error while running rtems-test with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Apr 13 18:16:55 UTC 2018
It just shows this.(with only hello)
Running covoar for score
WARNING: Unable to read coverage file
/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe.cov
ERROR: No information to analyze
***Cleaning tempfiles***
error: covoar failure exit code: 1
The log file shows this
RTEMS Testing - Tester, 5 (58acb6d61ac7 modified)
2 Command Line:
/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test
--rtems-t ools=/home/lunatic/development/rtems/5
--log=coverage_analysis.log --rtems-bsp=leon3_qemu - -coverage
--rtems-builddir=/home/lunatic/development/rtems/kernel/leon3
sparc-rtems5/c/leon 3/testsuites/samples/hello
3 Python: 2.7.14 (default, Feb 27 2018, 20:43:24) [GCC 7.3.1 20180130
(Red Hat 7.3.1-2)]
4 Host: Linux-4.15.8-300.fc27.x86_64-x86_64-with-fedora-27-Twenty_Seven
(Linux lunatic 4.15.8 -300.fc27.x86_64 #1 SMP Fri Mar 9 18:11:36 UTC
2018 x86_64 x86_64)
5 Coverage environment prepared
6 [1/1] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | sparc/leon3_qemu: hello.exe
7
8 Passed: 1
9 Failed: 0
10 User Input: 0
11 Expected Fail: 0
12 Indeterminate: 0
13 Benchmark: 0
14 Timeout: 0
15 Invalid: 0
16 Wrong Version: 0
17 Wrong Build: 0
18 Wrong Tools: 0
19 ----------------
20 Total: 1
21
22 Average test time: 0:00:01.505199
23 Testing time : 0:00:01.505199
24 Running covoar for score
25 shell: covoar -s /home/lunatic/coverage_test/coverage/score.symcfg -O
/home/lunatic/coverag e_test/test/score -f QEMU -T sparc-rtems5 -E
ls/tester/rtems/testing/coverage/Explanations.txt -c .cov -e exe -p RTEMS-5
/home/lunatic/d
26 WARNING: Unable to read coverage file
1,1 Top
-- vijay
On 13 April 2018 at 23:40, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Is there anywhere in that output that it shows the qemu command that is
> running?
> On Fri, 13 Apr 2018, 19:02 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> -- vijay
>> On 13 April 2018 at 23:29, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> I can't say for certain but I don't think that will be visible to
>>> qemu.cfg unless it's a global variable. Chris might know off the top of his
>>> head.
>>> On Fri, 13 Apr 2018, 18:51 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> can we set it in [coverage] ?
>>>> It runs with the same warnings of unable to read the .cov files
>>> -- vijay
>>>> On 13 April 2018 at 23:15, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> Alright so we're back to ini update stuff. That error is because in
>>>>> the old leon3-qemu.mc we had this global variable set. So you need to
>>>>> find out how to get that global variable set in the new leon3-qemu.ini
>>>>> Heres the old version from the .MC file
>>>>> [global]
>>>>> bsp: none, none, 'leon3'
>>>>> coverage_supported: none, none, '1'
>>>>> On Fri, 13 Apr 2018, 18:29 Vijay Kumar Banerjee, <
>>>>>> It shows the following error
>>>>>> [ 3/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>>>> sparc/leon3_qemu: cdtest.exe
>>>>>> [ 1/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>>>> sparc/leon3_qemu: base_sp.exe
>>>>>> [ 2/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>>>> sparc/leon3_qemu: capture.exe
>>>>>> [ 4/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>>>> sparc/leon3_qemu: fileio.exe
>>>>>> error: qemu.cfg:77: macro '%{coverage_supported}' not found
>>>>>> warning: switched to dry run due to errors
>>>>>> error: qemu.cfg:77: invalid if bool value: %if %{coverage_supported}
>>>>>> Traceback (most recent call last):
>>>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test",
>>>>>> line 40, in <module>
>>>>>> rt.test.run()
>>>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py",
>>>>>> line 353, in run
>>>>>> tst.reraise()
>>>>>> line 160, in reraise
>>>>>> _test_reraise(*self.result)
>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>> -- vijay
>>>>>> On 13 April 2018 at 22:54, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> Ah yes, your missing the qemu arguments to run the coverage. Try this
>>>>>>> # Coverage analysis
>>>>>>> %define coverage_arg %{nil}
>>>>>>> %if %{defined _coverage}
>>>>>>> %define coverage_arg -exec-trace %{test_executable}.cov
>>>>>>> %else
>>>>>>> %error "Coverage analysis unsupported for %{bsp}"
>>>>>>> %endif
>>>>>>> %endif
>>>>>>> # Executable
>>>>>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel %{test_executable} %{coverage_arg}
>>>>>>> On Fri, 13 Apr 2018, 18:18 Vijay Kumar Banerjee, <
>>>>>>>> sure
>>>>>>>> # RTEMS Tools Project (http://www.rtems.org/)
>>>>>>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>>>>>>> # All rights reserved.
