (section = 0; section < RTEMS_RTL_RAP_SECS; ++section)
-    uint32_t               header = 0;
-    int                    relocs;
-    bool                   is_rela;
-    int                    r;
+    uint32_t            header = 0;
+    int                 relocs;
+    bool                is_rela;
+    int                 r;
     targetsect = rtems_rtl_obj_find_section (obj, rap_sections[section].name);
@@ -320,7 +320,7 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
       if ((info & (1 << 31)) == 0)
         symsect = rtems_rtl_obj_find_section_by_index (obj, info >> 8);
         if (!symsect)
@@ -333,7 +333,7 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
       else if (rtems_rtl_elf_rel_resolve_sym (type))
-        rtems_rtl_obj_sym_t* symbol;
+        rtems_rtl_obj_sym* symbol;
         symname_size = (info & ~(3 << 30)) >> 8;
@@ -432,7 +432,7 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
 static bool
-rtems_rtl_rap_load_linkmap (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
+rtems_rtl_rap_load_linkmap (rtems_rtl_rap* rap, rtems_rtl_obj* obj)
   void*            detail;
   struct link_map* tmp1;
@@ -565,13 +565,13 @@ rtems_rtl_rap_load_linkmap (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
 static bool
-rtems_rtl_rap_load_symbols (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
+rtems_rtl_rap_load_symbols (rtems_rtl_rap* rap, rtems_rtl_obj* obj)
-  int                  sym;
+  int                sym;
   obj->global_size =
-    rap->symbols * sizeof (rtems_rtl_obj_sym_t) + rap->strtab_size;
+    rap->symbols * sizeof (rtems_rtl_obj_sym) + rap->strtab_size;
@@ -585,7 +585,7 @@ rtems_rtl_rap_load_symbols (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
   obj->global_syms = rap->symbols;
   rap->strtab = (((char*) obj->global_table) +
-                 (rap->symbols * sizeof (rtems_rtl_obj_sym_t)));
+                 (rap->symbols * sizeof (rtems_rtl_obj_sym)));
   if (!rtems_rtl_obj_comp_read (rap->decomp, rap->strtab, rap->strtab_size))
@@ -595,10 +595,10 @@ rtems_rtl_rap_load_symbols (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
   for (sym = 0, gsym = obj->global_table; sym < rap->symbols; ++sym)
-    uint32_t              data;
-    uint32_t              name;
-    uint32_t              value;
+    uint32_t            data;
+    uint32_t            name;
+    uint32_t            value;
     if (!rtems_rtl_rap_read_uint32 (rap->decomp, &data) ||
         !rtems_rtl_rap_read_uint32 (rap->decomp, &name) ||
@@ -756,15 +756,15 @@ rtems_rtl_rap_parse_header (uint8_t*  rhdr,
 bool
-rtems_rtl_rap_file_check (rtems_rtl_obj_t* obj, int fd)
+rtems_rtl_rap_file_check (rtems_rtl_obj* obj, int fd)
-  uint8_t*               rhdr = NULL;
-  size_t                 rlen = 64;
-  uint32_t               length = 0;
-  uint32_t               version = 0;
-  uint32_t               compression = 0;
-  uint32_t               checksum = 0;
+  uint8_t*             rhdr = NULL;
+  size_t               rlen = 64;
+  uint32_t             length = 0;
+  uint32_t             version = 0;
+  uint32_t             compression = 0;
+  uint32_t             checksum = 0;
@@ -784,12 +784,12 @@ rtems_rtl_rap_file_check (rtems_rtl_obj_t* obj, int fd)
 bool
-rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
+rtems_rtl_rap_file_load (rtems_rtl_obj* obj, int fd)
-  rtems_rtl_rap_t rap = { 0 };
-  size_t          rlen = 64;
-  int             section;
+  rtems_rtl_rap rap = { 0 };
+  size_t        rlen = 64;
+  int           section;
   rtems_rtl_obj_caches (&rap.file, NULL, NULL);
@@ -811,8 +811,8 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
    * Set up the decompressor.
-  rtems_rtl_obj_comp (&rap.decomp, rap.file, fd, rap.compression,
-                      rlen + obj->ooffset);
+  rtems_rtl_obj_decompress (&rap.decomp, rap.file, fd, rap.compression,
+                            rlen + obj->ooffset);
    * uint32_t: machinetype
@@ -990,13 +990,13 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
 bool
-rtems_rtl_rap_file_unload (rtems_rtl_obj_t* obj)
+rtems_rtl_rap_file_unload (rtems_rtl_obj* obj)
   (void) obj;
   return true;
 rtems_rtl_rap_file_sig (void)
   return &rap_sig;
diff --git a/cpukit/libdl/rtl-rap.h b/cpukit/libdl/rtl-rap.h
index e96f342cea..ae656c25ca 100644
--- a/cpukit/libdl/rtl-rap.h
+++ b/cpukit/libdl/rtl-rap.h
@@ -1,5 +1,5 @@
@@ -30,7 +30,7 @@ extern "C" {
-bool rtems_rtl_rap_file_check (rtems_rtl_obj_t* obj, int fd);
+bool rtems_rtl_rap_file_check (rtems_rtl_obj* obj, int fd);
  * The RAP format load handler.
@@ -38,21 +38,21 @@ bool rtems_rtl_rap_file_check (rtems_rtl_obj_t* obj, int fd);
-bool rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd);
+bool rtems_rtl_rap_file_load (rtems_rtl_obj* obj, int fd);
  * The RAP format unload handler.
