[PATCH] bsp/pc386: Remove bin2boot support
Thu Apr 26 05:30:35 UTC 2018
Close #3410.
 bsps/i386/pc386/config/pc386.cfg               |  36 ---
 c/src/lib/libbsp/i386/pc386/Makefile.am        |  22 --
 c/src/lib/libbsp/i386/pc386/configure.ac       |   2 -
 c/src/lib/libbsp/i386/pc386/tools/Makefile.am  |  29 --
 c/src/lib/libbsp/i386/pc386/tools/Spec.doc     | 353 ----------------------
 c/src/lib/libbsp/i386/pc386/tools/bin2boot.c   | 403 -------------------------
 c/src/lib/libbsp/i386/pc386/tools/configure.ac |  24 --
 7 files changed, 869 deletions(-)
 delete mode 100644 c/src/lib/libbsp/i386/pc386/tools/Makefile.am
 delete mode 100644 c/src/lib/libbsp/i386/pc386/tools/Spec.doc
 delete mode 100644 c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
 delete mode 100644 c/src/lib/libbsp/i386/pc386/tools/configure.ac
diff --git a/bsps/i386/pc386/config/pc386.cfg b/bsps/i386/pc386/config/pc386.cfg
index dd7f554cbc..6e55cbb60f 100644
--- a/bsps/i386/pc386/config/pc386.cfg
+++ b/bsps/i386/pc386/config/pc386.cfg
@@ -20,39 +20,3 @@ CFLAGS_OPTIMIZE_V = -O2 -g
 CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
 LDFLAGS = -Wl,--gc-sections
-# Here is the rule to actually build a $(ARCH)/foo$(EXEEXT)
-# It also builds $(ARCH)/foo.sr and $(ARCH)/foo.nm
-# Usage ref: src/tests/sptest/sp1/Makefile
-#| Set the value of RELOCADDR to the address where you want your image to
-#| load. If you'll be using GRUB to load the images it will have to be >=
-#| 0x100000 (1024K). If you are using NetBoot to load the images it can be
-#| >= 0x10000 (64K) AND <= 0x97C00 (607K) OR >= 0x100000 (1024K). The memory
-#| top is of course another limit. Make sure there is enough space before the
-#| upper memory limits for the image and the memory allocated by it to fit.
-#| Make sure the value you choose is aligned to 4 bytes.
-  RELOCADDR=0x00100000
-START16FILE=$(PROJECT_RELEASE)/lib/start16$(LIB_VARIANT).bin
-START16ADDR=0x00097C00
-HEADERADDR=0x00097E00
-LDFLAGS += -Wl,-Ttext,$(RELOCADDR)
-define bsp-post-link
-	$(default-bsp-post-link)
-	$(OBJCOPY) -O elf32-i386 \
-	    --remove-section=.comment \
-	    --remove-section=.note \
-	    --strip-unneeded $(basename $@)$(EXEEXT) $(basename $@).nxe
-	$(OBJCOPY) -O binary $(basename $@).nxe $(basename $@).bin
-	$(PROJECT_TOOLS)/bin2boot -v $(basename $@)$(DOWNEXT) $(HEADERADDR)\
-	  $(START16FILE) $(START16ADDR) 0 $(basename $@).bin $(RELOCADDR) 0
-	rm -f $(basename $@).nxe
-endef
-# BSP-specific tools
-BIN2BOOT=$(PROJECT_TOOLS)/bin2boot
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
index 94eef01035..cec8fd6b92 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -16,32 +16,10 @@ dist_project_lib_DATA = ../../../../../../bsps/i386/pc386/start/bsp_specs
 noinst_PROGRAMS =
-_SUBDIRS = . tools
-TMPINSTALL_FILES =
 start.$(OBJEXT): ../../../../../../bsps/i386/pc386/start/start.S
 	$(CPPASCOMPILE) -o $@ -c $<
 project_lib_DATA = start.$(OBJEXT)
-start16.$(OBJEXT): ../../../../../../bsps/i386/pc386/start/start16.S
