Significant Increase in Build Failures
Joel Sherrill
joel at rtems.org
Fri Apr 20 14:22:37 UTC 2018
On Fri, Apr 20, 2018 at 2:16 AM, Sebastian Huber <
> On 18/04/18 15:55, Joel Sherrill wrote:
>> 4/18: https://lists.rtems.org/pipermail/build/2018-April/000626.html
>> I haven't looked into these and won't have time today.
> One failure is for example:
> 14 debug sparc/ngmp configure:
> configure: /home/joel/rtems-work/rtems/configure --target=sparc-\
> rtems5 --enable-rtemsbsp=ngmp --prefix=/home/joel/rtems-work/bsps\
> --enable-debug
> There is no sparc/ngmp BSP.
Good spot. The files in rtems-tools are out of date. They haven't been
updated since we went to real part numbers.
Which leon3 variants don't support smp?
I will submit a patch for this much of the issue.
--joel
> Address : Dornierstr. 4, D-82178 Puchheim, Ger
> <https://maps.google.com/?q=s+:+Dornierstr.+4,+D-82178+Puchheim,+Ger&entry=gmail&source=g>
> many
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180420/beffb99d/attachment.html>
