odd waf error from examples-v2
Joel Sherrill
joel at rtems.org
Thu Apr 26 13:42:19 UTC 2018
Hi
I am getting this on rtbf64c which is running this version of CentOS:
CentOS Linux release 7.4.1708 (Core)
It doesn't occur on my VM which has the same version:
$ cat /etc/redhat-release
Any ideas?
$ ./waf configure
Traceback (most recent call last):
File "./waf", line 164, in <module>
from waflib import Scripting
File
"/data/home/joel/rtems-work/examples-v2/.waf-2.0.1-5ae960fa4d6912cc4ddfbaf813e870c3/waflib/Scripting.py",
line 7, in <module>
from waflib import
Utils,Configure,Logs,Options,ConfigSet,Context,Errors,Build,Node
File
"/data/home/joel/rtems-work/examples-v2/.waf-2.0.1-5ae960fa4d6912cc4ddfbaf813e870c3/waflib/Configure.py",
line 6, in <module>
from waflib import ConfigSet,Utils,Options,Logs,Context,Build,Errors
File
"/data/home/joel/rtems-work/examples-v2/.waf-2.0.1-5ae960fa4d6912cc4ddfbaf813e870c3/waflib/Options.py",
line 6, in <module>
from waflib import Logs,Utils,Context,Errors
File
"/data/home/joel/rtems-work/examples-v2/.waf-2.0.1-5ae960fa4d6912cc4ddfbaf813e870c3/waflib/Context.py",
line 174
raise Errors.WafError('Execution failure:
%s'%str(e),ex=e),None,sys.exc_info()[2],None,sys.exc_info()[2]
SyntaxError: invalid syntax
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180426/09aac529/attachment.html>