-bool rtems_rtl_rap_file_unload (rtems_rtl_obj_t* obj);
+bool rtems_rtl_rap_file_unload (rtems_rtl_obj* obj);
  * The RAP format signature handler.
-rtems_rtl_loader_format_t* rtems_rtl_rap_file_sig (void);
+rtems_rtl_loader_format* rtems_rtl_rap_file_sig (void);
 #ifdef __cplusplus
diff --git a/cpukit/libdl/rtl-shell.c b/cpukit/libdl/rtl-shell.c
index e1a197ed62..5c144977a0 100644
--- a/cpukit/libdl/rtl-shell.c
+++ b/cpukit/libdl/rtl-shell.c
@@ -1,5 +1,5 @@
@@ -33,17 +33,17 @@
  * The type of the shell handlers we have.
-typedef int (*rtems_rtl_shell_handler_t) (rtems_rtl_data_t* rtl, int argc, char *argv[]);
+typedef int (*rtems_rtl_shell_handler) (rtems_rtl_data* rtl, int argc, char *argv[]);
  * Table of handlers we parse to invoke the command.
 typedef struct
-  const char*               name;    /**< The sub-command's name. */
-  rtems_rtl_shell_handler_t handler; /**< The sub-command's handler. */
-  const char*               help;    /**< The sub-command's help. */
-} rtems_rtl_shell_cmd_t;
+  const char*             name;    /**< The sub-command's name. */
+  rtems_rtl_shell_handler handler; /**< The sub-command's handler. */
+  const char*             help;    /**< The sub-command's help. */
+} rtems_rtl_shell_cmd;
  * Object summary data.
@@ -53,7 +53,7 @@ typedef struct
   int    count;   /**< The number of object files. */
   size_t exec;    /**< The amount of executable memory allocated. */
   size_t symbols; /**< The amount of symbol memory allocated. */
-} rtems_rtl_obj_summary_t;
+} rtems_rtl_obj_summary;
  * Object summary iterator.
@@ -61,8 +61,8 @@ typedef struct
 static bool
 rtems_rtl_obj_summary_iterator (rtems_chain_node* node, void* data)
-  rtems_rtl_obj_summary_t* summary = data;
+  rtems_rtl_obj_summary* summary = data;
   ++summary->count;
   summary->exec += obj->exec_size;
   summary->symbols += obj->global_size;
@@ -73,7 +73,7 @@ rtems_rtl_obj_summary_iterator (rtems_chain_node* node, void* data)
  * Count the number of symbols.
 static int
-rtems_rtl_count_symbols (rtems_rtl_data_t* rtl)
+rtems_rtl_count_symbols (rtems_rtl_data* rtl)
   int count;
   int bucket;
@@ -83,10 +83,10 @@ rtems_rtl_count_symbols (rtems_rtl_data_t* rtl)
 static int
-rtems_rtl_shell_status (rtems_rtl_data_t* rtl, int argc, char *argv[])
+rtems_rtl_shell_status (rtems_rtl_data* rtl, int argc, char *argv[])
-  rtems_rtl_obj_summary_t summary;
-  size_t                  total_memory;
+  rtems_rtl_obj_summary summary;
+  size_t                total_memory;
   summary.count   = 0;
   summary.exec    = 0;
@@ -98,7 +98,7 @@ rtems_rtl_shell_status (rtems_rtl_data_t* rtl, int argc, char *argv[])
    * Currently does not include the name strings in the obj struct.
   total_memory =
-    sizeof (*rtl) + (summary.count * sizeof (rtems_rtl_obj_t)) +
+    sizeof (*rtl) + (summary.count * sizeof (rtems_rtl_obj)) +
     summary.exec + summary.symbols;
   printf ("Runtime Linker Status:\n");
@@ -117,14 +117,14 @@ rtems_rtl_shell_status (rtems_rtl_data_t* rtl, int argc, char *argv[])
 typedef struct
-  rtems_rtl_data_t* rtl; /**< The RTL data. */
-  int  indent;           /**< Spaces to indent. */
-  bool oname;            /**< Print object names. */
-  bool names;            /**< Print details of all names. */
-  bool memory_map;       /**< Print the memory map. */
-  bool symbols;          /**< Print the global symbols. */
-  bool base;             /**< Include the base object file. */
-} rtems_rtl_obj_print_t;
+  rtems_rtl_data* rtl;        /**< The RTL data. */
+  int             indent;     /**< Spaces to indent. */
+  bool            oname;      /**< Print object names. */
+  bool            names;      /**< Print details of all names. */
+  bool            memory_map; /**< Print the memory map. */
+  bool            symbols;    /**< Print the global symbols. */
+  bool            base;       /**< Include the base object file. */
+} rtems_rtl_obj_print;
  * Return the different between 2 void*.
