[PATCH 05/40] bsps: Move uart-output-char.c to bsps
Thu Apr 19 13:26:30 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
 .../lib/libbsp/shared/src => bsps/shared/dev/serial}/uart-output-char.c | 0
 c/src/lib/libbsp/arm/lpc176x/Makefile.am                                | 2 +-
 c/src/lib/libbsp/arm/lpc24xx/Makefile.am                                | 2 +-
 c/src/lib/libbsp/arm/lpc32xx/Makefile.am                                | 2 +-
 4 files changed, 3 insertions(+), 3 deletions(-)
 rename {c/src/lib/libbsp/shared/src => bsps/shared/dev/serial}/uart-output-char.c (100%)
diff --git a/c/src/lib/libbsp/shared/src/uart-output-char.c b/bsps/shared/dev/serial/uart-output-char.c
similarity index 100%
rename from c/src/lib/libbsp/shared/src/uart-output-char.c
rename to bsps/shared/dev/serial/uart-output-char.c
diff --git a/c/src/lib/libbsp/arm/lpc176x/Makefile.am b/c/src/lib/libbsp/arm/lpc176x/Makefile.am
index e1059fe3ac..8817a283c5 100644
--- a/c/src/lib/libbsp/arm/lpc176x/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc176x/Makefile.am
@@ -46,7 +46,7 @@ librtemsbsp_a_SOURCES += ../../shared/bspgetworkarea.c
 librtemsbsp_a_SOURCES += ../../shared/bsppredriverhook.c
 librtemsbsp_a_SOURCES += ../../shared/sbrk.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/stackalloc.c
-librtemsbsp_a_SOURCES += ../../shared/src/uart-output-char.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/uart-output-char.c
 # Startup
 librtemsbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
diff --git a/c/src/lib/libbsp/arm/lpc24xx/Makefile.am b/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
index ea6f3c36ba..a4b5857244 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
@@ -55,7 +55,7 @@ librtemsbsp_a_SOURCES += ../../shared/bspgetworkarea.c
 librtemsbsp_a_SOURCES += ../../shared/cpucounterdiff.c
 # Startup
diff --git a/c/src/lib/libbsp/arm/lpc32xx/Makefile.am b/c/src/lib/libbsp/arm/lpc32xx/Makefile.am
index bf633287d4..33531d516c 100644
--- a/c/src/lib/libbsp/arm/lpc32xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc32xx/Makefile.am
@@ -47,7 +47,7 @@ librtemsbsp_a_SOURCES += ../../shared/bsppredriverhook.c
 librtemsbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
2.12.3
