error while running rtems-test with coverage
Cillian O'Donnell
cpodonnell8 at gmail.com
Mon Apr 16 07:24:01 UTC 2018
Yup good idea.
On Mon, 16 Apr 2018, 08:23 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> the coverage is running now, shall we start a new mail thread for
> covoar report ?
> -- vijay
> On 16 April 2018 at 12:35, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> Ok thanks, so now we need to look into covoar.
>> Do you have any sample output that will give me an idea of what it should
>> look like ?
>> On Mon, 16 Apr 2018, 11:13 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>> wrote:
>>> Probably what'll happen is, when the reports are generating properly,
>>> Chris will review the changes and come up with a list of blockers that must
>>> be fixed before he would be happy accepting the code into rtems-tools
>>> master. Then when that's done you can submit the patches.
>>> The thing with the data missing from the reports is tricky because
>>> there's no error messages or log output to go on. Last time I seen that it
>>> was because we were changing how the symbols were parsed and they were
>>> being chopped up in odd ways and so none of them were found and so the
>>> report was empty. This time I'm not sure because we haven't changed
>>> anything like that. If I think of any clues, I'll let you know.
>>> On Mon, 16 Apr 2018, 05:36 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 15 April 2018 at 15:33, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> On 15 April 2018 at 10:09, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> Not sure what's happening there. Send me a link to your github branch.
>>>>>> On 15 April 2018 at 09:35, Vijay Kumar Banerjee <
>>>>>>> On 15 April 2018 at 14:02, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> On 15 April 2018 at 06:46, Vijay Kumar Banerjee <
>>>>>>>>> On 15 April 2018 at 01:45, Cillian O'Donnell <
>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>> Switch one of these lines out in qemu.cfg.
>>>>>>>>>> #%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>>>>>> -nographic
>>>>>>>>>> #%define qemu_opts_base -no-reboot -serial null -serial
>>>>>>>>>> mon:stdio -nographic
>>>>>>>>>> %define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>>>>>>> -nographic
>>>>>>>>>> Just comment out the one that's being used and uncomment one of
>>>>>>>>>> the others. It should cause a complaint when the tests are run and the qemu
>>>>>>>>>> cmd should show up in the log so we can take a look at it.
>>>>>>>>> error: qemu.cfg:71: execute failed: qemu-system-sparc -no-reboot
>>>>>>>>> -monitor null -serial stdio -nographic -no-reboot -monitor null -serial
>>>>>>>>> stdio -nographic -M leon3_generic -kernel
>>>>>>>>> /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.exe:
>>>>>>>>> exit-code:1
>>>>>>>>> run: qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>>>>> -nographic -no-reboot -mo nitor null -serial stdio -nographic -M
>>>>>>>>> leon3_generic -kernel /home/lunatic/development/rtem
>>>>>>>>> -exec-trace
>>>>>>>>> ted/unlimited.exe.cov
>>>>>>>> Are those line breaks actually there or is it from the copy and
>>>>>>>> paste. Like unlimi ted. If so that's definitely the problem. What does
>>>>>>>> your last section in qemu.cfg look like now? The execute section.
>>>>>>> They are from copy paste .
>>>>>>> I'm pasting the qemu.cfg here
>>>>>>> # RTEMS Tools Project (http://www.rtems.org/)
>>>>>>> # Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
>>>>>>> # All rights reserved.
>>>>>>> # This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>>> # Redistribution and use in source and binary forms, with or without
>>>>>>> # modification, are permitted provided that the following conditions
>>>>>>> are met:
>>>>>>> # 1. Redistributions of source code must retain the above copyright
>>>>>>> notice,
>>>>>>> # this list of conditions and the following disclaimer.
>>>>>>> # 2. Redistributions in binary form must reproduce the above
>>>>>>> copyright notice,
>>>>>>> # this list of conditions and the following disclaimer in the
>>>>>>> documentation
>>>>>>> # and/or other materials provided with the distribution.
>>>>>>> # this software is provided by the copyright holders and
>>>>>>> contributors "as is"
>>>>>>> # and any express or implied warranties, including, but not limited
>>>>>>> to, the
>>>>>>> # implied warranties of merchantability and fitness for a particular
>>>>>>> purpose
>>>>>>> # are disclaimed. in no event shall the copyright holder or
>>>>>>> contributors be
>>>>>>> # liable for any direct, indirect, incidental, special, exemplary, or
>>>>>>> # consequential damages (including, but not limited to, procurement
>>>>>>> of
>>>>>>> # substitute goods or services; loss of use, data, or profits; or
>>>>>>> business
>>>>>>> # interruption) however caused and on any theory of liability,
>>>>>>> whether in
>>>>>>> # contract, strict liability, or tort (including negligence or
>>>>>>> otherwise)
>>>>>>> # arising in any way out of the use of this software, even if
>>>>>>> advised of the
>>>>>>> # possibility of such damage.
>>>>>>> # qemu
>>>>>>> # use a qemu command to run the executable in the qemu simulator.
>>>>>>> %include %{_configdir}/base.cfg
>>>>>>> %include %{_configdir}/checks.cfg
>>>>>>> # console.
>>>>>>> %define console_stdio
>>>>>>> %include %{_configdir}/console.cfg
>>>>>>> # rtems version
>>>>>>> %include %{_rtdir}/rtems/version.cfg
>>>>>>> # qemu common option patterns.