@@ -172,7 +172,7 @@ rtems_rtl_symbols_arg (int argc, char *argv[])
  * Object printer.
 static bool
-rtems_rtl_obj_printer (rtems_rtl_obj_print_t* print, rtems_rtl_obj_t* obj)
+rtems_rtl_obj_printer (rtems_rtl_obj_print* print, rtems_rtl_obj* obj)
   char flags_str[33];
@@ -239,10 +239,10 @@ rtems_rtl_obj_printer (rtems_rtl_obj_print_t* print, rtems_rtl_obj_t* obj)
  * Object unresolved symbols printer.
 static bool
-rtems_rtl_unresolved_printer (rtems_rtl_unresolv_rec_t* rec,
-                              void*                     data)
+rtems_rtl_unresolved_printer (rtems_rtl_unresolv_rec* rec,
+                              void*                   data)
-  rtems_rtl_obj_print_t* print = (rtems_rtl_obj_print_t*) data;
+  rtems_rtl_obj_print* print = (rtems_rtl_obj_print*) data;
   if (rec->type == rtems_rtl_unresolved_name)
     printf ("%-*c%s\n", print->indent + 2, ' ', rec->rec.name.name);
   return false;
@@ -254,15 +254,15 @@ rtems_rtl_unresolved_printer (rtems_rtl_unresolv_rec_t* rec,
 static bool
 rtems_rtl_obj_print_iterator (rtems_chain_node* node, void* data)
-  rtems_rtl_obj_print_t* print = data;
+  rtems_rtl_obj_print* print = data;
   return rtems_rtl_obj_printer (print, obj);
 static int
-rtems_rtl_shell_list (rtems_rtl_data_t* rtl, int argc, char *argv[])
+rtems_rtl_shell_list (rtems_rtl_data* rtl, int argc, char *argv[])
-  rtems_rtl_obj_print_t print;
+  rtems_rtl_obj_print print;
   print.rtl = rtl;
   print.indent = 1;
   print.oname = true;
@@ -277,9 +277,9 @@ rtems_rtl_shell_list (rtems_rtl_data_t* rtl, int argc, char *argv[])
 static int
-rtems_rtl_shell_sym (rtems_rtl_data_t* rtl, int argc, char *argv[])
+rtems_rtl_shell_sym (rtems_rtl_data* rtl, int argc, char *argv[])
   print.rtl = rtl;
   print.indent = 1;
   print.oname = true;
@@ -296,7 +296,7 @@ rtems_rtl_shell_sym (rtems_rtl_data_t* rtl, int argc, char *argv[])
 static int
-rtems_rtl_shell_object (rtems_rtl_data_t* rtl, int argc, char *argv[])
+rtems_rtl_shell_object (rtems_rtl_data* rtl, int argc, char *argv[])
   return 0;
@@ -315,7 +315,7 @@ rtems_rtl_shell_usage (const char* arg)
 int
 rtems_rtl_shell_command (int argc, char* argv[])
-  const rtems_rtl_shell_cmd_t table[] =
+  const rtems_rtl_shell_cmd table[] =
     { "status", rtems_rtl_shell_status,
       "Display the status of the RTL" },
@@ -343,7 +343,7 @@ rtems_rtl_shell_command (int argc, char* argv[])
       case 'l':
         printf ("%s: commands are:\n", argv[0]);
         for (t = 0;
-             t < (sizeof (table) / sizeof (const rtems_rtl_shell_cmd_t));
+             t < (sizeof (table) / sizeof (const rtems_rtl_shell_cmd));
              ++t)
           printf ("  %s\t%s\n", table[t].name, table[t].help);
         return 0;
@@ -358,13 +358,13 @@ rtems_rtl_shell_command (int argc, char* argv[])
   else
     for (t = 0;
          ++t)
       if (strncmp (argv[arg], table[t].name, strlen (argv[arg])) == 0)
-        rtems_rtl_data_t* rtl = rtems_rtl_data ();
-        int               r;
+        int             r;
         if (!rtl)
           printf ("error: cannot lock the linker\n");
diff --git a/cpukit/libdl/rtl-sym.c b/cpukit/libdl/rtl-sym.c
index 17eca99738..c27f2ee676 100644
--- a/cpukit/libdl/rtl-sym.c
+++ b/cpukit/libdl/rtl-sym.c
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2012-2014 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2012-2014, 2018 Chris Johns <chrisj at rtems.org>
@@ -32,7 +32,7 @@
  * The single symbol forced into the global symbol table that is used to load a
  * symbol table from an object file.
