[PATCH] bootstrap: Do not create acinlude.m4 files
Mon Apr 23 07:07:58 UTC 2018
On 23/04/18 08:51, Chris Johns wrote:
>> A RSB script
>> which modifies files of the repository is an extra error source.
> Why not remove `generate_bspdir_acinclude()` from the bootstrap script and we
> maintained the file by hand? After all adding or removing BSPs from RTEMS is not
> done that often and is a manual process anyway.
> Doing this also means both processes to bootstrap are the same which is a good
> outcome.
Maintaining this file by hand is not a big deal. I will remove the stuff
from the bootstrap script.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