-	$(CPPASCOMPILE) $(AM_CPPFLAGS) -DHEADERADDR=$(HEADERADDR) -o $@ -c $<
-start16-elf32.$(OBJEXT): start16.$(OBJEXT)
-	$(LD) -N -Ttext $(START16ADDR) -e start16 -nostdlib \
-	  --oformat=elf32-i386 \
-	-o $@ $<
-start16.bin: start16-elf32.$(OBJEXT)
-	$(OBJCOPY) -O binary $< $@
-CLEANFILES += start16.bin
-$(PROJECT_LIB)/start16.bin: start16.bin $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/start16.bin
-TMPINSTALL_FILES += $(PROJECT_LIB)/start16.bin
-project_lib_DATA += start16.bin
 project_lib_DATA += linkcmds
 project_lib_LIBRARIES = librtemsbsp.a
diff --git a/c/src/lib/libbsp/i386/pc386/configure.ac b/c/src/lib/libbsp/i386/pc386/configure.ac
index f455132daf..13e0adff5c 100644
--- a/c/src/lib/libbsp/i386/pc386/configure.ac
+++ b/c/src/lib/libbsp/i386/pc386/configure.ac
@@ -142,8 +142,6 @@ AM_CONDITIONAL(RTEMS_GAS_CODE16,[test "$RTEMS_GAS_CODE16" = "yes"])
 AC_SUBST([RTEMS_ROOT],[${rtems_updir}'$(top_builddir)'])
-RTEMS_CONFIG_BUILD_SUBDIRS(tools)
 AC_SUBST(RTEMS_BSP)
 RTEMS_BSP_CLEANUP_OPTIONS
diff --git a/c/src/lib/libbsp/i386/pc386/tools/Makefile.am b/c/src/lib/libbsp/i386/pc386/tools/Makefile.am
deleted file mode 100644
index 42da8dc883..0000000000
--- a/c/src/lib/libbsp/i386/pc386/tools/Makefile.am
+++ /dev/null
@@ -1,29 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../../../aclocal
-# HACK: autoconf wants to transform the name, but RTEMS *.cfgs are not able
-# to deal with it.
-# FIXME: The installation directory is arguable
-transform =
-bsptools_bindir = ${exec_prefix}/@RTEMS_BSP@/build-tools
-bsptools_bin_PROGRAMS = bin2boot
-bin2boot_SOURCES = bin2boot.c
-## HACK: install into build-tree
-all-local: $(TMPINSTALL_FILES)
-TMPINSTALL_FILES =
-$(PROJECT_ROOT)/@RTEMS_BSP@/build-tools/$(dirstamp):
-	@$(MKDIR_P) $(PROJECT_ROOT)/@RTEMS_BSP@/build-tools
-	@: > $(PROJECT_ROOT)/@RTEMS_BSP@/build-tools/$(dirstamp)
-TMPINSTALL_FILES += $(PROJECT_ROOT)/@RTEMS_BSP@/build-tools/$(dirstamp)
-$(PROJECT_ROOT)/@RTEMS_BSP@/build-tools/bin2boot$(EXEEXT): bin2boot$(EXEEXT) $(PROJECT_ROOT)/@RTEMS_BSP@/build-tools/$(dirstamp)
-	$(INSTALL_PROGRAM) $< $(PROJECT_ROOT)/@RTEMS_BSP@/build-tools/bin2boot$(EXEEXT)
-TMPINSTALL_FILES += $(PROJECT_ROOT)/@RTEMS_BSP@/build-tools/bin2boot$(EXEEXT)
-CLEANFILES = $(TMPINSTALL_FILES)
-include $(top_srcdir)/../../../../../automake/host.am
diff --git a/c/src/lib/libbsp/i386/pc386/tools/Spec.doc b/c/src/lib/libbsp/i386/pc386/tools/Spec.doc
index 92ce7a88cf..0000000000
--- a/c/src/lib/libbsp/i386/pc386/tools/Spec.doc
+++ /dev/null
@@ -1,353 +0,0 @@
-        2-28-1995 GK
-In order to provide more functionality to the boot rom code I changed
-Jamie's draft a little bit. All my changes have a bar sign (|) in the
-79th column.
-Gero Kuhlmann
-0. Numbering
-This is Draft Net Boot Image Proposal 0.2, February 28, 1995                   |
-1. Preamble - the why
-Whilst researching what other boot proms do (at least those implementing
-TCP/IP protocols) it is clear that each 'does their own thing' in
-terms of what they expect in a boot image.
