[PATCH 21/40] bsps: Move pci_bus_count.c to bsps
Thu Apr 19 13:26:46 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
 {c/src/lib/libbsp/shared => bsps/shared/dev}/pci/pci_bus_count.c | 0
 c/src/lib/libbsp/i386/pc386/Makefile.am                          | 2 +-
 2 files changed, 1 insertion(+), 1 deletion(-)
 rename {c/src/lib/libbsp/shared => bsps/shared/dev}/pci/pci_bus_count.c (100%)
diff --git a/c/src/lib/libbsp/shared/pci/pci_bus_count.c b/bsps/shared/dev/pci/pci_bus_count.c
similarity index 100%
rename from c/src/lib/libbsp/shared/pci/pci_bus_count.c
rename to bsps/shared/dev/pci/pci_bus_count.c
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
index d50edebfee..c8981800b7 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -100,7 +100,7 @@ librtemsbsp_a_SOURCES += ../shared/comm/gdb_glue.c
 # pci
 librtemsbsp_a_SOURCES += ../shared/pci/pcibios.c
 librtemsbsp_a_SOURCES += ../shared/pci/pci_io.c
-librtemsbsp_a_SOURCES += ../../shared/pci/pci_bus_count.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/pci/pci_bus_count.c
 librtemsbsp_a_SOURCES += ../../shared/pci/pci_find_device.c
 # startup
2.12.3
