[PATCH 2/2] rtems-tools/../testing: Add configuration files for coverage analysis.
Cillian O'Donnell cpodonnell8 at gmail.com
Wed Apr 25 20:33:59 UTC 2018
Co-author: Krzysztof Miesowicz <krzysztof.miesowicz at gmail.com>
Co-author: Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
 tester/rtems/testing/bsps/leon3_qemu.ini           |  52 ++++++
 tester/rtems/testing/coverage.ini                  |  49 +++++
 tester/rtems/testing/coverage/Categories.txt       |  19 ++
 tester/rtems/testing/coverage/Explanations.txt     |  35 ++++
 .../coverage/SPARC-Annul-Slot-Explanation.txt      |  56 ++++++
 tester/rtems/testing/coverage/style.css            | 197 +++++++++++++++++++++
 tester/rtems/testing/coverage/symbol_sets.cfg      |   3 +
 tester/rtems/testing/qemu.cfg                      |  14 +-
 8 files changed, 424 insertions(+), 1 deletion(-)
 create mode 100644 tester/rtems/testing/bsps/leon3_qemu.ini
 create mode 100644 tester/rtems/testing/coverage.ini
 create mode 100644 tester/rtems/testing/coverage/Categories.txt
 create mode 100644 tester/rtems/testing/coverage/Explanations.txt
 create mode 100644 tester/rtems/testing/coverage/SPARC-Annul-Slot-Explanation.txt
 create mode 100644 tester/rtems/testing/coverage/style.css
 create mode 100644 tester/rtems/testing/coverage/symbol_sets.cfg
diff --git a/tester/rtems/testing/bsps/leon3_qemu.ini b/tester/rtems/testing/bsps/leon3_qemu.ini
new file mode 100644
index 0000000..9888008
--- /dev/null
+++ b/tester/rtems/testing/bsps/leon3_qemu.ini
@@ -0,0 +1,52 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The Leon 3 QEMU BSP
+[global]
+coverage_supported   = 1
+bsp                  = leon3_qemu
+[leon3_qemu]
+bsp           = leon3_qemu
+arch          = sparc
+tester        = %{_rtscripts}/qemu.cfg
+bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
+[coverage]
+format               = QEMU
+target               = sparc-rtems5
+explanations         = %{_rtscripts}/coverage/Explanations.txt
+coverage_extension   = .cov
+gcnos_file           = %{_rtscripts}/coverage/rtems.gcnos
+executable_extension = exe
+project_name         = RTEMS-5
+report_format        = html
diff --git a/tester/rtems/testing/coverage.ini b/tester/rtems/testing/coverage.ini
index 0000000..c1eef2e
--- /dev/null
+++ b/tester/rtems/testing/coverage.ini
@@ -0,0 +1,49 @@
+# All paths in defaults must be Unix format. Do not store any Windows format
+# paths in the defaults.
+# Every entry must describe the type of checking a host must pass.
+# Records:
+#  key: type, attribute, value
+#   type     : none, dir, exe, triplet
+#   attribute: none, required, optional
+#   value    : 'single line', '''multi line'''
+# Global defaults
+[global]
+__covoar  = covoar
+_coverage = 1
diff --git a/tester/rtems/testing/coverage/Categories.txt b/tester/rtems/testing/coverage/Categories.txt
index 0000000..e19a456
--- /dev/null
+++ b/tester/rtems/testing/coverage/Categories.txt
@@ -0,0 +1,19 @@
+This is the list of Explanation Categories used when analyzing RTEMS
+Coverage report.  By using standard categories, the table filter on
+the web site works better.
+Simple Test Case
+Hard Test Tase
+Uncalled Routine
+Interrupt Critical Section
+Simple Error Case
+Hard Error Case
+Allocation Error
+Bharath Suri
diff --git a/tester/rtems/testing/coverage/Explanations.txt b/tester/rtems/testing/coverage/Explanations.txt
index 0000000..a5917f6
--- /dev/null
+++ b/tester/rtems/testing/coverage/Explanations.txt
@@ -0,0 +1,35 @@
+schedulerpriorityyield.c:47
+Simple Test Case
+Branch Never Taken
+New test where there is more than one thread at a priority with the
+executing thread being non-preemptive.  Create a higher priority thread
+and then yield.