-If we could all agree on working toward an open standard, O/S suppliers
-and boot rom suppliers can build their products to this norm, and be confident
-that they will work with each other.
-This is a description of how I will implement the boot rom for
-Linux. I  believe it to be flexible enough for any OS that will be loaded
-when a PC boots from a network in the TCP/IP environment.
-It would be good if this could be turned into some form of standard.
-This is very much a first draft. I am inviting comment.
-The ideas presented here should be independant of any implementation.
-In the end, where there is a conflict between the final of this draft, and an
-implementation, this description should prevail.
-The terms I use are defined at the end.
-2. The target
-The target is to have a PC retrieve a boot image from a network in the TCP/IP
-environment.
-The boot may take place from a network adaptor rom, from a boot floppy, or
-from a program in MSDOS.
-3. Net Boot Process Description.
-The net boot process can be started either as a result of the PC
-boot process, or through normal DOS execution of a program. The net boot
-program can reside on a rom, e.g. on an adaptor card, or in ram, either
-as a result of reading off disk or transferred from ram.
-The boot process may execute in any mode (e.g. 8086, 80386) it desires.
-When it jumps to the start location in the boot image, it must be in
-8086 mode and be capable of going into any mode supported by the
-underlying processor.
-The image cannot be loaded into address spaces below 10000h, or between
-A0000h through FFFFFh, or between 98000h through 9FFFFh. Once the image
-starts executing, all the memory is available to it, so it can relocate
-parts of itself to these areas.
-The boot process must be capable of loading the image into all other
-memory locations. Specifically, where the machine supports this, this means
-memory over 100000h.
-The net boot process must execute the bootp protocol, followed by
-the tftp protocol, as defined in the relevant rfc's.
-The file name used in the tftp protocol must be that given by the bootp
-record.
-If less than 512 bytes are loaded, the net boot process attempts to display
-on the screen any ascii data at the start of the image. The net boot
-process then exits in the normal manner. For a boot prom, this will
-allow normal disk booting. For DOS programs, this will mean a normal return
-to DOS.
-When the first 512 bytes have been loaded, the boot process checks
-for an initial magic number, which is defined later. If this number
-is present, the net process continues loading under the control
-of the image format. The image, which is described later, tells the
-net boot process where to put this record and all subsequent data.
-If no initial magic number is present the net boot process checks for a second
-magic number at offset 510. If the magic number 510 = 55h, 511 = AAh,
-then the net process continues. If this second magic number is not
-present, then the net boot process terminates the tftp protocol, displays
-an error message and exits in the normal manner.
-If no initial magic number is present and the second one is, the net boot
-process relocates the 512 bytes to location 7c00h. The net boot process
-continues to load any further image data to 10000h up. This data can overwrite
-the first 512 boot bytes. If the image reaches 98000h, then any further data is
-continued to be loaded above 100000h. When all the data has been loaded, the
-net boot process jumps to location 0:7c00.
-When the net boot process calls the image, it places 2 far pointers onto       |
-the stack, in standard intel order (e.g. segment:offset representation).       |
-The first far pointer which immediately follows the return address on          |
-the stack, points to the loaded boot image header. The second far pointer      |
-which is placed above the first one, shows to the memory area where the        |
-net boot process saved the bootp reply.                                        |
-4. Image Format with Initial Magic Number.
-The first 512 bytes of the image file contain the image header,
-and image loading information records. This contains all the
-information needed by the net boot process as to where data
-is to be loaded.
-The magic number (in time-honoured tradition (well why not?)) is:
-        0 = 36h
-        1 = 13h
-        2 = 03h
-        3 = 1Bh
-Apart from the two magic numbers, all words and double words are in PC
-native endian.
-Including the initial magic number the header record is:
-        | Initial Magic No.   |  4 bytes
-        | Flags and length    |  double word
-        | Location Address    |  double word in ds:bx format
-        | Execute Address     |  double word in cs:ip format
-The Location address is where to place the 512 bytes. The net boot
-process does this before loading the rest of the image. The location
-address cannot be one of the reserved locations mentioned above, but
-must be an address lower than 100000h.
-The rest of the image must not overwrite these initial 512 bytes, placed
-at the required location. The writing of data by the net boot process
-into these 512 bytes is deprecated. These 512 bytes must be available for
-the image to interogate once it is loaded and running.
