[PATCH 36/40] bsps: Move console-polled.c to bsps
Thu Apr 19 13:27:01 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
 {c/src/lib/libbsp/shared => bsps/shared/dev/serial}/console-polled.c | 0
 c/src/lib/libbsp/arm/gdbarmsim/Makefile.am                           | 2 +-
 c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am                   | 2 +-
 c/src/lib/libbsp/m32c/m32cbsp/Makefile.am                            | 2 +-
 c/src/lib/libbsp/m68k/csb360/Makefile.am                             | 2 +-
 c/src/lib/libbsp/mips/csb350/Makefile.am                             | 2 +-
 c/src/lib/libbsp/mips/jmr3904/Makefile.am                            | 2 +-
 c/src/lib/libbsp/moxie/moxiesim/Makefile.am                          | 2 +-
 c/src/lib/libbsp/nios2/nios2_iss/Makefile.am                         | 2 +-
 c/src/lib/libbsp/powerpc/psim/Makefile.am                            | 2 +-
 c/src/lib/libbsp/powerpc/qemuppc/Makefile.am                         | 2 +-
 c/src/lib/libbsp/riscv/riscv_generic/Makefile.am                     | 2 +-
 c/src/lib/libbsp/sh/shsim/Makefile.am                                | 2 +-
 c/src/lib/libbsp/v850/gdbv850sim/Makefile.am                         | 2 +-
 14 files changed, 13 insertions(+), 13 deletions(-)
 rename {c/src/lib/libbsp/shared => bsps/shared/dev/serial}/console-polled.c (100%)
diff --git a/c/src/lib/libbsp/shared/console-polled.c b/bsps/shared/dev/serial/console-polled.c
similarity index 100%
rename from c/src/lib/libbsp/shared/console-polled.c
rename to bsps/shared/dev/serial/console-polled.c
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
index 428083e686..335e4c4e1c 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
+++ b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
@@ -28,7 +28,7 @@ librtemsbsp_a_SOURCES += startup/syscalls.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/cpucounter/cpucounterdiff.c
 # console
-librtemsbsp_a_SOURCES += ../../shared/console-polled.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-polled.c
 librtemsbsp_a_SOURCES += console/console-io.c
 # clock
 librtemsbsp_a_SOURCES += ../../shared/clock_driver_simidle.c
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am b/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
index 56a0414618..16de15cf7e 100644
--- a/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
@@ -48,7 +48,7 @@ librtemsbsp_a_SOURCES += ../../shared/clock_driver_simidle.c
 librtemsbsp_a_SOURCES += timer/timer.c
 # console
 # IRQ
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
diff --git a/c/src/lib/libbsp/m32c/m32cbsp/Makefile.am b/c/src/lib/libbsp/m32c/m32cbsp/Makefile.am
index 8861518b50..6da3215c28 100644
--- a/c/src/lib/libbsp/m32c/m32cbsp/Makefile.am
+++ b/c/src/lib/libbsp/m32c/m32cbsp/Makefile.am
@@ -24,7 +24,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
 librtemsbsp_a_SOURCES += startup/crtn.S
 librtemsbsp_a_SOURCES += console/syscalls.S
diff --git a/c/src/lib/libbsp/m68k/csb360/Makefile.am b/c/src/lib/libbsp/m68k/csb360/Makefile.am
index cce7610faf..ab51f085fb 100644
--- a/c/src/lib/libbsp/m68k/csb360/Makefile.am
+++ b/c/src/lib/libbsp/m68k/csb360/Makefile.am
@@ -28,7 +28,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/setvec.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
 # console
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/cache/nocache.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/m68k/shared/memProbe.c
