[PATCH v2] 5: Use a specific RTEMS tools version
Wed Apr 18 06:12:55 UTC 2018
On 18/04/2018 15:53, Sebastian Huber wrote:
> On 18/04/18 07:51, Sebastian Huber wrote:
>> Download via cgit archive.
>> Close #3403.
> The rtems-tools-common-1.cfg seems to be only used by rtems-tools-5-1.cfg. Maybe
> we can merge these two files. The %{rsb_released} stuff makes the logic a bit
> complicated.
It would be best to push as much common logic down to `rtems-tools-common-1.cfg`
so `rtems-tools-5-1.cfg` is simple so `rtems-tools-6-1.cfg` is simple to make.
Carrying the logic in `rtems-tools-5-1.cfg` means the change history is lost in
the next release.