-static rtems_rtl_obj_sym_t global_sym_add =
+static rtems_rtl_obj_sym global_sym_add =
   .name  = "rtems_rtl_base_sym_global_add",
   .value = (void*) rtems_rtl_base_sym_global_add
@@ -49,8 +49,8 @@ rtems_rtl_symbol_hash (const char *s)
 static void
-rtems_rtl_symbol_global_insert (rtems_rtl_symbols_t* symbols,
-                                rtems_rtl_obj_sym_t* symbol)
+rtems_rtl_symbol_global_insert (rtems_rtl_symbols* symbols,
+                                rtems_rtl_obj_sym* symbol)
   uint_fast32_t hash = rtems_rtl_symbol_hash (symbol->name);
   rtems_chain_append (&symbols->buckets[hash % symbols->nbuckets],
@@ -58,8 +58,8 @@ rtems_rtl_symbol_global_insert (rtems_rtl_symbols_t* symbols,
 bool
-rtems_rtl_symbol_table_open (rtems_rtl_symbols_t* symbols,
-                             size_t               buckets)
+rtems_rtl_symbol_table_open (rtems_rtl_symbols* symbols,
+                             size_t             buckets)
   symbols->buckets = rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_SYMBOL,
                                           buckets * sizeof (rtems_chain_control),
@@ -77,21 +77,21 @@ rtems_rtl_symbol_table_open (rtems_rtl_symbols_t* symbols,
 void
-rtems_rtl_symbol_table_close (rtems_rtl_symbols_t* symbols)
+rtems_rtl_symbol_table_close (rtems_rtl_symbols* symbols)
   rtems_rtl_alloc_del (RTEMS_RTL_ALLOC_SYMBOL, symbols->buckets);
 bool
-rtems_rtl_symbol_global_add (rtems_rtl_obj_t*     obj,
+rtems_rtl_symbol_global_add (rtems_rtl_obj*       obj,
                              const unsigned char* esyms,
                              unsigned int         size)
-  rtems_rtl_symbols_t* symbols;
-  rtems_rtl_obj_sym_t* sym;
-  size_t               count;
-  size_t               s;
-  uint32_t             marker;
+  rtems_rtl_symbols* symbols;
+  rtems_rtl_obj_sym* sym;
+  size_t             count;
+  size_t             s;
+  uint32_t           marker;
   count = 0;
   s = 0;
@@ -127,7 +127,7 @@ rtems_rtl_symbol_global_add (rtems_rtl_obj_t*     obj,
   if (rtems_rtl_trace (RTEMS_RTL_TRACE_GLOBAL_SYM))
     printf ("rtl: global symbol add: %zi\n", count);
-  obj->global_size = count * sizeof (rtems_rtl_obj_sym_t);
+  obj->global_size = count * sizeof (rtems_rtl_obj_sym);
@@ -172,10 +172,10 @@ rtems_rtl_symbol_global_add (rtems_rtl_obj_t*     obj,
   return true;
-rtems_rtl_obj_sym_t*
+rtems_rtl_obj_sym*
 rtems_rtl_symbol_global_find (const char* name)
   uint_fast32_t        hash;
   rtems_chain_control* bucket;
   rtems_chain_node*    node;
@@ -188,7 +188,7 @@ rtems_rtl_symbol_global_find (const char* name)
   while (!rtems_chain_is_tail (bucket, node))
-    rtems_rtl_obj_sym_t* sym = (rtems_rtl_obj_sym_t*) node;
+    rtems_rtl_obj_sym* sym = (rtems_rtl_obj_sym*) node;
      * Use the hash. I could add this to the symbol but it uses more memory.
@@ -200,11 +200,11 @@ rtems_rtl_symbol_global_find (const char* name)
   return NULL;
-rtems_rtl_symbol_obj_find (rtems_rtl_obj_t* obj, const char* name)
+rtems_rtl_obj_sym*
+rtems_rtl_symbol_obj_find (rtems_rtl_obj* obj, const char* name)
-  size_t               s;
+  size_t             s;
    * Check the object file's symbols first. If not found search the
    * global symbol table.
@@ -225,11 +225,11 @@ rtems_rtl_symbol_obj_find (rtems_rtl_obj_t* obj, const char* name)
 void
-rtems_rtl_symbol_obj_add (rtems_rtl_obj_t* obj)
+rtems_rtl_symbol_obj_add (rtems_rtl_obj* obj)
-  size_t               s;
+  size_t             s;
   symbols = rtems_rtl_global_symbols ();
@@ -238,7 +238,7 @@ rtems_rtl_symbol_obj_add (rtems_rtl_obj_t* obj)
 void
-rtems_rtl_symbol_obj_erase_local (rtems_rtl_obj_t* obj)
+rtems_rtl_symbol_obj_erase_local (rtems_rtl_obj* obj)
   if (obj->local_table)
@@ -250,13 +250,13 @@ rtems_rtl_symbol_obj_erase_local (rtems_rtl_obj_t* obj)
 void
-rtems_rtl_symbol_obj_erase (rtems_rtl_obj_t* obj)
+rtems_rtl_symbol_obj_erase (rtems_rtl_obj* obj)
   rtems_rtl_symbol_obj_erase_local (obj);
   if (obj->global_table)
-    size_t               s;
+    size_t             s;
     for (s = 0, sym = obj->global_table; s < obj->global_syms; ++s, ++sym)
         if (!rtems_chain_is_node_off_chain (&sym->node))
           rtems_chain_extract (&sym->node);
diff --git a/cpukit/libdl/rtl-unresolved.c b/cpukit/libdl/rtl-unresolved.c
index 0e318f4805..7422cee47b 100644
--- a/cpukit/libdl/rtl-unresolved.c
+++ b/cpukit/libdl/rtl-unresolved.c
@@ -1,5 +1,5 @@
@@ -28,16 +28,16 @@
 #include <rtems/rtl/rtl-unresolved.h>
-static rtems_rtl_unresolv_block_t*
-rtems_rtl_unresolved_block_alloc (rtems_rtl_unresolved_t* unresolved)
+static rtems_rtl_unresolv_block*
+rtems_rtl_unresolved_block_alloc (rtems_rtl_unresolved* unresolved)
    * The block header contains a record.
