error while running rtems-test with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Apr 16 07:05:15 UTC 2018
Ok thanks, so now we need to look into covoar.
Do you have any sample output that will give me an idea of what it should
look like ?
On Mon, 16 Apr 2018, 11:13 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
> Probably what'll happen is, when the reports are generating properly,
> Chris will review the changes and come up with a list of blockers that must
> be fixed before he would be happy accepting the code into rtems-tools
> master. Then when that's done you can submit the patches.
> The thing with the data missing from the reports is tricky because there's
> no error messages or log output to go on. Last time I seen that it was
> because we were changing how the symbols were parsed and they were being
> chopped up in odd ways and so none of them were found and so the report was
> empty. This time I'm not sure because we haven't changed anything like
> that. If I think of any clues, I'll let you know.
> On Mon, 16 Apr 2018, 05:36 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 15 April 2018 at 15:33, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> On 15 April 2018 at 10:09, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Not sure what's happening there. Send me a link to your github branch.
>>>> On 15 April 2018 at 09:35, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> On 15 April 2018 at 14:02, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On 15 April 2018 at 06:46, Vijay Kumar Banerjee <
>>>>>>> On 15 April 2018 at 01:45, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Switch one of these lines out in qemu.cfg.
>>>>>>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>>>> -nographic
>>>>>>>> #%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>>>>>>> -nographic
>>>>>>>> %define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>>>>> -nographic
>>>>>>>> Just comment out the one that's being used and uncomment one of the
>>>>>>>> others. It should cause a complaint when the tests are run and the qemu cmd
>>>>>>>> should show up in the log so we can take a look at it.
>>>>>>> error: qemu.cfg:71: execute failed: qemu-system-sparc -no-reboot
>>>>>>> -monitor null -serial stdio -nographic -no-reboot -monitor null -serial
>>>>>>> stdio -nographic -M leon3_generic -kernel /home/lunatic/development/
>>>>>>> rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/
>>>>>>> samples/unlimited/unlimited.exe: exit-code:1
>>>>>>> run: qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>>> -nographic -no-reboot -mo nitor null -serial stdio -nographic -M
>>>>>>> leon3_generic -kernel /home/lunatic/development/rtem
>>>>>>> s/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe
>>>>>>> -exec-trace /home/lunatic/development/rtems/kernel/leon3/sparc-
>>>>>>> rtems5/c/leon3/testsuites/samples/unlimi ted/unlimited.exe.cov
>>>>>> Are those line breaks actually there or is it from the copy and
>>>>>> paste. Like unlimi ted. If so that's definitely the problem. What does
>>>>>> your last section in qemu.cfg look like now? The execute section.
>>>>> They are from copy paste .
>>>>> I'm pasting the qemu.cfg here
>>>>> # RTEMS Tools Project (http://www.rtems.org/)
>>>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>>>> # All rights reserved.
>>>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>> # Redistribution and use in source and binary forms, with or without
>>>>> # modification, are permitted provided that the following conditions
>>>>> are met:
>>>>> # 1. Redistributions of source code must retain the above copyright
>>>>> notice,
>>>>> # this list of conditions and the following disclaimer.
>>>>> # 2. Redistributions in binary form must reproduce the above copyright
>>>>> notice,
>>>>> # this list of conditions and the following disclaimer in the
>>>>> documentation
>>>>> # and/or other materials provided with the distribution.
>>>>> # this software is provided by the copyright holders and contributors
>>>>> "as is"
>>>>> # and any express or implied warranties, including, but not limited
>>>>> to, the
>>>>> # implied warranties of merchantability and fitness for a particular
>>>>> purpose
>>>>> # are disclaimed. in no event shall the copyright holder or
>>>>> contributors be
>>>>> # liable for any direct, indirect, incidental, special, exemplary, or
>>>>> # consequential damages (including, but not limited to, procurement of
>>>>> # substitute goods or services; loss of use, data, or profits; or
>>>>> business
>>>>> # interruption) however caused and on any theory of liability, whether
>>>>> in
>>>>> # contract, strict liability, or tort (including negligence or
>>>>> otherwise)
>>>>> # arising in any way out of the use of this software, even if advised
>>>>> of the
>>>>> # possibility of such damage.
>>>>> # qemu
>>>>> # use a qemu command to run the executable in the qemu simulator.
>>>>> %include %{_configdir}/base.cfg
>>>>> %include %{_configdir}/checks.cfg
>>>>> # console.
>>>>> %define console_stdio
>>>>> %include %{_configdir}/console.cfg
>>>>> # rtems version
>>>>> %include %{_rtdir}/rtems/version.cfg
>>>>> # qemu common option patterns.
