Fwd: Deprecation of powerpc*-*-*spe*
Wed Apr 18 14:10:25 UTC 2018
FYI
---------- Forwarded message ----------
Date: Wed, Apr 18, 2018 at 3:57 AM
Subject: Deprecation of powerpc*-*-*spe*
To: gcc at gcc.gnu.org
As has been discussed in the
https://gcc.gnu.org/ml/gcc/2017-02/msg00041.html
https://gcc.gnu.org/ml/gcc-patches/2017-05/msg01227.html
https://gcc.gnu.org/ml/gcc-patches/2018-04/msg00810.html
threads and in
https://gcc.gnu.org/PR81084
the powerpc*-*-*spe* support which has been split into a separate backend
hasn't been given enough maintainance and so is deprecated in GCC 8.
It can still be built with --enable-obsolete.  If the maintainers don't
manage to remove the dead parts of the port and start actually maintaining
it early in the GCC 9 stage1 development, the port will be removed.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180418/1500ad60/attachment.html>