-The execute address is the location in cs:ip of the initial instruction
-once the full image has been loaded. This must be lower than 100000h,
-since the initial instructions will be executed in 8086 mode. When the
-jump (actaully a far call) is made to the boot image, the stack contains a
-far return address, with a far pointer parameter above that, pointing
-to the location of this header.
-The flags and length field is broken up in the following way:
-Bits 0 to 3 (lowest 4 bits) define the length of the non vendor header in
-double words. Currently the value is 4.
-Bits 4 to 7 define the length required by the vendor extra information
-in double words. A value of zero indicates no extra vendor information.
-Bits 8 to 31 are reserved for future use and must be set to zero.
-After this header, and any vendor header, come the image loading information
-records. These specify where data is to be loaded, how long it is, and
-communicates to the loaded image what sort of data it is.
-The format of each image loading information record is :
-          | Flags, tags and     |  double word
-          | lengths             |
-          | Load Address        |  double word
-          | Image Length        |  double word
-          | Memory Length       |  double word
-Each image loading information record follows the previous, or the header.
-The memory length, image length and load address fields are unsigned 32
-numbers. They do not have the segment:offset format used by the 8086.
-The flags, tags and lengths field is broken up as follows:
-Bits 0 to 3 (lowest 4 bits) are the length of the non vendor part of this
-header in double words. Currently this value is 4.
-Bits 4 to 7 indicate the length of any vendor information, in double words.
-Bits 8 to 15 are for vendor's tags. The vendor tag is a private number that
-the loaded image can use to determine what sort of image is at this particular
-location.
-Bits 16 to 23 are for future expansion and should be set to zero.
-Bits 24 to 31 are for flags, which are defined later.
-Vendors may place further information after this information record, and
-before the next. Each information record may have a different vendor
-length.
-There are two restrictions on vendor information.
-One is that the header and all information records that the net boot process
-is to use fall within the first 512 bytes.
-The second restriction is that the net boot process must ignore all
-vendor additions. The net boot process may not overwrite vendor supplied
-information, or other undefined data in the initial 512 bytes.
-The flags are used to modify the load address field, and to indicate
-that this is the last information record that the net boot process should
-use.
-Bit 24 works in conjunction with bit 25 to specify the meaning of the
-load address.
-          B24    B25
-           0     0    load address is an absolute 32 number
-           1     0    add the load address to the location one past the last byte
-                      of the memory area required by the last image loaded.
-                      If the first image, then add to 512 plus the location
-                      where the 512 bytes were placed
-           0     1    subtract the load address from the one past the
-                      last writeable location in memory. Thus 1 would
-                      be the last location one could write in memory.
-           1     1    load address is subtracted from the start of
-                      the last image loaded. If the first image, then
-                      subtract from the start of where the 512 bytes were
-                      placed
-(For convenience bit 24 is byte 0 of the flag field)
-Bit 26 is the end marker for the net boot process. It is set when
-this is the last information record the net boot process should
-look at. More records may be present, but the net boot process will not
-look at them. (Vendors can continue information records out past the 512
-boundary for private use in this manner).
-The image length tells the net boot process how many bytes are to be loaded.
-Zero is a valid value. This can be used to mark memory areas such as
-shared memory for interprocessor communication, flash eproms, data in eproms.
-The image length can also be different from the memory length. This allows
-decompression programs to fluff up the kernel image. It also allows a file
-system to be larger then the loaded file system image.
-Bits 27 through 31 are not defined as yet and must be set to zero until
-they are.
-6. Boot prom entry points.
-I have not defined boot entry points, and means of obtaining them.
-It could be useful to down load part of an image, and have that image
-load more of itself by using handy parts of the net boot program.
-This can be considered 'for further study'.
-7. Example of a boot image.