>>>>> -nographic
>>>>> -nographic
>>>>> #%define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>> -nographic
>>>>> %define qemu_opts_no_net -net none
>>>>> # qemu executable
>>>>> %ifn %{defined bsp_qemu_opts}
>>>>> %define bsp_qemu_opts %{nil}
>>>>> %endif
>>>>> %define qemu_cmd qemu-system-%{bsp_arch}
>>>>> %define qemu_opts %{bsp_qemu_opts}
>>>>> # Coverage analysis
>>>>> %define coverage_arg %{nil}
>>>>> %if %{defined _coverage}
>>>>> %if %{coverage_supported}
>>>>> %define coverage_arg -exec-trace %{test_executable}.cov
>>>>> %else
>>>>> %error "Coverage analysis unsupported for %{bsp}"
>>>>> %endif
>>>>> %endif
>>>>> # executable
>>>>> #%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel
>>>>> %{test_executable} %{coverage_arg}
>>> Just get rid of %{qemu_opts_base} (Theres a double count of options)
>>> and that should run without errors from the tester now. Unfortunately the
>>> report generated wont contain any data so we've moved on to problems in
>>> covoar now.
>> should I submit a patch now or should I apply the changes into current
>> master and them submit ?
>>>>> -nographic
>>>>> -nographic
>>>>> -nographic
>>>>>>>> On 14 April 2018 at 20:37, Vijay Kumar Banerjee <
>>>>>>>>> -- vijay
>>>>>>>>> On 15 April 2018 at 00:50, Vijay Kumar Banerjee <
>>>>>>>>>> On 14 April 2018 at 16:42, Cillian O'Donnell <
>>>>>>>>>>> On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>>>>>>> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>>> Getting this error now seems like something is missing.
>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>>>>>>>>>>>>> Coverage environment prepared
>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>> File "/home/lunatic/development/
>>>>>>>>>>>>> rtems/test/rtems-tools/tester/rtems-test", line 40, in
>>>>>>>>>>>>> <module>
>>>>>>>>>>>>> rt.test.run()
>>>>>>>>>>>>> rtems/test/rtems-tools/tester/rt/test.py", line 353, in run
>>>>>>>>>>>>> tst.reraise()
>>>>>>>>>>>>> rtems/test/rtems-tools/tester/rt/test.py", line 160, in
>>>>>>>>>>>>> reraise
>>>>>>>>>>>>> _test_reraise(*self.result)
>>>>>>>>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>>>>>>>> The reraise logic was moved to the rtemstoolkit last year:
>>>>>>>>>>>> https://git.rtems.org/rtems-tools/commit/?id=
>>>>>>>>>>>> fa81491764861e63785a3faa241c488469087209
>>>>>>>>>>>> It had some issues that have been fixed and it is being reused
>>>>>>>>>>>> else where in the tester.
>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <
>>>>>>>>>>>>> vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> On 13 April 2018 at 23:51, Cillian O'Donnell <
>>>>>>>>>>>>> <mailto:cpodonnell8 at gmail.com>> wrote:
>>>>>>>>>>>>> Hmmm it's not there. Even so I can almost guarantee
>>>>>>>>>>>>> you, the
>>>>>>>>>>>>> reason it's not running is that coverage_supported
>>>>>>>>>>>>> variable is
>>>>>>>>>>>>> not being found as true in qemu.cfg and so the the
>>>>>>>>>>>>> command to
>>>>>>>>>>>>> generated the trace files isn't run and there's no
>>>>>>>>>>>>> .cov files in
>>>>>>>>>>>>> the end. So that's what you'll have to dig into.
>>>>>>>>>>>>> Okay , I'll set it to global then.
>>>>>>>>>>>> Changes need to be on the latest version of master before I
>>>>>>>>>>>> will review them. The failure above indicate the code you have is not up to
>>>>>>>>>>>> date.
>>>>>>>>>>> Yes that was the plan. Just to check Vijay your starting point
>>>>>>>>>>> was using the ini-update branch from here?
>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>>> That branch is current rtems-tools master that I started to add
>>>>>>>>>>> things back in. The only reraise in there is the one improrted from
>>>>>>>>>>> rtemstoolkit.
>>>>>>>>>> yes this is the branch I'm using , I checked the reraise error , not
>>>>>>>>>> sure how it showed up buit I called it from the reraise module ,
>>>>>>>>>> and it got fixed . now I'm stuck here
>>>>>>>>>> error: config error: qemu.cfg:36: No 'target' defined
>>>>>>>>> okay , fixed that .
>>>>>>>>> still getting the warnings of the unable to read .cov
>>>>>>>>>> are we supposed to set the bsp to global as well ?
>>>>>>>>>>>> The change you have made is generating an exception in the
>>>>>>>>>>>> tester thread. If you want to continue down this path you will need to fix
>>>>>>>>>>>> what ever you have added.
>>>>>>>>>>>> The tests are run as threads separate from the main thread so
>>>>>>>>>>>> the exception is caught and re-raised in the main thread letting you know.
>>>>>>>>>>>> This is broken in the old code base you are using.
>>>>>>>>>>>> Why not investigate the reason as indicated and sort if out
>>>>>>>>>>>> what the new format configuration file needs?
>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180416/acb24b98/attachment-0001.html>
