BSP source re-organization status
Tue Apr 24 05:37:06 UTC 2018
On 23/04/2018 23:26, Sebastian Huber wrote:
> On 20/04/18 15:23, Sebastian Huber wrote:
>> Hello,
>> I moved about 600 files today. The SPARC BSPs contain no longer source and
>> header files in "c".  Everything moved to "bsps". Please review this
>> architecture to check that everything is all right.  I updated the BSP guide
>> to describe the new source layout:
>> https://docs.rtems.org/branches/master/bsp-howto/target_dependant_files.html#board-support-package-structure
>> There are still more than 800 files to move.
> I moved a couple of files today. There are still 303 files left (not counting
> build files). The remaining files are all somewhat special.
> What do we want to do with the "times" files? I tend to remove them.
I am OK with removing them. A copy is easy to get from the 4.11 branch.
Maybe the tmtests can be instrumented so rtems-test can generate the reports?
