[PATCH] bootstrap: Do not create acinlude.m4 files
Mon Apr 23 06:05:39 UTC 2018
On 23/04/2018 15:45, Sebastian Huber wrote:
> The generation of files which are part of the Git repository should be
> done by the normal bootstrap script only since this is a RTEMS
> maintainer job.
Really? I am a bit lost by this change. I have never understood why acinclude.m4
is in the repo.
> This patch is a part of the BSP source reorganization.
I am sorry I do not see the relationship to this task.
Could you please explain what you are changing in this task that breaks the RSB
bootstrap script? I assume you are updating the shell script?
The RSB script is used when releasing so not keeping them in sync will break
releasing.