   size_t size =
-    (sizeof(rtems_rtl_unresolv_block_t) +
-     (sizeof(rtems_rtl_unresolv_rec_t) * (unresolved->block_recs - 1)));
-  rtems_rtl_unresolv_block_t* block =
+    (sizeof(rtems_rtl_unresolv_block) +
+     (sizeof(rtems_rtl_unresolv_rec) * (unresolved->block_recs - 1)));
+  rtems_rtl_unresolv_block* block =
     rtems_rtl_alloc_new (RTEMS_RTL_ALLOC_EXTERNAL, size, true);
   if (block)
     rtems_chain_append (&unresolved->blocks, &block->link);
@@ -50,25 +50,25 @@ static size_t
 rtems_rtl_unresolved_name_recs (const char* name)
   size_t length = strlen (name);
-  return ((length + sizeof(rtems_rtl_unresolv_name_t) - 1) /
-          sizeof(rtems_rtl_unresolv_name_t));
+  return ((length + sizeof(rtems_rtl_unresolv_name) - 1) /
+          sizeof(rtems_rtl_unresolv_name));
 static int
-rtems_rtl_unresolved_rec_index (rtems_rtl_unresolv_block_t* block,
-                                rtems_rtl_unresolv_rec_t* rec)
+rtems_rtl_unresolved_rec_index (rtems_rtl_unresolv_block* block,
+                                rtems_rtl_unresolv_rec* rec)
-  return (rec - &block->rec) / sizeof (rtems_rtl_unresolv_rec_t);
+  return (rec - &block->rec) / sizeof (rtems_rtl_unresolv_rec);
-static rtems_rtl_unresolv_rec_t*
-rtems_rtl_unresolved_rec_first (rtems_rtl_unresolv_block_t* block)
+static rtems_rtl_unresolv_rec*
+rtems_rtl_unresolved_rec_first (rtems_rtl_unresolv_block* block)
   return &block->rec;
-rtems_rtl_unresolved_rec_next (rtems_rtl_unresolv_rec_t* rec)
+rtems_rtl_unresolved_rec_next (rtems_rtl_unresolv_rec* rec)
   switch (rec->type)
@@ -84,8 +84,8 @@ rtems_rtl_unresolved_rec_next (rtems_rtl_unresolv_rec_t* rec)
        * Determine how many records the name occupies. Round up.
-      rec += ((rec->rec.name.length + sizeof(rtems_rtl_unresolv_name_t) - 1) /
+      rec += ((rec->rec.name.length + sizeof(rtems_rtl_unresolv_name) - 1) /
       break;
     case rtems_rtl_unresolved_reloc:
@@ -100,23 +100,23 @@ rtems_rtl_unresolved_rec_next (rtems_rtl_unresolv_rec_t* rec)
 static bool
-rtems_rtl_unresolved_rec_is_last (rtems_rtl_unresolv_block_t* block,
+rtems_rtl_unresolved_rec_is_last (rtems_rtl_unresolv_block* block,
   int index = (rec - &block->rec) / sizeof (rec);
   return !rec || (index >= block->recs) || (rec->type == rtems_rtl_unresolved_empty);
-rtems_rtl_unresolved_rec_first_free (rtems_rtl_unresolv_block_t* block)
+rtems_rtl_unresolved_rec_first_free (rtems_rtl_unresolv_block* block)
   return &block->rec + block->recs;
 static int
-rtems_rtl_unresolved_find_name (rtems_rtl_unresolved_t* unresolved,
-                                const char*             name,
-                                bool                    update_refcount)
+rtems_rtl_unresolved_find_name (rtems_rtl_unresolved* unresolved,
+                                const char*           name,
+                                bool                  update_refcount)
   int    index = 1;
@@ -124,8 +124,8 @@ rtems_rtl_unresolved_find_name (rtems_rtl_unresolved_t* unresolved,
   rtems_chain_node* node = rtems_chain_first (&unresolved->blocks);
   while (!rtems_chain_is_tail (&unresolved->blocks, node))
-    rtems_rtl_unresolv_block_t* block = (rtems_rtl_unresolv_block_t*) node;
-    rtems_rtl_unresolv_rec_t* rec = rtems_rtl_unresolved_rec_first (block);
+    rtems_rtl_unresolv_block* block = (rtems_rtl_unresolv_block*) node;
+    rtems_rtl_unresolv_rec* rec = rtems_rtl_unresolved_rec_first (block);
     while (!rtems_rtl_unresolved_rec_is_last (block, rec))
@@ -152,21 +152,21 @@ rtems_rtl_unresolved_find_name (rtems_rtl_unresolved_t* unresolved,
  * Struct to pass relocation data in the interator.