>>>>>>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>>>> # Redistribution and use in source and binary forms, with or without
>>>>>>>> # modification, are permitted provided that the following
>>>>>>>> conditions are met:
>>>>>>>> # 1. Redistributions of source code must retain the above copyright
>>>>>>>> notice,
>>>>>>>> # this list of conditions and the following disclaimer.
>>>>>>>> # 2. Redistributions in binary form must reproduce the above
>>>>>>>> copyright notice,
>>>>>>>> # this list of conditions and the following disclaimer in the
>>>>>>>> documentation
>>>>>>>> # and/or other materials provided with the distribution.
>>>>>>>> # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>>> CONTRIBUTORS "AS IS"
>>>>>>>> # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>>>>>>> TO, THE
>>>>>>>> # IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>>> PARTICULAR PURPOSE
>>>>>>>> # ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>>>> CONTRIBUTORS BE
>>>>>>>> # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>>>>>>> OR
>>>>>>>> # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>>>>>>> OF
>>>>>>>> # SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>>>> BUSINESS
>>>>>>>> # INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>>>> WHETHER IN
>>>>>>>> # CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>>>> OTHERWISE)
>>>>>>>> # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>>>> ADVISED OF THE
>>>>>>>> # POSSIBILITY OF SUCH DAMAGE.
>>>>>>>> # QEMU
>>>>>>>> # Use a qemu command to run the executable in the qemu simulator.
>>>>>>>> %include %{_configdir}/base.cfg
>>>>>>>> %include %{_configdir}/checks.cfg
>>>>>>>> # Console.
>>>>>>>> %define console_stdio
>>>>>>>> %include %{_configdir}/console.cfg
>>>>>>>> # RTEMS version
>>>>>>>> %include %{_rtdir}/rtems/version.cfg
>>>>>>>> # Qemu common option patterns.
>>>>>>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>>>> -nographic
>>>>>>>> #%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>>>>>>> -nographic
>>>>>>>> %define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>>>>> -nographic
>>>>>>>> %define qemu_opts_no_net -net none
>>>>>>>> # Qemu executable
>>>>>>>> %ifn %{defined bsp_qemu_opts}
>>>>>>>> %define bsp_qemu_opts %{nil}
>>>>>>>> %endif
>>>>>>>> %define qemu_cmd qemu-system-%{bsp_arch}
>>>>>>>> %define qemu_opts %{bsp_qemu_opts}
>>>>>>>> # Executable
>>>>>>>> %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>>>>>>> -- vijay
>>>>>>>> On 13 April 2018 at 22:19, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> Yeah that's fine but can you just paste the contents here anyway.
>>>>>>>>> I'm not near a laptop and I can't remember which branch your starting from.
>>>>>>>>> On Fri, 13 Apr 2018, 13:51 Vijay Kumar Banerjee, <
>>>>>>>>>> I haven't made any local changes to qemu.cfg
>>>>>>>>>> -- vijay
>>>>>>>>>> On 13 April 2018 at 11:43, Cillian O'Donnell <
>>>>>>>>>>> No that's the right one. I think it might be something to do
>>>>>>>>>>> with qemu.cfg in rtems-tools then. What's in your qemu.cfg? It's in
>>>>>>>>>>> rtems-tools/tester/rtems/testing
>>>>>>>>>>> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <
>>>>>>>>>>>> I manually built qemu from here
>>>>>>>>>>>> https://github.com/AdaCore/qemu
>>>>>>>>>>>> I guess this is regular qemu , please send a link for
>>>>>>>>>>>> couverture qemu for manual build.
>>>>>>>>>>>> -- vijay
>>>>>>>>>>>> On 12 April 2018 at 22:23, Cillian O'Donnell <
>>>>>>>>>>>>> Ah that's good progress, those .cov files are supposed to be
>>>>>>>>>>>>> generated by couverture-qemu as the test are run. They contain the trace
>>>>>>>>>>>>> data. Are you definitely running couverture-qemu and not regular qemu?
>>>>>>>>>>>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>> I got the parsing of the coverage from the ini file running ,
>>>>>>>>>>>>>> now I'm getting the following error and warnings .
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/capture/capture.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/fileio/fileio.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/iostream/cxx_iostream.
>>>>>>>>>>>>>> exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/loopback/loopback.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/minimum/minimum.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/nsecs/nsecs.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/paranoia/paranoia.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/pppd/pppd.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/ticker/ticker.exe.cov
>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe.cov
>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>> I managed to get the tests running with the following two
>>>>>>>>>>>>>>> patches .