-Here is an example of how the boot image would look for Linux:
-          0x1B031336,  /* magic number */
-          0x4,         /* length of header is 16 bytes, no vendor info */
-          0x90000000,  /* location in ds:bx format */
-          0x90000200,  /* execute address in cs:ip format */
-                       /* 2048 setup.S bytes */
-	  0x4,	       /* flags, not end, absolute address, 16 bytes this
-                          record, no vendor info */
-          0x90200,     /* load address - note format */
-          0x800,       /* 4 8 512 byte blocks for linux */
-          0x800,
-                       /* kernel image */
-          0x10000,     /* load address - note format */
-          0x80000,     /* 512K (this could be shorter */
-          0x80000,
-                       /* ramdisk for root file system */
-	  0x04000004,  /* flags = last, absolute address, 16 bytes this
-                          record, no vendor info *//
-          0x100000,    /* load address - in extended memory */
-          0x80000,     /* 512K for instance */
-          0x80000,
-                       /* Then follows linux specific information */
-8. Terms
-When I say 'the net boot process', I mean the act of loading the image into
-memory, setting up any tables, up until the jump to the required location
-in the image.
-The net booting program executes the net boot process. The net boot program
-may be a rom, but not neccassarily. It is a set of instructions and data
-residing on the booting machine.
-The image, or boot image,  consists of the data loaded by the net boot process.
-When I say 'the PC boot process', I mean the general PC rom bios boot process,
-the setting up of hardware, the scanning for adaptor roms, the execution
-of adaptor roms, the loading in of the initial boot track. The PC boot
-process will include the net boot process, if one is present.
-When I say client, I mean the PC booting up.
-When I say 'image host', I mean the host where the boot image is comming from.
-This may not have the same architecture as the client.
-The bootp protocol is defined in RFC951 and RFC1084. The tftp protocol
-is defined in RFC783. These are available on many sites.
-See Comer 1991 for details on how to obtain them.
-A bootp server is the machine that answers the bootp request. It is not
-neccassarily the image host.
-'Can' and 'may' means doesn't have to, but is allowed to and might.
-'Must' means just that. 'Cannot' means must not.
-9 References
-Comer, D.E. 1991, Internetworking with TCP/IP Vol I: Principles, Protocols,
-and Architecture Second Edition, Prentice Hall, Englewood Cliffs, N.J., 1991
-Stevens, W.R 1990, Unix Network Programming, Prentice Hall,
-Englewood Cliffs, N.J., 1990
diff --git a/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c b/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
index 00556411d9..0000000000
--- a/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
+++ /dev/null
@@ -1,403 +0,0 @@
- * Simplyfied version of original bin2boot
-#include <stdio.h>
-#include <stdlib.h>
-#include <stdint.h>
-#include <inttypes.h>
-#include <unistd.h>
-#include <string.h>
-static unsigned char buf[512];
-static void usage(void)
-  printf("usage: bin2boot [-h][-v] <outFile> <headerAddr> \n");
-  printf("<imFile1> <imAddr1> <imSize1> [<imFile2> <imAddr2> <imSize2>]\n");
-  printf("this function makes image bootable by netboot\n");
-  printf("from one or two binary images\n");
-  printf("-h         - prints this message\n");
-  printf("-v         - verbose output\n");
-  printf("outFile    - output file\n");
-  printf("headerAddr - address to place header in memory\n");
