error while running rtems-test with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Apr 13 18:27:54 UTC 2018
On 13 April 2018 at 23:51, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Hmmm it's not there. Even so I can almost guarantee you, the reason it's
> not running is that coverage_supported variable is not being found as true
> in qemu.cfg and so the the command to generated the trace files isn't run
> and there's no .cov files in the end. So that's what you'll have to dig
> into.
Okay , I'll set it to global then.
> On Fri, 13 Apr 2018, 19:16 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> It just shows this.(with only hello)
>> Running covoar for score
>> WARNING: Unable to read coverage file /home/lunatic/development/
>> rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/
>> samples/hello/hello.exe.cov
>> ERROR: No information to analyze
>> ***Cleaning tempfiles***
>> error: covoar failure exit code: 1
>> The log file shows this
>> RTEMS Testing - Tester, 5 (58acb6d61ac7 modified)
>> 2 Command Line: /home/lunatic/development/
>> rtems/test/rtems-tools/tester/rtems-test --rtems-t ools=/home/lunatic/development/rtems/5
>> --log=coverage_analysis.log --rtems-bsp=leon3_qemu - -coverage
>> --rtems-builddir=/home/lunatic/development/rtems/kernel/leon3
>> sparc-rtems5/c/leon 3/testsuites/samples/hello
>> 3 Python: 2.7.14 (default, Feb 27 2018, 20:43:24) [GCC 7.3.1 20180130
>> (Red Hat 7.3.1-2)]
>> 4 Host: Linux-4.15.8-300.fc27.x86_64-x86_64-with-fedora-27-Twenty_Seven
>> (Linux lunatic 4.15.8 -300.fc27.x86_64 #1 SMP Fri Mar 9 18:11:36 UTC
>> 2018 x86_64 x86_64)
>> 5 Coverage environment prepared
>> 6 [1/1] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 | sparc/leon3_qemu:
>> hello.exe
>> 7
>> 8 Passed: 1
>> 9 Failed: 0
>> 10 User Input: 0
>> 11 Expected Fail: 0
>> 12 Indeterminate: 0
>> 13 Benchmark: 0
>> 14 Timeout: 0
>> 15 Invalid: 0
>> 16 Wrong Version: 0
>> 17 Wrong Build: 0
>> 18 Wrong Tools: 0
>> 19 ----------------
>> 20 Total: 1
>> 21
>> 22 Average test time: 0:00:01.505199
>> 23 Testing time : 0:00:01.505199
>> 24 Running covoar for score
>> 25 shell: covoar -s /home/lunatic/coverage_test/coverage/score.symcfg
>> -O /home/lunatic/coverag e_test/test/score -f QEMU -T sparc-rtems5 -E
>> /home/lunatic/development/rtems/test/rtems-too
>> ls/tester/rtems/testing/coverage/Explanations.txt -c .cov -e exe -p
>> RTEMS-5 /home/lunatic/d evelopment/rtems/kernel/leon3/
>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>> 26 WARNING: Unable to read coverage file /home/lunatic/development/rtems/kernel/leon3/sparc-rt
>> ems5/c/leon3/testsuites/samples/hello/hello.exe.cov
>> 1,1 Top
>> -- vijay
>> On 13 April 2018 at 23:40, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> Is there anywhere in that output that it shows the qemu command that is
>>> running?
>>> On Fri, 13 Apr 2018, 19:02 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> -- vijay
>>>> On 13 April 2018 at 23:29, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> I can't say for certain but I don't think that will be visible to
>>>>> qemu.cfg unless it's a global variable. Chris might know off the top of his
>>>>> head.
>>>>> On Fri, 13 Apr 2018, 18:51 Vijay Kumar Banerjee, <
>>>>>> can we set it in [coverage] ?
