[PATCH 23/40] bsps: Remove unused rtems-stub-glue.c
Thu Apr 19 13:26:48 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
 c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c | 1341 ---------------------
 1 file changed, 1341 deletions(-)
 delete mode 100644 c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c
diff --git a/c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c b/c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c
deleted file mode 100644
index 49e4f31843..0000000000
--- a/c/src/lib/libbsp/shared/gdbstub/rtems-stub-glue.c
+++ /dev/null
@@ -1,1341 +0,0 @@
- *  This file contains the RTEMS thread awareness support for GDB stubs.
- *  This file is derived from an RTEMS thread aware i386-stub.c that
- *  had the following copyright announcements:
- *    This software is Copyright (C) 1998 by T.sqware - all rights limited
- *    It is provided in to the public domain "as is", can be freely modified
- *    as far as this copyight notice is kept unchanged, but does not imply
- *    an endorsement by T.sqware of the product in which it is included.
- *     Modifications for RTEMS threads and more
- *     Copyright (C) 2000 Quality Quorum, Inc.
- *     All Rights Reserved
- *     Permission to use, copy, modify, and distribute this software and its
- *     documentation for any purpose and without fee is hereby granted.
- *     QQI DISCLAIMS ALL WARRANTIES WITH REGARD TO THIS SOFTWARE, INCLUDING
- *     ALL IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS, IN NO EVENT SHALL
- *     QQI BE LIABLE FOR ANY SPECIAL, INDIRECT OR CONSEQUENTIAL DAMAGES OR
- *     ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
- *     WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
- *     ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
- *     SOFTWARE.
-#include <rtems.h>
-#include <rtems/score/sysstate.h>
-#include <rtems/score/objectimpl.h>
-#include <string.h>
-#include "gdb_if.h"
-/* Change it to something meaningful when debugging */
-#undef ASSERT
-#define ASSERT(x)
-extern const char gdb_hexchars[];
- *  Prototypes for CPU dependent routines that are conditional
- *  at the bottom of this file.
-void rtems_gdb_stub_get_registers_from_context(
-  unsigned int   *registers,
-  Thread_Control *th
-/* Check whether it is OK to enable thread support */
-int rtems_gdb_stub_thread_support_ok(void)
-  if (_System_state_Get() == SYSTEM_STATE_UP) {
-    return 1;
-  return 0;
- *  rtems_gdb_stub_id_to_index
- *  Return the gdb thread id for the specified RTEMS thread id
-static int rtems_gdb_stub_id_to_index(
-  Objects_Id thread_obj_id
-  int gdb_index = 0;
-  int first = 1;
-  size_t api_index;
-  if (_System_state_Get() != SYSTEM_STATE_UP) {
-    /* We have one thread let us use value reserved for idle thread */
-    gdb_index = 1;
-  for (
-    api_index = 1;
-    gdb_index == 0 && api_index <= OBJECTS_APIS_LAST;
-    ++api_index
-    if (_Objects_Information_table[api_index] != NULL) {
-      const Objects_Information *info =
-        _Objects_Information_table[api_index][1];
-      Objects_Id min_id = info->minimum_id;
-      Objects_Id max_id = info->maximum_id;
-      int last = first + (int) (max_id - min_id);
-      if (thread_obj_id >= min_id && thread_obj_id < max_id) {
-        gdb_index = first + (int) (thread_obj_id - min_id);
-      first = last + 1;
-  return gdb_index;
-/* Return the RTEMS thread id from a gdb thread id */
-Thread_Control *rtems_gdb_index_to_stub_id(
-  int gdb_index
-  Thread_Control *th = NULL;
-  int first = 1;
-  size_t api_index;
-  ASSERT(registers != NULL);