+   init task at priority 2, non-preemptive
+   create task at priority 2
+   create task at priority 1
+   yield
+schedulerpriorityyield.c:51
+Simple Test Case
+Branch Always Taken
+New test where only one thread at a priority (non-preemptive), create a
+thread at higher priority, then yield.
+   yield
+schedulerpriorityyield.c:52
+Simple Test Case
+Not Executed
+Same test case as schedulerpriorityyield.c:51
+coremsg.c:86
+Simple Test Case
+We need to request enough messages of a certain size that the math
+overflows to less than a single message.
diff --git a/tester/rtems/testing/coverage/SPARC-Annul-Slot-Explanation.txt b/tester/rtems/testing/coverage/SPARC-Annul-Slot-Explanation.txt
index 0000000..ef740d3
--- /dev/null
+++ b/tester/rtems/testing/coverage/SPARC-Annul-Slot-Explanation.txt
@@ -0,0 +1,56 @@
+The SPARC assembly is often hard to understand because a single
+instruction will show up as not executed.  The instructions before
+and after it will be marked as executed.  The instruction before
+the one not executed should be a "bxx,a" instruction which means
+that the instruction following the branch instruction is executed
+ONLY if the branch is taken.  Otherwise it is "annulled" or skipped.
+So when you see these cases, it means the branch was NOT taken.
+Subject: <offlist> annul slot explanation
+From: Jiri Gaisler <jiri at gaisler.com>
+Date: Wed, 3 Jun 2009 14:57:48 -0500
+To: Joel Sherrill <Joel.Sherrill at OARcorp.com>
+Joel Sherrill wrote:
+> > Hi,
+> > I am trying to look at more coverage cases and
+> > wanted to make sure I am reading things correctly.
+> > The code in question is:
+> >      if ( the_thread->current_priority > interested_priority )
+> > 200fd00:    d8 00 e0 14     ld  [ %g3 + 0x14 ], %o4
+> > 200fd04:    80 a3 00 04     cmp  %o4, %g4
+> > 200fd08:    38 80 00 1c     bgu,a   200fd78 <killinfo+0x224>
+> > 200fd0c:    98 10 00 04     mov  %g4,
+> > %o4                                            <== NOT EXECUTED
+> >       *  If this thread is not interested, then go on to the next thread.
+> >      api = the_thread->API_Extensions[ THREAD_API_POSIX ];
+> > 200fd10:    d4 00 e1 6c     ld  [ %g3 + 0x16c ], %o2
+> > Am I correct in interpreting this as meaning 0x200fd0c
+> > is not executed because the bgu,a is never taken. And it
+> > is not executed as part of falling through.
+Yes, this is correct. The branch delay slot is only executed
+when the branch is taken.
+Jiri.
+> > So in this case we need a test where the "if" condition
+> > is true if I am reading things correctly.
+> > Thanks.  There are a number of these 4 byte cases which
+> > are probably easy to hit if I read the code correctly.
