the generated coverage report doesn't contain any data
Cillian O'Donnell
cpodonnell8 at gmail.com
Tue Apr 17 06:29:28 UTC 2018
Also if there's any file in covoar directory of coverage-merge branch
that's called symbol-set.c symbol_set_reader.h or any variation of that,
that you don't already have pull all of them into your current branch.
On Tue, 17 Apr 2018, 07:19 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
> Some things are definitely missing there. Git checkout main.c
> coverage-merge. If you have that branch lying around, that definitely has
> everything in it. I must of missed of some things updating to current
> master. Fingers crossed this solves our problems
> On Mon, 16 Apr 2018, 22:52 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On Tue, 17 Apr 2018, 03:19 Joel Sherrill, <joel at rtems.org> wrote:
>>> On Mon, Apr 16, 2018 at 4:47 PM, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 17 April 2018 at 01:43, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> On 16 April 2018 at 17:46, Joel Sherrill <joel at rtems.org> wrote:
>>>>>> On Mon, Apr 16, 2018 at 2:33 AM, Vijay Kumar Banerjee <
>>>>>>> current status :
>>>>>>> the coverage is running now with rtems-test and generating the
>>>>>>> report, however, the report doesn't show any data.
>>>>>> I've been lurking as you have been making progress. Now you have
>>>>>> crossed
>>>>>> into something you probably need some hints at. Some things to check:
>>>>>> + Obviously, check output for signs that something didn't happen
>>>>>> right.
>>>>>> Anything from a path wrong, etc. The configuration has to be right to
>>>>>> point to the source code, object code, executables, etc.
>>>>>> + A lot of source code has moved around since last summer. Check
>>>>>> that it is looking in the right places inside RTEMS.
>>>>>> + Does the mechanism to get debug information actually work? Cillian?
>>>>> The covoar debug option just disables the cleaning of the tempfiles to
>>>>> take a look, so it's not as powerful as it might seem :)... I always used
>>>>> gdb here so that's probably the way to go.
>>>>>> + There is a utility named trace-converter. Make sure your qemu traces
>>>>>> have information in them.
>>>>>> + Cillian probably has guidance on running it just on one test (say
>>>>>> ticker)
>>>>>> so you can see every step.
>>>>>> + Check that the executables have symbolic information. "file" should
>>>>>> show if they are stripped or not.
>>>>>> I recall covoar has a verbose mode which should be of use.
>>>>>> Cillian .. do you have instructions on running covoar in gdb?
>>>>> Alright so run rtems-test with --no-clean option to leave the coverage
>>>>> files lying around
>>>>> $HOME/development/rtems/test/test/rtems-tools/tester/rtems-test
>>>>> --rtems-tools=$HOME/development/rtems/5 --log=coverage-analysis.log
>>>>> --rtems-bsp=leon3_qemu --coverage --no-clean
>>>>> --rtems-builddir=$HOME/development/rtems/leon3
>>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>>> Then run
>>>>> gdb covoar
>>>>> from gdb prompt
>>>>> run -S /home/cpod/coverage_test/leon3/coverage/score.symcfg -O
>>>>> /home/cpod/coverage_test/leon3/test/score -fQEMU -Tsparc-rtems5
>>>>> -E/home/cpod/development/rtems/test/test/vijay/rtems-tools/tester/rtems/testing/coverage/Explanations.txt
>>>>> -c.cov -eexe -pRTEMS-5
>>>>> /home/cpod/development/rtems/leon3/sparc-rtems5/c/leon3/testsuites/samples/base_sp/base_sp.exe
>>>>> The options there are ( if you're wondering )
>>>>> -c COVERAGEFILE_EXTENSION EXECUTABLE1 ... EXECUTABLE2
>>>>> -v - verbose output
>>>>> -T TARGET - architecture target name
>>>>> -f FORMAT - simulator format
>>>>> (RTEMS, QEMU, TSIM or Skyeye)
>>>>> -E EXPLANATIONS - file of explanations
>>>>> -s SYMBOLS_FILE - symbols of interest
>>>>> -S SYMBOL_SET_FILE - path to symbol_sets.cfg
>>>>> -1 EXECUTABLE - executable to get symbols from
>>>>> -e EXE_EXTENSION - suffix for executables
>>>>> -c COVERAGEFILE_EXT - coverage file suffix
>>>>> -g GCNOS_LIST - list of *.gcno files
>>>>> -p PROJECT_NAME - name of the project
>>>>> -O Output_Directory - output directory default=.
>>>>> -d debug - disable cleaning of tempfiles.
>>>> maybe the problem is here . I am getting an error for the -S . Here are
>>>> the list of options that show up , capital S for symbol_set_file is not one
>>>> of them .
>>>> Usage: /home/lunatic/development/rtems/5/bin/covoar [-v] -T TARGET -f
>>>> FORMAT [-E EXPLANATIONS] -e EXE_EXTENSION -c COVERAGEFILE_EXTENSION
>>>> -v - verbose at initialization
>>>> -T TARGET - target name
>>>> -f FORMAT - coverage file format (RTEMS, QEMU, TSIM
>>>> or Skyeye)
>>>> -E EXPLANATIONS - name of file with explanations
>>>> -s SYMBOLS_FILE - name of file with symbols of interest
>>>> -1 EXECUTABLE - name of executable to get symbols from
>>>> -e EXE_EXTENSION - extension of the executables to analyze
>>>> -c COVERAGEFILE_EXTENSION - extension of the coverage files to analyze
>>>> -g GCNOS_LIST - name of file with list of *.gcno files
>>>> -C ConfigurationFileName - name of configuration file
>>>> -O Output_Directory - name of output directory (default=.
>>> Is it processed by the getopts switch statement in main() but not listed
>>> in the usage? That is
>>> an easy mistake to creep in.
>> It gives an "invalid option" error
>>>>> Just trying it there, it runs into segmentation fault. So trying to
>>>>> access memory it shouldn't.
>>>>> Starting program: /home/cpod/covoar -S
>>>>> Reading configuration symbol set file:
>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>> 0x00007ffff7b769bb in std::__cxx11::basic_string<char,
>>>>> std::char_traits<char>, std::allocator<char>
>>>>> >::basic_string(std::__cxx11::basic_string<char, std::char_traits<char>,
>>>>> std::allocator<char> > const&) ()
>>>>> from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
>>>>> Ahhh feels good to have error messages back.
>>>>> Oh also build covoar with no optimization and you'll have an easier
>>>>> time looking at stuff in gdb
>>>>> cd rtems-tools/tester/covoar
>>>>> vim wscript and change the '-O2' to '-O0' and then build again with
>>>>> waf and use that covoar to with gdb
>>>>>>> -- vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180417/c1a8453d/attachment-0001.html>