diff --git a/c/src/lib/libbsp/mips/csb350/Makefile.am b/c/src/lib/libbsp/mips/csb350/Makefile.am
index b32949b4b2..7bb6d0a39e 100644
--- a/c/src/lib/libbsp/mips/csb350/Makefile.am
+++ b/c/src/lib/libbsp/mips/csb350/Makefile.am
@@ -29,7 +29,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
 librtemsbsp_a_SOURCES += clock/clockdrv.c
 # console
 # timer
 #isr
diff --git a/c/src/lib/libbsp/mips/jmr3904/Makefile.am b/c/src/lib/libbsp/mips/jmr3904/Makefile.am
index 15e3bd0966..ff11c4c5f8 100644
--- a/c/src/lib/libbsp/mips/jmr3904/Makefile.am
+++ b/c/src/lib/libbsp/mips/jmr3904/Makefile.am
@@ -27,7 +27,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
 # clock
 # console
 # timer
diff --git a/c/src/lib/libbsp/moxie/moxiesim/Makefile.am b/c/src/lib/libbsp/moxie/moxiesim/Makefile.am
index 4576fdb444..25769e4311 100644
--- a/c/src/lib/libbsp/moxie/moxiesim/Makefile.am
+++ b/c/src/lib/libbsp/moxie/moxiesim/Makefile.am
@@ -30,7 +30,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
 # clock
 # console
 # timer
diff --git a/c/src/lib/libbsp/nios2/nios2_iss/Makefile.am b/c/src/lib/libbsp/nios2/nios2_iss/Makefile.am
index 233830ada0..38032bca87 100644
--- a/c/src/lib/libbsp/nios2/nios2_iss/Makefile.am
+++ b/c/src/lib/libbsp/nios2/nios2_iss/Makefile.am
@@ -32,7 +32,7 @@ librtemsbsp_a_SOURCES += startup/setvec.c
 librtemsbsp_a_SOURCES += clock/clock.c
 # console
 librtemsbsp_a_SOURCES += console/console.c
 # timer
diff --git a/c/src/lib/libbsp/powerpc/psim/Makefile.am b/c/src/lib/libbsp/powerpc/psim/Makefile.am
index db19b052eb..abe572f93a 100644
--- a/c/src/lib/libbsp/powerpc/psim/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/psim/Makefile.am
@@ -32,7 +32,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
 # pclock
 librtemsbsp_a_SOURCES += ../shared/clock/p_clock.c
 # console
 # debugio
 librtemsbsp_a_SOURCES += console/consupp.S
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/Makefile.am b/c/src/lib/libbsp/powerpc/qemuppc/Makefile.am
index c17c54a63e..fb24188f1f 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/qemuppc/Makefile.am
@@ -31,7 +31,7 @@ librtemsbsp_a_SOURCES += startup/bspstart.c
 # pclock
 librtemsbsp_a_SOURCES += ../shared/clock/clock.c
 # console
 # irq
diff --git a/c/src/lib/libbsp/riscv/riscv_generic/Makefile.am b/c/src/lib/libbsp/riscv/riscv_generic/Makefile.am
index d884bd89e7..7eba19cdc5 100644
--- a/c/src/lib/libbsp/riscv/riscv_generic/Makefile.am
+++ b/c/src/lib/libbsp/riscv/riscv_generic/Makefile.am
@@ -48,7 +48,7 @@ librtemsbsp_a_SOURCES += clock/clockdrv.c
 # console
 # IRQ
diff --git a/c/src/lib/libbsp/sh/shsim/Makefile.am b/c/src/lib/libbsp/sh/shsim/Makefile.am
index 0c834a7db6..a4b22acf87 100644
--- a/c/src/lib/libbsp/sh/shsim/Makefile.am
+++ b/c/src/lib/libbsp/sh/shsim/Makefile.am
@@ -32,7 +32,7 @@ librtemsbsp_a_SOURCES += startup/ispshgdb.c
 # console
 librtemsbsp_a_SOURCES += console/console-support.S
 librtemsbsp_a_SOURCES += console/console-debugio.c
diff --git a/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am b/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
index cc73de0da1..d7c6fa32a5 100644
--- a/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
+++ b/c/src/lib/libbsp/v850/gdbv850sim/Makefile.am
@@ -27,7 +27,7 @@ librtemsbsp_a_SOURCES += ../shared/crt1.c
 librtemsbsp_a_SOURCES += startup/trap.S
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
2.12.3
