error while running rtems-test with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Apr 13 18:02:26 UTC 2018
-- vijay
On 13 April 2018 at 23:29, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> I can't say for certain but I don't think that will be visible to qemu.cfg
> unless it's a global variable. Chris might know off the top of his head.
> On Fri, 13 Apr 2018, 18:51 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> can we set it in [coverage] ?
>> It runs with the same warnings of unable to read the .cov files
> -- vijay
>> On 13 April 2018 at 23:15, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> Alright so we're back to ini update stuff. That error is because in the
>>> old leon3-qemu.mc we had this global variable set. So you need to find
>>> out how to get that global variable set in the new leon3-qemu.ini
>>> Heres the old version from the .MC file
>>> [global]
>>> bsp: none, none, 'leon3'
>>> coverage_supported: none, none, '1'
>>> On Fri, 13 Apr 2018, 18:29 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> It shows the following error
>>>> RTEMS Testing - Tester, 5 (58acb6d61ac7 modified)
>>>> Coverage environment prepared
>>>> [ 3/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>> sparc/leon3_qemu: cdtest.exe
>>>> [ 1/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>> sparc/leon3_qemu: base_sp.exe
>>>> [ 2/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>> sparc/leon3_qemu: capture.exe
>>>> [ 4/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>> sparc/leon3_qemu: fileio.exe
>>>> error: qemu.cfg:77: macro '%{coverage_supported}' not found
>>>> warning: switched to dry run due to errors
>>>> error: qemu.cfg:77: invalid if bool value: %if %{coverage_supported}
>>>> Traceback (most recent call last):
>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test",
>>>> line 40, in <module>
>>>> rt.test.run()
>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py",
>>>> line 353, in run
>>>> tst.reraise()
>>>> line 160, in reraise
>>>> _test_reraise(*self.result)
>>>> NameError: global name '_test_reraise' is not defined
>>>> -- vijay
>>>> On 13 April 2018 at 22:54, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> Ah yes, your missing the qemu arguments to run the coverage. Try this
>>>>> # Coverage analysis
>>>>> %define coverage_arg %{nil}
>>>>> %if %{defined _coverage}
>>>>> %define coverage_arg -exec-trace %{test_executable}.cov
>>>>> %else
>>>>> %error "Coverage analysis unsupported for %{bsp}"
>>>>> %endif
>>>>> %endif
>>>>> # Executable
>>>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel %{test_executable} %{coverage_arg}
>>>>> On Fri, 13 Apr 2018, 18:18 Vijay Kumar Banerjee, <
>>>>>> sure
>>>>>> # RTEMS Tools Project (http://www.rtems.org/)
>>>>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>>>>> # All rights reserved.
>>>>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>> # Redistribution and use in source and binary forms, with or without
>>>>>> # modification, are permitted provided that the following conditions
>>>>>> are met:
>>>>>> # 1. Redistributions of source code must retain the above copyright
>>>>>> notice,
>>>>>> # this list of conditions and the following disclaimer.
>>>>>> # 2. Redistributions in binary form must reproduce the above
>>>>>> copyright notice,
>>>>>> # this list of conditions and the following disclaimer in the
>>>>>> documentation
>>>>>> # and/or other materials provided with the distribution.
>>>>>> # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>>>>> "AS IS"
>>>>>> # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>>> TO, THE
>>>>>> # IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>>>>> PURPOSE
>>>>>> # ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>> CONTRIBUTORS BE
>>>>>> # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>>>> # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>>>>> # SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>> BUSINESS
>>>>>> # INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>> WHETHER IN
>>>>>> # CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>> OTHERWISE)
>>>>>> # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>>>>> OF THE
>>>>>> # POSSIBILITY OF SUCH DAMAGE.
>>>>>> # QEMU
>>>>>> # Use a qemu command to run the executable in the qemu simulator.
>>>>>> %include %{_configdir}/base.cfg
>>>>>> %include %{_configdir}/checks.cfg
>>>>>> # Console.