>>>>>> It runs with the same warnings of unable to read the .cov files
>>>>> -- vijay
>>>>>> On 13 April 2018 at 23:15, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> Alright so we're back to ini update stuff. That error is because in
>>>>>>> the old leon3-qemu.mc we had this global variable set. So you need
>>>>>>> to find out how to get that global variable set in the new leon3-qemu.ini
>>>>>>> Heres the old version from the .MC file
>>>>>>> [global]
>>>>>>> bsp: none, none, 'leon3'
>>>>>>> coverage_supported: none, none, '1'
>>>>>>> On Fri, 13 Apr 2018, 18:29 Vijay Kumar Banerjee, <
>>>>>>>> It shows the following error
>>>>>>>> [ 3/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>>>>>> sparc/leon3_qemu: cdtest.exe
>>>>>>>> [ 1/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>>>>>> sparc/leon3_qemu: base_sp.exe
>>>>>>>> [ 2/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>>>>>> sparc/leon3_qemu: capture.exe
>>>>>>>> [ 4/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 W:0 |
>>>>>>>> sparc/leon3_qemu: fileio.exe
>>>>>>>> error: qemu.cfg:77: macro '%{coverage_supported}' not found
>>>>>>>> warning: switched to dry run due to errors
>>>>>>>> error: qemu.cfg:77: invalid if bool value: %if
>>>>>>>> Traceback (most recent call last):
>>>>>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test",
>>>>>>>> line 40, in <module>
>>>>>>>> rt.test.run()
>>>>>>>> File "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py",
>>>>>>>> line 353, in run
>>>>>>>> tst.reraise()
>>>>>>>> line 160, in reraise
>>>>>>>> _test_reraise(*self.result)
>>>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>>>> -- vijay
>>>>>>>> On 13 April 2018 at 22:54, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> Ah yes, your missing the qemu arguments to run the coverage. Try
>>>>>>>>> this
>>>>>>>>> # Coverage analysis
>>>>>>>>> %define coverage_arg %{nil}
>>>>>>>>> %if %{defined _coverage}
>>>>>>>>> %if %{coverage_supported}
>>>>>>>>> %define coverage_arg -exec-trace %{test_executable}.cov
>>>>>>>>> %else
>>>>>>>>> %error "Coverage analysis unsupported for %{bsp}"
>>>>>>>>> %endif
>>>>>>>>> %endif
>>>>>>>>> # Executable
>>>>>>>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel %{test_executable} %{coverage_arg}
>>>>>>>>> On Fri, 13 Apr 2018, 18:18 Vijay Kumar Banerjee, <
>>>>>>>>>> sure
>>>>>>>>>> # RTEMS Tools Project (http://www.rtems.org/)
>>>>>>>>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>>>>>>>>> # All rights reserved.
>>>>>>>>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>>>>>> # Redistribution and use in source and binary forms, with or
>>>>>>>>>> without
>>>>>>>>>> # modification, are permitted provided that the following
>>>>>>>>>> conditions are met:
>>>>>>>>>> # 1. Redistributions of source code must retain the above
>>>>>>>>>> copyright notice,
>>>>>>>>>> # this list of conditions and the following disclaimer.
>>>>>>>>>> # 2. Redistributions in binary form must reproduce the above
>>>>>>>>>> copyright notice,
>>>>>>>>>> # this list of conditions and the following disclaimer in the
>>>>>>>>>> documentation
>>>>>>>>>> # and/or other materials provided with the distribution.
>>>>>>>>>> # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>>>>> CONTRIBUTORS "AS IS"
>>>>>>>>>> # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>>>>>> LIMITED TO, THE
>>>>>>>>>> # IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>>>>> PARTICULAR PURPOSE
>>>>>>>>>> # ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>>>>>> CONTRIBUTORS BE
>>>>>>>>>> # LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>>>>>>>>>> EXEMPLARY, OR
>>>>>>>>>> # CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>>>>> PROCUREMENT OF
>>>>>>>>>> # SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>>>>>> BUSINESS
>>>>>>>>>> # INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>>>>>> WHETHER IN
>>>>>>>>>> # CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>>>>>> OTHERWISE)
>>>>>>>>>> # ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>>>>>> ADVISED OF THE
>>>>>>>>>> # POSSIBILITY OF SUCH DAMAGE.
>>>>>>>>>> # QEMU
>>>>>>>>>> # Use a qemu command to run the executable in the qemu simulator.
>>>>>>>>>> %include %{_configdir}/base.cfg
>>>>>>>>>> %include %{_configdir}/checks.cfg
>>>>>>>>>> # Console.
>>>>>>>>>> %define console_stdio
>>>>>>>>>> %include %{_configdir}/console.cfg
>>>>>>>>>> # RTEMS version
>>>>>>>>>> %include %{_rtdir}/rtems/version.cfg
>>>>>>>>>> # Qemu common option patterns.
>>>>>>>>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>>>>>> -nographic
>>>>>>>>>> #%define qemu_opts_base -no-reboot -serial null -serial
>>>>>>>>>> mon:stdio -nographic
>>>>>>>>>> %define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>>>>>>> -nographic
>>>>>>>>>> %define qemu_opts_no_net -net none
>>>>>>>>>> # Qemu executable
>>>>>>>>>> %ifn %{defined bsp_qemu_opts}
>>>>>>>>>> %define bsp_qemu_opts %{nil}
>>>>>>>>>> %endif
>>>>>>>>>> %define qemu_cmd qemu-system-%{bsp_arch}
>>>>>>>>>> %define qemu_opts %{bsp_qemu_opts}
>>>>>>>>>> # Executable
>>>>>>>>>> %execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>>>>>>>>> -- vijay
>>>>>>>>>> On 13 April 2018 at 22:19, Cillian O'Donnell <
>>>>>>>>>>> Yeah that's fine but can you just paste the contents here
>>>>>>>>>>> anyway. I'm not near a laptop and I can't remember which branch your
>>>>>>>>>>> starting from.