>>>>>>>>>>>>>>> Please review them .
>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>> I tried to solve the empty get in the way shown in the
>>>>>>>>>>>>>>>>> patch , but it doesn't seems to work, I'm getting the following error now
>>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rtems-test", line 40, in <module>
>>>>>>>>>>>>>>>>> rt.test.run()
>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 303, in run
>>>>>>>>>>>>>>>>> bsp = config.load(bsp[1], opts)
>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/config.py", line 461, in load
>>>>>>>>>>>>>>>>> return opts.defaults['bsp']
>>>>>>>>>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py",
>>>>>>>>>>>>>>>>> line 190, in __getitem__
>>>>>>>>>>>>>>>>> raise IndexError('key: %s' % (key))
>>>>>>>>>>>>>>>>> IndexError: key: bsp
>>>>>>>>>>>>>>>>> I still Couldn't figure out why it's happening, when I use
>>>>>>>>>>>>>>>> RawConfigParse , it seems to run nicely though .
>>>>>>>>>>>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>>>> I got the rtems-test running
>>>>>>>>>>>>>>>>>>> I found that get_item_names(section, err) in
>>>>>>>>>>>>>>>>>>> configuration.py was returning an empty list to the
>>>>>>>>>>>>>>>>>>> item_names in load(bsp,opts) for config.py this was
>>>>>>>>>>>>>>>>>>> giving out the error mandatory item not found .
>>>>>>>>>>>>>>>>>>> I have attached the patch file .
>>>>>>>>>>>>>>>>>>> current status :
>>>>>>>>>>>>>>>>>>> rtems-test is running without coverage
>>>>>>>>>>>>>>>>>>> running coverage gives the following error :
>>>>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>>>>>>>>>>> <module>
>>>>>>>>>>>>>>>>>>> rt.test.run()
>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 310, in run
>>>>>>>>>>>>>>>>>>> coverage = coverage_get_obj(opts,
>>>>>>>>>>>>>>>>>>> path_to_builddir[1])
>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 230, in
>>>>>>>>>>>>>>>>>>> coverage_get_obj
>>>>>>>>>>>>>>>>>>> coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>>>>>>>>>>>> path_to_builddir)
>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/coverage.py", line 335, in
>>>>>>>>>>>>>>>>>>> __init__
>>>>>>>>>>>>>>>>>>> self.report_format = self.config_map['report_
>>>>>>>>>>>>>>>>>>> format'][2]
>>>>>>>>>>>>>>>>>> This is back to the difference in cfg formats. It's
>>>>>>>>>>>>>>>>>> looking for the last line here
>>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/
>>>>>>>>>>>>>>>>>> blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>>>>>>>>>>>> Which is now
>>>>>>>>>>>>>>>>>> blob/ini-update/tester/rtems/testing/bsps/leon3_qemu.ini
>>>>>>>>>>>>>>>>>> It's trying to grab the 'html' text so it can trigger the
>>>>>>>>>>>>>>>>>> right section of code in coverage.py
>>>>>>>>>>>>>>>>>> It's something just to tell which format we want the
>>>>>>>>>>>>>>>>>> report to output
>>>>>>>>>>>>>>>>> Understood , I'll come to that after I manage to get the
>>>>>>>>>>>>>>>>> test running first .
>>>>>>>>>>>>>>>>>> TypeError: 'NoneType' object has no attribute
>>>>>>>>>>>>>>>>>>> '__getitem__'
>>>>>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <chrisj at rtems.org>
>>>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>>>>>>>>>>>> tree/ini-update
>>>>>>>>>>>>>>>>>>>> Any local changes?
>>>>>>>>>>>>>>>>>>>> > I tried running the rtems-test with the following
>>>>>>>>>>>>>>>>>>>> command
>>>>>>>>>>>>>>>>>>>> > $HOME/development/rtems/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
>>>>>>>>>>>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>>>>>>>>>>>> Please paste the command and output as it appears in
>>>>>>>>>>>>>>>>>>>> the terminal?
>>>>>>>>>>>>>>>>>>>> > current status :
>>>>>>>>>>>>>>>>>>>> > the same command gives the error :
>>>>>>>>>>>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>>>>>>>>>>>> > to make sure I didn't break something , I also tried
>>>>>>>>>>>>>>>>>>>> running from a freshly
>>>>>>>>>>>>>>>>>>>> > downloaded directory as well, it gives the same error.
>>>>>>>>>>>>>>>>>>>> Did you try running the following command from the top
>>>>>>>>>>>>>>>>>>>> of the source tree:
>>>>>>>>>>>>>>>>>>>> $ grep -r "mandatory item not found" *
>>>>>>>>>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/f93774f8/attachment-0001.html>