-  if (_System_state_Get() != SYSTEM_STATE_UP || gdb_index <= 0) {
-     /* Should not happen */
-     return NULL;
-  for (
-    api_index = 1;
-    th == NULL && api_index <= OBJECTS_APIS_LAST;
-    ++api_index
-      if (gdb_index <= first + (int) (max_id - min_id)) {
-        th = (Thread_Control *)
-          info->local_table[gdb_index - first + 1];
-      first = last + 1;
-  return th;
-/* Get id of the thread stopped by exception */
-int rtems_gdb_stub_get_current_thread(void)
-  return rtems_gdb_stub_id_to_index( rtems_task_self() );
-/* Get id of the next thread after athread, if argument <= 0 find the
-   first available thread, return thread if found or 0 if not */
-int rtems_gdb_stub_get_next_thread(int gdb_index)
-  int next_gdb_index = 0;
-  int first = 1;
-  size_t api_index;
-    /* We have one thread let us use value of idle thread */
-    return (gdb_index < 1) ? 1 : 0;
-  for (
-    api_index = 1;
-    next_gdb_index == 0 && api_index <= OBJECTS_APIS_LAST;
-    ++api_index
-      if (gdb_index <= last) {
-        int start = gdb_index < first ? first : gdb_index + 1;
-        int potential_next;
-        for (
-          potential_next = start;
-          next_gdb_index == 0 && potential_next <= last;
-          ++potential_next
-          if (info->local_table[potential_next - first + 1] != NULL) {
-            next_gdb_index = potential_next;
-      first = last + 1;
-  return next_gdb_index;
-/* Get thread registers, return 0 if thread does not
-   exist, and 1 otherwise */
-int rtems_gdb_stub_get_thread_regs(
-  int thread,
-   Thread_Control *th;
-   th= rtems_gdb_index_to_stub_id(thread);
-   if( th )
-      rtems_gdb_stub_get_registers_from_context( registers, th );
-      return 1;
-   return 0;
-/* Set thread registers, return 0 if thread does not
-   exist or register values will screw up the threads,
-   and 1 otherwise */
-int rtems_gdb_stub_set_thread_regs(
-  int thread,
-  /* In current situation there is no point in changing any registers here
-     thread status is displayed as being deep inside thread switching
-     and we better do not screw up anything there - it may be fixed eventually
-     though */
-  return 1;
-/* Get thread information, return 0 if thread does not
-   exist and 1 otherwise */
-static int rtems_gdb_stub_get_thread_info(
-  int gdb_index,
-  struct rtems_gdb_stub_thread_info *info
-   int first = 1;
-   size_t api_index;
-   ASSERT(info != NULL);
-   if (gdb_index <= 0) {
-      return 0;
-   if (_System_state_Get() != SYSTEM_STATE_UP || gdb_index == 1) {
-         which will never happen for real thread */
-      strcpy(info->display, "idle thread");
-      strcpy(info->name, "IDLE");
-      info->more_display[0] = 0; /* Nothing */
-      return 1;
-   for (
-     api_index = 1;
-     api_index <= OBJECTS_APIS_LAST;
-     ++api_index
-       const Objects_Information *obj_info =
-       Objects_Id min_id = obj_info->minimum_id;
-       Objects_Id max_id = obj_info->maximum_id;
-         Thread_Control *th = (Thread_Control *)
-           obj_info->local_table[gdb_index - first + 1];
-         if (th != NULL) {
-           char tmp_buf[9];
-           strcpy(info->display, "task: control at 0x");
-           tmp_buf[0] = gdb_hexchars[(((int)th) >> 28) & 0xf];
-           tmp_buf[1] = gdb_hexchars[(((int)th) >> 24) & 0xf];
-           tmp_buf[2] = gdb_hexchars[(((int)th) >> 20) & 0xf];
-           tmp_buf[3] = gdb_hexchars[(((int)th) >> 16) & 0xf];
-           tmp_buf[4] = gdb_hexchars[(((int)th) >> 12) & 0xf];
-           tmp_buf[5] = gdb_hexchars[(((int)th) >> 8) & 0xf];