>>>>>>>>>>> On Fri, 13 Apr 2018, 13:51 Vijay Kumar Banerjee, <
>>>>>>>>>>>> I haven't made any local changes to qemu.cfg
>>>>>>>>>>>> -- vijay
>>>>>>>>>>>> On 13 April 2018 at 11:43, Cillian O'Donnell <
>>>>>>>>>>>>> No that's the right one. I think it might be something to do
>>>>>>>>>>>>> with qemu.cfg in rtems-tools then. What's in your qemu.cfg? It's in
>>>>>>>>>>>>> rtems-tools/tester/rtems/testing
>>>>>>>>>>>>> On Fri, 13 Apr 2018, 06:39 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>> I manually built qemu from here
>>>>>>>>>>>>>> https://github.com/AdaCore/qemu
>>>>>>>>>>>>>> I guess this is regular qemu , please send a link for
>>>>>>>>>>>>>> couverture qemu for manual build.
>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>> On 12 April 2018 at 22:23, Cillian O'Donnell <
>>>>>>>>>>>>>>> Ah that's good progress, those .cov files are supposed to be
>>>>>>>>>>>>>>> generated by couverture-qemu as the test are run. They contain the trace
>>>>>>>>>>>>>>> data. Are you definitely running couverture-qemu and not regular qemu?
>>>>>>>>>>>>>>> On Thu, 12 Apr 2018, 17:41 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>> I got the parsing of the coverage from the ini file running
>>>>>>>>>>>>>>>> , now I'm getting the following error and warnings .
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/capture/capture.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/fileio/fileio.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/hello/hello.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/iostream/cxx_iostream.
>>>>>>>>>>>>>>>> exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/loopback/loopback.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/minimum/minimum.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/nsecs/nsecs.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/paranoia/paranoia.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/pppd/pppd.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/ticker/ticker.exe.cov
>>>>>>>>>>>>>>>> rtems5/c/leon3/testsuites/samples/unlimited/unlimited.
>>>>>>>>>>>>>>>> exe.cov
>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>> On 10 April 2018 at 18:10, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>> I managed to get the tests running with the following two
>>>>>>>>>>>>>>>>> patches .
>>>>>>>>>>>>>>>>> Please review them .
>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>> On 9 April 2018 at 15:28, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>> On Fri, 6 Apr 2018, 02:24 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>>>> I tried to solve the empty get in the way shown in the
>>>>>>>>>>>>>>>>>>> patch , but it doesn't seems to work, I'm getting the following error now
>>>>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (1ed6e2e64090)
>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rtems-test", line 40, in
>>>>>>>>>>>>>>>>>>> <module>
>>>>>>>>>>>>>>>>>>> rt.test.run()
>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 303, in run
>>>>>>>>>>>>>>>>>>> bsp = config.load(bsp[1], opts)
>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/config.py", line 461, in
>>>>>>>>>>>>>>>>>>> load
>>>>>>>>>>>>>>>>>>> return opts.defaults['bsp']
>>>>>>>>>>>>>>>>>>> File "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/macros.py",
>>>>>>>>>>>>>>>>>>> line 190, in __getitem__
>>>>>>>>>>>>>>>>>>> raise IndexError('key: %s' % (key))
>>>>>>>>>>>>>>>>>>> IndexError: key: bsp
>>>>>>>>>>>>>>>>>>> I still Couldn't figure out why it's happening, when I
>>>>>>>>>>>>>>>>>> use RawConfigParse , it seems to run nicely though .
>>>>>>>>>>>>>>>>>> Any Ideas on solving it without using RawConfigParser ?
>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>> On 5 April 2018 at 11:51, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>> On Wed, 4 Apr 2018, 11:18 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>>>>>> I got the rtems-test running
>>>>>>>>>>>>>>>>>>>>> I found that get_item_names(section, err) in
>>>>>>>>>>>>>>>>>>>>> configuration.py was returning an empty list to the
>>>>>>>>>>>>>>>>>>>>> item_names in load(bsp,opts) for config.py this was
>>>>>>>>>>>>>>>>>>>>> giving out the error mandatory item not found .
