[PATCH 2/2] rtems-tools/../testing: Add configuration files for coverage analysis.
Fri Apr 27 07:34:15 UTC 2018
On 27/04/2018 17:28, Cillian O'Donnell wrote:
> Yeah the config files are definitely a bit of a pick-a-mix. I only really made
> changes in the .ini and symbolset.cfg. The rest is mostly yours I guess Joel.
> You probably have the best idea of what to do with it. I think Chris wants to
> squash it together, add his changes and make new patches.
I have resolved those issues and the coverage config logic.
Once I have these changes done I will generate a single patch to post for
review. It will be different in parts so I hope that is OK.
