[PATCH 28/40] bsps: Move shared CPU counter support to bsps
Thu Apr 19 13:26:53 UTC 2018
This patch is a part of the BSP source reorganization.
Update #3285.
 .../lib/libbsp/shared => bsps/shared/dev/cpucounter}/cpucounterdiff.c | 0
 .../lib/libbsp/shared => bsps/shared/dev/cpucounter}/cpucounterread.c | 0
 c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am                     | 2 +-
 c/src/lib/libbsp/arm/atsam/Makefile.am                                | 2 +-
 c/src/lib/libbsp/arm/beagle/Makefile.am                               | 4 ++--
 c/src/lib/libbsp/arm/csb336/Makefile.am                               | 4 ++--
 c/src/lib/libbsp/arm/csb337/Makefile.am                               | 4 ++--
 c/src/lib/libbsp/arm/edb7312/Makefile.am                              | 4 ++--
 c/src/lib/libbsp/arm/gdbarmsim/Makefile.am                            | 4 ++--
 c/src/lib/libbsp/arm/gumstix/Makefile.am                              | 4 ++--
 c/src/lib/libbsp/arm/imx/Makefile.am                                  | 2 +-
 c/src/lib/libbsp/arm/lm3s69xx/Makefile.am                             | 4 ++--
 c/src/lib/libbsp/arm/lpc24xx/Makefile.am                              | 2 +-
 c/src/lib/libbsp/arm/lpc32xx/Makefile.am                              | 2 +-
 c/src/lib/libbsp/arm/raspberrypi/Makefile.am                          | 4 ++--
 c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am                      | 2 +-
 c/src/lib/libbsp/arm/rtl22xx/Makefile.am                              | 4 ++--
 c/src/lib/libbsp/arm/smdk2410/Makefile.am                             | 4 ++--
 c/src/lib/libbsp/arm/stm32f4/Makefile.am                              | 4 ++--
 c/src/lib/libbsp/arm/tms570/Makefile.am                               | 2 +-
 c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am                          | 2 +-
 21 files changed, 30 insertions(+), 30 deletions(-)
 rename {c/src/lib/libbsp/shared => bsps/shared/dev/cpucounter}/cpucounterdiff.c (100%)
 rename {c/src/lib/libbsp/shared => bsps/shared/dev/cpucounter}/cpucounterread.c (100%)
diff --git a/c/src/lib/libbsp/shared/cpucounterdiff.c b/bsps/shared/dev/cpucounter/cpucounterdiff.c
similarity index 100%
rename from c/src/lib/libbsp/shared/cpucounterdiff.c
rename to bsps/shared/dev/cpucounter/cpucounterdiff.c
diff --git a/c/src/lib/libbsp/shared/cpucounterread.c b/bsps/shared/dev/cpucounter/cpucounterread.c
rename from c/src/lib/libbsp/shared/cpucounterread.c
rename to bsps/shared/dev/cpucounter/cpucounterread.c
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
index f14cfe108c..42e5f3fbf5 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am
@@ -80,7 +80,7 @@ librtemsbsp_a_SOURCES += hwlib/src/hwmgr/alt_reset_manager.c
 # Shared
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
-librtemsbsp_a_SOURCES += ../../shared/cpucounterdiff.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/cpucounter/cpucounterdiff.c
 librtemsbsp_a_SOURCES += ../../shared/sbrk.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bsp-fdt.c
diff --git a/c/src/lib/libbsp/arm/atsam/Makefile.am b/c/src/lib/libbsp/arm/atsam/Makefile.am
index ef9809e9fc..f17f92d897 100644
--- a/c/src/lib/libbsp/arm/atsam/Makefile.am
+++ b/c/src/lib/libbsp/arm/atsam/Makefile.am
@@ -36,7 +36,7 @@ librtemsbsp_a_LIBADD =
 # Shared
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-default.c
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/stackalloc.c
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 6e32235b7a..5f8cea8582 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -44,9 +44,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-defa
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/gpio/gpio-support.c
-librtemsbsp_a_SOURCES += ../../shared/cpucounterread.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
 librtemsbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
 librtemsbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
 librtemsbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
diff --git a/c/src/lib/libbsp/arm/csb336/Makefile.am b/c/src/lib/libbsp/arm/csb336/Makefile.am
index 8b818d453e..5dd53bf1db 100644
--- a/c/src/lib/libbsp/arm/csb336/Makefile.am
+++ b/c/src/lib/libbsp/arm/csb336/Makefile.am
@@ -25,8 +25,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
 librtemsbsp_a_SOURCES += startup/memmap.c