>>>>>>>>>>>>>>>>>>>>> I have attached the patch file .
>>>>>>>>>>>>>>>>>>>>> current status :
>>>>>>>>>>>>>>>>>>>>> rtems-test is running without coverage
>>>>>>>>>>>>>>>>>>>>> running coverage gives the following error :
>>>>>>>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (092c569e81ae)
>>>>>>>>>>>>>>>>>>>>> <module>
>>>>>>>>>>>>>>>>>>>>> rt.test.run()
>>>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 310, in run
>>>>>>>>>>>>>>>>>>>>> coverage = coverage_get_obj(opts,
>>>>>>>>>>>>>>>>>>>>> path_to_builddir[1])
>>>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/test.py", line 230, in
>>>>>>>>>>>>>>>>>>>>> coverage_get_obj
>>>>>>>>>>>>>>>>>>>>> coverage_obj = coverage.coverage_run(opts.defaults,
>>>>>>>>>>>>>>>>>>>>> path_to_builddir)
>>>>>>>>>>>>>>>>>>>>> rtems/rtems-tools/tester/rt/coverage.py", line 335,
>>>>>>>>>>>>>>>>>>>>> in __init__
>>>>>>>>>>>>>>>>>>>>> self.report_format = self.config_map['report_
>>>>>>>>>>>>>>>>>>>>> format'][2]
>>>>>>>>>>>>>>>>>>>> This is back to the difference in cfg formats. It's
>>>>>>>>>>>>>>>>>>>> looking for the last line here
>>>>>>>>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/
>>>>>>>>>>>>>>>>>>>> blob/coverage/tester/rtems/testing/bsps/leon3-qemu.mc
>>>>>>>>>>>>>>>>>>>> Which is now
>>>>>>>>>>>>>>>>>>>> blob/ini-update/tester/rtems/
>>>>>>>>>>>>>>>>>>>> testing/bsps/leon3_qemu.ini
>>>>>>>>>>>>>>>>>>>> It's trying to grab the 'html' text so it can trigger
>>>>>>>>>>>>>>>>>>>> the right section of code in coverage.py
>>>>>>>>>>>>>>>>>>>> It's something just to tell which format we want the
>>>>>>>>>>>>>>>>>>>> report to output
>>>>>>>>>>>>>>>>>>> Understood , I'll come to that after I manage to get the
>>>>>>>>>>>>>>>>>>> test running first .
>>>>>>>>>>>>>>>>>>>> TypeError: 'NoneType' object has no attribute
>>>>>>>>>>>>>>>>>>>>> '__getitem__'
>>>>>>>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>> On 4 April 2018 at 11:16, Chris Johns <
>>>>>>>>>>>>>>>>>>>>> chrisj at rtems.org> wrote:
>>>>>>>>>>>>>>>>>>>>>> On 04/04/2018 06:36, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>>>>>>>>>>>> > after pulling the ini-update branch from
>>>>>>>>>>>>>>>>>>>>>> tree/ini-update
>>>>>>>>>>>>>>>>>>>>>> Any local changes?
>>>>>>>>>>>>>>>>>>>>>> > I tried running the rtems-test with the following
>>>>>>>>>>>>>>>>>>>>>> command
>>>>>>>>>>>>>>>>>>>>>> > $HOME/development/rtems/rtems-
>>>>>>>>>>>>>>>>>>>>>> > --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>>> > --rtems-bsp=leon3_qemu --rtems-builddir=$HOME/
>>>>>>>>>>>>>>>>>>>>>> > was getting the KeyError for 'coverage'
>>>>>>>>>>>>>>>>>>>>>> Please paste the command and output as it appears in
>>>>>>>>>>>>>>>>>>>>>> the terminal?
>>>>>>>>>>>>>>>>>>>>>> > current status :
>>>>>>>>>>>>>>>>>>>>>> > the same command gives the error :
>>>>>>>>>>>>>>>>>>>>>> > "mandatory item not found in bsp section : bsp,"
>>>>>>>>>>>>>>>>>>>>>> > to make sure I didn't break something , I also
>>>>>>>>>>>>>>>>>>>>>> tried running from a freshly
>>>>>>>>>>>>>>>>>>>>>> > downloaded directory as well, it gives the same
>>>>>>>>>>>>>>>>>>>>>> error.
>>>>>>>>>>>>>>>>>>>>>> Did you try running the following command from the
>>>>>>>>>>>>>>>>>>>>>> top of the source tree:
>>>>>>>>>>>>>>>>>>>>>> $ grep -r "mandatory item not found" *
>>>>>>>>>>>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180413/2057eca8/attachment-0001.html>
