BSP source re-organization status
Mon Apr 23 06:19:31 UTC 2018
On 23/04/2018 15:42, Sebastian Huber wrote:
> On 23/04/18 07:37, Sebastian Huber wrote:
>> On 23/04/18 03:08, Chris Johns wrote:
>>> On 20/04/2018 23:23, Sebastian Huber wrote:
>>>> PS: How can I use brackets { and } in a :file:`...{...}...` directive?
>>> Found and tested:
>>>   :file:`c/src/lib/libbsp/${{CPU}}/${{BSP}}/startup/bspstart.c`
>>> worked.
>> No, this doesn't work:
>> <p>The BSPs are all under the <a class="reference external"
>> href="https://git.rtems.org/rtems/tree/bsps">bsps</a>
>> directory.  The structure in this source subtree is:</p>
>> <ul class="simple">
>> <li><code class="file docutils literal"><span
>> class="pre">bsps/shared</span></code></li>
>> class="pre">bsps/$</span><em><span class="pre">{RTEMS_CPU</span></em><span
>> class="pre">}/shared</span></code></li>
>> class="pre">}/$</span><em><span class="pre">{RTEMS_BSP_FAMILY</span></em><span
>> class="pre">}</span></code></li>
>> </ul>
>> Please note the generation of "<em><span class="pre">...</em>" blocks.
I get the same output and it looks OK. I had not checked the HTML.
Do you have a different style sheet that is showing something different?
> From the sphinx documentation:
> "|:file:|
>    The name of a file or directory. Within the contents, you can use
>    curly braces to indicate a “variable” part, for example:
>    ... is installed in :file:`/usr/lib/python2.{x}/site-packages` ...
>    In the built documentation, the |x| will be displayed differently to
>    indicate that it is to be replaced by the Python minor version."
I am sorry I do not know what else you can do.