-           tmp_buf[6] = gdb_hexchars[(((int)th) >> 4) & 0xf];
-           tmp_buf[7] = gdb_hexchars[((int)th) & 0xf];
-           tmp_buf[8] = 0;
-           strcat(info->display, tmp_buf);
-           rtems_object_get_name( th->Object.id, 5, info->name );
-           return 1;
-         } else {
-           /* Thread does not exist */
-           return 0;
-       first = last + 1;
-   return 0;
-/* Format: x<type-1x>,<address-x>,<length-x>, where x is 'z' or 'Z' */
-int parse_zbreak(const char *in, int *type, unsigned char **addr, int *len)
-  int ttmp, atmp, ltmp;
-  ASSERT(in != NULL);
-  ASSERT(type != NULL);
-  ASSERT(addr != NULL);
-  ASSERT(len != NULL);
-  ASSERT(*in == 'z' || *in == 'Z');
-  in++;
-  if (!hstr2nibble(in, &ttmp) || *(in+1) != ',')
-      return 0;
-  in += 2;
-  in = vhstr2int(in, &atmp);
-  if (in == NULL || *in != ',')
-      return 0;
-  in++;
-  in = vhstr2int(in, &ltmp);
-  if (in == NULL || ltmp < 1)
-      return 0;
-  *type = ttmp;
-  *addr = (unsigned char *)atmp;
-  *len  = ltmp;
-  return 1;
-/* Format: qP<mask-08x><thread_id-ft> */
-static int
-parse_qp(const char *in, int *mask, int *thread)
-  const char *ptr;
-  ASSERT(*in == 'q');
-  ASSERT(*(in+1) == 'P');
-  ptr = fhstr2int(in+2, mask);
-  if (ptr == NULL)
-      return 0;
-  ptr = fhstr2thread(ptr, thread);
-  if (ptr == NULL)
-      return 0;
-  return 1;
-/* Format: qQ<mask-08x><thread_id-ft><tag-08x><length-02x><value>...] */
-static void
-pack_qq(char *out, int mask, int thread, struct rtems_gdb_stub_thread_info *info)
-  int len;
-  ASSERT(out != NULL);
-  *out++ = 'q';
-  *out++ = 'Q';
-  out = int2fhstr(out, mask);
-  out = thread2fhstr(out, thread);
-  if (mask & 0x1) {
-    /* Thread id once again */
-    memcpy(out, "00000001", 8);
-    out   += 8;
-    *out++ = '1';
-    *out++ = '0';
-  if (mask & 0x2) {
-    /* Exists */
-    memcpy(out, "00000002", 8);
-    out   += 8;
-    *out++ = '0';
-    *out++ = '1';
-    *out++ = '1';
-  if (mask & 0x4) {
-    /* Display */
-    memcpy(out, "00000004", 8);
-    out += 8;
-    info->display[sizeof(info->display)-1] = 0; /* Fot God sake */
-    len = strlen(info->display);
-    *out++ = gdb_hexchars[len >> 4];
-    *out++ = gdb_hexchars[len & 0x0f];
-    memcpy(out, info->display, len);
-    out += len;
-  if (mask & 0x8) {
-    /* Name */
-    memcpy(out, "00000008", 8);
-    out += 8;
-    info->name[sizeof(info->name)-1] = 0; /* Fot God sake */
-    len = strlen(info->name);
-    memcpy(out, info->name, len);
-    out += len;
-  if (mask & 0x10) {
-    /* More display */
-    memcpy(out, "00000010", 8);
-    out += 8;
-    info->more_display[sizeof(info->more_display)-1] = 0; /* Fot God sake */
-    len = strlen(info->more_display);
-    memcpy(out, info->more_display, len);
-    out += len;
-  *out = 0;
-  return;
-/* Format qL<first-01x><max_count-02x><arg_thread_id-ft> */
-static int
-parse_ql(const char *in, int *first, int *max_count, int *athread)
-  const char *ptr;
-  ASSERT(*(in+1) == 'L');
-  ASSERT(first != NULL);
-  ASSERT(max_count != NULL);
-  ASSERT(athread != NULL);
-  ptr = in + 2;
-  /*  First */
-  if (!hstr2nibble(ptr, first))
-      return 0;
-  ptr++;
-  /* Max count */
-  if (!hstr2byte(ptr, max_count))
-      return 0;
-  ptr += 2;
-  /* A thread */
-  ptr = fhstr2thread(ptr, athread);
-  if (ptr == NULL)
-      return 0;
-  return 1;
-/* Format: qM<count-02x><done-01x><arg_thread_id>[<found_thread_id-ft>...] */
-static char *
-reserve_qm_header(char *out)
-  return out + 21;
-static char*
-pack_qm_thread(char *out, int thread)