 librtemsbsp_a_SOURCES += clock/clockdrv.c
 librtemsbsp_a_SOURCES += timer/timer.c
 # console
diff --git a/c/src/lib/libbsp/arm/csb337/Makefile.am b/c/src/lib/libbsp/arm/csb337/Makefile.am
index 624b9acc86..581a283bd7 100644
--- a/c/src/lib/libbsp/arm/csb337/Makefile.am
+++ b/c/src/lib/libbsp/arm/csb337/Makefile.am
@@ -34,8 +34,8 @@ librtemsbsp_a_SOURCES += startup/bspreset.c
 librtemsbsp_a_SOURCES += startup/pmc.c
 librtemsbsp_a_SOURCES += clock/clock.c
diff --git a/c/src/lib/libbsp/arm/edb7312/Makefile.am b/c/src/lib/libbsp/arm/edb7312/Makefile.am
index 08421da6bf..5b1276b272 100644
--- a/c/src/lib/libbsp/arm/edb7312/Makefile.am
+++ b/c/src/lib/libbsp/arm/edb7312/Makefile.am
@@ -23,8 +23,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
 # clock
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
index 7d0dd6848b..1b3b02f50c 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
+++ b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
@@ -25,8 +25,8 @@ librtemsbsp_a_SOURCES += startup/bspreset.c
 librtemsbsp_a_SOURCES += startup/syscalls.c
 # console
 librtemsbsp_a_SOURCES += ../../shared/console-polled.c
 librtemsbsp_a_SOURCES += console/console-io.c
diff --git a/c/src/lib/libbsp/arm/gumstix/Makefile.am b/c/src/lib/libbsp/arm/gumstix/Makefile.am
index e36b123234..df34b9fc12 100644
--- a/c/src/lib/libbsp/arm/gumstix/Makefile.am
+++ b/c/src/lib/libbsp/arm/gumstix/Makefile.am
@@ -24,8 +24,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
 librtemsbsp_a_SOURCES += startup/bspstart.c
diff --git a/c/src/lib/libbsp/arm/imx/Makefile.am b/c/src/lib/libbsp/arm/imx/Makefile.am
index df0bdde7ef..2be44a91aa 100644
--- a/c/src/lib/libbsp/arm/imx/Makefile.am
+++ b/c/src/lib/libbsp/arm/imx/Makefile.am
@@ -31,7 +31,7 @@ librtemsbsp_a_SOURCES =
 # Shared
diff --git a/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am b/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
index 1e121d650a..892cf23e36 100644
--- a/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lm3s69xx/Makefile.am
@@ -34,8 +34,8 @@ librtemsbsp_a_SOURCES =
diff --git a/c/src/lib/libbsp/arm/lpc24xx/Makefile.am b/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
index 568bd36f91..b24459fe52 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
@@ -55,7 +55,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-defa
 librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/uart-output-char.c
 # Startup
diff --git a/c/src/lib/libbsp/arm/lpc32xx/Makefile.am b/c/src/lib/libbsp/arm/lpc32xx/Makefile.am
index 85e311d7d8..c14bbbab93 100644
--- a/c/src/lib/libbsp/arm/lpc32xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc32xx/Makefile.am
@@ -43,7 +43,7 @@ librtemsbsp_a_SOURCES =
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index a7235dee5d..194a7d4433 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -39,8 +39,8 @@ librtemsbsp_a_SOURCES =
 # Shared
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
index ba9f04c270..416064a344 100644
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
@@ -40,7 +40,7 @@ librtemsbsp_a_SOURCES =
diff --git a/c/src/lib/libbsp/arm/rtl22xx/Makefile.am b/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
index 5a685fd5c8..987cb4da31 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/rtl22xx/Makefile.am
@@ -25,8 +25,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
 # console
diff --git a/c/src/lib/libbsp/arm/smdk2410/Makefile.am b/c/src/lib/libbsp/arm/smdk2410/Makefile.am
index 2b2b5b66f8..7647d19e95 100644
--- a/c/src/lib/libbsp/arm/smdk2410/Makefile.am
+++ b/c/src/lib/libbsp/arm/smdk2410/Makefile.am
@@ -25,8 +25,8 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy
 librtemsbsp_a_SOURCES += clock/support.c
diff --git a/c/src/lib/libbsp/arm/stm32f4/Makefile.am b/c/src/lib/libbsp/arm/stm32f4/Makefile.am
index 7993585bfd..2bd42bce8a 100644
--- a/c/src/lib/libbsp/arm/stm32f4/Makefile.am
+++ b/c/src/lib/libbsp/arm/stm32f4/Makefile.am
@@ -33,8 +33,8 @@ librtemsbsp_a_SOURCES =
diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
index 530954d4b1..738d12d87a 100644
--- a/c/src/lib/libbsp/arm/tms570/Makefile.am
+++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
@@ -44,7 +44,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index cfed83190b..c6c97ed885 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -38,7 +38,7 @@ librtemsbsp_a_SOURCES =
2.12.3