>>>>>> %define console_stdio
>>>>>> %include %{_configdir}/console.cfg
>>>>>> # RTEMS version
>>>>>> %include %{_rtdir}/rtems/version.cfg
>>>>>> # Qemu common option patterns.
>>>>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>> -nographic
>>>>>> #%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>>>>> -nographic
>>>>>> %define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>>> -nographic
>>>>>> %define qemu_opts_no_net -net none
>>>>>> # Qemu executable
>>>>>> %ifn %{defined bsp_qemu_opts}
>>>>>> %define bsp_qemu_opts %{nil}
>>>>>> %endif
>>>>>> %define qemu_cmd qemu-system-%{bsp_arch}
>>>>>> %define qemu_opts %{bsp_qemu_opts}
>>>>>> # Executable
>>>>>> %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>>>>> -- vijay
>>>>>> On 13 April 2018 at 22:19, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> Yeah that's fine but can you just paste the contents here anyway.
>>>>>>> I'm not near a laptop and I can't remember which branch your starting from.
>>>>>>> On Fri, 13 Apr 2018, 13:51 Vijay Kumar Banerjee, <
>>>>>>>> I haven't made any local changes to qemu.cfg
>>>>>>>> -- vijay
>>>>>>>> On 13 April 2018 at 11:43, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> No that's the right one. I think it might be something to do with
>>>>>>>>> qemu.cfg in rtems-tools then. What's in your qemu.cfg? It's in
>>>>>>>>> rtems-tools/tester/rtems/testing
>>>>>>>>> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <
>>>>>>>>>> I manually built qemu from here
>>>>>>>>>> https://github.com/AdaCore/qemu
>>>>>>>>>> I guess this is regular qemu , please send a link for couverture
>>>>>>>>>> qemu for manual build.
>>>>>>>>>> -- vijay
>>>>>>>>>> On 12 April 2018 at 22:23, Cillian O'Donnell <
>>>>>>>>>>> Ah that's good progress, those .cov files are supposed to be
>>>>>>>>>>> generated by couverture-qemu as the test are run. They contain the trace
>>>>>>>>>>> data. Are you definitely running couverture-qemu and not regular qemu?
>>>>>>>>>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>>>>>>>>>>> I got the parsing of the coverage from the ini file running ,
>>>>>>>>>>>> now I'm getting the following error and warnings .
>>>>>>>>>>>> Running covoar for score
>>>>>>>>>>>> WARNING: Unable to read coverage file /home/lunatic/development/
>>>>>>>>>>>> rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/
>>>>>>>>>>>> samples/base_sp/base_sp.exe.cov
>>>>>>>>>>>> samples/capture/capture.exe.cov
>>>>>>>>>>>> samples/cdtest/cdtest.exe.cov
>>>>>>>>>>>> samples/fileio/fileio.exe.cov
>>>>>>>>>>>> samples/hello/hello.exe.cov
>>>>>>>>>>>> samples/iostream/cxx_iostream.exe.cov
>>>>>>>>>>>> samples/loopback/loopback.exe.cov
>>>>>>>>>>>> samples/minimum/minimum.exe.cov
>>>>>>>>>>>> samples/nsecs/nsecs.exe.cov
>>>>>>>>>>>> samples/paranoia/paranoia.exe.cov
>>>>>>>>>>>> samples/pppd/pppd.exe.cov
>>>>>>>>>>>> samples/ticker/ticker.exe.cov
>>>>>>>>>>>> samples/unlimited/unlimited.exe.cov
>>>>>>>>>>>> ERROR: No information to analyze
>>>>>>>>>>>> ***Cleaning tempfiles***
>>>>>>>>>>>> error: covoar failure exit code: 1
>>>>>>>>>>>> -- vijay
>>>>>>>>>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>>>>>>>>>> I managed to get the tests running with the following two
>>>>>>>>>>>>> patches .
>>>>>>>>>>>>> Please review them .