-typedef struct rtems_rtl_unresolved_reloc_data_s
+typedef struct rtems_rtl_unresolved_reloc_data
   uint16_t                  name;     /**< Name index. */
-  rtems_rtl_unresolv_rec_t* name_rec; /**< Name record. */
-  rtems_rtl_obj_sym_t*      sym;      /**< The symbol record. */
-} rtems_rtl_unresolved_reloc_data_t;
+  rtems_rtl_unresolv_rec* name_rec; /**< Name record. */
+  rtems_rtl_obj_sym*      sym;      /**< The symbol record. */
+} rtems_rtl_unresolved_reloc_data;
 static bool
-rtems_rtl_unresolved_resolve_reloc (rtems_rtl_unresolv_rec_t* rec,
-                                    void*                     data)
+rtems_rtl_unresolved_resolve_reloc (rtems_rtl_unresolv_rec* rec,
+                                    void*                   data)
   if (rec->type == rtems_rtl_unresolved_reloc)
-    rtems_rtl_unresolved_reloc_data_t* rd;
-    rd = (rtems_rtl_unresolved_reloc_data_t*) data;
+    rtems_rtl_unresolved_reloc_data* rd;
+    rd = (rtems_rtl_unresolved_reloc_data*) data;
     if (rec->rec.reloc.name == rd->name)
@@ -190,13 +190,13 @@ rtems_rtl_unresolved_resolve_reloc (rtems_rtl_unresolv_rec_t* rec,
 static bool
-rtems_rtl_unresolved_resolve_iterator (rtems_rtl_unresolv_rec_t* rec,
-                                       void*                     data)
+rtems_rtl_unresolved_resolve_iterator (rtems_rtl_unresolv_rec* rec,
+                                       void*                   data)
     ++rd->name;
@@ -223,25 +223,25 @@ rtems_rtl_unresolved_resolve_iterator (rtems_rtl_unresolv_rec_t* rec,
 static void
-rtems_rtl_unresolved_clean_block (rtems_rtl_unresolv_block_t* block,
-                                  rtems_rtl_unresolv_rec_t* rec,
-                                  size_t count,
-                                  size_t recs_per_block)
+rtems_rtl_unresolved_clean_block (rtems_rtl_unresolv_block* block,
+                                  rtems_rtl_unresolv_rec*   rec,
+                                  size_t                    count,
+                                  size_t                    recs_per_block)
   size_t index = rtems_rtl_unresolved_rec_index (block, rec);
   size_t bytes =
-    (block->recs - index - count) * sizeof (rtems_rtl_unresolv_rec_t);
+    (block->recs - index - count) * sizeof (rtems_rtl_unresolv_rec);
   if (bytes)
     memmove (rec, rec + count, bytes);
   --block->recs;
-  bytes = count * sizeof (rtems_rtl_unresolv_rec_t);
+  bytes = count * sizeof (rtems_rtl_unresolv_rec);
   memset (&block->rec + block->recs, 0, bytes);
 static void
 rtems_rtl_unresolved_compact (void)
-  rtems_rtl_unresolved_t* unresolved = rtems_rtl_unresolved ();
+  rtems_rtl_unresolved* unresolved = rtems_rtl_unresolved_unprotected ();
   if (unresolved)
@@ -251,9 +251,9 @@ rtems_rtl_unresolved_compact (void)
     rtems_chain_node* node = rtems_chain_last (&unresolved->blocks);
     while (!rtems_chain_is_head (&unresolved->blocks, node))
-      rtems_chain_node* prev = rtems_chain_previous (node);
+      rtems_chain_node*         prev = rtems_chain_previous (node);
@@ -295,8 +295,8 @@ rtems_rtl_unresolved_compact (void)
 bool
-rtems_rtl_unresolved_table_open (rtems_rtl_unresolved_t* unresolved,
-                                 size_t                  block_recs)
+rtems_rtl_unresolved_table_open (rtems_rtl_unresolved* unresolved,
+                                 size_t                block_recs)
   unresolved->marker = 0xdeadf00d;
   unresolved->block_recs = block_recs;
@@ -305,7 +305,7 @@ rtems_rtl_unresolved_table_open (rtems_rtl_unresolved_t* unresolved,
 void
-rtems_rtl_unresolved_table_close (rtems_rtl_unresolved_t* unresolved)
+rtems_rtl_unresolved_table_close (rtems_rtl_unresolved* unresolved)
@@ -317,17 +317,17 @@ rtems_rtl_unresolved_table_close (rtems_rtl_unresolved_t* unresolved)
 bool
-rtems_rtl_unresolved_interate (rtems_rtl_unresolved_iterator_t iterator,
-                               void*                           data)
+rtems_rtl_unresolved_interate (rtems_rtl_unresolved_iterator iterator,
+                               void*                         data)
   if (unresolved)
@@ -343,24 +343,24 @@ rtems_rtl_unresolved_interate (rtems_rtl_unresolved_iterator_t iterator,
 bool
-rtems_rtl_unresolved_add (rtems_rtl_obj_t*        obj,
-                          const uint16_t          flags,
-                          const char*             name,
-                          const uint16_t          sect,
-                          const rtems_rtl_word_t* rel)
+rtems_rtl_unresolved_add (rtems_rtl_obj*        obj,
+                          const uint16_t        flags,
+                          const char*           name,
+                          const uint16_t        sect,
+                          const rtems_rtl_word* rel)
-  rtems_rtl_unresolved_t* unresolved;
-  rtems_chain_node* node;
-  rtems_rtl_unresolv_block_t* block;
-  rtems_rtl_unresolv_rec_t* rec;
-  int name_index;
-  size_t name_recs;
+  rtems_rtl_unresolved*     unresolved;
+  rtems_chain_node*         node;
+  rtems_rtl_unresolv_block* block;
+  rtems_rtl_unresolv_rec*   rec;
+  int                       name_index;
+  size_t                    name_recs;
   if (rtems_rtl_trace (RTEMS_RTL_TRACE_UNRESOLVED))
     printf ("rtl: unresolv: add: %s(s:%d) -> %s\n",
             rtems_rtl_obj_oname (obj), sect, name);
-  unresolved = rtems_rtl_unresolved ();
+  unresolved = rtems_rtl_unresolved_unprotected ();
   if (!unresolved)
     return false;
@@ -371,7 +371,7 @@ rtems_rtl_unresolved_add (rtems_rtl_obj_t*        obj,
   block = NULL;
-    block = (rtems_rtl_unresolv_block_t*) node;
+    block = (rtems_rtl_unresolv_block*) node;
     if (block->recs < unresolved->block_recs)
       break;
     block = NULL;
@@ -397,7 +397,7 @@ rtems_rtl_unresolved_add (rtems_rtl_obj_t*        obj,
   if (name_index < 0)
-    rtems_rtl_unresolv_block_t* name_block = block;
+    rtems_rtl_unresolv_block* name_block = block;
      * Is there enough room to fit the name ? It not add a new block.