>>>>>>> -nographic
>>>>>>> #%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>>>>>> -nographic
>>>>>>> #%define qemu_opts_base -no-reboot -monitor null -serial stdio
>>>>>>> -nographic
>>>>>>> %define qemu_opts_no_net -net none
>>>>>>> # qemu executable
>>>>>>> %ifn %{defined bsp_qemu_opts}
>>>>>>> %define bsp_qemu_opts %{nil}
>>>>>>> %endif
>>>>>>> %define qemu_cmd qemu-system-%{bsp_arch}
>>>>>>> %define qemu_opts %{bsp_qemu_opts}
>>>>>>> # Coverage analysis
>>>>>>> %define coverage_arg %{nil}
>>>>>>> %if %{defined _coverage}
>>>>>>> %if %{coverage_supported}
>>>>>>> %define coverage_arg -exec-trace %{test_executable}.cov
>>>>>>> %else
>>>>>>> %error "Coverage analysis unsupported for %{bsp}"
>>>>>>> %endif
>>>>>>> %endif
>>>>>>> # executable
>>>>>>> #%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
>>>>>>> %execute %{qemu_cmd} %{qemu_opts_base} %{qemu_opts} -kernel
>>>>>>> %{test_executable} %{coverage_arg}
>>>>> Just get rid of %{qemu_opts_base} (Theres a double count of options)
>>>>> and that should run without errors from the tester now. Unfortunately the
>>>>> report generated wont contain any data so we've moved on to problems in
>>>>> covoar now.
>>>> should I submit a patch now or should I apply the changes into current
>>>> master and them submit ?
>>>>>>> -nographic
>>>>>>> -nographic
>>>>>>> -nographic
>>>>>>>>>> On 14 April 2018 at 20:37, Vijay Kumar Banerjee <
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 15 April 2018 at 00:50, Vijay Kumar Banerjee <
>>>>>>>>>>>> On 14 April 2018 at 16:42, Cillian O'Donnell <
>>>>>>>>>>>>> On 14 April 2018 at 07:11, Chris Johns <chrisj at rtems.org>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> On 14/4/18 8:02 am, Vijay Kumar Banerjee wrote:
>>>>>>>>>>>>>>> Getting this error now seems like something is missing.
>>>>>>>>>>>>>>> RTEMS Testing - Tester, 5 (b2ba08b0da42 modified)
>>>>>>>>>>>>>>> Coverage environment prepared
>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/test/rtems-tools/tester/rtems-test", line
>>>>>>>>>>>>>>> 40, in <module>
>>>>>>>>>>>>>>> rt.test.run()
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/lunatic/development/rtems/test/rtems-tools/tester/rt/test.py", line
>>>>>>>>>>>>>>> 353, in run
>>>>>>>>>>>>>>> tst.reraise()
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> 160, in reraise
>>>>>>>>>>>>>>> _test_reraise(*self.result)
>>>>>>>>>>>>>>> NameError: global name '_test_reraise' is not defined
>>>>>>>>>>>>>> The reraise logic was moved to the rtemstoolkit last year:
>>>>>>>>>>>>>> https://git.rtems.org/rtems-tools/commit/?id=fa81491764861e63785a3faa241c488469087209
>>>>>>>>>>>>>> It had some issues that have been fixed and it is being
>>>>>>>>>>>>>> reused else where in the tester.
>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>> On 13 April 2018 at 23:57, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>> vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>
>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> On 13 April 2018 at 23:51, Cillian O'Donnell <
>>>>>>>>>>>>>>> <mailto:cpodonnell8 at gmail.com>> wrote:
>>>>>>>>>>>>>>> Hmmm it's not there. Even so I can almost guarantee
>>>>>>>>>>>>>>> you, the
>>>>>>>>>>>>>>> reason it's not running is that coverage_supported
>>>>>>>>>>>>>>> variable is
>>>>>>>>>>>>>>> not being found as true in qemu.cfg and so the the
>>>>>>>>>>>>>>> command to
>>>>>>>>>>>>>>> generated the trace files isn't run and there's no
>>>>>>>>>>>>>>> .cov files in
>>>>>>>>>>>>>>> the end. So that's what you'll have to dig into.
>>>>>>>>>>>>>>> Okay , I'll set it to global then.
>>>>>>>>>>>>>> Changes need to be on the latest version of master before I
>>>>>>>>>>>>>> will review them. The failure above indicate the code you have is not up to
>>>>>>>>>>>>>> date.
>>>>>>>>>>>>> Yes that was the plan. Just to check Vijay your starting point
>>>>>>>>>>>>> was using the ini-update branch from here?
>>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>>>>> That branch is current rtems-tools master that I started to
>>>>>>>>>>>>> add things back in. The only reraise in there is the one improrted from
>>>>>>>>>>>>> rtemstoolkit.
>>>>>>>>>>>> yes this is the branch I'm using , I checked the reraise error
>>>>>>>>>>>> , not sure how it showed up buit I called it from the reraise
>>>>>>>>>>>> module , and it got fixed . now I'm stuck here
>>>>>>>>>>>> error: config error: qemu.cfg:36: No 'target' defined
>>>>>>>>>>> okay , fixed that .
>>>>>>>>>>> still getting the warnings of the unable to read .cov
>>>>>>>>>>>> are we supposed to set the bsp to global as well ?
>>>>>>>>>>>>>> The change you have made is generating an exception in the
>>>>>>>>>>>>>> tester thread. If you want to continue down this path you will need to fix
>>>>>>>>>>>>>> what ever you have added.
>>>>>>>>>>>>>> The tests are run as threads separate from the main thread so
>>>>>>>>>>>>>> the exception is caught and re-raised in the main thread letting you know.
>>>>>>>>>>>>>> This is broken in the old code base you are using.
>>>>>>>>>>>>>> Why not investigate the reason as indicated and sort if out
>>>>>>>>>>>>>> what the new format configuration file needs?
>>>>>>>>>>>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180416/5a21a14d/attachment-0001.html>
