BSP source re-organization status
Mon Apr 23 05:42:30 UTC 2018
On 23/04/18 07:37, Sebastian Huber wrote:
> On 23/04/18 03:08, Chris Johns wrote:
>> On 20/04/2018 23:23, Sebastian Huber wrote:
>>> PS: How can I use brackets { and } in a :file:`...{...}...` directive?
>> Found and tested:
>>   :file:`c/src/lib/libbsp/${{CPU}}/${{BSP}}/startup/bspstart.c`
>> worked.
> No, this doesn't work:
> <p>The BSPs are all under the <a class="reference external"
> href="https://git.rtems.org/rtems/tree/bsps">bsps</a>
> directory.  The structure in this source subtree is:</p>
> <ul class="simple">
> <li><code class="file docutils literal"><span
> class="pre">bsps/shared</span></code></li>
> class="pre">bsps/$</span><em><span
> class="pre">{RTEMS_CPU</span></em><span
> class="pre">}/shared</span></code></li>
> class="pre">}/$</span><em><span
> class="pre">{RTEMS_BSP_FAMILY</span></em><span
> class="pre">}</span></code></li>
> </ul>
> Please note the generation of "<em><span class="pre">...</em>" blocks.
 From the sphinx documentation:
"|:file:|
    The name of a file or directory. Within the contents, you can use
    curly braces to indicate a “variable” part, for example:
    ... is installed in :file:`/usr/lib/python2.{x}/site-packages` ...
    In the built documentation, the |x| will be displayed differently to
    indicate that it is to be replaced by the Python minor version."
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
