error while running rtems-test with coverage
Cillian O'Donnell
cpodonnell8 at gmail.com
Fri Apr 13 06:13:02 UTC 2018
No that's the right one. I think it might be something to do with qemu.cfg
in rtems-tools then. What's in your qemu.cfg? It's in
rtems-tools/tester/rtems/testing
On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> I manually built qemu from here
> https://github.com/AdaCore/qemu
> I guess this is regular qemu , please send a link for couverture qemu for
> manual build.
> -- vijay
> On 12 April 2018 at 22:23, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> Ah that's good progress, those .cov files are supposed to be generated by
>> couverture-qemu as the test are run. They contain the trace data. Are you
>> definitely running couverture-qemu and not regular qemu?
>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> I got the parsing of the coverage from the ini file running , now I'm
>>> getting the following error and warnings .
>>> Running covoar for score
>>> WARNING: Unable to read coverage file
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/capture/capture.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/fileio/fileio.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/iostream/cxx_iostream.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/loopback/loopback.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/minimum/minimum.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/nsecs/nsecs.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/paranoia/paranoia.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/pppd/pppd.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/ticker/ticker.exe.cov
>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe.cov
>>> ERROR: No information to analyze
>>> ***Cleaning tempfiles***
>>> error: covoar failure exit code: 1
>>> -- vijay
>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>> I managed to get the tests running with the following two patches .
>>>> Please review them .
>>>> -- vijay
>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>> I tried to solve the empty get in the way shown in the patch , but it
>>>>>> doesn't seems to work, I'm getting the following error now
>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>> Traceback (most recent call last):
>>>>>> File
>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test", line 40,
>>>>>> in <module>
>>>>>> rt.test.run()
>>>>>> File
>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 303,
>>>>>> in run
>>>>>> bsp = config.load(bsp[1], opts)
>>>>>> File
>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/config.py", line
>>>>>> 461, in load
>>>>>> return opts.defaults['bsp']
>>>>>> File
>>>>>> "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py", line
>>>>>> 190, in __getitem__
>>>>>> raise IndexError('key: %s' % (key))
>>>>>> IndexError: key: bsp
>>>>>> I still Couldn't figure out why it's happening, when I use
>>>>> RawConfigParse , it seems to run nicely though .
>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>> -- vijay
>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>> I got the rtems-test running
>>>>>>>> I found that get_item_names(section, err) in configuration.py was
>>>>>>>> returning an empty list to the
>>>>>>>> item_names in load(bsp,opts) for config.py this was giving out the
>>>>>>>> error mandatory item not found .
>>>>>>>> I have attached the patch file .
>>>>>>>> current status :
>>>>>>>> rtems-test is running without coverage
>>>>>>>> running coverage gives the following error :
>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>> File
>>>>>>>> in <module>
>>>>>>>> rt.test.run()
>>>>>>>> File
>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 310,
>>>>>>>> in run
>>>>>>>> coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>>>>> File
>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py", line 230,
>>>>>>>> in coverage_get_obj
>>>>>>>> coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>> path_to_builddir)
>>>>>>>> File
>>>>>>>> "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py", line
>>>>>>>> 335, in __init__
>>>>>>>> self.report_format = self.config_map['report_format'][2]
>>>>>>> This is back to the difference in cfg formats. It's looking for the
>>>>>>> last line here
>>>>>>> https://github.com/cillianodonnell/rtems-tools/blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>> Which is now
>>>>>>> https://github.com/cillianodonnell/rtems-tools/blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>> It's trying to grab the 'html' text so it can trigger the right
>>>>>>> section of code in coverage.py
>>>>>>> It's something just to tell which format we want the report to output
>>>>>> Understood , I'll come to that after I manage to get the test running
>>>>>> first .
>>>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>>>>> Thanks
>>>>>>>> -- vijay
>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>> > https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>> Any local changes?
>>>>>>>>> > I tried running the rtems-test with the following command
>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>> --log=coverage_analysis.log
>>>>>>>>> > --rtems-bsp=leon3_qemu
>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>> Please paste the command and output as it appears in the terminal?
>>>>>>>>> > current status :
>>>>>>>>> > the same command gives the error :
>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>> > to make sure I didn't break something , I also tried running
>>>>>>>>> from a freshly
>>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>>> Did you try running the following command from the top of the
>>>>>>>>> source tree:
>>>>>>>>> $ grep -r "mandatory item not found" *
>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/1a0644b2/attachment-0001.html>
