[PATCH] bsp-howto: Update BSP source code structure
Sebastian Huber
Tue Apr 17 09:33:17 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
bsp-howto/target_dependant_files.rst | 104 +++++++++++++----------------------
1 file changed, 38 insertions(+), 66 deletions(-)
diff --git a/bsp-howto/target_dependant_files.rst b/bsp-howto/target_dependant_files.rst
index fdfe5d2..bbd13ae 100644
--- a/bsp-howto/target_dependant_files.rst
+++ b/bsp-howto/target_dependant_files.rst
@@ -165,69 +165,41 @@ appropriate subdirectories for the specific CPU model your BSP has.
Board Support Package Structure
-The BSPs are all under the ``c/src/lib/libbsp`` directory. Below this
-directory, there is a subdirectory for each CPU family. Each BSP is found
-under the subdirectory for the appropriate processor family (arm, powerpc,
-sparc, etc.). In addition, there is source code available which may be shared
-across all BSPs regardless of the CPU family or just across BSPs within a
-single CPU family. This results in a BSP using the following directories:
-.. code-block:: c
- c/src/lib/libbsp/shared
- c/src/lib/libbsp/<CPU>/shared
- c/src/lib/libbsp/<CPU>/<BSP>
-Under each BSP specific directory, there is a collection of subdirectories.
-For commonly provided functionality, the BSPs follow a convention on
-subdirectory naming. The following list describes the commonly found
-subdirectories under each BSP.
-- ``console``:
- is technically the serial driver for the BSP rather than just a console
- driver, it deals with the board UARTs (i.e. serial devices).
-- ``clock``:
- support for the clock tick - a regular time basis to the kernel.
-- ``timer``:
- support of timer devices.
-- ``rtc`` or ``tod``:
- support for the hardware real-time clock.
-- ``nvmem``:
- support for non-volatile memory such as EEPROM or Flash.
-- ``network``:
- the Ethernet driver.
-- ``shmsupp``:
- support of shared memory driver MPCI layer in a multiprocessor system,
-- ``include``:
- include files for this BSP.
-- ``gnatsupp``:
- BSP specific support for the GNU Ada run-time. Each BSP that wishes to have
- the possibility to map faults or exceptions into Ada language exceptions or
- hardware interrupts into Ada interrupt tasks must provide this support.
-There may be other directories in the BSP tree and the name should be
-indicative of the functionality of the code within that directory.
-The build order of the BSP is determined by the Makefile structure. This
-structure is discussed in more detail in the :ref:`Makefiles` chapter.
-.. sidebar:
-This manual refers to the gen68340 BSP for numerous concrete examples. You
-should have a copy of the gen68340 BSP available while reading this piece of
-documentation. This BSP is located in the following directory:
-.. code-block:: c
- c/src/lib/libbsp/m68k/gen68340
-Later in this document, the $BSP340_ROOT label will be used to refer to this
-directory.
+The BSPs are all under the `bsps <https://git.rtems.org/rtems/tree/bsps>`_
+directory. The structure in the source subtree is:
+* :file:`bsps/shared`
+* :file:`bsps/@RTEMS_CPU@/shared`
+* :file:`bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILY@`
+The ``@RTEMS_CPU@`` is a particular architecture, e.g. arm,
+powerpc, sparc, etc. The ``@RTEMS_BSP_FAMILY@`` directories
+contain BSPs for a particular system on chip (SoC) or processor family.
+Use the following structure under the :file:`bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILY@`:
+* :file:`ata` - the legacy ATA/IDE driver.
+* :file:`cache` - cache controller support.
+* :file:`clock` - the clock driver.
+* :file:`config` - build system configuration files.
+* :file:`console` - the console driver.
+* :file:`contrib` - imports of external sources.
+ * The layout of external sources should be used as is if possible.
+* :file:`i2c` - the I2C driver.
+* :file:`include` - public header files.
+* :file:`irq` - the interrupt controller support.
+* :file:`mpci` - support for heterogeneous multiprocessing
+ (``RTEMS_MULTIPROCESSING``).
+* :file:`net` - legacy network stack drivers.
+* :file:`rtc` - the RTC driver.
+* :file:`spi` - the SPI driver.
+* :file:`start` - everything required to run a minimal application without
+ devices.
+ * :file:`start.S` - lowest level startup code.
+ * :file:`bspstart.c` - low level startup code.
+ * :file:`bspsmp.c` - SMP support.
+ * :file:`linkcmds` - the linker command file.
+* :file:`btimer` - the benchmark timer driver.
2.12.3
