sp36?
Sun Apr 22 12:44:38 UTC 2018
On Sat, Apr 21, 2018 at 2:25 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Apr 21, 2018, 12:22 PM Gedare Bloom <gedare at rtems.org> wrote:
>> I don't think this test is valid. It should be removed.
>> Justification: It tests the (never really working) strict order mutex
>> option. That option doesn't exist, and we test mutexes by other good
>> means (spmutex01, spsem*).
> Should there be a ticket to remove it on the 4.11 branch as well? I don't
> think it was in 4.10
Yes, these should have tickets. It's also in 4.10. It can be removed
from 4.10 since now we have fixed the PIP issue. The 4.11 fixes for
PIP are still in progress, so I can probably add removing this test to
that ticket.
>> -Gedare
>> On Fri, Apr 20, 2018 at 9:43 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > Hello,
>> > the recent Makefile changes resurrected sp36. This test fails. What do
>> > we
>> > want to do with this test?
>> > Sebastian Huber, embedded brains GmbH
>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> > Phone   : +49 89 189 47 41-16
>> > Fax     : +49 89 189 47 41-09
>> > E-Mail  : sebastian.huber at embedded-brains.de
>> > PGP     : Public key available on request.
>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