@@ -447,7 +447,7 @@ rtems_rtl_unresolved_add (rtems_rtl_obj_t*        obj,
 void
 rtems_rtl_unresolved_resolve (void)
-  rtems_rtl_unresolved_reloc_data_t rd;
+  rtems_rtl_unresolved_reloc_data rd;
     printf ("rtl: unresolv: global resolve\n");
   rd.name = 0;
@@ -458,15 +458,14 @@ rtems_rtl_unresolved_resolve (void)
 bool
-rtems_rtl_unresolved_remove (rtems_rtl_obj_t*        obj,
-                             const char*             name,
+rtems_rtl_unresolved_remove (rtems_rtl_obj*        obj,
+                             const char*           name,
   if (!unresolved)
     return false;
   return false;
diff --git a/cpukit/libdl/rtl-unwind-dw2.c b/cpukit/libdl/rtl-unwind-dw2.c
index d9237c5b7e..29525db213 100644
--- a/cpukit/libdl/rtl-unwind-dw2.c
+++ b/cpukit/libdl/rtl-unwind-dw2.c
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2012-2016 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2012-2016, 2018 Chris Johns <chrisj at rtems.org>
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -35,9 +35,9 @@ void __register_frame (void *begin);
 void __deregister_frame (void *begin);
 bool
-rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj_t* obj,
-                                const char*            name,
-                                uint32_t               flags)
+rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj* obj,
+                                const char*          name,
+                                uint32_t             flags)
   return
     ((flags & RTEMS_RTL_OBJ_SECT_CONST) != 0) &&
@@ -46,9 +46,9 @@ rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj_t* obj,
 bool
-rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj_t* obj)
+rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj* obj)
-  rtems_rtl_obj_sect_t* sect = rtems_rtl_obj_find_section (obj, ".eh_frame");
+  rtems_rtl_obj_sect* sect = rtems_rtl_obj_find_section (obj, ".eh_frame");
   if (sect != NULL && sect->size > 0 && sect->base != NULL)
@@ -58,9 +58,9 @@ rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj_t* obj)
   return true;
-bool rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj_t* obj)
+bool rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj* obj)
diff --git a/cpukit/libdl/rtl-unwind-dw2.h b/cpukit/libdl/rtl-unwind-dw2.h
index 55b97970c2..ef76a3771b 100644
--- a/cpukit/libdl/rtl-unwind-dw2.h
+++ b/cpukit/libdl/rtl-unwind-dw2.h
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2016 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2016, 2018 Chris Johns <chrisj at rtems.org>
@@ -42,9 +42,9 @@ extern "C" {
  * @retval true The section contains unwind information.
  * @retval false The section does not contain unwind information.
-bool rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj_t* obj,
-				     const char*            name,
-				     uint32_t               flags);
+bool rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj* obj,
+				     const char*          name,
+				     uint32_t             flags);
  * Architecture specific handler to add an object file's unwind information to
@@ -54,7 +54,7 @@ bool rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj_t* obj,
  * @retval true The unwind information has been registered.
  * @retval false The unwind information could not be registered.
-bool rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj_t* obj);
+bool rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj* obj);
  * Architecture specific handler to remove an object file's unwind information
@@ -64,7 +64,7 @@ bool rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj_t* obj);
  * @retval true The unwind information has been deregistered.
  * @retval false The unwind information could not be deregistered.
-bool rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj_t* obj);
+bool rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj* obj);
  * Read signed and unsigned LEB128 values.
diff --git a/cpukit/libdl/rtl-unwind.h b/cpukit/libdl/rtl-unwind.h
index f88787e1ba..36ec5c4a11 100644
--- a/cpukit/libdl/rtl-unwind.h
+++ b/cpukit/libdl/rtl-unwind.h
@@ -1,5 +1,5 @@
@@ -32,9 +32,9 @@ extern "C" {
-bool rtems_rtl_elf_unwind_parse (const rtems_rtl_obj_t* obj,
-                                 const char*            name,
-                                 uint32_t               flags);
+bool rtems_rtl_elf_unwind_parse (const rtems_rtl_obj* obj,
+                                 const char*          name,
+                                 uint32_t             flags);
@@ -44,7 +44,7 @@ bool rtems_rtl_elf_unwind_parse (const rtems_rtl_obj_t* obj,
-bool rtems_rtl_elf_unwind_register (rtems_rtl_obj_t* obj);
+bool rtems_rtl_elf_unwind_register (rtems_rtl_obj* obj);
@@ -54,7 +54,7 @@ bool rtems_rtl_elf_unwind_register (rtems_rtl_obj_t* obj);
-bool rtems_rtl_elf_unwind_deregister (rtems_rtl_obj_t* obj);
+bool rtems_rtl_elf_unwind_deregister (rtems_rtl_obj* obj);
 #ifdef __cplusplus
diff --git a/cpukit/libdl/rtl.c b/cpukit/libdl/rtl.c
index 36641ea83c..628fc771bc 100644
--- a/cpukit/libdl/rtl.c
+++ b/cpukit/libdl/rtl.c
@@ -1,5 +1,5 @@
- *  COPYRIGHT (c) 2012 Chris Johns <chrisj at rtems.org>
+ *  COPYRIGHT (c) 2012, 2018 Chris Johns <chrisj at rtems.org>
@@ -54,8 +54,8 @@
  * Static RTL data is returned to the user when the linker is locked.