-  ASSERT(out != 0);
-  return thread2fhstr(out, thread);
-static void
-pack_qm_header(char *out, int count, int done, int athread)
-   ASSERT(out != 0);
-   ASSERT(count >= 0 && count < 256);
-   *out++ = 'q';
-   *out++ = 'M';
-   *out++ = gdb_hexchars[(count >> 4) & 0x0f];
-   *out++ = gdb_hexchars[count & 0x0f];
-   if (done) {
-      *out++ = '1';
-   } else {
-      *out++ = '0';
-   thread2fhstr(out, athread);
-   return;
-void rtems_gdb_process_query(
-  char *inbuffer,
-  char *outbuffer,
-  int   do_threads,
-  int   thread
-  char *optr;
-  switch(inbuffer[1]) {
-    case 'C':
-      /* Current thread query query - return stopped thread */
-      if (!do_threads) {
-        break;
-      optr = outbuffer;
-      *optr++ = 'Q';
-      *optr++ = 'C';
-      optr    = thread2vhstr(optr, thread);
-      *optr   = 0;
-      break;
-    case 'P':
-      /* Thread info query */
-        break;
-        int ret, rthread, mask;
-        struct rtems_gdb_stub_thread_info info;
-        ret = parse_qp(inbuffer, &mask, &rthread);
-        if (!ret|| mask & ~0x1f) {
-          strcpy(outbuffer, "E01");
-          break;
-        ret = rtems_gdb_stub_get_thread_info(rthread, &info);
-        if (!ret) {
-          /* Good implementation would never ask for non-existing thread,
-             should we care about bad ones - it does not seem so */
-          strcpy(outbuffer, "E02");
-          break;
-        /* Build response */
-        pack_qq(outbuffer, mask, rthread, &info);
-      break;
-    case 'L':
-      /* Thread list query */
-        break;
-        int ret, athread, first, max_cnt, i, done, rthread;
-        ret = parse_ql(inbuffer, &first, &max_cnt, &athread);
-        if (!ret) {
-          break;
-        if (max_cnt == 0) {
-          break;
-        if (max_cnt > QM_MAX_THREADS) {
-          /* Limit max count by buffer size */
-          max_cnt = QM_MAX_THREADS;
-        /* Reserve place for output header */
-        optr = reserve_qm_header(outbuffer);
-        if (first) {
-          rthread = 0;
-        } else {
-          rthread = athread;
-        done = 0;
-        for (i=0; i<max_cnt; i++) {
-          rthread = rtems_gdb_stub_get_next_thread(rthread);
-          if (rthread <= 0) {
-            done = 1; /* Set done flag */
-            break;
-          optr = pack_qm_thread(optr, rthread);
-        *optr = 0;
-        ASSERT((optr - outbuffer) < BUFMAX);
-        /* Fill header */
-        pack_qm_header(outbuffer, i, done, athread);
-      break;
-    default:
-      if (memcmp(inbuffer, "qOffsets", 8) == 0) {
-        unsigned char *t, *d, *b;
-        char *out;
-        if (!rtems_gdb_stub_get_offsets(&t, &d, &b)) {
-          break;
-        out = outbuffer;
-        *out++ = 'T';
-        *out++ = 'e';
-        *out++ = 'x';
-        *out++ = 't';
-        *out++ = '=';
-        out = int2vhstr(out, (int)t);
-        *out++ = ';';
-        *out++ = 'D';
-        *out++ = 'a';
-        *out++ = 't';
-        *out++ = 'a';
-        *out++ = '=';
-        out = int2vhstr(out, (int)d);
-        *out++ = ';';
-        *out++ = 'B';
-        *out++ = 's';
-        *out++ = 's';
-        *out++ = '=';
-        out = int2vhstr(out, (int)b);
-        *out++ = ';';
-        *out++ = 0;
-        break;
-      /*  qCRC, qRcmd, qu and qz will be added here */
-      break;
-/* Present thread in the variable length string format */
-char*
-thread2vhstr(char *buf, int thread)
-  int i, nibble, shift;
-  ASSERT(buf != NULL);
-  for(i=0, shift=28; i<8; i++, shift-=4)
-      nibble = (thread >> shift) & 0x0f;