-  printf("             it should be below or equal 0x97e00\n");
-  printf("imFile1    - first image\n");
-  printf("imAddr1    - its start address, image has to be placed whole\n");
-  printf("             below 0x98000 and should not overlap with header\n");
-  printf("imSize1    - actual size of compressed image, 0 for uncompressed\n");
-  printf("imFile2    - second image\n");
-  printf("imAddr2    - its start address\n");
-  printf("imSize2    - actual size of compressed image, 0 for uncompressed\n");
-  return;
-int main(int argc, char* argv[])
-  int      c, verbose;
-  extern   int optind;
-  FILE     *ofp, *ifp;
-  uintptr_t headerAddr, addr1, addr2;
-  int      size1, size2, len1, len2, len, imageCnt, cnt;
-  char     *ofile, *ifile, *end;
-  len2 = 0;   /* avoid warning */
-  size2 = 0;  /* avoid warning */
-  addr2 = 0;  /* avoid warning */
-  verbose = 0;
-  /* parse command line options */
-  while ((c = getopt(argc, argv, "hv")) >= 0)
-      switch (c)
-	case 'v':
-	  verbose = 1;
-	  break;
-	case 'h':
-	  usage();
-	  return 0;
-	default:
-	  usage();
-	  return 1;
-  if((argc - optind) != 8 && (argc - optind) != 5)
-      usage();
-      return 1;
-  ofile = argv[optind];
-  ofp   = fopen(ofile, "wb");
-  if(ofp == NULL)
-      fprintf(stderr, "unable to open file %s\n", ofile);
-      return 1;
-   * Layout is very simple first 512 is header shared by all
-   * images, then images at 512 bytes border
-  /* Fill buffer with 0's */
-  memset(buf, 0, sizeof(buf));
-  fwrite(buf, 1, sizeof(buf), ofp);
-  optind++;
-  headerAddr = strtoul(argv[optind], &end, 0);
-  if(end == argv[optind])
-      fprintf(stderr, "bad headerAddr %s\n", argv[optind]);
-      fclose(ofp);
-      return 1;
-  if(headerAddr > 0x97e00)
-      fprintf(stderr, "headerAddr is too high 0x%08lx\n", headerAddr);
-      fclose(ofp);
-      return 1;
-  /* Copy the first image */
-  optind++;
-  ifile = argv[optind];
-  ifp   = fopen(ifile,"rb");
-  if(ifp == NULL)
-      fprintf(stderr, "unable to open output file %s\n", ifile);
-      fclose(ofp);
-      return 1;
-  optind++;
-  addr1 = strtoul(argv[optind], &end, 0);
-      fprintf(stderr, "bad image address %s\n", argv[optind]);
-      fclose(ofp);
-      return 1;
-  optind++;
-  size1 = strtoul(argv[optind], &end, 0);
-      fprintf(stderr, "bad image size %s\n", argv[optind]);
-      fclose(ofp);
-      return 1;
-  /* Copy first image out and remember its length */
-  cnt  = 0;
-  for(;;)
-      len = fread(buf, 1, sizeof(buf), ifp);
-      if(len != 0)
-	  fwrite(buf, 1, len, ofp);
-	  cnt += sizeof(buf);
-          if(len != sizeof(buf))
-	      memset(buf, 0, sizeof(buf) - len);
-	      fwrite(buf, 1, sizeof(buf) - len, ofp);
-	      break;
-      else
-	  break;
-  fclose(ifp);
-  len1 = cnt;
-  if(size1 == 0)
-      size1 = cnt;
-  else
-      while(cnt < size1)
-      size1 = cnt;
-  /* Let us check agains overlapping */
-  if(!(addr1 >= (headerAddr + sizeof(buf)) || (headerAddr >= addr1+size1)))
-      /* Areas overlapped */
-      printf("area overlapping: \n");
-      printf("header address      0x%08lx, its memory size 0x%08zx\n",
-	     headerAddr, sizeof(buf));
-      printf("first image address 0x%08lx, its memory size 0x%08x\n",
-	     addr1, size1);
-      fclose(ofp);
-      return 1;
-  if((addr1 + size1) > 0x98000)
-      fprintf(stderr, "imAddr1 is too high 0x%08lx\n", addr1);
-      fclose(ofp);
-      return 1;
-  if(optind == (argc - 1))
-      imageCnt = 1;
-      goto writeHeader;
-  imageCnt = 2;
-  /* Copy Second Image */
-  optind++;
-  if(ifp == NULL)
-      fclose(ofp);
-      return 1;