-static rtems_rtl_data_t* rtl;
-static bool              rtl_data_init;
+static rtems_rtl_data* rtl;
+static bool            rtl_data_init;
  * Define a default base global symbol loader function that is weak
@@ -101,7 +101,7 @@ rtems_rtl_data_init (void)
        * Always in the heap.
-      rtl = malloc (sizeof (rtems_rtl_data_t));
+      rtl = malloc (sizeof (rtems_rtl_data));
       if (!rtl)
         rtems_libio_unlock ();
@@ -109,7 +109,7 @@ rtems_rtl_data_init (void)
         return false;
-      *rtl = (rtems_rtl_data_t) { 0 };
+      *rtl = (rtems_rtl_data) { 0 };
        * The initialise the allocator data.
@@ -230,13 +230,13 @@ rtems_rtl_data_init (void)
   return true;
-rtems_rtl_data_t*
-rtems_rtl_data (void)
+rtems_rtl_data*
+rtems_rtl_data_unprotected (void)
   return rtl;
-rtems_rtl_symbols_t*
+rtems_rtl_symbols*
 rtems_rtl_global_symbols (void)
   if (!rtl)
@@ -247,8 +247,8 @@ rtems_rtl_global_symbols (void)
   return &rtl->globals;
-rtems_rtl_unresolved_t*
-rtems_rtl_unresolved (void)
+rtems_rtl_unresolved*
+rtems_rtl_unresolved_unprotected (void)
   if (!rtl)
@@ -259,9 +259,9 @@ rtems_rtl_unresolved (void)
 void
-rtems_rtl_obj_caches (rtems_rtl_obj_cache_t** symbols,
-                      rtems_rtl_obj_cache_t** strings,
-                      rtems_rtl_obj_cache_t** relocs)
+rtems_rtl_obj_caches (rtems_rtl_obj_cache** symbols,
+                      rtems_rtl_obj_cache** strings,
+                      rtems_rtl_obj_cache** relocs)
   if (!rtl)
@@ -295,11 +295,11 @@ rtems_rtl_obj_caches_flush (void)
 void
-rtems_rtl_obj_comp (rtems_rtl_obj_comp_t** decomp,
-                    int                    fd,
-                    int                    compression,
-                    off_t                  offset)
+rtems_rtl_obj_decompress (rtems_rtl_obj_comp** decomp,
+                          int                  fd,
+                          int                  compression,
+                          off_t                offset)
   if (!rtl)
@@ -312,7 +312,7 @@ rtems_rtl_obj_comp (rtems_rtl_obj_comp_t** decomp,
-rtems_rtl_data_t*
+rtems_rtl_data*
 rtems_rtl_lock (void)
   if (!rtems_rtl_data_init ())
@@ -329,10 +329,10 @@ rtems_rtl_unlock (void)
   rtems_recursive_mutex_unlock (&rtl->lock);
-rtems_rtl_obj_t*
+rtems_rtl_obj*
 rtems_rtl_check_handle (void* handle)
-  rtems_rtl_obj_t*    obj;
+  rtems_rtl_obj*    obj;
   obj = handle;
@@ -340,7 +340,7 @@ rtems_rtl_check_handle (void* handle)
-    rtems_rtl_obj_t* check = (rtems_rtl_obj_t*) node;
+    rtems_rtl_obj* check = (rtems_rtl_obj*) node;
     if (check == obj)
       return obj;
@@ -349,11 +349,11 @@ rtems_rtl_check_handle (void* handle)
   return NULL;
-rtems_rtl_obj_t*
+rtems_rtl_obj*
 rtems_rtl_find_obj (const char* name)
-  rtems_rtl_obj_t*  found = NULL;
+  rtems_rtl_obj*    found = NULL;
   const char*       aname = NULL;
   const char*       oname = NULL;
   off_t             ooffset;
@@ -365,7 +365,7 @@ rtems_rtl_find_obj (const char* name)
     if ((aname == NULL && strcmp (obj->oname, oname) == 0) ||
         (aname != NULL &&
          strcmp (obj->aname, aname) == 0 && strcmp (obj->oname, oname) == 0))
@@ -385,10 +385,10 @@ rtems_rtl_find_obj (const char* name)
   return found;
-rtems_rtl_obj_t*
+rtems_rtl_obj*
 rtems_rtl_load_object (const char* name, int mode)
     printf ("rtl: loading '%s'\n", name);
@@ -464,7 +464,7 @@ rtems_rtl_load_object (const char* name, int mode)
 bool
-rtems_rtl_unload_object (rtems_rtl_obj_t* obj)
+rtems_rtl_unload_object (rtems_rtl_obj* obj)
   bool ok = true;
@@ -505,7 +505,7 @@ rtems_rtl_unload_object (rtems_rtl_obj_t* obj)
 void
-rtems_rtl_run_ctors (rtems_rtl_obj_t* obj)
+rtems_rtl_run_ctors (rtems_rtl_obj* obj)
   rtems_rtl_obj_run_ctors (obj);
@@ -615,7 +615,7 @@ rtems_rtl_base_sym_global_add (const unsigned char* esyms,
   rtems_rtl_unlock ();
-rtems_rtl_obj_t*
+rtems_rtl_obj*
 rtems_rtl_baseimage (void)
   return NULL;
2.15.1