>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>>>>>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>> I tried to solve the empty get in the way shown in the patch
>>>>>>>>>>>>>>> , but it doesn't seems to work, I'm getting the following error now
>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/tester/rtems-test",
>>>>>>>>>>>>>>> rt.test.run()
>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 303, in run
>>>>>>>>>>>>>>> bsp = config.load(bsp[1], opts)
>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/config.py", line 461, in load
>>>>>>>>>>>>>>> return opts.defaults['bsp']
>>>>>>>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py",
>>>>>>>>>>>>>>> line 190, in __getitem__
>>>>>>>>>>>>>>> raise IndexError('key: %s' % (key))
>>>>>>>>>>>>>>> IndexError: key: bsp
>>>>>>>>>>>>>>> I still Couldn't figure out why it's happening, when I use
>>>>>>>>>>>>>> RawConfigParse , it seems to run nicely though .
>>>>>>>>>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <
>>>>>>>>>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>> I got the rtems-test running
>>>>>>>>>>>>>>>>> I found that get_item_names(section, err) in
>>>>>>>>>>>>>>>>> configuration.py was returning an empty list to the
>>>>>>>>>>>>>>>>> item_names in load(bsp,opts) for config.py this was giving
>>>>>>>>>>>>>>>>> out the error mandatory item not found .
>>>>>>>>>>>>>>>>> I have attached the patch file .
>>>>>>>>>>>>>>>>> current status :
>>>>>>>>>>>>>>>>> rtems-test is running without coverage
>>>>>>>>>>>>>>>>> running coverage gives the following error :
>>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rtems-test", line 40, in <module>
>>>>>>>>>>>>>>>>> rt.test.run()
>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 310, in run
>>>>>>>>>>>>>>>>> coverage = coverage_get_obj(opts, path_to_builddir[1])
>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 230, in
>>>>>>>>>>>>>>>>> coverage_get_obj
>>>>>>>>>>>>>>>>> coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>>>>>>>>>> path_to_builddir)
>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/coverage.py", line 335, in
>>>>>>>>>>>>>>>>> __init__
>>>>>>>>>>>>>>>>> self.report_format = self.config_map['report_
>>>>>>>>>>>>>>>>> format'][2]
>>>>>>>>>>>>>>>> This is back to the difference in cfg formats. It's looking
>>>>>>>>>>>>>>>> for the last line here
>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/
>>>>>>>>>>>>>>>> blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>>>>>>>>>> Which is now
>>>>>>>>>>>>>>>> blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>>>>>>>>>>> It's trying to grab the 'html' text so it can trigger the
>>>>>>>>>>>>>>>> right section of code in coverage.py
>>>>>>>>>>>>>>>> It's something just to tell which format we want the report
>>>>>>>>>>>>>>>> to output
>>>>>>>>>>>>>>> Understood , I'll come to that after I manage to get the
>>>>>>>>>>>>>>> test running first .
>>>>>>>>>>>>>>>> TypeError: 'NoneType' object has no attribute '__getitem__'
>>>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org>
>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>>>>>>>>>> tree/ini-update
>>>>>>>>>>>>>>>>>> Any local changes?
>>>>>>>>>>>>>>>>>> > I tried running the rtems-test with the following
>>>>>>>>>>>>>>>>>> command
>>>>>>>>>>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>> --log=coverage_analysis.log
>>>>>>>>>>>>>>>>>> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
>>>>>>>>>>>>>>>>>> development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>> > sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>>>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>>>>>>>>>> Please paste the command and output as it appears in the
>>>>>>>>>>>>>>>>>> terminal?
>>>>>>>>>>>>>>>>>> > current status :
>>>>>>>>>>>>>>>>>> > the same command gives the error :
>>>>>>>>>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>>>>>>>>>> > to make sure I didn't break something , I also tried
>>>>>>>>>>>>>>>>>> running from a freshly
>>>>>>>>>>>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>>>>>>>>>>>> Did you try running the following command from the top of
>>>>>>>>>>>>>>>>>> the source tree:
>>>>>>>>>>>>>>>>>> $ grep -r "mandatory item not found" *
>>>>>>>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/dd9072e9/attachment-0001.html>