-  optind++;
-  addr2 = strtoul(argv[optind], &end, 0);
-      fclose(ofp);
-      return 1;
-  optind++;
-  size2 = strtoul(argv[optind], &end, 0);
-      fclose(ofp);
-      return 1;
-  /* Copy second image out and remember its length */
-  cnt  = 0;
-  for(;;)
-      if(len != 0)
-	  fwrite(buf, len, 1, ofp);
-	      break;
-      else
-	  break;
-  fclose(ifp);
-  len2 = cnt;
-  if(size2 == 0)
-      size2 = cnt;
-  else
-      while(cnt < size2)
-      size2 = cnt;
-  /* Let us check against overlapping */
-  if(!((addr2 >= (addr1 + size1) && addr2 >= (headerAddr + sizeof(buf))) ||
-       (addr2 < addr1 && addr2 < headerAddr) ||
-       (addr1 > headerAddr && addr2 > (headerAddr + sizeof(buf)) &&
-	(addr2 + size2) <= addr1) ||
-       (addr1 < headerAddr && addr2 > (addr1 + size1) &&
-	(addr2 + size2) <= headerAddr)))
-      printf("header address       0x%08" PRIxPTR ", its memory size 0x%08zx\n",
-      printf("first  image address 0x%08" PRIxPTR ", its memory size 0x%08x\n",
-	     addr1, size1);
-      printf("second image address 0x%08" PRIxPTR ", its memory size 0x%08x\n",
-	     addr2, size2);
-      fclose(ofp);
-      return 1;
-writeHeader:
-  /* We know everything so it is time to write buffer */
-  memset(buf, 0, 0x30);
-  buf[0x0]  = 0x36;
-  buf[0x1]  = 0x13;
-  buf[0x2]  = 0x03;
-  buf[0x3]  = 0x1b;
-  buf[0x4]  = 4;
-  /* Header address in ds:bx format */
-  buf[0x8]  = headerAddr & 0xf;
-  buf[0x9]  = 0;
-  buf[0xa]  = (headerAddr >> 4) & 0xff;
-  buf[0xb]  = (headerAddr >> 12) & 0xff;
-   * Execute address in cs:ip format, which addr1
-  buf[0xc] = addr1 & 0xf;
-  buf[0xd] = 0;
-  buf[0xe] = (addr1 >> 4) & 0xff;
-  buf[0xf] = (addr1 >> 12) & 0xff;
-  /* Flags, tags and lengths */
-  buf[0x10] = 4;
-  if(imageCnt == 1)
-      buf[0x13] = 4;
-  /* Load address */
-  buf[0x14] = addr1 & 0xff;
-  buf[0x15] = (addr1 >> 8) & 0xff;
-  buf[0x16] = (addr1 >> 16) & 0xff;
-  buf[0x17] = (addr1 >> 24) & 0xff;
-  /* Image Length */
-  buf[0x18] = len1 & 0xff;
-  buf[0x19] = (len1 >> 8) & 0xff;
-  buf[0x1a] = (len1 >> 16) & 0xff;
-  buf[0x1b] = (len1 >> 24) & 0xff;
-  /* Memory Size */
-  buf[0x1c] = size1 & 0xff;
-  buf[0x1d] = (size1 >> 8) & 0xff;
-  buf[0x1e] = (size1 >> 16) & 0xff;
-  buf[0x1f] = (size1 >> 24) & 0xff;
-  if(imageCnt != 1)
-      buf[0x20] = 4;
-      buf[0x23] = 4;
-      buf[0x24] = addr2 & 0xff;
-      buf[0x25] = (addr2 >> 8) & 0xff;
-      buf[0x26] = (addr2 >> 16) & 0xff;
-      buf[0x27] = (addr2 >> 24) & 0xff;
-      buf[0x28] = len2 & 0xff;
-      buf[0x29] = (len2 >> 8) & 0xff;
-      buf[0x2a] = (len2 >> 16) & 0xff;
-      buf[0x2b] = (len2 >> 24) & 0xff;
-      /* Memory Size */
-      buf[0x2c] = size2 & 0xff;
-      buf[0x2d] = (size2 >> 8) & 0xff;
-      buf[0x2e] = (size2 >> 16) & 0xff;
-      buf[0x2f] = (size2 >> 24) & 0xff;
-  rewind(ofp);
-  fwrite(buf, 1, 0x30, ofp);
-  fclose(ofp);
-  if(verbose)
-	     addr1, size1);
-	     addr2, size2);
-  return 0;
diff --git a/c/src/lib/libbsp/i386/pc386/tools/configure.ac b/c/src/lib/libbsp/i386/pc386/tools/configure.ac
index 8c6d47bbb6..0000000000
--- a/c/src/lib/libbsp/i386/pc386/tools/configure.ac
+++ /dev/null
@@ -1,24 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-i386-pc386-tools],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-RTEMS_TOP(../../../../../../..)
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-CFLAGS="-g -O2 -Wall"
-AM_INIT_AUTOMAKE([no-define foreign subdir-objects 1.12.2])
-AM_MAINTAINER_MODE
-RTEMS_ENV_RTEMSBSP
-AC_PROG_CC
-AC_CHECK_FUNCS(strtoul)
-RTEMS_PROJECT_ROOT
-RTEMS_TOOLPATHS
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
2.12.3