diff --git a/tester/rtems/testing/coverage/style.css b/tester/rtems/testing/coverage/style.css
index 0000000..c715518
--- /dev/null
+++ b/tester/rtems/testing/coverage/style.css
@@ -0,0 +1,197 @@
+body {
+    background: rgb(253,253,253);
+    color: rgb(0,0,0);
+    font-family: helvetica, sans-serif;
+    font-size: 1em;
+    line-height: 1.4;
+    margin: 5px, 5px, 5px, 5px;
+    padding: 0;
+a:link {
+    color: rgb(180, 50, 50);
+    font-size: 1.0em;
+a:visited {
+    color: purple;
+    font-size: 1.0em;
+a:hover {
+    color: rgb(0, 0, 0);
+    font-size: 1.0em;
+a:active {
+    color: red;
+    font-size: 1.0em;
+.heading {
+    background: rgb(250,250,250);
+    background-image: url("http://www.rtems.org/logos/rtems_logo.jpg");
+    background-repeat: no-repeat;
+    color: rgb(55,55,55);
+    font-size: 1.5em;
+    height: 140px;
+    padding-top: 20px;
+    padding-left: 300px;
+.heading-title {
+    text-align:  center;
+    font-size: 0.9em;
+    font-weight: bold;
+    padding-top: 5px;
+    padding-left: 0px;
+    width: 100%;
+.datetime {
+    font-size: 0.8em;
+    padding-top: 5px;
+    width: 100%;
+.info {
+    font-size: 0.6em;
+    padding-top: 5px;
+    padding-left: 00px;
+    width: 100%;
+.stats-table {
+    background: rgb(225,225,225);
+    font-size: 0.9em;
+    border: 1px solid rgb(200, 200, 200);
+    padding: 0;
+    margin-top: 3px;
+    margin-left: 10px;
+    width: 70%;
+.stats-table-target {
+    background: rgb(243,243,243);
+    font-size: 1.2em;
+    padding-left: 10px;
+    text-align: left;
+.stats-target-results {
+    font-size: 0.9em;
+    text-align: right;
+    padding-right: 10px;
+.stats-target-good {
+    background: rgb(30,230,30);
+    font-size: 0.9em;
+    background: rgb(50,180,50);
+    color: rgb(230,230,230);
+    font-size: 0.9em;
+.stats-target-bad {
+    background: rgb(180,50,50);
+    font-size: 0.9em;
+.stats-table-top {
+    font-size: 0.9em;
+    padding-left: 2px;
+.stats-table-row {
+    font-size: 0.9em;
+    padding: 1px;
+.error-table {
+    font-size: 0.9em;
+    padding: 0;
+    width: 96%;
+.error-table-top {
+    font-size: 0.9em;
+.error-table-on {
+    font-size: 0.9em;
+.error-table-off {
+    font-size: 0.9em;
+.error-table-dups {
+    padding-right: 2px;
+.error-table-error {
+    background: rgb(255,150,150);
+    font-size: 0.9em;
+.error-table-warning {
+    font-size: 0.9em;
+.navbar {
+    margin-left: auto;
+    margin-right: auto;
+    margin-top: 10px;
+    width: 40%;
+th.table-sortable {
+  background-image:url("unsorted.gif");
+  cursor: pointer;
+  background-position: center left;
+  padding-left: 15px;
+th.table-sorted-asc {
+  background-image:url("descending.gif");
+th.table-sorted-desc {
+  background-image:url("ascending.gif");
\ No newline at end of file
diff --git a/tester/rtems/testing/coverage/symbol_sets.cfg b/tester/rtems/testing/coverage/symbol_sets.cfg
index 0000000..7f62cce
--- /dev/null
+++ b/tester/rtems/testing/coverage/symbol_sets.cfg
@@ -0,0 +1,3 @@
+symbolset:
+	name=score
+	lib=sparc-rtems5/c/leon3/cpukit/score/libscore.a
diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cfg
index db5b6b2..7a65ddd 100644
--- a/tester/rtems/testing/qemu.cfg
+++ b/tester/rtems/testing/qemu.cfg
@@ -64,6 +64,18 @@
 %define qemu_opts %{bsp_qemu_opts}
+# Coverage analysis
+%define coverage_arg %{nil}
+%if %{defined _coverage}
+  %if %{coverage_supported}
+    %define coverage_arg -exec-trace %{test_executable}.cov
+  %else
+     %error "Coverage analysis unsupported for %{bsp}"
+  %endif
+%endif
 # Executable
-%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable}
+%execute %{qemu_cmd} %{qemu_opts} -kernel %{test_executable} %{coverage_arg}
2.7.4