-      if (nibble != 0)
-	  break;
-  if (i == 8)
-      *buf++ = '0';
-      return buf;
-  *buf++ = gdb_hexchars[nibble];
-  for(i++, shift-=4; i<8; i++, shift-=4, buf++)
-      *buf   = gdb_hexchars[nibble];
-  return buf;
-/* Present thread in fixed length string format */
-char*
-thread2fhstr(char *buf, int thread)
-  for(i=0; i<8; i++, buf++)
-      *buf = '0';
-  for(i=0, shift=28; i<8; i++, shift-=4, buf++)
-  return buf;
-/* Parse thread presented in fixed length format */
-const char*
-fhstr2thread(const char *buf, int *thread)
-  int i, val, nibble;
-  ASSERT(thread != NULL);
-      if (*buf != '0')
-	  return NULL;
-  val = 0;
-      if (!hstr2nibble(buf, &nibble))
-	  return NULL;
-      ASSERT(nibble >=0 && nibble < 16);
-      val = (val << 4) | nibble;
-  *thread = val;
-  return buf;
-/* Parse thread presented in variable length format */
-const char*
-vhstr2thread(const char *buf, int *thread)
-  int found_zero, lim;
-  /* If we have leading zeros, skip them */
-  found_zero = 0;
-  for(i=0; i<16; i++, buf++)
-      if (*buf != '0')
-	  break;
-      found_zero = 1;
-  /* Process non-zeros */
-  lim = 16 - i;
-  val = 0;
-  for(i=0; i<lim; i++, buf++)
-	  if (i == 0 && !found_zero)
-	      /* Empty value */
-	      return NULL;
-	  *thread = val;
-	  return buf;
-      ASSERT(nibble >= 0 && nibble < 16);
-  if (hstr2nibble(buf, &nibble))
-      /* Value is too long */
-      return NULL;
-  *thread = val;
-  return buf;
-/* Present integer in the variable length string format */
-char*
-int2vhstr(char *buf, int val)
-      nibble = (val >> shift) & 0x0f;
-      if (nibble != 0)
-	  break;
-  if (i == 8)
-      *buf++ = '0';
-      return buf;
-  return buf;
-/* Present int in fixed length string format */
-char*
-int2fhstr(char *buf, int val)
-  return buf;
-/* Parse int presented in fixed length format */
-const char*
-fhstr2int(const char *buf, int *ival)
-  ASSERT(ival != NULL);
-  val = 0;
-	  return NULL;
-  *ival = val;
-  return buf;
-/* Parse int presented in variable length format */
-const char*
-vhstr2int(const char *buf, int *ival)
-  found_zero = 0;
-      if (*buf != '0')
-	  break;
-      found_zero = 1;
-  lim = 8 - i;
-  val = 0;
-	      /* Empty value */
-	      return NULL;
-	  *ival = val;
-	  return buf;
-      return NULL;
-  *ival = val;
-  return buf;
-int
-hstr2byte(const char *buf, int *bval)
-  int hnib, lnib;
-  ASSERT(bval != NULL);
-  if (!hstr2nibble(buf, &hnib) || !hstr2nibble(buf+1, &lnib))
-      return 0;
-  *bval = (hnib << 4) | lnib;
-  return 1;
-int
-hstr2nibble(const char *buf, int *nibble)
-  int ch;
-  ASSERT(nibble != NULL);
-  ch = *buf;
-  if (ch >= '0' && ch <= '9')
-      *nibble = ch  - '0';
-      return 1;
-  if (ch >= 'a' && ch <= 'f')
-      *nibble = ch - 'a' + 10;
-      return 1;
-  if (ch >= 'A' && ch <= 'F')
-      *nibble = ch - 'A' + 10;
-      return 1;
-  return 0;
-static volatile char mem_err = 0;
-void  set_mem_err(void);
-static void (*volatile mem_fault_routine) (void) = NULL;
-/* convert count bytes of the memory pointed to by mem into hex string,
-   placing result in buf, return pointer to next location in hex strng
-   in case of success or NULL otherwise */
-char*
-mem2hstr(char *buf, const unsigned char *mem, int count)
-  int i;
-  unsigned char ch;
-  mem_err = 0;
-  mem_fault_routine = set_mem_err;
-  for (i = 0; i<count; i++, mem++)
-      ch = get_byte (mem);
-      if (mem_err)
-	  mem_fault_routine = NULL;
-	  return NULL;
-      *buf++ = gdb_hexchars[ch >> 4];
-      *buf++ = gdb_hexchars[ch & 0x0f];
-  *buf = 0;
-  return buf;
-/* convert the hex string to into count bytes of binary to be placed in mem
-   return 1 in case of success and  0 otherwise */
-int
-hstr2mem (unsigned char *mem, const char *buf, int count)
-  int i;
-  int bval;
-  mem_err = 0;
-  for (i = 0; i < count; i++, mem++, buf+=2)
-      if (!hstr2byte(buf, &bval))
-	  return 0;
-      ASSERT(bval >=0 && bval < 256);
-      set_byte (mem, bval);
-      if (mem_err)
-	  return 0;
-  return 1;
-void
-set_mem_err (void)
-  mem_err = 1;
-/* These are separate functions so that they are so short and sweet
-   that the compiler won't save any registers (if there is a fault
-   to mem_fault, they won't get restored, so there better not be any
-   saved).  */
-unsigned char
-get_byte (const unsigned char *addr)
-  return *addr;
-void
-set_byte (unsigned char *addr, int val)
-  *addr = val;
- *  From here down, the code is CPU model specific and generally maps
- *  the RTEMS thread context format to gdb's.
-#if defined(__i386__)
-#include "i386-stub.h"
-/* Packing order of registers */
-enum i386_stub_regnames {
-  I386_STUB_REG_EAX, I386_STUB_REG_ECX, I386_STUB_REG_EDX, I386_STUB_REG_EBX,
-  I386_STUB_REG_ESP, I386_STUB_REG_EBP, I386_STUB_REG_ESI, I386_STUB_REG_EDI,
-  I386_STUB_REG_PC /* also known as eip */ ,
-  I386_STUB_REG_PS /* also known as eflags */ ,
-  I386_STUB_REG_CS, I386_STUB_REG_SS, I386_STUB_REG_DS, I386_STUB_REG_ES,
-  I386_STUB_REG_FS, I386_STUB_REG_GS
-  registers[I386_STUB_REG_EAX] = 0;
-  registers[I386_STUB_REG_ECX] = 0;
-  registers[I386_STUB_REG_EDX] = 0;
-  registers[I386_STUB_REG_EBX] = (int)th->Registers.ebx;
-  registers[I386_STUB_REG_ESP] = (int)th->Registers.esp;
-  registers[I386_STUB_REG_EBP] = (int)th->Registers.ebp;
-  registers[I386_STUB_REG_ESI] = (int)th->Registers.esi;
-  registers[I386_STUB_REG_EDI] = (int)th->Registers.edi;
-  registers[I386_STUB_REG_PC]  = *(int *)th->Registers.esp;
-  registers[I386_STUB_REG_PS]  = (int)th->Registers.eflags;
-  /* RTEMS never changes base registers (especially once
-     threads are running) */
-  registers[I386_STUB_REG_CS]  = 0x8; /* We just know these values */
-  registers[I386_STUB_REG_SS]  = 0x10;
-  registers[I386_STUB_REG_DS]  = 0x10;
-  registers[I386_STUB_REG_ES]  = 0x10;
-  registers[I386_STUB_REG_FS]  = 0x10;
-  registers[I386_STUB_REG_GS]  = 0x10;
-int rtems_gdb_stub_get_offsets(
-  unsigned char **text_addr,
-  unsigned char **data_addr,
-  unsigned char **bss_addr
-  extern unsigned char _text_start;
-  extern unsigned char _data_start;
-  extern unsigned char _bss_start;
-  *text_addr = &_text_start;
-  *data_addr = &_data_start;
-  *bss_addr  = &_bss_start;
-  return 1;
-#elif defined(__mips__)
-   registers[S0] = (unsigned)th->Registers.s0;
-   registers[S1] = (unsigned)th->Registers.s1;
-   registers[S2] = (unsigned)th->Registers.s2;
-   registers[S3] = (unsigned)th->Registers.s3;
-   registers[S4] = (unsigned)th->Registers.s4;
-   registers[S5] = (unsigned)th->Registers.s5;
-   registers[S6] = (unsigned)th->Registers.s6;
-   registers[S7] = (unsigned)th->Registers.s7;
-   registers[SP] = (unsigned)th->Registers.sp;
-   registers[RA] = (unsigned)th->Registers.ra;
-   registers[SR] = (unsigned)th->Registers.c0_sr;
-   registers[PC] = (unsigned)th->Registers.c0_epc;
-  extern uint32_t   _ftext;
-  extern uint32_t   _fdata;
-  extern uint32_t   _bss_start;
-  *text_addr = &_ftext;
-  *data_addr = &_fdata;
-  *text_addr = 0;
-  *data_addr = 0;
-  *bss_addr  = 0;
-  return 1;
-#elif defined(__mc68000__)
-   * how about register D0/D1/A0/A1
-   * they are located on thread stack ...
-   * -> they are not needed for context switch
-  registers[D0] = 0;
-  registers[D1] = 0;
-  registers[D2] = (uint32_t)th->Registers.d2;
-  registers[D3] = (uint32_t)th->Registers.d3;
-  registers[D4] = (uint32_t)th->Registers.d4;
-  registers[D5] = (uint32_t)th->Registers.d5;
-  registers[D6] = (uint32_t)th->Registers.d6;
-  registers[D7] = (uint32_t)th->Registers.d7;
-  registers[A0] = 0;
-  registers[A1] = 0;
-  registers[A2] = (uint32_t)th->Registers.a2;
-  registers[A3] = (uint32_t)th->Registers.a3;
-  registers[A4] = (uint32_t)th->Registers.a4;
-  registers[A5] = (uint32_t)th->Registers.a5;
-  registers[A6] = (uint32_t)th->Registers.a6;
-  registers[A7] = (uint32_t)th->Registers.a7_msp;
-  registers[PS] = (uint32_t)th->Registers.sr;
-#if 0
-  registers[PC] = *(uint32_t*)th->Registers.a7_msp; /* *SP = ret adr */
-#else
-  registers[PC] = (uint32_t)_CPU_Context_switch;
-#endif
-  *text_addr = 0;
-  *data_addr = 0;
-  *bss_addr  = 0;
-  return 1;
-#elif defined(__lm32__)
-  registers[LM32_REG_R11] = (uint32_t)th->Registers.r11;
-  registers[LM32_REG_R12] = (uint32_t)th->Registers.r12;
-  registers[LM32_REG_R13] = (uint32_t)th->Registers.r13;
-  registers[LM32_REG_R14] = (uint32_t)th->Registers.r14;
-  registers[LM32_REG_R15] = (uint32_t)th->Registers.r15;
-  registers[LM32_REG_R16] = (uint32_t)th->Registers.r16;
-  registers[LM32_REG_R17] = (uint32_t)th->Registers.r17;
-  registers[LM32_REG_R18] = (uint32_t)th->Registers.r18;
-  registers[LM32_REG_R19] = (uint32_t)th->Registers.r19;
-  registers[LM32_REG_R20] = (uint32_t)th->Registers.r20;
-  registers[LM32_REG_R21] = (uint32_t)th->Registers.r21;
-  registers[LM32_REG_R22] = (uint32_t)th->Registers.r22;
-  registers[LM32_REG_R23] = (uint32_t)th->Registers.r23;
-  registers[LM32_REG_R24] = (uint32_t)th->Registers.r24;
-  registers[LM32_REG_R25] = (uint32_t)th->Registers.r25;
-  registers[LM32_REG_GP] = (uint32_t)th->Registers.gp;
-  registers[LM32_REG_FP] = (uint32_t)th->Registers.fp;
-  registers[LM32_REG_SP] = (uint32_t)th->Registers.sp;
-  registers[LM32_REG_RA] = (uint32_t)th->Registers.ra;
-  registers[LM32_REG_IE] = (uint32_t)th->Registers.ie;
-#if 1
-  registers[LM32_REG_PC] = (uint32_t)th->Registers.epc;
-#else
-  registers[LM32_REG_PC] = (uint32_t)_CPU_Context_switch;
-#endif
-  *text_addr = 0;
-  *data_addr = 0;
-  *bss_addr  = 0;
-  return 1;
-#else
-#error "rtems-gdb-stub.c: Unsupported CPU!"
-#endif
2.12.3
